--- ray/src/rt/rc2.c 2016/08/18 00:52:48 2.18 +++ ray/src/rt/rc2.c 2023/04/07 00:03:26 2.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rc2.c,v 2.18 2016/08/18 00:52:48 greg Exp $"; +static const char RCSid[] = "$Id: rc2.c,v 2.25 2023/04/07 00:03:26 greg Exp $"; #endif /* * Accumulate ray contributions for a set of materials @@ -116,6 +116,8 @@ printheader(FILE *fout, const char *info) fputs("NCOMP=3\n", fout); /* always RGB */ if (info != NULL) /* add extra info if given */ fputs(info, fout); + if ((outfmt == 'f') | (outfmt == 'd')) + fputendian(fout); fputformat(formstr(outfmt), fout); fputc('\n', fout); /* empty line ends header */ } @@ -141,11 +143,15 @@ getostream(const char *ospec, const char *mname, int b LUENT *lep; STREAMOUT *sop; char *cp; - + + info[0] = '\0'; if (ospec == NULL) { /* use stdout? */ if (!noopen & !using_stdout) { if (outfmt != 'a') SET_FILE_BINARY(stdout); +#ifdef getc_unlocked + flockfile(stdout); /* avoid lock/unlock overhead */ +#endif if (header) { cp = info; if (yres > 0) { @@ -162,9 +168,6 @@ getostream(const char *ospec, const char *mname, int b if (waitflush > 0) fflush(stdout); stdos.xr = xres; stdos.yr = yres; -#ifdef getc_unlocked - flockfile(stdout); /* avoid lock/unlock overhead */ -#endif using_stdout = 1; } stdos.ofp = stdout; @@ -184,7 +187,7 @@ getostream(const char *ospec, const char *mname, int b sop = (STREAMOUT *)malloc(sizeof(STREAMOUT)); if (sop == NULL) error(SYSTEM, "out of memory in getostream"); - sop->outpipe = oname[0] == '!'; + sop->outpipe = (oname[0] == '!'); sop->reclen = 0; sop->ofp = NULL; /* open iff noopen==0 */ sop->xr = xres; sop->yr = yres; @@ -194,6 +197,12 @@ getostream(const char *ospec, const char *mname, int b errno = EEXIST; /* file exists */ goto openerr; } + } else if (noopen && outfmt == 'c' && /* stream exists to picture? */ + (sop->xr > 0) & (sop->yr > 0)) { + if (ofl & OF_BIN) + return(NULL); /* let caller offset bins */ + sprintf(errmsg, "output '%s' not a valid picture", oname); + error(WARNING, errmsg); } if (!noopen && sop->ofp == NULL) { /* open output stream */ if (oname[0] == '!') /* output to command */ @@ -331,17 +340,17 @@ put_contrib(const DCOLOR cnt, FILE *fout) void mod_output(MODCONT *mp) { - STREAMOUT *sop = getostream(mp->outspec, mp->modname, 0, 0); + STREAMOUT *sop = getostream(mp->outspec, mp->modname, mp->bin0, 0); int j; put_contrib(mp->cbin[0], sop->ofp); if (mp->nbins > 3 && /* minor optimization */ - sop == getostream(mp->outspec, mp->modname, 1, 0)) { + sop == getostream(mp->outspec, mp->modname, mp->bin0+1, 0)) { for (j = 1; j < mp->nbins; j++) put_contrib(mp->cbin[j], sop->ofp); } else { for (j = 1; j < mp->nbins; j++) { - sop = getostream(mp->outspec, mp->modname, j, 0); + sop = getostream(mp->outspec, mp->modname, mp->bin0+j, 0); put_contrib(mp->cbin[j], sop->ofp); } } @@ -439,7 +448,7 @@ reload_output() char *outvfmt; LUENT *oent; int xr, yr; - STREAMOUT sout; + STREAMOUT *sop; DCOLOR rgbv; if (outfmt == 'a') @@ -452,50 +461,43 @@ reload_output() error(USER, "cannot reload from stdout"); if (mp->outspec[0] == '!') error(USER, "cannot reload from command"); - for (j = 0; ; j++) { /* load each modifier bin */ - ofl = ofname(oname, mp->outspec, mp->modname, j); + for (j = 0; j < mp->nbins; j++) { /* load each modifier bin */ + ofl = ofname(oname, mp->outspec, mp->modname, mp->bin0+j); if (ofl < 0) error(USER, "bad output file specification"); oent = lu_find(&ofiletab, oname); - if (oent->data != NULL) { - sout = *(STREAMOUT *)oent->data; - } else { - sout.reclen = 0; - sout.outpipe = 0; - sout.xr = xres; sout.yr = yres; - sout.ofp = NULL; - } - if (sout.ofp == NULL) { /* open output as input */ - sout.ofp = fopen(oname, fmode); - if (sout.ofp == NULL) { - if (j == mp->nbins) - break; /* assume end of modifier */ + if (oent->data == NULL) + error(INTERNAL, "unallocated stream in reload_output()"); + sop = (STREAMOUT *)oent->data; + if (sop->ofp == NULL) { /* open output as input */ + sop->ofp = fopen(oname, fmode); + if (sop->ofp == NULL) { sprintf(errmsg, "missing reload file '%s'", oname); error(WARNING, errmsg); break; } #ifdef getc_unlocked - flockfile(sout.ofp); + flockfile(sop->ofp); #endif - if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) { + if (header && checkheader(sop->ofp, outvfmt, NULL) != 1) { sprintf(errmsg, "format mismatch for '%s'", oname); error(USER, errmsg); } - if ((sout.reclen == 1) & (sout.xr > 0) & (sout.yr > 0) && - (!fscnresolu(&xr, &yr, sout.ofp) || - (xr != sout.xr) | - (yr != sout.yr))) { + if ((sop->reclen == 1) & (sop->xr > 0) & (sop->yr > 0) && + (!fscnresolu(&xr, &yr, sop->ofp) || + (xr != sop->xr) | + (yr != sop->yr))) { sprintf(errmsg, "resolution mismatch for '%s'", oname); error(USER, errmsg); } } /* read in RGB value */ - if (!get_contrib(rgbv, sout.ofp)) { + if (!get_contrib(rgbv, sop->ofp)) { if (!j) { - fclose(sout.ofp); + fclose(sop->ofp); break; /* ignore empty file */ } if (j < mp->nbins) { @@ -504,21 +506,8 @@ reload_output() error(USER, errmsg); } break; - } - if (j >= mp->nbins) { /* check modifier size */ - sprintf(errmsg, - "mismatched -bn setting for reloading '%s'", - modname[i]); - error(USER, errmsg); - } - + } copycolor(mp->cbin[j], rgbv); - if (oent->key == NULL) /* new file entry */ - oent->key = strcpy((char *) - malloc(strlen(oname)+1), oname); - if (oent->data == NULL) - oent->data = (char *)malloc(sizeof(STREAMOUT)); - *(STREAMOUT *)oent->data = sout; } } lu_doall(&ofiletab, &myclose, NULL); /* close all files */ @@ -533,7 +522,7 @@ myseeko(const LUENT *e, void *p) off_t nbytes = *(off_t *)p; if (sop->reclen > 1) - nbytes = nbytes * sop->reclen; + nbytes *= (off_t)sop->reclen; if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) { sprintf(errmsg, "seek error on file '%s'", e->key); error(SYSTEM, errmsg); @@ -554,7 +543,7 @@ recover_output() int ofl; char oname[1024]; LUENT *oent; - STREAMOUT sout; + STREAMOUT *sop; off_t nvals; int xr, yr; @@ -583,88 +572,61 @@ recover_output() error(USER, "cannot recover from stdout"); if (mp->outspec[0] == '!') error(USER, "cannot recover from command"); - for (j = 0; ; j++) { /* check each bin's file */ - ofl = ofname(oname, mp->outspec, mp->modname, j); + for (j = 0; j < mp->nbins; j++) { /* check each bin's file */ + ofl = ofname(oname, mp->outspec, mp->modname, mp->bin0+j); if (ofl < 0) error(USER, "bad output file specification"); oent = lu_find(&ofiletab, oname); - if (oent->data != NULL) { - sout = *(STREAMOUT *)oent->data; - } else { - sout.reclen = 0; - sout.outpipe = 0; - sout.xr = xres; - sout.yr = yres; - sout.ofp = NULL; - } - if (sout.ofp != NULL) { /* already open? */ + if (oent->data == NULL) + error(INTERNAL, "unallocated stream in recover_output()"); + sop = (STREAMOUT *)oent->data; + if (sop->ofp != NULL) { /* already open? */ if (ofl & OF_BIN) continue; break; } /* open output */ - sout.ofp = fopen(oname, "rb+"); - if (sout.ofp == NULL) { - if (j == mp->nbins) - break; /* assume end of modifier */ + sop->ofp = fopen(oname, "rb+"); + if (sop->ofp == NULL) { sprintf(errmsg, "missing recover file '%s'", oname); error(WARNING, errmsg); + lastout = 0; break; } - nvals = lseek(fileno(sout.ofp), 0, SEEK_END); + nvals = lseek(fileno(sop->ofp), 0, SEEK_END); if (nvals <= 0) { lastout = 0; /* empty output, quit here */ - fclose(sout.ofp); + fclose(sop->ofp); break; } - if (!sout.reclen) { - if (!(ofl & OF_BIN)) { - sprintf(errmsg, - "need -bn to recover file '%s'", - oname); - error(USER, errmsg); - } - recsiz = outvsiz; - } else - recsiz = outvsiz * sout.reclen; + recsiz = outvsiz * sop->reclen; - lseek(fileno(sout.ofp), 0, SEEK_SET); - if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) { + lseek(fileno(sop->ofp), 0, SEEK_SET); + if (header && checkheader(sop->ofp, outvfmt, NULL) != 1) { sprintf(errmsg, "format mismatch for '%s'", oname); error(USER, errmsg); } - if ((sout.reclen == 1) & (sout.xr > 0) & (sout.yr > 0) && - (!fscnresolu(&xr, &yr, sout.ofp) || - (xr != sout.xr) | - (yr != sout.yr))) { + if ((sop->reclen == 1) & (sop->xr > 0) & (sop->yr > 0) && + (!fscnresolu(&xr, &yr, sop->ofp) || + (xr != sop->xr) | + (yr != sop->yr))) { sprintf(errmsg, "resolution mismatch for '%s'", oname); error(USER, errmsg); } - nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz; + nvals = (nvals - (off_t)ftell(sop->ofp)) / recsiz; if ((lastout < 0) | (nvals < lastout)) lastout = nvals; - if (oent->key == NULL) /* new entry */ - oent->key = strcpy((char *) - malloc(strlen(oname)+1), oname); - if (oent->data == NULL) - oent->data = (char *)malloc(sizeof(STREAMOUT)); - *(STREAMOUT *)oent->data = sout; if (!(ofl & OF_BIN)) break; /* no bin separation */ } if (!lastout) { /* empty output */ error(WARNING, "no previous data to recover"); - lu_done(&ofiletab); /* reclose all outputs */ + /* reclose all outputs */ + lu_doall(&ofiletab, &myclose, NULL); return; - } - if (j > mp->nbins) { /* check modifier size */ - sprintf(errmsg, - "mismatched -bn setting for recovering '%s'", - modname[i]); - error(USER, errmsg); } } if (lastout < 0) {
