--- ray/src/rt/rc2.c 2012/06/11 05:07:55 2.3 +++ ray/src/rt/rc2.c 2017/02/07 16:48:14 2.22 @@ -1,14 +1,15 @@ #ifndef lint -static const char RCSid[] = "$Id: rc2.c,v 2.3 2012/06/11 05:07:55 greg Exp $"; +static const char RCSid[] = "$Id: rc2.c,v 2.22 2017/02/07 16:48:14 greg Exp $"; #endif /* * Accumulate ray contributions for a set of materials * File i/o and recovery */ +#include +#include "platform.h" #include "rcontrib.h" #include "resolu.h" -#include "platform.h" /* Close output stream and free record */ static void @@ -112,6 +113,7 @@ printheader(FILE *fout, const char *info) printargs(gargc-1, gargv, fout); /* add our command */ fprintf(fout, "SOFTWARE= %s\n", VersionID); fputnow(fout); + fputs("NCOMP=3\n", fout); /* always RGB */ if (info != NULL) /* add extra info if given */ fputs(info, fout); fputformat(formstr(outfmt), fout); @@ -132,20 +134,31 @@ printresolu(FILE *fout, int xr, int yr) STREAMOUT * getostream(const char *ospec, const char *mname, int bn, int noopen) { - /* static const DCOLOR nocontrib = BLKCOLOR; */ static STREAMOUT stdos; + char info[1024]; int ofl; char oname[1024]; LUENT *lep; STREAMOUT *sop; + char *cp; if (ospec == NULL) { /* use stdout? */ if (!noopen & !using_stdout) { if (outfmt != 'a') SET_FILE_BINARY(stdout); - if (header) - printheader(stdout, NULL); - printresolu(stdout, xres, yres); + if (header) { + cp = info; + if (yres > 0) { + sprintf(cp, "NROWS=%d\n", yres * + (xres + !xres) ); + while (*cp) ++cp; + } + if ((xres <= 0) | (stdos.reclen > 1)) + sprintf(cp, "NCOLS=%d\n", stdos.reclen); + printheader(stdout, info); + } + if (stdos.reclen == 1) + printresolu(stdout, xres, yres); if (waitflush > 0) fflush(stdout); stdos.xr = xres; stdos.yr = yres; @@ -171,7 +184,7 @@ getostream(const char *ospec, const char *mname, int b sop = (STREAMOUT *)malloc(sizeof(STREAMOUT)); if (sop == NULL) error(SYSTEM, "out of memory in getostream"); - sop->outpipe = oname[0] == '!'; + sop->outpipe = (oname[0] == '!'); sop->reclen = 0; sop->ofp = NULL; /* open iff noopen==0 */ sop->xr = xres; sop->yr = yres; @@ -181,9 +194,14 @@ getostream(const char *ospec, const char *mname, int b errno = EEXIST; /* file exists */ goto openerr; } + } else if (noopen && outfmt == 'c' && /* stream exists to picture? */ + (sop->xr > 0) & (sop->yr > 0)) { + if (ofl & OF_BIN) + return(NULL); /* let caller offset bins */ + sprintf(errmsg, "output '%s' not a valid picture", oname); + error(WARNING, errmsg); } if (!noopen && sop->ofp == NULL) { /* open output stream */ - long i; if (oname[0] == '!') /* output to command */ sop->ofp = popen(oname+1, "w"); else /* else open file */ @@ -195,9 +213,11 @@ getostream(const char *ospec, const char *mname, int b #ifdef getc_unlocked flockfile(sop->ofp); /* avoid lock/unlock overhead */ #endif + if (accumulate > 0) { /* global resolution */ + sop->xr = xres; sop->yr = yres; + } if (header) { - char info[512]; - char *cp = info; + cp = info; if (ofl & OF_MODIFIER || sop->reclen == 1) { sprintf(cp, "MODIFIER=%s\n", mname); while (*cp) ++cp; @@ -206,24 +226,17 @@ getostream(const char *ospec, const char *mname, int b sprintf(cp, "BIN=%d\n", bn); while (*cp) ++cp; } - *cp = '\0'; + if (sop->yr > 0) { + sprintf(cp, "NROWS=%d\n", sop->yr * + (sop->xr + !sop->xr) ); + while (*cp) ++cp; + } + if ((sop->xr <= 0) | (sop->reclen > 1)) + sprintf(cp, "NCOLS=%d\n", sop->reclen); printheader(sop->ofp, info); } - if (accumulate > 0) { /* global resolution */ - sop->xr = xres; sop->yr = yres; - } - printresolu(sop->ofp, sop->xr, sop->yr); -#if 0 - /* play catch-up */ - for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) { - int j = sop->reclen; - if (j <= 0) j = 1; - while (j--) - put_contrib(nocontrib, sop->ofp); - if (outfmt == 'a') - putc('\n', sop->ofp); - } -#endif + if (sop->reclen == 1) + printresolu(sop->ofp, sop->xr, sop->yr); if (waitflush > 0) fflush(sop->ofp); } @@ -255,12 +268,12 @@ getvec(FVECT vec) } break; case 'f': /* binary float */ - if (fread((char *)vf, sizeof(float), 3, stdin) != 3) + if (getbinary((char *)vf, sizeof(float), 3, stdin) != 3) return(-1); VCOPY(vec, vf); break; case 'd': /* binary double */ - if (fread((char *)vd, sizeof(double), 3, stdin) != 3) + if (getbinary((char *)vd, sizeof(double), 3, stdin) != 3) return(-1); VCOPY(vec, vd); break; @@ -296,23 +309,23 @@ put_contrib(const DCOLOR cnt, FILE *fout) scalecolor(fv, sf); } else copycolor(fv, cnt); - fwrite(fv, sizeof(float), 3, fout); + putbinary(fv, sizeof(float), 3, fout); break; case 'd': if (accumulate > 1) { DCOLOR dv; copycolor(dv, cnt); scalecolor(dv, sf); - fwrite(dv, sizeof(double), 3, fout); + putbinary(dv, sizeof(double), 3, fout); } else - fwrite(cnt, sizeof(double), 3, fout); + putbinary(cnt, sizeof(double), 3, fout); break; case 'c': if (accumulate > 1) setcolr(cv, sf*cnt[0], sf*cnt[1], sf*cnt[2]); else setcolr(cv, cnt[0], cnt[1], cnt[2]); - fwrite(cv, sizeof(cv), 1, fout); + putbinary(cv, sizeof(cv), 1, fout); break; default: error(INTERNAL, "botched output format"); @@ -324,17 +337,17 @@ put_contrib(const DCOLOR cnt, FILE *fout) void mod_output(MODCONT *mp) { - STREAMOUT *sop = getostream(mp->outspec, mp->modname, 0, 0); + STREAMOUT *sop = getostream(mp->outspec, mp->modname, mp->bin0, 0); int j; put_contrib(mp->cbin[0], sop->ofp); if (mp->nbins > 3 && /* minor optimization */ - sop == getostream(mp->outspec, mp->modname, 1, 0)) { + sop == getostream(mp->outspec, mp->modname, mp->bin0+1, 0)) { for (j = 1; j < mp->nbins; j++) put_contrib(mp->cbin[j], sop->ofp); } else { for (j = 1; j < mp->nbins; j++) { - sop = getostream(mp->outspec, mp->modname, j, 0); + sop = getostream(mp->outspec, mp->modname, mp->bin0+j, 0); put_contrib(mp->cbin[j], sop->ofp); } } @@ -364,7 +377,7 @@ void end_record() { --waitflush; - lu_doall(&ofiletab, puteol, NULL); + lu_doall(&ofiletab, &puteol, NULL); if (using_stdout & (outfmt == 'a')) putc('\n', stdout); if (!waitflush) { @@ -387,14 +400,14 @@ get_contrib(DCOLOR cnt, FILE *finp) case 'a': return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3); case 'f': - if (fread(fv, sizeof(fv[0]), 3, finp) != 3) + if (getbinary(fv, sizeof(fv[0]), 3, finp) != 3) return(0); copycolor(cnt, fv); return(1); case 'd': - return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3); + return(getbinary(cnt, sizeof(cnt[0]), 3, finp) == 3); case 'c': - if (fread(cv, sizeof(cv), 1, finp) != 1) + if (getbinary(cv, sizeof(cv), 1, finp) != 1) return(0); colr_color(fv, cv); copycolor(cnt, fv); @@ -432,7 +445,7 @@ reload_output() char *outvfmt; LUENT *oent; int xr, yr; - STREAMOUT sout; + STREAMOUT *sop; DCOLOR rgbv; if (outfmt == 'a') @@ -445,50 +458,43 @@ reload_output() error(USER, "cannot reload from stdout"); if (mp->outspec[0] == '!') error(USER, "cannot reload from command"); - for (j = 0; ; j++) { /* load each modifier bin */ - ofl = ofname(oname, mp->outspec, mp->modname, j); + for (j = 0; j < mp->nbins; j++) { /* load each modifier bin */ + ofl = ofname(oname, mp->outspec, mp->modname, mp->bin0+j); if (ofl < 0) error(USER, "bad output file specification"); oent = lu_find(&ofiletab, oname); - if (oent->data != NULL) { - sout = *(STREAMOUT *)oent->data; - } else { - sout.reclen = 0; - sout.outpipe = 0; - sout.xr = xres; sout.yr = yres; - sout.ofp = NULL; - } - if (sout.ofp == NULL) { /* open output as input */ - sout.ofp = fopen(oname, fmode); - if (sout.ofp == NULL) { - if (j == mp->nbins) - break; /* assume end of modifier */ + if (oent->data == NULL) + error(INTERNAL, "unallocated stream in reload_output()"); + sop = (STREAMOUT *)oent->data; + if (sop->ofp == NULL) { /* open output as input */ + sop->ofp = fopen(oname, fmode); + if (sop->ofp == NULL) { sprintf(errmsg, "missing reload file '%s'", oname); error(WARNING, errmsg); break; } #ifdef getc_unlocked - flockfile(sout.ofp); + flockfile(sop->ofp); #endif - if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) { + if (header && checkheader(sop->ofp, outvfmt, NULL) != 1) { sprintf(errmsg, "format mismatch for '%s'", oname); error(USER, errmsg); } - if ((sout.xr > 0) & (sout.yr > 0) && - (!fscnresolu(&xr, &yr, sout.ofp) || - (xr != sout.xr) | - (yr != sout.yr))) { + if ((sop->reclen == 1) & (sop->xr > 0) & (sop->yr > 0) && + (!fscnresolu(&xr, &yr, sop->ofp) || + (xr != sop->xr) | + (yr != sop->yr))) { sprintf(errmsg, "resolution mismatch for '%s'", oname); error(USER, errmsg); } } /* read in RGB value */ - if (!get_contrib(rgbv, sout.ofp)) { + if (!get_contrib(rgbv, sop->ofp)) { if (!j) { - fclose(sout.ofp); + fclose(sop->ofp); break; /* ignore empty file */ } if (j < mp->nbins) { @@ -497,24 +503,11 @@ reload_output() error(USER, errmsg); } break; - } - if (j >= mp->nbins) { /* check modifier size */ - sprintf(errmsg, - "mismatched -bn setting for reloading '%s'", - modname[i]); - error(USER, errmsg); - } - + } copycolor(mp->cbin[j], rgbv); - if (oent->key == NULL) /* new file entry */ - oent->key = strcpy((char *) - malloc(strlen(oname)+1), oname); - if (oent->data == NULL) - oent->data = (char *)malloc(sizeof(STREAMOUT)); - *(STREAMOUT *)oent->data = sout; } } - lu_doall(&ofiletab, myclose, NULL); /* close all files */ + lu_doall(&ofiletab, &myclose, NULL); /* close all files */ } @@ -526,7 +519,7 @@ myseeko(const LUENT *e, void *p) off_t nbytes = *(off_t *)p; if (sop->reclen > 1) - nbytes = nbytes * sop->reclen; + nbytes *= (off_t)sop->reclen; if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) { sprintf(errmsg, "seek error on file '%s'", e->key); error(SYSTEM, errmsg); @@ -547,7 +540,7 @@ recover_output() int ofl; char oname[1024]; LUENT *oent; - STREAMOUT sout; + STREAMOUT *sop; off_t nvals; int xr, yr; @@ -576,88 +569,62 @@ recover_output() error(USER, "cannot recover from stdout"); if (mp->outspec[0] == '!') error(USER, "cannot recover from command"); - for (j = 0; ; j++) { /* check each bin's file */ - ofl = ofname(oname, mp->outspec, mp->modname, j); + for (j = 0; j < mp->nbins; j++) { /* check each bin's file */ + ofl = ofname(oname, mp->outspec, mp->modname, mp->bin0+j); if (ofl < 0) error(USER, "bad output file specification"); oent = lu_find(&ofiletab, oname); - if (oent->data != NULL) { - sout = *(STREAMOUT *)oent->data; - } else { - sout.reclen = 0; - sout.outpipe = 0; - sout.ofp = NULL; - } - if (sout.ofp != NULL) { /* already open? */ + if (oent->data == NULL) + error(INTERNAL, "unallocated stream in recover_output()"); + sop = (STREAMOUT *)oent->data; + if (sop->ofp != NULL) { /* already open? */ if (ofl & OF_BIN) continue; break; } /* open output */ - sout.ofp = fopen(oname, "rb+"); - if (sout.ofp == NULL) { - if (j == mp->nbins) - break; /* assume end of modifier */ + sop->ofp = fopen(oname, "rb+"); + if (sop->ofp == NULL) { sprintf(errmsg, "missing recover file '%s'", oname); error(WARNING, errmsg); + lastout = 0; break; } - nvals = lseek(fileno(sout.ofp), 0, SEEK_END); + nvals = lseek(fileno(sop->ofp), 0, SEEK_END); if (nvals <= 0) { lastout = 0; /* empty output, quit here */ - fclose(sout.ofp); + fclose(sop->ofp); break; } - if (!sout.reclen) { - if (!(ofl & OF_BIN)) { - sprintf(errmsg, - "need -bn to recover file '%s'", - oname); - error(USER, errmsg); - } - recsiz = outvsiz; - } else - recsiz = outvsiz * sout.reclen; + recsiz = outvsiz * sop->reclen; - lseek(fileno(sout.ofp), 0, SEEK_SET); - if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) { + lseek(fileno(sop->ofp), 0, SEEK_SET); + if (header && checkheader(sop->ofp, outvfmt, NULL) != 1) { sprintf(errmsg, "format mismatch for '%s'", oname); error(USER, errmsg); } - sout.xr = xres; sout.yr = yres; - if ((sout.xr > 0) & (sout.yr > 0) && - (!fscnresolu(&xr, &yr, sout.ofp) || - (xr != sout.xr) | - (yr != sout.yr))) { + if ((sop->reclen == 1) & (sop->xr > 0) & (sop->yr > 0) && + (!fscnresolu(&xr, &yr, sop->ofp) || + (xr != sop->xr) | + (yr != sop->yr))) { sprintf(errmsg, "resolution mismatch for '%s'", oname); error(USER, errmsg); } - nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz; + nvals = (nvals - (off_t)ftell(sop->ofp)) / recsiz; if ((lastout < 0) | (nvals < lastout)) lastout = nvals; - if (oent->key == NULL) /* new entry */ - oent->key = strcpy((char *) - malloc(strlen(oname)+1), oname); - if (oent->data == NULL) - oent->data = (char *)malloc(sizeof(STREAMOUT)); - *(STREAMOUT *)oent->data = sout; if (!(ofl & OF_BIN)) break; /* no bin separation */ } if (!lastout) { /* empty output */ error(WARNING, "no previous data to recover"); - lu_done(&ofiletab); /* reclose all outputs */ + /* reclose all outputs */ + lu_doall(&ofiletab, &myclose, NULL); return; } - if (j > mp->nbins) { /* check modifier size */ - sprintf(errmsg, - "mismatched -bn setting for recovering '%s'", - modname[i]); - error(USER, errmsg); - } } if (lastout < 0) { error(WARNING, "no output files to recover"); @@ -670,14 +637,15 @@ recover_output() } /* seek on all files */ nvals = lastout * outvsiz; - lu_doall(&ofiletab, myseeko, &nvals); + lu_doall(&ofiletab, &myseeko, &nvals); /* skip repeated input */ + lastout *= accumulate; for (nvals = 0; nvals < lastout; nvals++) { FVECT vdummy; if (getvec(vdummy) < 0 || getvec(vdummy) < 0) error(USER, "unexpected EOF on input"); } - lastray = lastdone = lastout * accumulate; + lastray = lastdone = (RNUMBER)lastout; if (raysleft) raysleft -= lastray; }
