--- ray/src/rt/rc2.c 2016/09/16 04:49:15 2.20 +++ ray/src/rt/rc2.c 2024/05/22 21:44:03 2.27 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rc2.c,v 2.20 2016/09/16 04:49:15 greg Exp $"; +static const char RCSid[] = "$Id: rc2.c,v 2.27 2024/05/22 21:44:03 greg Exp $"; #endif /* * Accumulate ray contributions for a set of materials @@ -113,9 +113,13 @@ printheader(FILE *fout, const char *info) printargs(gargc-1, gargv, fout); /* add our command */ fprintf(fout, "SOFTWARE= %s\n", VersionID); fputnow(fout); - fputs("NCOMP=3\n", fout); /* always RGB */ + fputncomp(NCSAMP, fout); + if (NCSAMP > 3) + fputwlsplit(WLPART, fout); if (info != NULL) /* add extra info if given */ fputs(info, fout); + if ((outfmt == 'f') | (outfmt == 'd')) + fputendian(fout); fputformat(formstr(outfmt), fout); fputc('\n', fout); /* empty line ends header */ } @@ -141,11 +145,15 @@ getostream(const char *ospec, const char *mname, int b LUENT *lep; STREAMOUT *sop; char *cp; - + + info[0] = '\0'; if (ospec == NULL) { /* use stdout? */ if (!noopen & !using_stdout) { if (outfmt != 'a') SET_FILE_BINARY(stdout); +#ifdef getc_unlocked + flockfile(stdout); /* avoid lock/unlock overhead */ +#endif if (header) { cp = info; if (yres > 0) { @@ -162,9 +170,6 @@ getostream(const char *ospec, const char *mname, int b if (waitflush > 0) fflush(stdout); stdos.xr = xres; stdos.yr = yres; -#ifdef getc_unlocked - flockfile(stdout); /* avoid lock/unlock overhead */ -#endif using_stdout = 1; } stdos.ofp = stdout; @@ -268,12 +273,12 @@ getvec(FVECT vec) } break; case 'f': /* binary float */ - if (getbinary((char *)vf, sizeof(float), 3, stdin) != 3) + if (getbinary(vf, sizeof(float), 3, stdin) != 3) return(-1); VCOPY(vec, vf); break; case 'd': /* binary double */ - if (getbinary((char *)vd, sizeof(double), 3, stdin) != 3) + if (getbinary(vd, sizeof(double), 3, stdin) != 3) return(-1); VCOPY(vec, vd); break; @@ -286,46 +291,43 @@ getvec(FVECT vec) /* Put out ray contribution to file */ static void -put_contrib(const DCOLOR cnt, FILE *fout) +put_contrib(const DCOLORV *cnt, FILE *fout) { double sf = 1; - COLOR fv; - COLR cv; + SCOLOR fv; + SCOLR cv; + int i; if (accumulate > 1) sf = 1./(double)accumulate; switch (outfmt) { case 'a': - if (accumulate > 1) - fprintf(fout, "%.6e\t%.6e\t%.6e\t", - sf*cnt[0], sf*cnt[1], sf*cnt[2]); - else - fprintf(fout, "%.6e\t%.6e\t%.6e\t", - cnt[0], cnt[1], cnt[2]); + for (i = 0; i < NCSAMP; i++) + fprintf(fout, "%.6e\t", sf*cnt[i]); break; case 'f': - if (accumulate > 1) { - copycolor(fv, cnt); - scalecolor(fv, sf); - } else - copycolor(fv, cnt); - putbinary(fv, sizeof(float), 3, fout); + for (i = NCSAMP; i-- > 0; ) + fv[i] = cnt[i]; + if (accumulate > 1) + scalescolor(fv, sf); + putbinary(fv, sizeof(COLORV), NCSAMP, fout); break; case 'd': if (accumulate > 1) { - DCOLOR dv; - copycolor(dv, cnt); - scalecolor(dv, sf); - putbinary(dv, sizeof(double), 3, fout); + DCOLORV dv[MAXCSAMP]; + for (i = NCSAMP; i-- > 0; ) + dv[i] = sf*cnt[i]; + putbinary(dv, sizeof(DCOLORV), NCSAMP, fout); } else - putbinary(cnt, sizeof(double), 3, fout); + putbinary(cnt, sizeof(DCOLORV), NCSAMP, fout); break; case 'c': + for (i = NCSAMP; i-- > 0; ) + fv[i] = cnt[i]; if (accumulate > 1) - setcolr(cv, sf*cnt[0], sf*cnt[1], sf*cnt[2]); - else - setcolr(cv, cnt[0], cnt[1], cnt[2]); - putbinary(cv, sizeof(cv), 1, fout); + scalescolor(fv, sf); + scolor_scolr(cv, fv); + putbinary(cv, 1, LSCOLR, fout); break; default: error(INTERNAL, "botched output format"); @@ -340,15 +342,15 @@ mod_output(MODCONT *mp) STREAMOUT *sop = getostream(mp->outspec, mp->modname, mp->bin0, 0); int j; - put_contrib(mp->cbin[0], sop->ofp); + put_contrib(mp->cbin, sop->ofp); if (mp->nbins > 3 && /* minor optimization */ sop == getostream(mp->outspec, mp->modname, mp->bin0+1, 0)) { for (j = 1; j < mp->nbins; j++) - put_contrib(mp->cbin[j], sop->ofp); + put_contrib(mcbin(mp,j), sop->ofp); } else { for (j = 1; j < mp->nbins; j++) { sop = getostream(mp->outspec, mp->modname, mp->bin0+j, 0); - put_contrib(mp->cbin[j], sop->ofp); + put_contrib(mcbin(mp,j), sop->ofp); } } } @@ -391,31 +393,36 @@ end_record() /* Get ray contribution from previous file */ static int -get_contrib(DCOLOR cnt, FILE *finp) +get_contrib(DCOLORV *cnt, FILE *finp) { - COLOR fv; - COLR cv; + SCOLOR fv; + SCOLR cv; + int i; switch (outfmt) { case 'a': - return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3); - case 'f': - if (getbinary(fv, sizeof(fv[0]), 3, finp) != 3) - return(0); - copycolor(cnt, fv); + for (i = 0; i < NCSAMP; i++) + if (fscanf(finp, "%lf", &cnt[i]) != 1) + return(0); return(1); case 'd': - return(getbinary(cnt, sizeof(cnt[0]), 3, finp) == 3); + return(getbinary(cnt, sizeof(DCOLORV), NCSAMP, finp) == NCSAMP); + case 'f': + if (getbinary(fv, sizeof(COLORV), NCSAMP, finp) != NCSAMP) + return(0); + break; case 'c': - if (getbinary(cv, sizeof(cv), 1, finp) != 1) + if (getbinary(cv, 1, LSCOLR, finp) != LSCOLR) return(0); - colr_color(fv, cv); - copycolor(cnt, fv); - return(1); + scolr_scolor(fv, cv); + break; default: error(INTERNAL, "botched output format"); } - return(0); /* pro forma return */ + /* copy result from SCOLOR */ + for (i = NCSAMP; i-- > 0; ) + cnt[i] = fv[i]; + return(1); } @@ -446,11 +453,11 @@ reload_output() LUENT *oent; int xr, yr; STREAMOUT *sop; - DCOLOR rgbv; + DCOLORV contr[MAXCSAMP]; if (outfmt == 'a') fmode = "r"; - outvfmt = formstr(outfmt); + outvfmt = (char *)formstr(outfmt); /* reload modifier values */ for (i = 0; i < nmods; i++) { mp = (MODCONT *)lu_find(&modconttab,modname[i])->data; @@ -491,8 +498,8 @@ reload_output() error(USER, errmsg); } } - /* read in RGB value */ - if (!get_contrib(rgbv, sop->ofp)) { + /* read in spectral value */ + if (!get_contrib(contr, sop->ofp)) { if (!j) { fclose(sop->ofp); break; /* ignore empty file */ @@ -503,8 +510,8 @@ reload_output() error(USER, errmsg); } break; - } - copycolor(mp->cbin[j], rgbv); + } + memcpy(mcbin(mp,j), contr, DCOLORSIZ); } } lu_doall(&ofiletab, &myclose, NULL); /* close all files */ @@ -519,7 +526,7 @@ myseeko(const LUENT *e, void *p) off_t nbytes = *(off_t *)p; if (sop->reclen > 1) - nbytes = nbytes * sop->reclen; + nbytes *= (off_t)sop->reclen; if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) { sprintf(errmsg, "seek error on file '%s'", e->key); error(SYSTEM, errmsg); @@ -549,19 +556,19 @@ recover_output() error(USER, "cannot recover ASCII output"); return; case 'f': - outvsiz = sizeof(float)*3; + outvsiz = sizeof(float)*NCSAMP; break; case 'd': - outvsiz = sizeof(double)*3; + outvsiz = sizeof(double)*NCSAMP; break; case 'c': - outvsiz = sizeof(COLR); + outvsiz = LSCOLR; break; default: error(INTERNAL, "botched output format"); return; } - outvfmt = formstr(outfmt); + outvfmt = (char *)formstr(outfmt); /* check modifier outputs */ for (i = 0; i < nmods; i++) { mp = (MODCONT *)lu_find(&modconttab,modname[i])->data; @@ -588,6 +595,7 @@ recover_output() sprintf(errmsg, "missing recover file '%s'", oname); error(WARNING, errmsg); + lastout = 0; break; } nvals = lseek(fileno(sop->ofp), 0, SEEK_END); @@ -620,7 +628,8 @@ recover_output() } if (!lastout) { /* empty output */ error(WARNING, "no previous data to recover"); - lu_done(&ofiletab); /* reclose all outputs */ + /* reclose all outputs */ + lu_doall(&ofiletab, &myclose, NULL); return; } }
