root/radiance/ray/src/rt/rc2.c
Wed May 22 21:44:03 2024 UTC (12 months, 3 weeks ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26
fix(rcontrib): Added output of wavelength splits for hyperspectral results
Wed Nov 15 18:02:53 2023 UTC (19 months ago) by greg
Changes since 2.25: +57 -55 lines
Diff to previous 2.25
Fri Apr 7 00:03:26 2023 UTC (2 years, 2 months ago) by greg
Diff to previous 2.24
fix(rcontrib): Fixed potential string overrun while printing header
Wed Sep 4 20:19:51 2019 UTC (5 years, 9 months ago) by greg
Changes since 2.23: +4 -4 lines
Diff to previous 2.23
Minor change should not affect behavior
Wed Aug 14 20:07:20 2019 UTC (5 years, 10 months ago) by greg
Changes since 2.22: +3 -1 lines
Diff to previous 2.22
Added BigEndian= line to binary header output
Tue Feb 7 16:48:14 2017 UTC (8 years, 4 months ago) by greg
CVS Tags: rad5R1, rad5R2
Diff to previous 2.21
Minor changes
Fri Sep 16 05:06:07 2016 UTC (8 years, 9 months ago) by greg
Changes since 2.20: +4 -2 lines
Diff to previous 2.20
Addition tweaks/fixes to recovery when there is no data or missing file(s)
Fri Sep 16 04:49:15 2016 UTC (8 years, 9 months ago) by greg
Changes since 2.19: +38 -87 lines
Diff to previous 2.19
Fixed issue with new picture bin renumbering and recovery operation
Mon Sep 12 20:31:34 2016 UTC (8 years, 9 months ago) by greg
Changes since 2.18: +11 -5 lines
Diff to previous 2.18
Thu Aug 18 00:52:48 2016 UTC (8 years, 10 months ago) by greg
Changes since 2.17: +10 -10 lines
Diff to previous 2.17
Sun Mar 6 01:13:18 2016 UTC (9 years, 3 months ago) by schorsch
Changes since 2.16: +3 -2 lines
Diff to previous 2.16
Tue Mar 1 00:58:31 2016 UTC (9 years, 3 months ago) by greg
Changes since 2.15: +5 -4 lines
Diff to previous 2.15
Made recovery more consisten w.r.t. resolution string
Sun Aug 23 00:17:12 2015 UTC (9 years, 9 months ago) by greg
Changes since 2.14: +4 -4 lines
Diff to previous 2.14
Minor tweaks & performance improvements for rcontrib file locking
Fri Aug 21 18:21:05 2015 UTC (9 years, 9 months ago) by greg
Diff to previous 2.13
Hopefull fix to deadlock issues under Mac OS X 10.10.x (Yosemite)
Thu Jul 24 16:28:17 2014 UTC (10 years, 10 months ago) by greg
Changes since 2.12: +9 -5 lines
Diff to previous 2.12
Made NROWS/NCOLS more consistent with resolution string
Wed Jul 9 21:09:28 2014 UTC (10 years, 11 months ago) by greg
Changes since 2.11: +2 -3 lines
Removed redundant NCOLS= line in header
Fri Jun 13 01:16:41 2014 UTC (11 years ago) by greg
Changes since 2.10: +18 -6 lines
Added NROWS= setting to header
Fri May 30 16:05:52 2014 UTC (11 years ago) by greg
Added NCOMP to header
Thu May 29 04:56:43 2014 UTC (11 years ago) by greg
Changes since 2.8: +8 -6 lines
Added NCOLS= and NCOMP= to header output
Wed Aug 7 05:10:09 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.7: +2 -13 lines
Thu Nov 15 19:41:03 2012 UTC (12 years, 7 months ago) by greg
Thu Jun 21 17:14:32 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.5: +1 -2 lines
Accommodations for Windows
Tue Jun 19 00:12:08 2012 UTC (13 years ago) by greg
Changes since 2.4: +3 -2 lines
Added quick-exit mode and fixed bug in recovery option with -c > 1
Tue Jun 12 17:20:44 2012 UTC (13 years ago) by greg
Further efficiency improvements
Mon Jun 11 05:07:55 2012 UTC (13 years ago) by greg
Changes since 2.2: +25 -4 lines
Fixed a number of bugs -- still testing
Sun Jun 10 05:25:42 2012 UTC (13 years ago) by greg
Changes since 2.1: +12 -10 lines
Tweaks and bug fixes to new code
Sat Jun 9 07:16:47 2012 UTC (13 years ago) by greg
