1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: raytrace.c,v 2.52 2005/06/21 15:06:50 greg Exp $"; |
3 |
#endif |
4 |
5 |
* raytrace.c - routines for tracing and shading rays. |
6 |
7 |
* External symbols declared in ray.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include "ray.h" |
13 |
#include "source.h" |
14 |
#include "otypes.h" |
15 |
#include "otspecial.h" |
16 |
#include "random.h" |
17 |
18 |
#define MAXCSET ((MAXSET+1)*2-1) /* maximum check set size */ |
19 |
20 |
unsigned long raynum = 0; /* next unique ray number */ |
21 |
unsigned long nrays = 0; /* number of calls to localhit */ |
22 |
23 |
static RREAL Lambfa[5] = {PI, PI, PI, 0.0, 0.0}; |
24 |
OBJREC Lamb = { |
25 |
OVOID, MAT_PLASTIC, "Lambertian", |
26 |
{0, 5, NULL, Lambfa}, NULL, |
27 |
}; /* a Lambertian surface */ |
28 |
29 |
OBJREC Aftplane; /* aft clipping plane object */ |
30 |
31 |
#define RAYHIT (-1) /* return value for intercepted ray */ |
32 |
33 |
static int raymove(FVECT pos, OBJECT *cxs, int dirf, RAY *r, CUBE *cu); |
34 |
static int checkhit(RAY *r, CUBE *cu, OBJECT *cxs); |
35 |
static void checkset(OBJECT *os, OBJECT *cs); |
36 |
37 |
38 |
extern int |
39 |
rayorigin( /* start new ray from old one */ |
40 |
RAY *r, |
41 |
int rt, |
42 |
const RAY *ro, |
43 |
const COLOR rc |
44 |
45 |
46 |
double rw, re; |
47 |
/* assign coefficient/weight */ |
48 |
if (rc == NULL) { |
49 |
rw = 1.0; |
50 |
setcolor(r->rcoef, 1., 1., 1.); |
51 |
} else { |
52 |
rw = intens(rc); |
53 |
if (rc != r->rcoef) |
54 |
copycolor(r->rcoef, rc); |
55 |
56 |
if ((r->parent = ro) == NULL) { /* primary ray */ |
57 |
r->rlvl = 0; |
58 |
r->rweight = rw; |
59 |
r->crtype = r->rtype = rt; |
60 |
r->rsrc = -1; |
61 |
r->clipset = NULL; |
62 |
r->revf = raytrace; |
63 |
copycolor(r->cext, cextinction); |
64 |
copycolor(r->albedo, salbedo); |
65 |
r->gecc = seccg; |
66 |
r->slights = NULL; |
67 |
} else { /* spawned ray */ |
68 |
if (ro->rot >= FHUGE) { |
69 |
memset(r, 0, sizeof(RAY)); |
70 |
return(-1); /* illegal continuation */ |
71 |
72 |
r->rlvl = ro->rlvl; |
73 |
if (rt & RAYREFL) { |
74 |
r->rlvl++; |
75 |
r->rsrc = -1; |
76 |
r->clipset = ro->clipset; |
77 |
r->rmax = 0.0; |
78 |
} else { |
79 |
r->rsrc = ro->rsrc; |
80 |
r->clipset = ro->newcset; |
81 |
r->rmax = ro->rmax <= FTINY ? 0.0 : ro->rmax - ro->rot; |
82 |
83 |
r->revf = ro->revf; |
84 |
copycolor(r->cext, ro->cext); |
85 |
copycolor(r->albedo, ro->albedo); |
86 |
r->gecc = ro->gecc; |
87 |
r->slights = ro->slights; |
88 |
r->crtype = ro->crtype | (r->rtype = rt); |
89 |
VCOPY(r->rorg, ro->rop); |
90 |
r->rweight = ro->rweight * rw; |
91 |
/* estimate extinction */ |
92 |
re = colval(ro->cext,RED) < colval(ro->cext,GRN) ? |
93 |
colval(ro->cext,RED) : colval(ro->cext,GRN); |
94 |
if (colval(ro->cext,BLU) < re) re = colval(ro->cext,BLU); |
95 |
re *= ro->rot; |
96 |
if (re > 0.1) |
97 |
if (re > 92.) |
98 |
r->rweight = 0.0; |
99 |
else |
100 |
r->rweight *= exp(-re); |
101 |
102 |
rayclear(r); |
103 |
if (r->rweight <= 0.0) /* check for expiration */ |
104 |
return(-1); |
105 |
if (r->crtype & SHADOW) /* shadow commitment */ |
106 |
return(0); |
107 |
if (maxdepth <= 0 && rc != NULL) { /* Russian roulette */ |
108 |
if (minweight <= 0.0) |
109 |
error(USER, "zero ray weight in Russian roulette"); |
110 |
if (maxdepth < 0 && r->rlvl > -maxdepth) |
111 |
return(-1); /* upper reflection limit */ |
112 |
if (r->rweight >= minweight) |
113 |
return(0); |
114 |
if (frandom() < r->rweight/minweight) |
115 |
return(-1); |
116 |
rw = minweight/r->rweight; /* promote survivor */ |
117 |
scalecolor(r->rcoef, rw); |
118 |
r->rweight = minweight; |
119 |
return(0); |
120 |
121 |
return(r->rlvl <= maxdepth && r->rweight >= minweight ? 0 : -1); |
122 |
123 |
124 |
125 |
extern void |
126 |
rayclear( /* clear a ray for (re)evaluation */ |
127 |
register RAY *r |
128 |
129 |
130 |
r->rno = raynum++; |
131 |
r->newcset = r->clipset; |
132 |
r->hitf = rayhit; |
133 |
r->robj = OVOID; |
134 |
r->ro = NULL; |
135 |
r->rox = NULL; |
136 |
r->rt = r->rot = FHUGE; |
137 |
r->pert[0] = r->pert[1] = r->pert[2] = 0.0; |
138 |
r->uv[0] = r->uv[1] = 0.0; |
139 |
setcolor(r->pcol, 1.0, 1.0, 1.0); |
140 |
setcolor(r->rcol, 0.0, 0.0, 0.0); |
141 |
142 |
143 |
144 |
extern void |
145 |
raytrace( /* trace a ray and compute its value */ |
146 |
RAY *r |
147 |
148 |
149 |
if (localhit(r, &thescene)) |
150 |
raycont(r); /* hit local surface, evaluate */ |
151 |
else if (r->ro == &Aftplane) { |
152 |
r->ro = NULL; /* hit aft clipping plane */ |
153 |
r->rot = FHUGE; |
154 |
} else if (sourcehit(r)) |
155 |
rayshade(r, r->ro->omod); /* distant source */ |
156 |
157 |
if (trace != NULL) |
158 |
(*trace)(r); /* trace execution */ |
159 |
160 |
rayparticipate(r); /* for participating medium */ |
161 |
162 |
163 |
164 |
extern void |
165 |
raycont( /* check for clipped object and continue */ |
166 |
register RAY *r |
167 |
168 |
169 |
if ((r->clipset != NULL && inset(r->clipset, r->ro->omod)) || |
170 |
!rayshade(r, r->ro->omod)) |
171 |
raytrans(r); |
172 |
173 |
174 |
175 |
extern void |
176 |
raytrans( /* transmit ray as is */ |
177 |
register RAY *r |
178 |
179 |
180 |
RAY tr; |
181 |
182 |
if (rayorigin(&tr, TRANS, r, NULL) == 0) { |
183 |
VCOPY(tr.rdir, r->rdir); |
184 |
rayvalue(&tr); |
185 |
copycolor(r->rcol, tr.rcol); |
186 |
r->rt = r->rot + tr.rt; |
187 |
188 |
189 |
190 |
191 |
extern int |
192 |
rayshade( /* shade ray r with material mod */ |
193 |
register RAY *r, |
194 |
int mod |
195 |
196 |
197 |
register OBJREC *m; |
198 |
199 |
r->rt = r->rot; /* set effective ray length */ |
200 |
for ( ; mod != OVOID; mod = m->omod) { |
201 |
m = objptr(mod); |
202 |
/****** unnecessary test since modifier() is always called |
203 |
if (!ismodifier(m->otype)) { |
204 |
sprintf(errmsg, "illegal modifier \"%s\"", m->oname); |
205 |
error(USER, errmsg); |
206 |
207 |
208 |
/* hack for irradiance calculation */ |
209 |
if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS)) && |
210 |
m->otype != MAT_CLIP && |
211 |
(ofun[m->otype].flags & (T_M|T_X))) { |
212 |
if (irr_ignore(m->otype)) { |
213 |
raytrans(r); |
214 |
return(1); |
215 |
216 |
if (!islight(m->otype)) |
217 |
m = &Lamb; |
218 |
219 |
if ((*ofun[m->otype].funp)(m, r)) |
220 |
return(1); /* materials call raytexture() */ |
221 |
222 |
return(0); /* no material! */ |
223 |
224 |
225 |
226 |
extern void |
227 |
rayparticipate( /* compute ray medium participation */ |
228 |
register RAY *r |
229 |
230 |
231 |
COLOR ce, ca; |
232 |
double re, ge, be; |
233 |
234 |
if (intens(r->cext) <= 1./FHUGE) |
235 |
return; /* no medium */ |
236 |
re = r->rot*colval(r->cext,RED); |
237 |
ge = r->rot*colval(r->cext,GRN); |
238 |
be = r->rot*colval(r->cext,BLU); |
239 |
if (r->crtype & SHADOW) { /* no scattering for sources */ |
240 |
re *= 1. - colval(r->albedo,RED); |
241 |
ge *= 1. - colval(r->albedo,GRN); |
242 |
be *= 1. - colval(r->albedo,BLU); |
243 |
244 |
setcolor(ce, re<=FTINY ? 1. : re>92. ? 0. : exp(-re), |
245 |
ge<=FTINY ? 1. : ge>92. ? 0. : exp(-ge), |
246 |
be<=FTINY ? 1. : be>92. ? 0. : exp(-be)); |
247 |
multcolor(r->rcol, ce); /* path extinction */ |
248 |
if (r->crtype & SHADOW || intens(r->albedo) <= FTINY) |
249 |
return; /* no scattering */ |
250 |
setcolor(ca, |
251 |
colval(r->albedo,RED)*colval(ambval,RED)*(1.-colval(ce,RED)), |
252 |
colval(r->albedo,GRN)*colval(ambval,GRN)*(1.-colval(ce,GRN)), |
253 |
colval(r->albedo,BLU)*colval(ambval,BLU)*(1.-colval(ce,BLU))); |
254 |
addcolor(r->rcol, ca); /* ambient in scattering */ |
255 |
srcscatter(r); /* source in scattering */ |
256 |
257 |
258 |
259 |
extern void |
260 |
raytexture( /* get material modifiers */ |
261 |
RAY *r, |
262 |
OBJECT mod |
263 |
264 |
265 |
266 |
/* execute textures and patterns */ |
267 |
268 |
m = objptr(mod); |
269 |
270 |
271 |
272 |
273 |
274 |
275 |
if ((*ofun[m->otype].funp)(m, r)) { |
276 |
sprintf(errmsg, "conflicting material \"%s\"", |
277 |
m->oname); |
278 |
objerror(r->ro, USER, errmsg); |
279 |
280 |
281 |
282 |
283 |
284 |
extern int |
285 |
raymixture( /* mix modifiers */ |
286 |
register RAY *r, |
287 |
OBJECT fore, |
288 |
OBJECT back, |
289 |
double coef |
290 |
291 |
292 |
RAY fr, br; |
293 |
int foremat, backmat; |
294 |
register int i; |
295 |
/* bound coefficient */ |
296 |
if (coef > 1.0) |
297 |
coef = 1.0; |
298 |
else if (coef < 0.0) |
299 |
coef = 0.0; |
300 |
/* compute foreground and background */ |
301 |
foremat = backmat = 0; |
302 |
/* foreground */ |
303 |
fr = *r; |
304 |
if (coef > FTINY) |
305 |
foremat = rayshade(&fr, fore); |
306 |
/* background */ |
307 |
br = *r; |
308 |
if (coef < 1.0-FTINY) |
309 |
backmat = rayshade(&br, back); |
310 |
/* check for transparency */ |
311 |
if (backmat ^ foremat) { |
312 |
if (backmat && coef > FTINY) |
313 |
raytrans(&fr); |
314 |
else if (foremat && coef < 1.0-FTINY) |
315 |
raytrans(&br); |
316 |
317 |
/* mix perturbations */ |
318 |
for (i = 0; i < 3; i++) |
319 |
r->pert[i] = coef*fr.pert[i] + (1.0-coef)*br.pert[i]; |
320 |
/* mix pattern colors */ |
321 |
scalecolor(fr.pcol, coef); |
322 |
scalecolor(br.pcol, 1.0-coef); |
323 |
copycolor(r->pcol, fr.pcol); |
324 |
addcolor(r->pcol, br.pcol); |
325 |
/* return value tells if material */ |
326 |
if (!foremat & !backmat) |
327 |
return(0); |
328 |
/* mix returned ray values */ |
329 |
scalecolor(fr.rcol, coef); |
330 |
scalecolor(br.rcol, 1.0-coef); |
331 |
copycolor(r->rcol, fr.rcol); |
332 |
addcolor(r->rcol, br.rcol); |
333 |
r->rt = bright(fr.rcol) > bright(br.rcol) ? fr.rt : br.rt; |
334 |
return(1); |
335 |
336 |
337 |
338 |
extern double |
339 |
raydist( /* compute (cumulative) ray distance */ |
340 |
register const RAY *r, |
341 |
register int flags |
342 |
343 |
344 |
double sum = 0.0; |
345 |
346 |
while (r != NULL && r->crtype&flags) { |
347 |
sum += r->rot; |
348 |
r = r->parent; |
349 |
350 |
return(sum); |
351 |
352 |
353 |
354 |
extern void |
355 |
raycontrib( /* compute (cumulative) ray contribution */ |
356 |
double rc[3], |
357 |
const RAY *r, |
358 |
int flags |
359 |
360 |
361 |
double eext[3]; |
362 |
int i; |
363 |
364 |
eext[0] = eext[1] = eext[2] = 0.; |
365 |
rc[0] = rc[1] = rc[2] = 1.; |
366 |
367 |
368 |
for (i = 3; i--; ) { |
369 |
rc[i] *= colval(r->rcoef,i); |
370 |
eext[i] += r->rot * colval(r->cext,i); |
371 |
372 |
r = r->parent; |
373 |
374 |
for (i = 3; i--; ) |
375 |
rc[i] *= (eext[i] <= FTINY) ? 1. : |
376 |
(eext[i] > 92.) ? 0. : exp(-eext[i]); |
377 |
378 |
379 |
380 |
extern double |
381 |
raynormal( /* compute perturbed normal for ray */ |
382 |
FVECT norm, |
383 |
register RAY *r |
384 |
385 |
386 |
double newdot; |
387 |
register int i; |
388 |
389 |
/* The perturbation is added to the surface normal to obtain |
390 |
* the new normal. If the new normal would affect the surface |
391 |
* orientation wrt. the ray, a correction is made. The method is |
392 |
* still fraught with problems since reflected rays and similar |
393 |
* directions calculated from the surface normal may spawn rays behind |
394 |
* the surface. The only solution is to curb textures at high |
395 |
* incidence (namely, keep DOT(rdir,pert) < Rdot). |
396 |
397 |
398 |
399 |
norm[i] = r->ron[i] + r->pert[i]; |
400 |
401 |
if (normalize(norm) == 0.0) { |
402 |
objerror(r->ro, WARNING, "illegal normal perturbation"); |
403 |
VCOPY(norm, r->ron); |
404 |
return(r->rod); |
405 |
406 |
newdot = -DOT(norm, r->rdir); |
407 |
if ((newdot > 0.0) != (r->rod > 0.0)) { /* fix orientation */ |
408 |
409 |
norm[i] += 2.0*newdot*r->rdir[i]; |
410 |
newdot = -newdot; |
411 |
412 |
return(newdot); |
413 |
414 |
415 |
416 |
extern void |
417 |
newrayxf( /* get new tranformation matrix for ray */ |
418 |
RAY *r |
419 |
420 |
421 |
static struct xfn { |
422 |
struct xfn *next; |
423 |
FULLXF xf; |
424 |
} xfseed = { &xfseed }, *xflast = &xfseed; |
425 |
register struct xfn *xp; |
426 |
register const RAY *rp; |
427 |
428 |
429 |
* Search for transform in circular list that |
430 |
* has no associated ray in the tree. |
431 |
432 |
xp = xflast; |
433 |
for (rp = r->parent; rp != NULL; rp = rp->parent) |
434 |
if (rp->rox == &xp->xf) { /* xp in use */ |
435 |
xp = xp->next; /* move to next */ |
436 |
if (xp == xflast) { /* need new one */ |
437 |
xp = (struct xfn *)malloc(sizeof(struct xfn)); |
438 |
if (xp == NULL) |
439 |
error(SYSTEM, |
440 |
"out of memory in newrayxf"); |
441 |
/* insert in list */ |
442 |
xp->next = xflast->next; |
443 |
xflast->next = xp; |
444 |
break; /* we're done */ |
445 |
446 |
rp = r; /* start check over */ |
447 |
448 |
/* got it */ |
449 |
r->rox = &xp->xf; |
450 |
xflast = xp; |
451 |
452 |
453 |
454 |
extern void |
455 |
flipsurface( /* reverse surface orientation */ |
456 |
register RAY *r |
457 |
458 |
459 |
r->rod = -r->rod; |
460 |
r->ron[0] = -r->ron[0]; |
461 |
r->ron[1] = -r->ron[1]; |
462 |
r->ron[2] = -r->ron[2]; |
463 |
r->pert[0] = -r->pert[0]; |
464 |
r->pert[1] = -r->pert[1]; |
465 |
r->pert[2] = -r->pert[2]; |
466 |
467 |
468 |
469 |
extern void |
470 |
rayhit( /* standard ray hit test */ |
471 |
OBJECT *oset, |
472 |
RAY *r |
473 |
474 |
475 |
OBJREC *o; |
476 |
int i; |
477 |
478 |
for (i = oset[0]; i > 0; i--) { |
479 |
o = objptr(oset[i]); |
480 |
if ((*ofun[o->otype].funp)(o, r)) |
481 |
r->robj = oset[i]; |
482 |
483 |
484 |
485 |
486 |
extern int |
487 |
localhit( /* check for hit in the octree */ |
488 |
register RAY *r, |
489 |
register CUBE *scene |
490 |
491 |
492 |
OBJECT cxset[MAXCSET+1]; /* set of checked objects */ |
493 |
FVECT curpos; /* current cube position */ |
494 |
int sflags; /* sign flags */ |
495 |
double t, dt; |
496 |
register int i; |
497 |
498 |
nrays++; /* increment trace counter */ |
499 |
sflags = 0; |
500 |
for (i = 0; i < 3; i++) { |
501 |
curpos[i] = r->rorg[i]; |
502 |
if (r->rdir[i] > 1e-7) |
503 |
sflags |= 1 << i; |
504 |
else if (r->rdir[i] < -1e-7) |
505 |
sflags |= 0x10 << i; |
506 |
507 |
if (sflags == 0) |
508 |
error(CONSISTENCY, "zero ray direction in localhit"); |
509 |
/* start off assuming nothing hit */ |
510 |
if (r->rmax > FTINY) { /* except aft plane if one */ |
511 |
r->ro = &Aftplane; |
512 |
r->rot = r->rmax; |
513 |
514 |
r->rop[i] = r->rorg[i] + r->rot*r->rdir[i]; |
515 |
516 |
/* find global cube entrance point */ |
517 |
t = 0.0; |
518 |
if (!incube(scene, curpos)) { |
519 |
/* find distance to entry */ |
520 |
521 |
/* plane in our direction */ |
522 |
if (sflags & 1<<i) |
523 |
dt = scene->cuorg[i]; |
524 |
else if (sflags & 0x10<<i) |
525 |
dt = scene->cuorg[i] + scene->cusize; |
526 |
else |
527 |
continue; |
528 |
/* distance to the plane */ |
529 |
dt = (dt - r->rorg[i])/r->rdir[i]; |
530 |
if (dt > t) |
531 |
t = dt; /* farthest face is the one */ |
532 |
533 |
t += FTINY; /* fudge to get inside cube */ |
534 |
if (t >= r->rot) /* clipped already */ |
535 |
return(0); |
536 |
/* advance position */ |
537 |
538 |
curpos[i] += r->rdir[i]*t; |
539 |
540 |
if (!incube(scene, curpos)) /* non-intersecting ray */ |
541 |
return(0); |
542 |
543 |
cxset[0] = 0; |
544 |
raymove(curpos, cxset, sflags, r, scene); |
545 |
return((r->ro != NULL) & (r->ro != &Aftplane)); |
546 |
547 |
548 |
549 |
static int |
550 |
raymove( /* check for hit as we move */ |
551 |
FVECT pos, /* current position, modified herein */ |
552 |
OBJECT *cxs, /* checked objects, modified by checkhit */ |
553 |
int dirf, /* direction indicators to speed tests */ |
554 |
register RAY *r, |
555 |
register CUBE *cu |
556 |
557 |
558 |
int ax; |
559 |
double dt, t; |
560 |
561 |
if (istree(cu->cutree)) { /* recurse on subcubes */ |
562 |
CUBE cukid; |
563 |
register int br, sgn; |
564 |
565 |
cukid.cusize = cu->cusize * 0.5; /* find subcube */ |
566 |
VCOPY(cukid.cuorg, cu->cuorg); |
567 |
br = 0; |
568 |
if (pos[0] >= cukid.cuorg[0]+cukid.cusize) { |
569 |
cukid.cuorg[0] += cukid.cusize; |
570 |
br |= 1; |
571 |
572 |
if (pos[1] >= cukid.cuorg[1]+cukid.cusize) { |
573 |
cukid.cuorg[1] += cukid.cusize; |
574 |
br |= 2; |
575 |
576 |
if (pos[2] >= cukid.cuorg[2]+cukid.cusize) { |
577 |
cukid.cuorg[2] += cukid.cusize; |
578 |
br |= 4; |
579 |
580 |
for ( ; ; ) { |
581 |
cukid.cutree = octkid(cu->cutree, br); |
582 |
if ((ax = raymove(pos,cxs,dirf,r,&cukid)) == RAYHIT) |
583 |
return(RAYHIT); |
584 |
sgn = 1 << ax; |
585 |
if (sgn & dirf) /* positive axis? */ |
586 |
if (sgn & br) |
587 |
return(ax); /* overflow */ |
588 |
else { |
589 |
cukid.cuorg[ax] += cukid.cusize; |
590 |
br |= sgn; |
591 |
592 |
else |
593 |
if (sgn & br) { |
594 |
cukid.cuorg[ax] -= cukid.cusize; |
595 |
br &= ~sgn; |
596 |
} else |
597 |
return(ax); /* underflow */ |
598 |
599 |
/*NOTREACHED*/ |
600 |
601 |
if (isfull(cu->cutree)) { |
602 |
if (checkhit(r, cu, cxs)) |
603 |
return(RAYHIT); |
604 |
} else if (r->ro == &Aftplane && incube(cu, r->rop)) |
605 |
return(RAYHIT); |
606 |
/* advance to next cube */ |
607 |
if (dirf&0x11) { |
608 |
dt = dirf&1 ? cu->cuorg[0] + cu->cusize : cu->cuorg[0]; |
609 |
t = (dt - pos[0])/r->rdir[0]; |
610 |
ax = 0; |
611 |
} else |
612 |
t = FHUGE; |
613 |
if (dirf&0x22) { |
614 |
dt = dirf&2 ? cu->cuorg[1] + cu->cusize : cu->cuorg[1]; |
615 |
dt = (dt - pos[1])/r->rdir[1]; |
616 |
if (dt < t) { |
617 |
t = dt; |
618 |
ax = 1; |
619 |
620 |
621 |
if (dirf&0x44) { |
622 |
dt = dirf&4 ? cu->cuorg[2] + cu->cusize : cu->cuorg[2]; |
623 |
dt = (dt - pos[2])/r->rdir[2]; |
624 |
if (dt < t) { |
625 |
t = dt; |
626 |
ax = 2; |
627 |
628 |
629 |
pos[0] += r->rdir[0]*t; |
630 |
pos[1] += r->rdir[1]*t; |
631 |
pos[2] += r->rdir[2]*t; |
632 |
return(ax); |
633 |
634 |
635 |
636 |
static int |
637 |
checkhit( /* check for hit in full cube */ |
638 |
register RAY *r, |
639 |
CUBE *cu, |
640 |
OBJECT *cxs |
641 |
642 |
643 |
OBJECT oset[MAXSET+1]; |
644 |
645 |
objset(oset, cu->cutree); |
646 |
checkset(oset, cxs); /* avoid double-checking */ |
647 |
648 |
(*r->hitf)(oset, r); /* test for hit in set */ |
649 |
650 |
if (r->robj == OVOID) |
651 |
return(0); /* no scores yet */ |
652 |
653 |
return(incube(cu, r->rop)); /* hit OK if in current cube */ |
654 |
655 |
656 |
657 |
static void |
658 |
checkset( /* modify checked set and set to check */ |
659 |
register OBJECT *os, /* os' = os - cs */ |
660 |
register OBJECT *cs /* cs' = cs + os */ |
661 |
662 |
663 |
OBJECT cset[MAXCSET+MAXSET+1]; |
664 |
register int i, j; |
665 |
int k; |
666 |
/* copy os in place, cset <- cs */ |
667 |
cset[0] = 0; |
668 |
k = 0; |
669 |
for (i = j = 1; i <= os[0]; i++) { |
670 |
while (j <= cs[0] && cs[j] < os[i]) |
671 |
cset[++cset[0]] = cs[j++]; |
672 |
if (j > cs[0] || os[i] != cs[j]) { /* object to check */ |
673 |
os[++k] = os[i]; |
674 |
cset[++cset[0]] = os[i]; |
675 |
676 |
677 |
if (!(os[0] = k)) /* new "to check" set size */ |
678 |
return; /* special case */ |
679 |
while (j <= cs[0]) /* get the rest of cs */ |
680 |
681 |
if (cset[0] > MAXCSET) /* truncate "checked" set if nec. */ |
682 |
cset[0] = MAXCSET; |
683 |
/* setcopy(cs, cset); */ /* copy cset back to cs */ |
684 |
os = cset; |
685 |
for (i = os[0]; i-- >= 0; ) |
686 |
*cs++ = *os++; |
687 |
