| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: raytrace.c,v 2.40 2003/06/26 00:58:10 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* raytrace.c - routines for tracing and shading rays.
| 6 |
| 7 |
* External symbols declared in ray.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include "ray.h"
| 13 |
| 14 |
#include "otypes.h"
| 15 |
| 16 |
#include "otspecial.h"
| 17 |
| 18 |
#define MAXCSET ((MAXSET+1)*2-1) /* maximum check set size */
| 19 |
| 20 |
unsigned long raynum = 0; /* next unique ray number */
| 21 |
unsigned long nrays = 0; /* number of calls to localhit */
| 22 |
| 23 |
static RREAL Lambfa[5] = {PI, PI, PI, 0.0, 0.0};
| 24 |
OBJREC Lamb = {
| 25 |
OVOID, MAT_PLASTIC, "Lambertian",
| 26 |
{0, 5, NULL, Lambfa}, NULL,
| 27 |
}; /* a Lambertian surface */
| 28 |
| 29 |
OBJREC Aftplane; /* aft clipping plane object */
| 30 |
| 31 |
static int raymove(), checkhit();
| 32 |
static void checkset();
| 33 |
| 34 |
#ifndef MAXLOOP
| 35 |
#define MAXLOOP 0 /* modifier loop detection */
| 36 |
#endif
| 37 |
| 38 |
#define RAYHIT (-1) /* return value for intercepted ray */
| 39 |
| 40 |
| 41 |
int
| 42 |
rayorigin(r, ro, rt, rw) /* start new ray from old one */
| 43 |
register RAY *r, *ro;
| 44 |
int rt;
| 45 |
double rw;
| 46 |
| 47 |
double re;
| 48 |
| 49 |
if ((r->parent = ro) == NULL) { /* primary ray */
| 50 |
r->rlvl = 0;
| 51 |
r->rweight = rw;
| 52 |
r->crtype = r->rtype = rt;
| 53 |
r->rsrc = -1;
| 54 |
r->clipset = NULL;
| 55 |
r->revf = raytrace;
| 56 |
copycolor(r->cext, cextinction);
| 57 |
copycolor(r->albedo, salbedo);
| 58 |
r->gecc = seccg;
| 59 |
r->slights = NULL;
| 60 |
} else { /* spawned ray */
| 61 |
r->rlvl = ro->rlvl;
| 62 |
if (rt & RAYREFL) {
| 63 |
r->rlvl++;
| 64 |
r->rsrc = -1;
| 65 |
r->clipset = ro->clipset;
| 66 |
r->rmax = 0.0;
| 67 |
} else {
| 68 |
r->rsrc = ro->rsrc;
| 69 |
r->clipset = ro->newcset;
| 70 |
r->rmax = ro->rmax <= FTINY ? 0.0 : ro->rmax - ro->rot;
| 71 |
| 72 |
r->revf = ro->revf;
| 73 |
copycolor(r->cext, ro->cext);
| 74 |
copycolor(r->albedo, ro->albedo);
| 75 |
r->gecc = ro->gecc;
| 76 |
r->slights = ro->slights;
| 77 |
r->crtype = ro->crtype | (r->rtype = rt);
| 78 |
VCOPY(r->rorg, ro->rop);
| 79 |
r->rweight = ro->rweight * rw;
| 80 |
/* estimate absorption */
| 81 |
re = colval(ro->cext,RED) < colval(ro->cext,GRN) ?
| 82 |
colval(ro->cext,RED) : colval(ro->cext,GRN);
| 83 |
if (colval(ro->cext,BLU) < re) re = colval(ro->cext,BLU);
| 84 |
if (re > 0.)
| 85 |
r->rweight *= exp(-re*ro->rot);
| 86 |
| 87 |
rayclear(r);
| 88 |
return(r->rlvl <= maxdepth && r->rweight >= minweight ? 0 : -1);
| 89 |
| 90 |
| 91 |
| 92 |
void
| 93 |
rayclear(r) /* clear a ray for (re)evaluation */
| 94 |
register RAY *r;
| 95 |
| 96 |
r->rno = raynum++;
| 97 |
r->newcset = r->clipset;
| 98 |
r->hitf = rayhit;
| 99 |
r->robj = OVOID;
| 100 |
r->ro = NULL;
| 101 |
r->rox = NULL;
| 102 |
r->rt = r->rot = FHUGE;
| 103 |
r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
| 104 |
r->uv[0] = r->uv[1] = 0.0;
| 105 |
setcolor(r->pcol, 1.0, 1.0, 1.0);
| 106 |
setcolor(r->rcol, 0.0, 0.0, 0.0);
| 107 |
| 108 |
| 109 |
| 110 |
void
| 111 |
raytrace(r) /* trace a ray and compute its value */
| 112 |
RAY *r;
| 113 |
| 114 |
if (localhit(r, &thescene))
| 115 |
raycont(r); /* hit local surface, evaluate */
| 116 |
else if (r->ro == &Aftplane) {
| 117 |
r->ro = NULL; /* hit aft clipping plane */
| 118 |
r->rot = FHUGE;
| 119 |
} else if (sourcehit(r))
| 120 |
rayshade(r, r->ro->omod); /* distant source */
| 121 |
| 122 |
rayparticipate(r); /* for participating medium */
| 123 |
| 124 |
if (trace != NULL)
| 125 |
(*trace)(r); /* trace execution */
| 126 |
| 127 |
| 128 |
| 129 |
void
| 130 |
raycont(r) /* check for clipped object and continue */
| 131 |
register RAY *r;
| 132 |
| 133 |
if ((r->clipset != NULL && inset(r->clipset, r->ro->omod)) ||
| 134 |
!rayshade(r, r->ro->omod))
| 135 |
raytrans(r);
| 136 |
| 137 |
| 138 |
| 139 |
void
| 140 |
raytrans(r) /* transmit ray as is */
| 141 |
register RAY *r;
| 142 |
| 143 |
RAY tr;
| 144 |
| 145 |
if (rayorigin(&tr, r, TRANS, 1.0) == 0) {
| 146 |
VCOPY(tr.rdir, r->rdir);
| 147 |
rayvalue(&tr);
| 148 |
copycolor(r->rcol, tr.rcol);
| 149 |
r->rt = r->rot + tr.rt;
| 150 |
| 151 |
| 152 |
| 153 |
| 154 |
int
| 155 |
rayshade(r, mod) /* shade ray r with material mod */
| 156 |
register RAY *r;
| 157 |
int mod;
| 158 |
| 159 |
int gotmat;
| 160 |
register OBJREC *m;
| 161 |
#if MAXLOOP
| 162 |
static int depth = 0;
| 163 |
/* check for infinite loop */
| 164 |
if (depth++ >= MAXLOOP)
| 165 |
objerror(r->ro, USER, "possible modifier loop");
| 166 |
#endif
| 167 |
r->rt = r->rot; /* set effective ray length */
| 168 |
for (gotmat = 0; !gotmat && mod != OVOID; mod = m->omod) {
| 169 |
m = objptr(mod);
| 170 |
/****** unnecessary test since modifier() is always called
| 171 |
if (!ismodifier(m->otype)) {
| 172 |
sprintf(errmsg, "illegal modifier \"%s\"", m->oname);
| 173 |
error(USER, errmsg);
| 174 |
| 175 |
| 176 |
/* hack for irradiance calculation */
| 177 |
if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS)) &&
| 178 |
(ofun[m->otype].flags & (T_M|T_X))) {
| 179 |
if (irr_ignore(m->otype)) {
| 180 |
#if MAXLOOP
| 181 |
depth--;
| 182 |
#endif
| 183 |
raytrans(r);
| 184 |
return(1);
| 185 |
| 186 |
if (!islight(m->otype))
| 187 |
m = &Lamb;
| 188 |
| 189 |
/* materials call raytexture */
| 190 |
gotmat = (*ofun[m->otype].funp)(m, r);
| 191 |
| 192 |
#if MAXLOOP
| 193 |
depth--;
| 194 |
#endif
| 195 |
return(gotmat);
| 196 |
| 197 |
| 198 |
| 199 |
void
| 200 |
rayparticipate(r) /* compute ray medium participation */
| 201 |
register RAY *r;
| 202 |
| 203 |
COLOR ce, ca;
| 204 |
double re, ge, be;
| 205 |
| 206 |
if (intens(r->cext) <= 1./FHUGE)
| 207 |
return; /* no medium */
| 208 |
re = r->rot*colval(r->cext,RED);
| 209 |
ge = r->rot*colval(r->cext,GRN);
| 210 |
be = r->rot*colval(r->cext,BLU);
| 211 |
if (r->crtype & SHADOW) { /* no scattering for sources */
| 212 |
re *= 1. - colval(r->albedo,RED);
| 213 |
ge *= 1. - colval(r->albedo,GRN);
| 214 |
be *= 1. - colval(r->albedo,BLU);
| 215 |
| 216 |
setcolor(ce, re<=0. ? 1. : re>92. ? 0. : exp(-re),
| 217 |
ge<=0. ? 1. : ge>92. ? 0. : exp(-ge),
| 218 |
be<=0. ? 1. : be>92. ? 0. : exp(-be));
| 219 |
multcolor(r->rcol, ce); /* path absorption */
| 220 |
if (r->crtype & SHADOW || intens(r->albedo) <= FTINY)
| 221 |
return; /* no scattering */
| 222 |
setcolor(ca,
| 223 |
colval(r->albedo,RED)*colval(ambval,RED)*(1.-colval(ce,RED)),
| 224 |
colval(r->albedo,GRN)*colval(ambval,GRN)*(1.-colval(ce,GRN)),
| 225 |
colval(r->albedo,BLU)*colval(ambval,BLU)*(1.-colval(ce,BLU)));
| 226 |
addcolor(r->rcol, ca); /* ambient in scattering */
| 227 |
srcscatter(r); /* source in scattering */
| 228 |
| 229 |
| 230 |
| 231 |
void
| 232 |
raytexture(r, mod) /* get material modifiers */
| 233 |
RAY *r;
| 234 |
OBJECT mod;
| 235 |
| 236 |
register OBJREC *m;
| 237 |
#if MAXLOOP
| 238 |
| 239 |
| 240 |
| 241 |
objerror(r->ro, USER, "modifier loop");
| 242 |
#endif
| 243 |
/* execute textures and patterns */
| 244 |
for ( ; mod != OVOID; mod = m->omod) {
| 245 |
m = objptr(mod);
| 246 |
| 247 |
| 248 |
| 249 |
| 250 |
| 251 |
| 252 |
if ((*ofun[m->otype].funp)(m, r)) {
| 253 |
sprintf(errmsg, "conflicting material \"%s\"",
| 254 |
m->oname);
| 255 |
objerror(r->ro, USER, errmsg);
| 256 |
| 257 |
| 258 |
#if MAXLOOP
| 259 |
depth--; /* end here */
| 260 |
#endif
| 261 |
| 262 |
| 263 |
| 264 |
int
| 265 |
raymixture(r, fore, back, coef) /* mix modifiers */
| 266 |
register RAY *r;
| 267 |
OBJECT fore, back;
| 268 |
double coef;
| 269 |
| 270 |
RAY fr, br;
| 271 |
int foremat, backmat;
| 272 |
register int i;
| 273 |
/* bound coefficient */
| 274 |
if (coef > 1.0)
| 275 |
coef = 1.0;
| 276 |
else if (coef < 0.0)
| 277 |
coef = 0.0;
| 278 |
/* compute foreground and background */
| 279 |
foremat = backmat = 0;
| 280 |
/* foreground */
| 281 |
fr = *r;
| 282 |
if (coef > FTINY)
| 283 |
foremat = rayshade(&fr, fore);
| 284 |
/* background */
| 285 |
br = *r;
| 286 |
if (coef < 1.0-FTINY)
| 287 |
backmat = rayshade(&br, back);
| 288 |
/* check for transparency */
| 289 |
if (backmat ^ foremat) {
| 290 |
if (backmat && coef > FTINY)
| 291 |
raytrans(&fr);
| 292 |
else if (foremat && coef < 1.0-FTINY)
| 293 |
raytrans(&br);
| 294 |
| 295 |
/* mix perturbations */
| 296 |
for (i = 0; i < 3; i++)
| 297 |
r->pert[i] = coef*fr.pert[i] + (1.0-coef)*br.pert[i];
| 298 |
/* mix pattern colors */
| 299 |
scalecolor(fr.pcol, coef);
| 300 |
scalecolor(br.pcol, 1.0-coef);
| 301 |
copycolor(r->pcol, fr.pcol);
| 302 |
addcolor(r->pcol, br.pcol);
| 303 |
/* return value tells if material */
| 304 |
if (!foremat & !backmat)
| 305 |
return(0);
| 306 |
/* mix returned ray values */
| 307 |
scalecolor(fr.rcol, coef);
| 308 |
scalecolor(br.rcol, 1.0-coef);
| 309 |
copycolor(r->rcol, fr.rcol);
| 310 |
addcolor(r->rcol, br.rcol);
| 311 |
r->rt = bright(fr.rcol) > bright(br.rcol) ? fr.rt : br.rt;
| 312 |
return(1);
| 313 |
| 314 |
| 315 |
| 316 |
double
| 317 |
raydist(r, flags) /* compute (cumulative) ray distance */
| 318 |
register RAY *r;
| 319 |
register int flags;
| 320 |
| 321 |
double sum = 0.0;
| 322 |
| 323 |
while (r != NULL && r->crtype&flags) {
| 324 |
sum += r->rot;
| 325 |
r = r->parent;
| 326 |
| 327 |
return(sum);
| 328 |
| 329 |
| 330 |
| 331 |
double
| 332 |
raynormal(norm, r) /* compute perturbed normal for ray */
| 333 |
FVECT norm;
| 334 |
register RAY *r;
| 335 |
| 336 |
double newdot;
| 337 |
register int i;
| 338 |
| 339 |
/* The perturbation is added to the surface normal to obtain
| 340 |
* the new normal. If the new normal would affect the surface
| 341 |
* orientation wrt. the ray, a correction is made. The method is
| 342 |
* still fraught with problems since reflected rays and similar
| 343 |
* directions calculated from the surface normal may spawn rays behind
| 344 |
* the surface. The only solution is to curb textures at high
| 345 |
* incidence (namely, keep DOT(rdir,pert) < Rdot).
| 346 |
| 347 |
| 348 |
| 349 |
norm[i] = r->ron[i] + r->pert[i];
| 350 |
| 351 |
if (normalize(norm) == 0.0) {
| 352 |
objerror(r->ro, WARNING, "illegal normal perturbation");
| 353 |
VCOPY(norm, r->ron);
| 354 |
return(r->rod);
| 355 |
| 356 |
newdot = -DOT(norm, r->rdir);
| 357 |
if ((newdot > 0.0) != (r->rod > 0.0)) { /* fix orientation */
| 358 |
| 359 |
norm[i] += 2.0*newdot*r->rdir[i];
| 360 |
newdot = -newdot;
| 361 |
| 362 |
return(newdot);
| 363 |
| 364 |
| 365 |
| 366 |
void
| 367 |
newrayxf(r) /* get new tranformation matrix for ray */
| 368 |
RAY *r;
| 369 |
| 370 |
static struct xfn {
| 371 |
struct xfn *next;
| 372 |
FULLXF xf;
| 373 |
} xfseed = { &xfseed }, *xflast = &xfseed;
| 374 |
register struct xfn *xp;
| 375 |
register RAY *rp;
| 376 |
| 377 |
| 378 |
* Search for transform in circular list that
| 379 |
* has no associated ray in the tree.
| 380 |
| 381 |
xp = xflast;
| 382 |
for (rp = r->parent; rp != NULL; rp = rp->parent)
| 383 |
if (rp->rox == &xp->xf) { /* xp in use */
| 384 |
xp = xp->next; /* move to next */
| 385 |
if (xp == xflast) { /* need new one */
| 386 |
xp = (struct xfn *)malloc(sizeof(struct xfn));
| 387 |
if (xp == NULL)
| 388 |
error(SYSTEM,
| 389 |
"out of memory in newrayxf");
| 390 |
/* insert in list */
| 391 |
xp->next = xflast->next;
| 392 |
xflast->next = xp;
| 393 |
break; /* we're done */
| 394 |
| 395 |
rp = r; /* start check over */
| 396 |
| 397 |
/* got it */
| 398 |
r->rox = &xp->xf;
| 399 |
xflast = xp;
| 400 |
| 401 |
| 402 |
| 403 |
void
| 404 |
flipsurface(r) /* reverse surface orientation */
| 405 |
register RAY *r;
| 406 |
| 407 |
r->rod = -r->rod;
| 408 |
r->ron[0] = -r->ron[0];
| 409 |
r->ron[1] = -r->ron[1];
| 410 |
r->ron[2] = -r->ron[2];
| 411 |
r->pert[0] = -r->pert[0];
| 412 |
r->pert[1] = -r->pert[1];
| 413 |
r->pert[2] = -r->pert[2];
| 414 |
| 415 |
| 416 |
| 417 |
void
| 418 |
rayhit(oset, r) /* standard ray hit test */
| 419 |
OBJECT *oset;
| 420 |
RAY *r;
| 421 |
| 422 |
OBJREC *o;
| 423 |
int i;
| 424 |
| 425 |
for (i = oset[0]; i > 0; i--) {
| 426 |
o = objptr(oset[i]);
| 427 |
if ((*ofun[o->otype].funp)(o, r))
| 428 |
r->robj = oset[i];
| 429 |
| 430 |
| 431 |
| 432 |
| 433 |
int
| 434 |
localhit(r, scene) /* check for hit in the octree */
| 435 |
register RAY *r;
| 436 |
register CUBE *scene;
| 437 |
| 438 |
OBJECT cxset[MAXCSET+1]; /* set of checked objects */
| 439 |
FVECT curpos; /* current cube position */
| 440 |
int sflags; /* sign flags */
| 441 |
double t, dt;
| 442 |
register int i;
| 443 |
| 444 |
nrays++; /* increment trace counter */
| 445 |
sflags = 0;
| 446 |
for (i = 0; i < 3; i++) {
| 447 |
curpos[i] = r->rorg[i];
| 448 |
if (r->rdir[i] > 1e-7)
| 449 |
sflags |= 1 << i;
| 450 |
else if (r->rdir[i] < -1e-7)
| 451 |
sflags |= 0x10 << i;
| 452 |
| 453 |
if (sflags == 0)
| 454 |
error(CONSISTENCY, "zero ray direction in localhit");
| 455 |
/* start off assuming nothing hit */
| 456 |
if (r->rmax > FTINY) { /* except aft plane if one */
| 457 |
r->ro = &Aftplane;
| 458 |
r->rot = r->rmax;
| 459 |
| 460 |
r->rop[i] = r->rorg[i] + r->rot*r->rdir[i];
| 461 |
| 462 |
/* find global cube entrance point */
| 463 |
t = 0.0;
| 464 |
if (!incube(scene, curpos)) {
| 465 |
/* find distance to entry */
| 466 |
| 467 |
/* plane in our direction */
| 468 |
if (sflags & 1<<i)
| 469 |
dt = scene->cuorg[i];
| 470 |
else if (sflags & 0x10<<i)
| 471 |
dt = scene->cuorg[i] + scene->cusize;
| 472 |
else
| 473 |
continue;
| 474 |
/* distance to the plane */
| 475 |
dt = (dt - r->rorg[i])/r->rdir[i];
| 476 |
if (dt > t)
| 477 |
t = dt; /* farthest face is the one */
| 478 |
| 479 |
t += FTINY; /* fudge to get inside cube */
| 480 |
if (t >= r->rot) /* clipped already */
| 481 |
return(0);
| 482 |
/* advance position */
| 483 |
| 484 |
curpos[i] += r->rdir[i]*t;
| 485 |
| 486 |
if (!incube(scene, curpos)) /* non-intersecting ray */
| 487 |
return(0);
| 488 |
| 489 |
cxset[0] = 0;
| 490 |
raymove(curpos, cxset, sflags, r, scene);
| 491 |
return(r->ro != NULL & r->ro != &Aftplane);
| 492 |
| 493 |
| 494 |
| 495 |
static int
| 496 |
raymove(pos, cxs, dirf, r, cu) /* check for hit as we move */
| 497 |
FVECT pos; /* current position, modified herein */
| 498 |
OBJECT *cxs; /* checked objects, modified by checkhit */
| 499 |
int dirf; /* direction indicators to speed tests */
| 500 |
register RAY *r;
| 501 |
register CUBE *cu;
| 502 |
| 503 |
int ax;
| 504 |
double dt, t;
| 505 |
| 506 |
if (istree(cu->cutree)) { /* recurse on subcubes */
| 507 |
CUBE cukid;
| 508 |
register int br, sgn;
| 509 |
| 510 |
cukid.cusize = cu->cusize * 0.5; /* find subcube */
| 511 |
VCOPY(cukid.cuorg, cu->cuorg);
| 512 |
br = 0;
| 513 |
if (pos[0] >= cukid.cuorg[0]+cukid.cusize) {
| 514 |
cukid.cuorg[0] += cukid.cusize;
| 515 |
br |= 1;
| 516 |
| 517 |
if (pos[1] >= cukid.cuorg[1]+cukid.cusize) {
| 518 |
cukid.cuorg[1] += cukid.cusize;
| 519 |
br |= 2;
| 520 |
| 521 |
if (pos[2] >= cukid.cuorg[2]+cukid.cusize) {
| 522 |
cukid.cuorg[2] += cukid.cusize;
| 523 |
br |= 4;
| 524 |
| 525 |
for ( ; ; ) {
| 526 |
cukid.cutree = octkid(cu->cutree, br);
| 527 |
if ((ax = raymove(pos,cxs,dirf,r,&cukid)) == RAYHIT)
| 528 |
return(RAYHIT);
| 529 |
sgn = 1 << ax;
| 530 |
if (sgn & dirf) /* positive axis? */
| 531 |
if (sgn & br)
| 532 |
return(ax); /* overflow */
| 533 |
else {
| 534 |
cukid.cuorg[ax] += cukid.cusize;
| 535 |
br |= sgn;
| 536 |
| 537 |
else
| 538 |
if (sgn & br) {
| 539 |
cukid.cuorg[ax] -= cukid.cusize;
| 540 |
br &= ~sgn;
| 541 |
} else
| 542 |
return(ax); /* underflow */
| 543 |
| 544 |
/*NOTREACHED*/
| 545 |
| 546 |
if (isfull(cu->cutree)) {
| 547 |
if (checkhit(r, cu, cxs))
| 548 |
return(RAYHIT);
| 549 |
} else if (r->ro == &Aftplane && incube(cu, r->rop))
| 550 |
return(RAYHIT);
| 551 |
/* advance to next cube */
| 552 |
if (dirf&0x11) {
| 553 |
dt = dirf&1 ? cu->cuorg[0] + cu->cusize : cu->cuorg[0];
| 554 |
t = (dt - pos[0])/r->rdir[0];
| 555 |
ax = 0;
| 556 |
} else
| 557 |
t = FHUGE;
| 558 |
if (dirf&0x22) {
| 559 |
dt = dirf&2 ? cu->cuorg[1] + cu->cusize : cu->cuorg[1];
| 560 |
dt = (dt - pos[1])/r->rdir[1];
| 561 |
if (dt < t) {
| 562 |
t = dt;
| 563 |
ax = 1;
| 564 |
| 565 |
| 566 |
if (dirf&0x44) {
| 567 |
dt = dirf&4 ? cu->cuorg[2] + cu->cusize : cu->cuorg[2];
| 568 |
dt = (dt - pos[2])/r->rdir[2];
| 569 |
if (dt < t) {
| 570 |
t = dt;
| 571 |
ax = 2;
| 572 |
| 573 |
| 574 |
pos[0] += r->rdir[0]*t;
| 575 |
pos[1] += r->rdir[1]*t;
| 576 |
pos[2] += r->rdir[2]*t;
| 577 |
return(ax);
| 578 |
| 579 |
| 580 |
| 581 |
static int
| 582 |
checkhit(r, cu, cxs) /* check for hit in full cube */
| 583 |
register RAY *r;
| 584 |
CUBE *cu;
| 585 |
OBJECT *cxs;
| 586 |
| 587 |
OBJECT oset[MAXSET+1];
| 588 |
| 589 |
objset(oset, cu->cutree);
| 590 |
checkset(oset, cxs); /* avoid double-checking */
| 591 |
| 592 |
(*r->hitf)(oset, r); /* test for hit in set */
| 593 |
| 594 |
if (r->robj == OVOID)
| 595 |
return(0); /* no scores yet */
| 596 |
| 597 |
return(incube(cu, r->rop)); /* hit OK if in current cube */
| 598 |
| 599 |
| 600 |
| 601 |
static void
| 602 |
checkset(os, cs) /* modify checked set and set to check */
| 603 |
register OBJECT *os; /* os' = os - cs */
| 604 |
register OBJECT *cs; /* cs' = cs + os */
| 605 |
| 606 |
OBJECT cset[MAXCSET+MAXSET+1];
| 607 |
register int i, j;
| 608 |
int k;
| 609 |
/* copy os in place, cset <- cs */
| 610 |
cset[0] = 0;
| 611 |
k = 0;
| 612 |
for (i = j = 1; i <= os[0]; i++) {
| 613 |
while (j <= cs[0] && cs[j] < os[i])
| 614 |
cset[++cset[0]] = cs[j++];
| 615 |
if (j > cs[0] || os[i] != cs[j]) { /* object to check */
| 616 |
os[++k] = os[i];
| 617 |
cset[++cset[0]] = os[i];
| 618 |
| 619 |
| 620 |
if (!(os[0] = k)) /* new "to check" set size */
| 621 |
return; /* special case */
| 622 |
while (j <= cs[0]) /* get the rest of cs */
| 623 |
| 624 |
if (cset[0] > MAXCSET) /* truncate "checked" set if nec. */
| 625 |
cset[0] = MAXCSET;
| 626 |
/* setcopy(cs, cset); */ /* copy cset back to cs */
| 627 |
os = cset;
| 628 |
for (i = os[0]; i-- >= 0; )
| 629 |
*cs++ = *os++;
| 630 |
