root/Development/ray/src/rt/raytrace.c
Revision: 1.13
Committed: Sat Jan 12 14:05:01 1991 UTC (34 years, 10 months ago) by greg
Changes since 1.12: +0 -1 lines
eliminated what should be redundant assignment of rox in rayorigin
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * raytrace.c - routines for tracing and shading rays.
9 *
10 * 8/7/85
11 */
12
13 #include "ray.h"
14
15 #include "octree.h"
16
17 #include "otypes.h"
18
19 extern CUBE thescene; /* our scene */
20 extern int maxdepth; /* maximum recursion depth */
21 extern double minweight; /* minimum ray weight */
22
23 long nrays = 0L; /* number of rays traced */
24
25 #define MAXLOOP 128 /* modifier loop detection */
26
27 #define RAYHIT (-1) /* return value for intercepted ray */
28
29
30 rayorigin(r, ro, rt, rw) /* start new ray from old one */
31 register RAY *r, *ro;
32 int rt;
33 double rw;
34 {
35 if ((r->parent = ro) == NULL) { /* primary ray */
36 r->rlvl = 0;
37 r->rweight = rw;
38 r->crtype = r->rtype = rt;
39 r->rsrc = -1;
40 r->clipset = NULL;
41 } else { /* spawned ray */
42 r->rlvl = ro->rlvl;
43 if (rt & RAYREFL) {
44 r->rlvl++;
45 r->rsrc = -1;
46 r->clipset = ro->clipset;
47 } else {
48 r->rsrc = ro->rsrc;
49 r->clipset = ro->newcset;
50 }
51 r->rweight = ro->rweight * rw;
52 r->crtype = ro->crtype | (r->rtype = rt);
53 VCOPY(r->rorg, ro->rop);
54 }
55 r->rno = nrays;
56 r->newcset = r->clipset;
57 r->ro = NULL;
58 r->rot = FHUGE;
59 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
60 setcolor(r->pcol, 1.0, 1.0, 1.0);
61 setcolor(r->rcol, 0.0, 0.0, 0.0);
62 r->rt = 0.0;
63 return(r->rlvl <= maxdepth && r->rweight >= minweight ? 0 : -1);
64 }
65
66
67 rayvalue(r) /* compute a ray's value */
68 RAY *r;
69 {
70 extern int (*trace)();
71
72 if (localhit(r, &thescene) || sourcehit(r))
73 raycont(r);
74
75 if (trace != NULL)
76 (*trace)(r); /* trace execution */
77 }
78
79
80 raycont(r) /* check for clipped object and continue */
81 register RAY *r;
82 {
83 if (r->clipset != NULL && inset(r->clipset, r->ro->omod))
84 raytrans(r);
85 else
86 rayshade(r, r->ro->omod);
87 }
88
89
90 raytrans(r) /* transmit ray as is */
91 register RAY *r;
92 {
93 RAY tr;
94
95 if (rayorigin(&tr, r, TRANS, 1.0) == 0) {
96 VCOPY(tr.rdir, r->rdir);
97 rayvalue(&tr);
98 copycolor(r->rcol, tr.rcol);
99 r->rt = r->rot + tr.rt;
100 }
101 }
102
103
104 rayshade(r, mod) /* shade ray r with material mod */
105 register RAY *r;
106 int mod;
107 {
108 static int depth = 0;
109 register OBJREC *m;
110 /* check for infinite loop */
111 if (depth++ >= MAXLOOP)
112 objerror(r->ro, USER, "possible modifier loop");
113 for ( ; mod != OVOID; mod = m->omod) {
114 m = objptr(mod);
115 /****** unnecessary test since modifier() is always called
116 if (!ismodifier(m->otype)) {
117 sprintf(errmsg, "illegal modifier \"%s\"", m->oname);
118 error(USER, errmsg);
119 }
120 ******/
121 (*ofun[m->otype].funp)(m, r); /* execute function */
122 m->lastrno = r->rno;
123 if (ismaterial(m->otype)) { /* materials call raytexture */
124 depth--;
125 return; /* we're done */
126 }
127 }
128 objerror(r->ro, USER, "material not found");
129 }
130
131
132 raytexture(r, mod) /* get material modifiers */
133 RAY *r;
134 int mod;
135 {
136 static int depth = 0;
137 register OBJREC *m;
138 /* check for infinite loop */
139 if (depth++ >= MAXLOOP)
140 objerror(r->ro, USER, "modifier loop");
141 /* execute textures and patterns */
142 for ( ; mod != OVOID; mod = m->omod) {
143 m = objptr(mod);
144 if (!istexture(m->otype)) {
145 sprintf(errmsg, "illegal modifier \"%s\"", m->oname);
146 error(USER, errmsg);
147 }
148 (*ofun[m->otype].funp)(m, r);
149 m->lastrno = r->rno;
150 }
151 depth--; /* end here */
152 }
153
154
155 raymixture(r, fore, back, coef) /* mix modifiers */
156 register RAY *r;
157 OBJECT fore, back;
158 double coef;
159 {
160 FVECT curpert, forepert, backpert;
161 COLOR curpcol, forepcol, backpcol;
162 register int i;
163 /* clip coefficient */
164 if (coef > 1.0)
165 coef = 1.0;
166 else if (coef < 0.0)
167 coef = 0.0;
168 /* save current mods */
169 VCOPY(curpert, r->pert);
170 copycolor(curpcol, r->pcol);
171 /* compute new mods */
172 /* foreground */
173 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
174 setcolor(r->pcol, 1.0, 1.0, 1.0);
175 if (fore != OVOID && coef > FTINY)
176 raytexture(r, fore);
177 VCOPY(forepert, r->pert);
178 copycolor(forepcol, r->pcol);
179 /* background */
180 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
181 setcolor(r->pcol, 1.0, 1.0, 1.0);
182 if (back != OVOID && coef < 1.0-FTINY)
183 raytexture(r, back);
184 VCOPY(backpert, r->pert);
185 copycolor(backpcol, r->pcol);
186 /* sum perturbations */
187 for (i = 0; i < 3; i++)
188 r->pert[i] = curpert[i] + coef*forepert[i] +
189 (1.0-coef)*backpert[i];
190 /* multiply colors */
191 setcolor(r->pcol, coef*colval(forepcol,RED) +
192 (1.0-coef)*colval(backpcol,RED),
193 coef*colval(forepcol,GRN) +
194 (1.0-coef)*colval(backpcol,GRN),
195 coef*colval(forepcol,BLU) +
196 (1.0-coef)*colval(backpcol,BLU));
197 multcolor(r->pcol, curpcol);
198 }
199
200
201 double
202 raynormal(norm, r) /* compute perturbed normal for ray */
203 FVECT norm;
204 register RAY *r;
205 {
206 double newdot;
207 register int i;
208
209 /* The perturbation is added to the surface normal to obtain
210 * the new normal. If the new normal would affect the surface
211 * orientation wrt. the ray, a correction is made. The method is
212 * still fraught with problems since reflected rays and similar
213 * directions calculated from the surface normal may spawn rays behind
214 * the surface. The only solution is to curb textures at high
215 * incidence (namely, keep DOT(rdir,pert) < Rdot).
216 */
217
218 for (i = 0; i < 3; i++)
219 norm[i] = r->ron[i] + r->pert[i];
220
221 if (normalize(norm) == 0.0) {
222 objerror(r->ro, WARNING, "illegal normal perturbation");
223 VCOPY(norm, r->ron);
224 return(r->rod);
225 }
226 newdot = -DOT(norm, r->rdir);
227 if ((newdot > 0.0) != (r->rod > 0.0)) { /* fix orientation */
228 for (i = 0; i < 3; i++)
229 norm[i] += 2.0*newdot*r->rdir[i];
230 newdot = -newdot;
231 }
232 return(newdot);
233 }
234
235
236 newrayxf(r) /* get new tranformation matrix for ray */
237 RAY *r;
238 {
239 static struct xfn {
240 struct xfn *next;
241 FULLXF xf;
242 } xfseed = { &xfseed }, *xflast = &xfseed;
243 register struct xfn *xp;
244 register RAY *rp;
245
246 /*
247 * Search for transform in circular list that
248 * has no associated ray in the tree.
249 */
250 xp = xflast;
251 for (rp = r->parent; rp != NULL; rp = rp->parent)
252 if (rp->rox == &xp->xf) { /* xp in use */
253 xp = xp->next; /* move to next */
254 if (xp == xflast) { /* need new one */
255 xp = (struct xfn *)malloc(sizeof(struct xfn));
256 if (xp == NULL)
257 error(SYSTEM,
258 "out of memory in newrayxf");
259 /* insert in list */
260 xp->next = xflast->next;
261 xflast->next = xp;
262 break; /* we're done */
263 }
264 rp = r; /* start check over */
265 }
266 /* got it */
267 r->rox = &xp->xf;
268 xflast = xp;
269 }
270
271
272 flipsurface(r) /* reverse surface orientation */
273 register RAY *r;
274 {
275 r->rod = -r->rod;
276 r->ron[0] = -r->ron[0];
277 r->ron[1] = -r->ron[1];
278 r->ron[2] = -r->ron[2];
279 r->pert[0] = -r->pert[0];
280 r->pert[1] = -r->pert[1];
281 r->pert[2] = -r->pert[2];
282 }
283
284
285 localhit(r, scene) /* check for hit in the octree */
286 register RAY *r;
287 register CUBE *scene;
288 {
289 FVECT curpos; /* current cube position */
290 int sflags; /* sign flags */
291 double t, dt;
292 register int i;
293
294 nrays++; /* increment trace counter */
295
296 sflags = 0;
297 for (i = 0; i < 3; i++) {
298 curpos[i] = r->rorg[i];
299 if (r->rdir[i] > FTINY)
300 sflags |= 1 << i;
301 else if (r->rdir[i] < -FTINY)
302 sflags |= 0x10 << i;
303 }
304 t = 0.0;
305 if (!incube(scene, curpos)) {
306 /* find distance to entry */
307 for (i = 0; i < 3; i++) {
308 /* plane in our direction */
309 if (sflags & 1<<i)
310 dt = scene->cuorg[i];
311 else if (sflags & 0x10<<i)
312 dt = scene->cuorg[i] + scene->cusize;
313 else
314 continue;
315 /* distance to the plane */
316 dt = (dt - r->rorg[i])/r->rdir[i];
317 if (dt > t)
318 t = dt; /* farthest face is the one */
319 }
320 t += FTINY; /* fudge to get inside cube */
321 /* advance position */
322 for (i = 0; i < 3; i++)
323 curpos[i] += r->rdir[i]*t;
324
325 if (!incube(scene, curpos)) /* non-intersecting ray */
326 return(0);
327 }
328 return(raymove(curpos, sflags, r, scene) == RAYHIT);
329 }
330
331
332 static int
333 raymove(pos, dirf, r, cu) /* check for hit as we move */
334 FVECT pos; /* modified */
335 int dirf; /* direction indicators to speed tests */
336 register RAY *r;
337 register CUBE *cu;
338 {
339 int ax;
340 double dt, t;
341
342 if (istree(cu->cutree)) { /* recurse on subcubes */
343 CUBE cukid;
344 register int br, sgn;
345
346 cukid.cusize = cu->cusize * 0.5; /* find subcube */
347 VCOPY(cukid.cuorg, cu->cuorg);
348 br = 0;
349 if (pos[0] >= cukid.cuorg[0]+cukid.cusize) {
350 cukid.cuorg[0] += cukid.cusize;
351 br |= 1;
352 }
353 if (pos[1] >= cukid.cuorg[1]+cukid.cusize) {
354 cukid.cuorg[1] += cukid.cusize;
355 br |= 2;
356 }
357 if (pos[2] >= cukid.cuorg[2]+cukid.cusize) {
358 cukid.cuorg[2] += cukid.cusize;
359 br |= 4;
360 }
361 for ( ; ; ) {
362 cukid.cutree = octkid(cu->cutree, br);
363 if ((ax = raymove(pos,dirf,r,&cukid)) == RAYHIT)
364 return(RAYHIT);
365 sgn = 1 << ax;
366 if (sgn & dirf) /* positive axis? */
367 if (sgn & br)
368 return(ax); /* overflow */
369 else {
370 cukid.cuorg[ax] += cukid.cusize;
371 br |= sgn;
372 }
373 else
374 if (sgn & br) {
375 cukid.cuorg[ax] -= cukid.cusize;
376 br &= ~sgn;
377 } else
378 return(ax); /* underflow */
379 }
380 /*NOTREACHED*/
381 }
382 if (isfull(cu->cutree) && checkhit(r, cu))
383 return(RAYHIT);
384 /* advance to next cube */
385 if (dirf&0x11) {
386 dt = dirf&1 ? cu->cuorg[0] + cu->cusize : cu->cuorg[0];
387 t = (dt - pos[0])/r->rdir[0];
388 ax = 0;
389 } else
390 t = FHUGE;
391 if (dirf&0x22) {
392 dt = dirf&2 ? cu->cuorg[1] + cu->cusize : cu->cuorg[1];
393 dt = (dt - pos[1])/r->rdir[1];
394 if (dt < t) {
395 t = dt;
396 ax = 1;
397 }
398 }
399 if (dirf&0x44) {
400 dt = dirf&4 ? cu->cuorg[2] + cu->cusize : cu->cuorg[2];
401 dt = (dt - pos[2])/r->rdir[2];
402 if (dt < t) {
403 t = dt;
404 ax = 2;
405 }
406 }
407 pos[0] += r->rdir[0]*t;
408 pos[1] += r->rdir[1]*t;
409 pos[2] += r->rdir[2]*t;
410 return(ax);
411 }
412
413
414 static
415 checkhit(r, cu) /* check for hit in full cube */
416 register RAY *r;
417 CUBE *cu;
418 {
419 OBJECT oset[MAXSET+1];
420 register OBJREC *o;
421 register int i;
422
423 objset(oset, cu->cutree);
424 for (i = oset[0]; i > 0; i--) {
425 o = objptr(oset[i]);
426 if (o->lastrno == r->rno) /* checked already? */
427 continue;
428 (*ofun[o->otype].funp)(o, r);
429 o->lastrno = r->rno;
430 }
431 if (r->ro == NULL)
432 return(0); /* no scores yet */
433
434 return(incube(cu, r->rop)); /* hit OK if in current cube */
435 }
