root/radiance/ray/src/rt/raytrace.c
Thu Mar 16 00:25:24 2023 UTC (14 months, 3 weeks ago) by greg
Changes since 2.86: +14 -7 lines
Diff to previous 2.86 , to selected 1.20
feat: Added test for which side of flat surface is seen in case of coincident surfaces
Mon Feb 20 04:05:43 2023 UTC (15 months, 2 weeks ago) by greg
Changes since 2.85: +4 -2 lines
Diff to previous 2.85 , to selected 1.20
fix: bug found by R. Shakespeare where pattern was applied with -i option
Wed Jun 9 18:21:10 2021 UTC (3 years ago) by greg
Changes since 2.84: +12 -7 lines
Diff to previous 2.84 , to selected 1.20
fix: corrected minor inconsistencies in selecting surface intersections
Sun Jan 31 20:55:04 2021 UTC (3 years, 4 months ago) by greg
Changes since 2.83: +13 -11 lines
Diff to previous 2.83 , to selected 1.20
fix: improved consistency to favor later modifier definiton
Sun Jan 31 18:08:04 2021 UTC (3 years, 4 months ago) by greg
Changes since 2.82: +29 -1 lines
Diff to previous 2.82 , to selected 1.20
feat: added consistent handling of coincident surfaces, thanks to Peter A-B
Mon Jan 4 19:07:15 2021 UTC (3 years, 5 months ago) by greg
Changes since 2.81: +3 -1 lines
Diff to previous 2.81 , to selected 1.20
refactor: added default initialization of RAY ron, rod members
Sun Mar 29 18:21:57 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.80: +2 -1 lines
Diff to previous 2.80 , to selected 1.20
Added prophylaptic value for ray intersection point so no one gets random bits
Thu Mar 12 17:19:18 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.79: +2 -2 lines
Diff to previous 2.79 , to selected 1.20
Added precautionary testing when checking for FHUGE
Thu Jul 25 16:50:54 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.78: +3 -1 lines
Diff to previous 2.78 , to selected 1.20
Keep track of ray flips so rayreorient() can put it back as it was
Wed Apr 3 16:04:33 2019 UTC (5 years, 2 months ago) by greg
Diff to previous 2.77 , to selected 1.20
Leave mirrored ray length at FHUGE if no pure specular reflection
Fri Feb 22 19:42:27 2019 UTC (5 years, 3 months ago) by greg
Changes since 2.76: +13 -4 lines
Diff to previous 2.76 , to selected 1.20
Added warning for contribution coefficient calculation with participating media
Fri Feb 22 17:12:58 2019 UTC (5 years, 3 months ago) by greg
Changes since 2.75: +3 -11 lines
Diff to previous 2.75 , to selected 1.20
Removed ray contribution hack for participating media b/c it doesn't really work
Wed Feb 13 01:00:31 2019 UTC (5 years, 3 months ago) by greg
Changes since 2.74: +7 -2 lines
Diff to previous 2.74 , to selected 1.20
Made treatment of mirror reflection color more consistent
Wed Dec 5 02:12:23 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.73: +23 -11 lines
Diff to previous 2.73 , to selected 1.20
Created raytirrad() call to take care of irradiance hack
Tue Nov 13 19:58:33 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.72: +11 -5 lines
Diff to previous 2.72 , to selected 1.20
Tue Jan 9 05:01:15 2018 UTC (6 years, 5 months ago) by greg
Changes since 2.71: +3 -9 lines
Diff to previous 2.71 , to selected 1.20
Made proximity test (plugaleak) more robust with transparent surfaces, etc.
Mon May 16 17:32:10 2016 UTC (8 years ago) by greg
Changes since 2.70: +9 -3 lines
Diff to previous 2.70 , to selected 1.20
Made hack for irradiance calculation even uglier to accommodate BSDF proxies
Thu Mar 17 21:53:42 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.69: +3 -1 lines
Diff to previous 2.69 , to selected 1.20
Avoid setting ray weight > 1.0
Tue May 26 15:58:35 2015 UTC (9 years ago) by greg
Changes since 2.68: +7 -3 lines
Diff to previous 2.68 , to selected 1.20
More macro-management
Fri May 22 09:19:11 2015 UTC (9 years ago) by greg
Diff to previous 2.67 , to selected 1.20
Corrected test for ambient in photon map
Thu May 21 15:28:24 2015 UTC (9 years ago) by greg
Changes since 2.66: +9 -7 lines
Diff to previous 2.66 , to selected 1.20
Moved ambient ray truncation to rayorigin() -- remove ambRayInPmap() later
Tue Feb 24 19:39:27 2015 UTC (9 years, 3 months ago) by greg
Changes since 2.65: +12 -6 lines
Diff to previous 2.65 , to selected 1.20
Wed Feb 19 14:12:48 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.64: +17 -17 lines
Diff to previous 2.64 , to selected 1.20
Eliminated superfluous extern declarations
Fri Jun 1 19:17:17 2012 UTC (12 years ago) by greg
Changes since 2.63: +29 -29 lines
Diff to previous 2.63 , to selected 1.20
Minor optimizations
Wed Apr 6 00:14:26 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 2.62 , to selected 1.20
Improved output efficiency by reducing number of calls to fwrite()
Mon Oct 25 22:57:45 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.61: +4 -8 lines
Diff to previous 2.61 , to selected 1.20
Sun Sep 26 15:51:15 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.60: +5 -3 lines
Diff to previous 2.60 , to selected 1.20
Sat Dec 12 00:03:42 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.59: +3 -3 lines
Diff to previous 2.59 , to selected 1.20
Mon Jul 2 20:16:00 2007 UTC (16 years, 11 months ago) by greg
Changes since 2.58: +3 -1 lines
Diff to previous 2.58 , to selected 1.20
Corrected ray weighting for mixed materials
Wed Jun 7 17:52:04 2006 UTC (18 years ago) by schorsch
Changes since 2.57: +6 -4 lines
Diff to previous 2.57 , to selected 1.20
Fri Sep 23 19:04:53 2005 UTC (18 years, 8 months ago) by greg
Diff to previous 2.56 , to selected 1.20
Mon Aug 22 21:54:41 2005 UTC (18 years, 9 months ago) by greg
CVS Tags: rad3R7P2
Changes since 2.55: +2 -2 lines
Diff to previous 2.55 , to selected 1.20
Sat Jul 30 16:41:46 2005 UTC (18 years, 10 months ago) by greg
CVS Tags: rad3R7P1
Diff to previous 2.54 , to selected 1.20
Fixed serious bug in new Russian roulette algorithm
Fri Jul 8 05:52:29 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.53: +7 -3 lines
Diff to previous 2.53 , to selected 1.20
Fixed report of contributing weight for mixed materials
Thu Jun 23 09:11:38 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.52: +9 -4 lines
Diff to previous 2.52 , to selected 1.20
Added check to avoid exp underflow
Tue Jun 21 15:06:50 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.51: +16 -16 lines
Diff to previous 2.51 , to selected 1.20
Fixed bugs in black glass transmission and source weight computation
Changes since 2.50: +16 -1 lines
Diff to previous 2.50 , to selected 1.20
Thu May 26 06:55:22 2005 UTC (19 years ago) by greg
Changes since 2.49: +4 -2 lines
Diff to previous 2.49 , to selected 1.20
Changes since 2.48: +59 -21 lines
Diff to previous 2.48 , to selected 1.20
Fri Apr 15 04:44:51 2005 UTC (19 years, 1 month ago) by greg
Changes since 2.47: +2 -4 lines
Diff to previous 2.47 , to selected 1.20
Thu Apr 14 18:04:12 2005 UTC (19 years, 1 month ago) by greg
Changes since 2.46: +6 -6 lines
Diff to previous 2.46 , to selected 1.20
Thu Mar 10 22:37:00 2005 UTC (19 years, 3 months ago) by greg
Changes since 2.45: +4 -1 lines
Diff to previous 2.45 , to selected 1.20
Changes since 2.44: +94 -74 lines
Diff to previous 2.44 , to selected 1.20
Wed Dec 31 01:50:02 2003 UTC (20 years, 5 months ago) by greg
Changes since 2.43: +1 -26 lines
Diff to previous 2.43 , to selected 1.20
Tue Sep 9 03:28:43 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.42: +2 -1 lines
Diff to previous 2.42 , to selected 1.20
Bug fix for -i option using antimatter.
Changes since 2.41: +2 -2 lines
Diff to previous 2.41 , to selected 1.20
Changes since 2.40: +5 -4 lines
Diff to previous 2.40 , to selected 1.20
Diff to previous 2.39 , to selected 1.20
Fri May 9 22:18:03 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.38: +2 -1 lines
Diff to previous 2.38 , to selected 1.20
Added missing prototype for raytexture()
Tue Mar 11 19:29:05 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.37: +2 -1 lines
Diff to previous 2.37 , to selected 1.20
Tue Mar 11 17:08:55 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.36: +1 -0 lines
Diff to previous 2.36 , to selected 1.20
Tue Mar 4 19:02:22 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.35: +23 -10 lines
Diff to previous 2.35 , to selected 1.20
Modified new ray hit interface to check whole sets at a time
Changes since 2.34: +1 -56 lines
Diff to previous 2.34 , to selected 1.20
Changes since 2.33: +76 -24 lines
Diff to previous 2.33 , to selected 1.20
Tue Sep 15 09:52:39 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 2.32: +17 -5 lines
Diff to previous 2.32 , to selected 1.20
eliminated unecessary modifier loop checking (I hope!)
Thu Aug 6 10:30:38 1998 UTC (25 years, 10 months ago) by gwlarson
Diff to previous 2.31 , to selected 1.20
minor cosmetic fix to make code easier to read
Wed Jun 17 12:53:06 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.30: +11 -3 lines
Diff to previous 2.30 , to selected 1.20
improved the way ray weights are computed for participating media
Wed Apr 29 09:50:41 1998 UTC (26 years, 1 month ago) by gwlarson
Diff to previous 2.29 , to selected 1.20
fixed bug in mixture calculation
Tue Dec 23 18:25:15 1997 UTC (26 years, 5 months ago) by gregl
Changes since 2.28: +1 -2 lines
Diff to previous 2.28 , to selected 1.20
changed behavior to return FHUGE in r->rt when ray hits nothing
Fri Mar 7 16:58:54 1997 UTC (27 years, 3 months ago) by greg
Diff to previous 2.27 , to selected 1.20
added object number to ray structure for instance tracking
Wed Apr 24 16:27:56 1996 UTC (28 years, 1 month ago) by greg
Changes since 2.26: +3 -6 lines
Diff to previous 2.26 , to selected 1.20
removed distance mung for FHUGE
Wed Apr 17 14:06:35 1996 UTC (28 years, 1 month ago) by greg
Changes since 2.25: +16 -14 lines
Diff to previous 2.25 , to selected 1.20
Sat Mar 30 11:18:36 1996 UTC (28 years, 2 months ago) by greg
Changes since 2.24: +5 -5 lines
Diff to previous 2.24 , to selected 1.20
fixed improper use of salbedo in rayparticipate
Thu Mar 21 15:33:05 1996 UTC (28 years, 2 months ago) by greg
Changes since 2.23: +21 -32 lines
Diff to previous 2.23 , to selected 1.20
changed mixtures so that mixing material with void is allowed
also altered general behavoir so that surfaces without materials are invis.
Fri Dec 8 18:49:09 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.22: +51 -3 lines
Diff to previous 2.22 , to selected 1.20
Wed Dec 6 12:07:50 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.21: +2 -3 lines
Diff to previous 2.21 , to selected 1.20
changed aft clipping plane to work through transparent surfaces
Thu Nov 2 17:38:02 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.20: +15 -0 lines
Diff to previous 2.20 , to selected 1.20
added raydist() function
Fri Sep 29 10:46:12 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.19: +5 -2 lines
Diff to previous 2.19 , to selected 1.20
improved error message for conflicting materials
Thu Jan 26 15:34:55 1995 UTC (29 years, 4 months ago) by greg
Diff to previous 2.18 , to selected 1.20
bug fix for surfaces coincident with octree faces
Fri Jan 6 14:00:47 1995 UTC (29 years, 5 months ago) by greg
Changes since 2.17: +4 -1 lines
Diff to previous 2.17 , to selected 1.20
added test against aft plane in empty voxels
Wed Dec 21 09:10:23 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.16: +15 -11 lines
Diff to previous 2.16 , to selected 1.20
bug fixes from last change
Tue Dec 20 20:18:22 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.15: +19 -4 lines
Diff to previous 2.15 , to selected 1.20
Mon Feb 28 08:54:02 1994 UTC (30 years, 3 months ago) by greg
Diff to previous 2.14 , to selected 1.20
added missing value for return statement in rayshade()
Tue Jan 25 10:18:25 1994 UTC (30 years, 4 months ago) by greg
Diff to previous 2.13 , to selected 1.20
fixed bug for rays that hit nothing
Mon Jan 24 11:51:31 1994 UTC (30 years, 4 months ago) by greg
Changes since 2.12: +9 -4 lines
Diff to previous 2.12 , to selected 1.20
fixed bug in raymixture() when mixing materials with coef=0
Thu Jan 13 10:43:34 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.11: +13 -20 lines
Diff to previous 2.11 , to selected 1.20
bug fixes associated with material mixtures
Thu Jan 13 09:45:11 1994 UTC (30 years, 5 months ago) by greg
Diff to previous 2.10 , to selected 1.20
added missing material function return values
Wed Jan 12 20:42:34 1994 UTC (30 years, 5 months ago) by greg
Diff to previous 2.9 , to selected 1.20
minor bug fixes
Wed Jan 12 16:52:08 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.8: +58 -43 lines
Diff to previous 2.8 , to selected 1.20
Thu Dec 9 09:34:08 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.7 , to selected 1.20
removed use of FTINY that was causing errors with -DSMLFLT in localhit()
Wed Jul 21 15:36:13 1993 UTC (30 years, 10 months ago) by greg
Diff to previous 2.6 , to selected 1.20
fixed handling of void surfaces, which didn't work for instances
Tue May 25 10:30:01 1993 UTC (31 years ago) by greg
Diff to previous 2.5 , to selected 1.20
Mon Mar 8 12:37:30 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.4 , to selected 1.20
Tue Feb 23 13:57:11 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.3 , to selected 1.20
made void surfaces legal
Tue Jan 26 09:28:00 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.2: +24 -14 lines
Diff to previous 2.2 , to selected 1.20
moved check exclude set from ray structure to localhit()
Mon Jan 25 15:16:59 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.1: +30 -6 lines
Diff to previous 2.1 , to selected 1.20
modified OBJREC and RAY structures to avoid redundant intersection
testing using sets instead of flags
Tue Nov 12 17:09:44 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.23: +0 -0 lines
Diff to previous 1.23 , to selected 1.20
Wed Oct 23 13:43:45 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.22: +1 -1 lines
Diff to previous 1.22 , to selected 1.20
Wed Jul 17 12:38:48 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.21: +8 -1 lines
Diff to previous 1.21 , to selected 1.20
added rayclear() function
Thu Jun 20 13:29:32 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.20: +5 -3 lines
Diff to previous 1.20
added revf member to ray structure for dynamic evaluation
Revision 1.20 - (view) (download) (annotate) - [selected]
Mon Jun 17 08:26:18 1991 UTC (33 years ago) by greg
Changes since 1.19: +4 -4 lines
Diff to previous 1.19
added raynum counter and reinstated repeat call test in setfunc()
Fri Jun 14 10:34:26 1991 UTC (33 years ago) by greg
Changes since 1.18: +1 -0 lines
Diff to previous 1.18 , to selected 1.20
changed initialization of effective ray length
Wed May 29 11:09:23 1991 UTC (33 years ago) by greg
Diff to previous 1.17 , to selected 1.20
fixed bug related to distant sources and -i option
Fri May 10 08:51:06 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.16: +3 -1 lines
Diff to previous 1.16 , to selected 1.20
fixed bug introduced by better trans distance comp.
Thu May 2 11:58:20 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.15: +10 -8 lines
Diff to previous 1.15 , to selected 1.20
Wed May 1 11:17:01 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.14: +20 -1 lines
Diff to previous 1.14 , to selected 1.20
Tue Feb 12 12:57:07 1991 UTC (33 years, 4 months ago) by greg
Diff to previous 1.13 , to selected 1.20
changed allocation of transformations in newrayxf() to bmalloc
Sat Jan 12 14:05:01 1991 UTC (33 years, 5 months ago) by greg
Changes since 1.12: +0 -1 lines
Diff to previous 1.12 , to selected 1.20
eliminated what should be redundant assignment of rox in rayorigin
Sat Dec 15 15:03:32 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.11: +38 -1 lines
Diff to previous 1.11 , to selected 1.20
Sat Aug 18 04:25:59 1990 UTC (33 years, 9 months ago) by greg
Changes since 1.10: +24 -26 lines
Diff to previous 1.10 , to selected 1.20
simplified direction flag in raymove
Tue Mar 27 11:40:05 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.9: +2 -0 lines
Diff to previous 1.9 , to selected 1.20
Tue Mar 6 08:47:30 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.8 , to selected 1.20
comment change
Tue Jan 2 15:16:14 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.7: +13 -7 lines
Diff to previous 1.7 , to selected 1.20
Fixed bug in source ray initialization in direct()
Wed Nov 29 14:35:25 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.6: +5 -7 lines
Diff to previous 1.6 , to selected 1.20
fixed clip test causing problem with light sources
Mon Oct 16 18:57:02 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.5 , to selected 1.20
Reduced preposterous MAXLOOP value
Wed Jul 19 18:46:59 1989 UTC (34 years, 10 months ago) by greg
Changes since 1.4: +7 -6 lines
Diff to previous 1.4 , to selected 1.20
changed location of clip test
Sun May 7 17:50:51 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.3: +4 -2 lines
Diff to previous 1.3 , to selected 1.20
changed tests in rayshade
Wed Apr 19 22:24:28 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.2: +0 -2 lines
Diff to previous 1.2 , to selected 1.20
moved setting of ray transformation to intersection routines (bug)
Tue Apr 11 13:30:31 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +2 -1 lines
Diff to previous 1.1 , to selected 1.20
Thu Feb 2 10:41:34 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.20
