--- ray/src/rt/raytrace.c 1994/01/25 10:18:25 2.14 +++ ray/src/rt/raytrace.c 2003/12/31 01:50:02 2.44 @@ -1,51 +1,47 @@ -/* Copyright (c) 1994 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: raytrace.c,v 2.44 2003/12/31 01:50:02 greg Exp $"; #endif - /* * raytrace.c - routines for tracing and shading rays. * - * 8/7/85 + * External symbols declared in ray.h */ +#include "copyright.h" + #include "ray.h" -#include "octree.h" - #include "otypes.h" #include "otspecial.h" #define MAXCSET ((MAXSET+1)*2-1) /* maximum check set size */ -extern CUBE thescene; /* our scene */ -extern int maxdepth; /* maximum recursion depth */ -extern double minweight; /* minimum ray weight */ -extern int do_irrad; /* compute irradiance? */ - unsigned long raynum = 0; /* next unique ray number */ unsigned long nrays = 0; /* number of calls to localhit */ -static FLOAT Lambfa[5] = {PI, PI, PI, 0.0, 0.0}; +static RREAL Lambfa[5] = {PI, PI, PI, 0.0, 0.0}; OBJREC Lamb = { OVOID, MAT_PLASTIC, "Lambertian", {0, 5, NULL, Lambfa}, NULL, }; /* a Lambertian surface */ -static int raymove(), checkset(), checkhit(); +OBJREC Aftplane; /* aft clipping plane object */ -#define MAXLOOP 128 /* modifier loop detection */ +static int raymove(), checkhit(); +static void checkset(); #define RAYHIT (-1) /* return value for intercepted ray */ +int rayorigin(r, ro, rt, rw) /* start new ray from old one */ register RAY *r, *ro; int rt; double rw; { + double re; + if ((r->parent = ro) == NULL) { /* primary ray */ r->rlvl = 0; r->rweight = rw; @@ -53,71 +49,90 @@ double rw; r->rsrc = -1; r->clipset = NULL; r->revf = raytrace; + copycolor(r->cext, cextinction); + copycolor(r->albedo, salbedo); + r->gecc = seccg; + r->slights = NULL; } else { /* spawned ray */ r->rlvl = ro->rlvl; if (rt & RAYREFL) { r->rlvl++; r->rsrc = -1; r->clipset = ro->clipset; + r->rmax = 0.0; } else { r->rsrc = ro->rsrc; r->clipset = ro->newcset; + r->rmax = ro->rmax <= FTINY ? 0.0 : ro->rmax - ro->rot; } r->revf = ro->revf; - r->rweight = ro->rweight * rw; + copycolor(r->cext, ro->cext); + copycolor(r->albedo, ro->albedo); + r->gecc = ro->gecc; + r->slights = ro->slights; r->crtype = ro->crtype | (r->rtype = rt); VCOPY(r->rorg, ro->rop); + r->rweight = ro->rweight * rw; + /* estimate absorption */ + re = colval(ro->cext,RED) < colval(ro->cext,GRN) ? + colval(ro->cext,RED) : colval(ro->cext,GRN); + if (colval(ro->cext,BLU) < re) re = colval(ro->cext,BLU); + if (re > 0.) + r->rweight *= exp(-re*ro->rot); } rayclear(r); return(r->rlvl <= maxdepth && r->rweight >= minweight ? 0 : -1); } +void rayclear(r) /* clear a ray for (re)evaluation */ register RAY *r; { r->rno = raynum++; r->newcset = r->clipset; + r->hitf = rayhit; + r->robj = OVOID; r->ro = NULL; - r->rot = FHUGE; + r->rox = NULL; + r->rt = r->rot = FHUGE; r->pert[0] = r->pert[1] = r->pert[2] = 0.0; + r->uv[0] = r->uv[1] = 0.0; setcolor(r->pcol, 1.0, 1.0, 1.0); setcolor(r->rcol, 0.0, 0.0, 0.0); - r->rt = 0.0; } +void raytrace(r) /* trace a ray and compute its value */ RAY *r; { - extern int (*trace)(); - int gotmat; - if (localhit(r, &thescene)) - gotmat = raycont(r); - else if (sourcehit(r)) - gotmat = rayshade(r, r->ro->omod); + raycont(r); /* hit local surface, evaluate */ + else if (r->ro == &Aftplane) { + r->ro = NULL; /* hit aft clipping plane */ + r->rot = FHUGE; + } else if (sourcehit(r)) + rayshade(r, r->ro->omod); /* distant source */ - if (r->ro != NULL && !gotmat) - objerror(r->ro, USER, "material not found"); + rayparticipate(r); /* for participating medium */ if (trace != NULL) (*trace)(r); /* trace execution */ } +void raycont(r) /* check for clipped object and continue */ register RAY *r; { if ((r->clipset != NULL && inset(r->clipset, r->ro->omod)) || - r->ro->omod == OVOID) { + !rayshade(r, r->ro->omod)) raytrans(r); - return(1); - } - return(rayshade(r, r->ro->omod)); } +void raytrans(r) /* transmit ray as is */ register RAY *r; { @@ -132,16 +147,13 @@ register RAY *r; } +int rayshade(r, mod) /* shade ray r with material mod */ register RAY *r; int mod; { - static int depth = 0; int gotmat; register OBJREC *m; - /* check for infinite loop */ - if (depth++ >= MAXLOOP) - objerror(r->ro, USER, "possible modifier loop"); r->rt = r->rot; /* set effective ray length */ for (gotmat = 0; !gotmat && mod != OVOID; mod = m->omod) { m = objptr(mod); @@ -152,11 +164,12 @@ int mod; } ******/ /* hack for irradiance calculation */ - if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS))) { + if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS)) && + m->otype != MAT_CLIP && + (ofun[m->otype].flags & (T_M|T_X))) { if (irr_ignore(m->otype)) { - depth--; raytrans(r); - return; + return(1); } if (!islight(m->otype)) m = &Lamb; @@ -164,20 +177,48 @@ int mod; /* materials call raytexture */ gotmat = (*ofun[m->otype].funp)(m, r); } - depth--; return(gotmat); } +void +rayparticipate(r) /* compute ray medium participation */ +register RAY *r; +{ + COLOR ce, ca; + double re, ge, be; + + if (intens(r->cext) <= 1./FHUGE) + return; /* no medium */ + re = r->rot*colval(r->cext,RED); + ge = r->rot*colval(r->cext,GRN); + be = r->rot*colval(r->cext,BLU); + if (r->crtype & SHADOW) { /* no scattering for sources */ + re *= 1. - colval(r->albedo,RED); + ge *= 1. - colval(r->albedo,GRN); + be *= 1. - colval(r->albedo,BLU); + } + setcolor(ce, re<=0. ? 1. : re>92. ? 0. : exp(-re), + ge<=0. ? 1. : ge>92. ? 0. : exp(-ge), + be<=0. ? 1. : be>92. ? 0. : exp(-be)); + multcolor(r->rcol, ce); /* path absorption */ + if (r->crtype & SHADOW || intens(r->albedo) <= FTINY) + return; /* no scattering */ + setcolor(ca, + colval(r->albedo,RED)*colval(ambval,RED)*(1.-colval(ce,RED)), + colval(r->albedo,GRN)*colval(ambval,GRN)*(1.-colval(ce,GRN)), + colval(r->albedo,BLU)*colval(ambval,BLU)*(1.-colval(ce,BLU))); + addcolor(r->rcol, ca); /* ambient in scattering */ + srcscatter(r); /* source in scattering */ +} + + +void raytexture(r, mod) /* get material modifiers */ RAY *r; -int mod; +OBJECT mod; { - static int depth = 0; register OBJREC *m; - /* check for infinite loop */ - if (depth++ >= MAXLOOP) - objerror(r->ro, USER, "modifier loop"); /* execute textures and patterns */ for ( ; mod != OVOID; mod = m->omod) { m = objptr(mod); @@ -187,13 +228,16 @@ int mod; error(USER, errmsg); } ******/ - if ((*ofun[m->otype].funp)(m, r)) - objerror(r->ro, USER, "conflicting materials"); + if ((*ofun[m->otype].funp)(m, r)) { + sprintf(errmsg, "conflicting material \"%s\"", + m->oname); + objerror(r->ro, USER, errmsg); + } } - depth--; /* end here */ } +int raymixture(r, fore, back, coef) /* mix modifiers */ register RAY *r; OBJECT fore, back; @@ -202,31 +246,28 @@ double coef; RAY fr, br; int foremat, backmat; register int i; - /* clip coefficient */ + /* bound coefficient */ if (coef > 1.0) coef = 1.0; else if (coef < 0.0) coef = 0.0; /* compute foreground and background */ - foremat = backmat = -1; + foremat = backmat = 0; /* foreground */ - copystruct(&fr, r); - if (fore != OVOID && coef > FTINY) + fr = *r; + if (coef > FTINY) foremat = rayshade(&fr, fore); /* background */ - copystruct(&br, r); - if (back != OVOID && coef < 1.0-FTINY) + br = *r; + if (coef < 1.0-FTINY) backmat = rayshade(&br, back); - /* check */ - if (foremat < 0) - if (backmat < 0) - foremat = backmat = 0; - else - foremat = backmat; - else if (backmat < 0) - backmat = foremat; - if ((foremat==0) != (backmat==0)) - objerror(r->ro, USER, "mixing material with non-material"); + /* check for transparency */ + if (backmat ^ foremat) { + if (backmat && coef > FTINY) + raytrans(&fr); + else if (foremat && coef < 1.0-FTINY) + raytrans(&br); + } /* mix perturbations */ for (i = 0; i < 3; i++) r->pert[i] = coef*fr.pert[i] + (1.0-coef)*br.pert[i]; @@ -235,16 +276,31 @@ double coef; scalecolor(br.pcol, 1.0-coef); copycolor(r->pcol, fr.pcol); addcolor(r->pcol, br.pcol); + /* return value tells if material */ + if (!foremat & !backmat) + return(0); /* mix returned ray values */ - if (foremat) { - scalecolor(fr.rcol, coef); - scalecolor(br.rcol, 1.0-coef); - copycolor(r->rcol, fr.rcol); - addcolor(r->rcol, br.rcol); - r->rt = bright(fr.rcol) > bright(br.rcol) ? fr.rt : br.rt; + scalecolor(fr.rcol, coef); + scalecolor(br.rcol, 1.0-coef); + copycolor(r->rcol, fr.rcol); + addcolor(r->rcol, br.rcol); + r->rt = bright(fr.rcol) > bright(br.rcol) ? fr.rt : br.rt; + return(1); +} + + +double +raydist(r, flags) /* compute (cumulative) ray distance */ +register RAY *r; +register int flags; +{ + double sum = 0.0; + + while (r != NULL && r->crtype&flags) { + sum += r->rot; + r = r->parent; } - /* return value tells if material */ - return(foremat); + return(sum); } @@ -283,6 +339,7 @@ register RAY *r; } +void newrayxf(r) /* get new tranformation matrix for ray */ RAY *r; { @@ -302,7 +359,7 @@ RAY *r; if (rp->rox == &xp->xf) { /* xp in use */ xp = xp->next; /* move to next */ if (xp == xflast) { /* need new one */ - xp = (struct xfn *)bmalloc(sizeof(struct xfn)); + xp = (struct xfn *)malloc(sizeof(struct xfn)); if (xp == NULL) error(SYSTEM, "out of memory in newrayxf"); @@ -319,6 +376,7 @@ RAY *r; } +void flipsurface(r) /* reverse surface orientation */ register RAY *r; { @@ -332,6 +390,23 @@ register RAY *r; } +void +rayhit(oset, r) /* standard ray hit test */ +OBJECT *oset; +RAY *r; +{ + OBJREC *o; + int i; + + for (i = oset[0]; i > 0; i--) { + o = objptr(oset[i]); + if ((*ofun[o->otype].funp)(o, r)) + r->robj = oset[i]; + } +} + + +int localhit(r, scene) /* check for hit in the octree */ register RAY *r; register CUBE *scene; @@ -353,6 +428,14 @@ register CUBE *scene; } if (sflags == 0) error(CONSISTENCY, "zero ray direction in localhit"); + /* start off assuming nothing hit */ + if (r->rmax > FTINY) { /* except aft plane if one */ + r->ro = &Aftplane; + r->rot = r->rmax; + for (i = 0; i < 3; i++) + r->rop[i] = r->rorg[i] + r->rot*r->rdir[i]; + } + /* find global cube entrance point */ t = 0.0; if (!incube(scene, curpos)) { /* find distance to entry */ @@ -370,6 +453,8 @@ register CUBE *scene; t = dt; /* farthest face is the one */ } t += FTINY; /* fudge to get inside cube */ + if (t >= r->rot) /* clipped already */ + return(0); /* advance position */ for (i = 0; i < 3; i++) curpos[i] += r->rdir[i]*t; @@ -378,7 +463,8 @@ register CUBE *scene; return(0); } cxset[0] = 0; - return(raymove(curpos, cxset, sflags, r, scene) == RAYHIT); + raymove(curpos, cxset, sflags, r, scene); + return((r->ro != NULL) & (r->ro != &Aftplane)); } @@ -433,7 +519,10 @@ register CUBE *cu; } /*NOTREACHED*/ } - if (isfull(cu->cutree) && checkhit(r, cu, cxs)) + if (isfull(cu->cutree)) { + if (checkhit(r, cu, cxs)) + return(RAYHIT); + } else if (r->ro == &Aftplane && incube(cu, r->rop)) return(RAYHIT); /* advance to next cube */ if (dirf&0x11) { @@ -465,30 +554,27 @@ register CUBE *cu; } -static +static int checkhit(r, cu, cxs) /* check for hit in full cube */ register RAY *r; CUBE *cu; OBJECT *cxs; { OBJECT oset[MAXSET+1]; - register OBJREC *o; - register int i; objset(oset, cu->cutree); - checkset(oset, cxs); /* eliminate double-checking */ - for (i = oset[0]; i > 0; i--) { - o = objptr(oset[i]); - (*ofun[o->otype].funp)(o, r); - } - if (r->ro == NULL) + checkset(oset, cxs); /* avoid double-checking */ + + (*r->hitf)(oset, r); /* test for hit in set */ + + if (r->robj == OVOID) return(0); /* no scores yet */ return(incube(cu, r->rop)); /* hit OK if in current cube */ } -static +static void checkset(os, cs) /* modify checked set and set to check */ register OBJECT *os; /* os' = os - cs */ register OBJECT *cs; /* cs' = cs + os */
