root/radiance/ray/src/rt/raytrace.c
Revision: 2.13
Committed: Mon Jan 24 11:51:31 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.12: +9 -4 lines
fixed bug in raymixture() when mixing materials with coef=0
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * raytrace.c - routines for tracing and shading rays.
9 *
10 * 8/7/85
11 */
12
13 #include "ray.h"
14
15 #include "octree.h"
16
17 #include "otypes.h"
18
19 #include "otspecial.h"
20
21 #define MAXCSET ((MAXSET+1)*2-1) /* maximum check set size */
22
23 extern CUBE thescene; /* our scene */
24 extern int maxdepth; /* maximum recursion depth */
25 extern double minweight; /* minimum ray weight */
26 extern int do_irrad; /* compute irradiance? */
27
28 unsigned long raynum = 0; /* next unique ray number */
29 unsigned long nrays = 0; /* number of calls to localhit */
30
31 static FLOAT Lambfa[5] = {PI, PI, PI, 0.0, 0.0};
32 OBJREC Lamb = {
33 OVOID, MAT_PLASTIC, "Lambertian",
34 {0, 5, NULL, Lambfa}, NULL,
35 }; /* a Lambertian surface */
36
37 static int raymove(), checkset(), checkhit();
38
39 #define MAXLOOP 128 /* modifier loop detection */
40
41 #define RAYHIT (-1) /* return value for intercepted ray */
42
43
44 rayorigin(r, ro, rt, rw) /* start new ray from old one */
45 register RAY *r, *ro;
46 int rt;
47 double rw;
48 {
49 if ((r->parent = ro) == NULL) { /* primary ray */
50 r->rlvl = 0;
51 r->rweight = rw;
52 r->crtype = r->rtype = rt;
53 r->rsrc = -1;
54 r->clipset = NULL;
55 r->revf = raytrace;
56 } else { /* spawned ray */
57 r->rlvl = ro->rlvl;
58 if (rt & RAYREFL) {
59 r->rlvl++;
60 r->rsrc = -1;
61 r->clipset = ro->clipset;
62 } else {
63 r->rsrc = ro->rsrc;
64 r->clipset = ro->newcset;
65 }
66 r->revf = ro->revf;
67 r->rweight = ro->rweight * rw;
68 r->crtype = ro->crtype | (r->rtype = rt);
69 VCOPY(r->rorg, ro->rop);
70 }
71 rayclear(r);
72 return(r->rlvl <= maxdepth && r->rweight >= minweight ? 0 : -1);
73 }
74
75
76 rayclear(r) /* clear a ray for (re)evaluation */
77 register RAY *r;
78 {
79 r->rno = raynum++;
80 r->newcset = r->clipset;
81 r->ro = NULL;
82 r->rot = FHUGE;
83 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
84 setcolor(r->pcol, 1.0, 1.0, 1.0);
85 setcolor(r->rcol, 0.0, 0.0, 0.0);
86 r->rt = 0.0;
87 }
88
89
90 raytrace(r) /* trace a ray and compute its value */
91 RAY *r;
92 {
93 extern int (*trace)();
94 int gotmat;
95
96 if (localhit(r, &thescene))
97 gotmat = raycont(r);
98 else if (sourcehit(r))
99 gotmat = rayshade(r, r->ro->omod);
100
101 if (!gotmat)
102 objerror(r->ro, USER, "material not found");
103
104 if (trace != NULL)
105 (*trace)(r); /* trace execution */
106 }
107
108
109 raycont(r) /* check for clipped object and continue */
110 register RAY *r;
111 {
112 if ((r->clipset != NULL && inset(r->clipset, r->ro->omod)) ||
113 r->ro->omod == OVOID) {
114 raytrans(r);
115 return(1);
116 }
117 return(rayshade(r, r->ro->omod));
118 }
119
120
121 raytrans(r) /* transmit ray as is */
122 register RAY *r;
123 {
124 RAY tr;
125
126 if (rayorigin(&tr, r, TRANS, 1.0) == 0) {
127 VCOPY(tr.rdir, r->rdir);
128 rayvalue(&tr);
129 copycolor(r->rcol, tr.rcol);
130 r->rt = r->rot + tr.rt;
131 }
132 }
133
134
135 rayshade(r, mod) /* shade ray r with material mod */
136 register RAY *r;
137 int mod;
138 {
139 static int depth = 0;
140 int gotmat;
141 register OBJREC *m;
142 /* check for infinite loop */
143 if (depth++ >= MAXLOOP)
144 objerror(r->ro, USER, "possible modifier loop");
145 r->rt = r->rot; /* set effective ray length */
146 for (gotmat = 0; !gotmat && mod != OVOID; mod = m->omod) {
147 m = objptr(mod);
148 /****** unnecessary test since modifier() is always called
149 if (!ismodifier(m->otype)) {
150 sprintf(errmsg, "illegal modifier \"%s\"", m->oname);
151 error(USER, errmsg);
152 }
153 ******/
154 /* hack for irradiance calculation */
155 if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS))) {
156 if (irr_ignore(m->otype)) {
157 depth--;
158 raytrans(r);
159 return;
160 }
161 if (!islight(m->otype))
162 m = &Lamb;
163 }
164 /* materials call raytexture */
165 gotmat = (*ofun[m->otype].funp)(m, r);
166 }
167 depth--;
168 return(gotmat);
169 }
170
171
172 raytexture(r, mod) /* get material modifiers */
173 RAY *r;
174 int mod;
175 {
176 static int depth = 0;
177 register OBJREC *m;
178 /* check for infinite loop */
179 if (depth++ >= MAXLOOP)
180 objerror(r->ro, USER, "modifier loop");
181 /* execute textures and patterns */
182 for ( ; mod != OVOID; mod = m->omod) {
183 m = objptr(mod);
184 /****** unnecessary test since modifier() is always called
185 if (!ismodifier(m->otype)) {
186 sprintf(errmsg, "illegal modifier \"%s\"", m->oname);
187 error(USER, errmsg);
188 }
189 ******/
190 if ((*ofun[m->otype].funp)(m, r))
191 objerror(r->ro, USER, "conflicting materials");
192 }
193 depth--; /* end here */
194 }
195
196
197 raymixture(r, fore, back, coef) /* mix modifiers */
198 register RAY *r;
199 OBJECT fore, back;
200 double coef;
201 {
202 RAY fr, br;
203 int foremat, backmat;
204 register int i;
205 /* clip coefficient */
206 if (coef > 1.0)
207 coef = 1.0;
208 else if (coef < 0.0)
209 coef = 0.0;
210 /* compute foreground and background */
211 foremat = backmat = -1;
212 /* foreground */
213 copystruct(&fr, r);
214 if (fore != OVOID && coef > FTINY)
215 foremat = rayshade(&fr, fore);
216 /* background */
217 copystruct(&br, r);
218 if (back != OVOID && coef < 1.0-FTINY)
219 backmat = rayshade(&br, back);
220 /* check */
221 if (foremat < 0)
222 if (backmat < 0)
223 foremat = backmat = 0;
224 else
225 foremat = backmat;
226 else if (backmat < 0)
227 backmat = foremat;
228 if ((foremat==0) != (backmat==0))
229 objerror(r->ro, USER, "mixing material with non-material");
230 /* mix perturbations */
231 for (i = 0; i < 3; i++)
232 r->pert[i] = coef*fr.pert[i] + (1.0-coef)*br.pert[i];
233 /* mix pattern colors */
234 scalecolor(fr.pcol, coef);
235 scalecolor(br.pcol, 1.0-coef);
236 copycolor(r->pcol, fr.pcol);
237 addcolor(r->pcol, br.pcol);
238 /* mix returned ray values */
239 if (foremat) {
240 scalecolor(fr.rcol, coef);
241 scalecolor(br.rcol, 1.0-coef);
242 copycolor(r->rcol, fr.rcol);
243 addcolor(r->rcol, br.rcol);
244 r->rt = bright(fr.rcol) > bright(br.rcol) ? fr.rt : br.rt;
245 }
246 /* return value tells if material */
247 return(foremat);
248 }
249
250
251 double
252 raynormal(norm, r) /* compute perturbed normal for ray */
253 FVECT norm;
254 register RAY *r;
255 {
256 double newdot;
257 register int i;
258
259 /* The perturbation is added to the surface normal to obtain
260 * the new normal. If the new normal would affect the surface
261 * orientation wrt. the ray, a correction is made. The method is
262 * still fraught with problems since reflected rays and similar
263 * directions calculated from the surface normal may spawn rays behind
264 * the surface. The only solution is to curb textures at high
265 * incidence (namely, keep DOT(rdir,pert) < Rdot).
266 */
267
268 for (i = 0; i < 3; i++)
269 norm[i] = r->ron[i] + r->pert[i];
270
271 if (normalize(norm) == 0.0) {
272 objerror(r->ro, WARNING, "illegal normal perturbation");
273 VCOPY(norm, r->ron);
274 return(r->rod);
275 }
276 newdot = -DOT(norm, r->rdir);
277 if ((newdot > 0.0) != (r->rod > 0.0)) { /* fix orientation */
278 for (i = 0; i < 3; i++)
279 norm[i] += 2.0*newdot*r->rdir[i];
280 newdot = -newdot;
281 }
282 return(newdot);
283 }
284
285
286 newrayxf(r) /* get new tranformation matrix for ray */
287 RAY *r;
288 {
289 static struct xfn {
290 struct xfn *next;
291 FULLXF xf;
292 } xfseed = { &xfseed }, *xflast = &xfseed;
293 register struct xfn *xp;
294 register RAY *rp;
295
296 /*
297 * Search for transform in circular list that
298 * has no associated ray in the tree.
299 */
300 xp = xflast;
301 for (rp = r->parent; rp != NULL; rp = rp->parent)
302 if (rp->rox == &xp->xf) { /* xp in use */
303 xp = xp->next; /* move to next */
304 if (xp == xflast) { /* need new one */
305 xp = (struct xfn *)bmalloc(sizeof(struct xfn));
306 if (xp == NULL)
307 error(SYSTEM,
308 "out of memory in newrayxf");
309 /* insert in list */
310 xp->next = xflast->next;
311 xflast->next = xp;
312 break; /* we're done */
313 }
314 rp = r; /* start check over */
315 }
316 /* got it */
317 r->rox = &xp->xf;
318 xflast = xp;
319 }
320
321
322 flipsurface(r) /* reverse surface orientation */
323 register RAY *r;
324 {
325 r->rod = -r->rod;
326 r->ron[0] = -r->ron[0];
327 r->ron[1] = -r->ron[1];
328 r->ron[2] = -r->ron[2];
329 r->pert[0] = -r->pert[0];
330 r->pert[1] = -r->pert[1];
331 r->pert[2] = -r->pert[2];
332 }
333
334
335 localhit(r, scene) /* check for hit in the octree */
336 register RAY *r;
337 register CUBE *scene;
338 {
339 OBJECT cxset[MAXCSET+1]; /* set of checked objects */
340 FVECT curpos; /* current cube position */
341 int sflags; /* sign flags */
342 double t, dt;
343 register int i;
344
345 nrays++; /* increment trace counter */
346 sflags = 0;
347 for (i = 0; i < 3; i++) {
348 curpos[i] = r->rorg[i];
349 if (r->rdir[i] > 1e-7)
350 sflags |= 1 << i;
351 else if (r->rdir[i] < -1e-7)
352 sflags |= 0x10 << i;
353 }
354 if (sflags == 0)
355 error(CONSISTENCY, "zero ray direction in localhit");
356 t = 0.0;
357 if (!incube(scene, curpos)) {
358 /* find distance to entry */
359 for (i = 0; i < 3; i++) {
360 /* plane in our direction */
361 if (sflags & 1<<i)
362 dt = scene->cuorg[i];
363 else if (sflags & 0x10<<i)
364 dt = scene->cuorg[i] + scene->cusize;
365 else
366 continue;
367 /* distance to the plane */
368 dt = (dt - r->rorg[i])/r->rdir[i];
369 if (dt > t)
370 t = dt; /* farthest face is the one */
371 }
372 t += FTINY; /* fudge to get inside cube */
373 /* advance position */
374 for (i = 0; i < 3; i++)
375 curpos[i] += r->rdir[i]*t;
376
377 if (!incube(scene, curpos)) /* non-intersecting ray */
378 return(0);
379 }
380 cxset[0] = 0;
381 return(raymove(curpos, cxset, sflags, r, scene) == RAYHIT);
382 }
383
384
385 static int
386 raymove(pos, cxs, dirf, r, cu) /* check for hit as we move */
387 FVECT pos; /* current position, modified herein */
388 OBJECT *cxs; /* checked objects, modified by checkhit */
389 int dirf; /* direction indicators to speed tests */
390 register RAY *r;
391 register CUBE *cu;
392 {
393 int ax;
394 double dt, t;
395
396 if (istree(cu->cutree)) { /* recurse on subcubes */
397 CUBE cukid;
398 register int br, sgn;
399
400 cukid.cusize = cu->cusize * 0.5; /* find subcube */
401 VCOPY(cukid.cuorg, cu->cuorg);
402 br = 0;
403 if (pos[0] >= cukid.cuorg[0]+cukid.cusize) {
404 cukid.cuorg[0] += cukid.cusize;
405 br |= 1;
406 }
407 if (pos[1] >= cukid.cuorg[1]+cukid.cusize) {
408 cukid.cuorg[1] += cukid.cusize;
409 br |= 2;
410 }
411 if (pos[2] >= cukid.cuorg[2]+cukid.cusize) {
412 cukid.cuorg[2] += cukid.cusize;
413 br |= 4;
414 }
415 for ( ; ; ) {
416 cukid.cutree = octkid(cu->cutree, br);
417 if ((ax = raymove(pos,cxs,dirf,r,&cukid)) == RAYHIT)
418 return(RAYHIT);
419 sgn = 1 << ax;
420 if (sgn & dirf) /* positive axis? */
421 if (sgn & br)
422 return(ax); /* overflow */
423 else {
424 cukid.cuorg[ax] += cukid.cusize;
425 br |= sgn;
426 }
427 else
428 if (sgn & br) {
429 cukid.cuorg[ax] -= cukid.cusize;
430 br &= ~sgn;
431 } else
432 return(ax); /* underflow */
433 }
434 /*NOTREACHED*/
435 }
436 if (isfull(cu->cutree) && checkhit(r, cu, cxs))
437 return(RAYHIT);
438 /* advance to next cube */
439 if (dirf&0x11) {
440 dt = dirf&1 ? cu->cuorg[0] + cu->cusize : cu->cuorg[0];
441 t = (dt - pos[0])/r->rdir[0];
442 ax = 0;
443 } else
444 t = FHUGE;
445 if (dirf&0x22) {
446 dt = dirf&2 ? cu->cuorg[1] + cu->cusize : cu->cuorg[1];
447 dt = (dt - pos[1])/r->rdir[1];
448 if (dt < t) {
449 t = dt;
450 ax = 1;
451 }
452 }
453 if (dirf&0x44) {
454 dt = dirf&4 ? cu->cuorg[2] + cu->cusize : cu->cuorg[2];
455 dt = (dt - pos[2])/r->rdir[2];
456 if (dt < t) {
457 t = dt;
458 ax = 2;
459 }
460 }
461 pos[0] += r->rdir[0]*t;
462 pos[1] += r->rdir[1]*t;
463 pos[2] += r->rdir[2]*t;
464 return(ax);
465 }
466
467
468 static
469 checkhit(r, cu, cxs) /* check for hit in full cube */
470 register RAY *r;
471 CUBE *cu;
472 OBJECT *cxs;
473 {
474 OBJECT oset[MAXSET+1];
475 register OBJREC *o;
476 register int i;
477
478 objset(oset, cu->cutree);
479 checkset(oset, cxs); /* eliminate double-checking */
480 for (i = oset[0]; i > 0; i--) {
481 o = objptr(oset[i]);
482 (*ofun[o->otype].funp)(o, r);
483 }
484 if (r->ro == NULL)
485 return(0); /* no scores yet */
486
487 return(incube(cu, r->rop)); /* hit OK if in current cube */
488 }
489
490
491 static
492 checkset(os, cs) /* modify checked set and set to check */
493 register OBJECT *os; /* os' = os - cs */
494 register OBJECT *cs; /* cs' = cs + os */
495 {
496 OBJECT cset[MAXCSET+MAXSET+1];
497 register int i, j;
498 int k;
499 /* copy os in place, cset <- cs */
500 cset[0] = 0;
501 k = 0;
502 for (i = j = 1; i <= os[0]; i++) {
503 while (j <= cs[0] && cs[j] < os[i])
504 cset[++cset[0]] = cs[j++];
505 if (j > cs[0] || os[i] != cs[j]) { /* object to check */
506 os[++k] = os[i];
507 cset[++cset[0]] = os[i];
508 }
509 }
510 if (!(os[0] = k)) /* new "to check" set size */
511 return; /* special case */
512 while (j <= cs[0]) /* get the rest of cs */
513 cset[++cset[0]] = cs[j++];
514 if (cset[0] > MAXCSET) /* truncate "checked" set if nec. */
515 cset[0] = MAXCSET;
516 /* setcopy(cs, cset); */ /* copy cset back to cs */
517 os = cset;
518 for (i = os[0]; i-- >= 0; )
519 *cs++ = *os++;
520 }
