--- ray/src/rt/raytrace.c 1996/04/24 16:27:56 2.27 +++ ray/src/rt/raytrace.c 2003/02/22 02:07:29 2.34 @@ -1,36 +1,77 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: raytrace.c,v 2.34 2003/02/22 02:07:29 greg Exp $"; #endif - /* * raytrace.c - routines for tracing and shading rays. * - * 8/7/85 + * External symbols declared in ray.h */ +/* ==================================================================== + * The Radiance Software License, Version 1.0 + * + * Copyright (c) 1990 - 2002 The Regents of the University of California, + * through Lawrence Berkeley National Laboratory. All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * + * 3. The end-user documentation included with the redistribution, + * if any, must include the following acknowledgment: + * "This product includes Radiance software + * (http://radsite.lbl.gov/) + * developed by the Lawrence Berkeley National Laboratory + * (http://www.lbl.gov/)." + * Alternately, this acknowledgment may appear in the software itself, + * if and wherever such third-party acknowledgments normally appear. + * + * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" + * and "The Regents of the University of California" must + * not be used to endorse or promote products derived from this + * software without prior written permission. For written + * permission, please contact radiance@radsite.lbl.gov. + * + * 5. Products derived from this software may not be called "Radiance", + * nor may "Radiance" appear in their name, without prior written + * permission of Lawrence Berkeley National Laboratory. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR + * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * ==================================================================== + * + * This software consists of voluntary contributions made by many + * individuals on behalf of Lawrence Berkeley National Laboratory. For more + * information on Lawrence Berkeley National Laboratory, please see + * . + */ + #include "ray.h" -#include "octree.h" - #include "otypes.h" #include "otspecial.h" #define MAXCSET ((MAXSET+1)*2-1) /* maximum check set size */ -extern CUBE thescene; /* our scene */ -extern int maxdepth; /* maximum recursion depth */ -extern double minweight; /* minimum ray weight */ -extern int do_irrad; /* compute irradiance? */ -extern COLOR ambval; /* ambient value */ - -extern COLOR cextinction; /* global extinction coefficient */ -extern COLOR salbedo; /* global scattering albedo */ -extern double seccg; /* global scattering eccentricity */ -extern double ssampdist; /* scatter sampling distance */ - unsigned long raynum = 0; /* next unique ray number */ unsigned long nrays = 0; /* number of calls to localhit */ @@ -42,18 +83,24 @@ OBJREC Lamb = { OBJREC Aftplane; /* aft clipping plane object */ -static int raymove(), checkset(), checkhit(); +static int raymove(), checkhit(); +static void checkset(); -#define MAXLOOP 128 /* modifier loop detection */ +#ifndef MAXLOOP +#define MAXLOOP 0 /* modifier loop detection */ +#endif #define RAYHIT (-1) /* return value for intercepted ray */ +int rayorigin(r, ro, rt, rw) /* start new ray from old one */ register RAY *r, *ro; int rt; double rw; { + double re; + if ((r->parent = ro) == NULL) { /* primary ray */ r->rlvl = 0; r->rweight = rw; @@ -82,34 +129,41 @@ double rw; copycolor(r->albedo, ro->albedo); r->gecc = ro->gecc; r->slights = ro->slights; - r->rweight = ro->rweight * rw; r->crtype = ro->crtype | (r->rtype = rt); VCOPY(r->rorg, ro->rop); + r->rweight = ro->rweight * rw; + /* estimate absorption */ + re = colval(ro->cext,RED) < colval(ro->cext,GRN) ? + colval(ro->cext,RED) : colval(ro->cext,GRN); + if (colval(ro->cext,BLU) < re) re = colval(ro->cext,BLU); + if (re > 0.) + r->rweight *= exp(-re*ro->rot); } rayclear(r); return(r->rlvl <= maxdepth && r->rweight >= minweight ? 0 : -1); } +void rayclear(r) /* clear a ray for (re)evaluation */ register RAY *r; { r->rno = raynum++; r->newcset = r->clipset; + r->robj = OVOID; r->ro = NULL; - r->rot = FHUGE; + r->rox = NULL; + r->rt = r->rot = FHUGE; r->pert[0] = r->pert[1] = r->pert[2] = 0.0; setcolor(r->pcol, 1.0, 1.0, 1.0); setcolor(r->rcol, 0.0, 0.0, 0.0); - r->rt = 0.0; } +void raytrace(r) /* trace a ray and compute its value */ RAY *r; { - extern int (*trace)(); - if (localhit(r, &thescene)) raycont(r); /* hit local surface, evaluate */ else if (r->ro == &Aftplane) { @@ -125,6 +179,7 @@ RAY *r; } +void raycont(r) /* check for clipped object and continue */ register RAY *r; { @@ -134,6 +189,7 @@ register RAY *r; } +void raytrans(r) /* transmit ray as is */ register RAY *r; { @@ -148,16 +204,19 @@ register RAY *r; } +int rayshade(r, mod) /* shade ray r with material mod */ register RAY *r; int mod; { - static int depth = 0; int gotmat; register OBJREC *m; +#if MAXLOOP + static int depth = 0; /* check for infinite loop */ if (depth++ >= MAXLOOP) objerror(r->ro, USER, "possible modifier loop"); +#endif r->rt = r->rot; /* set effective ray length */ for (gotmat = 0; !gotmat && mod != OVOID; mod = m->omod) { m = objptr(mod); @@ -170,7 +229,9 @@ int mod; /* hack for irradiance calculation */ if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS))) { if (irr_ignore(m->otype)) { +#if MAXLOOP depth--; +#endif raytrans(r); return(1); } @@ -180,11 +241,14 @@ int mod; /* materials call raytexture */ gotmat = (*ofun[m->otype].funp)(m, r); } +#if MAXLOOP depth--; +#endif return(gotmat); } +void rayparticipate(r) /* compute ray medium participation */ register RAY *r; { @@ -220,11 +284,13 @@ raytexture(r, mod) /* get material modifiers */ RAY *r; int mod; { - static int depth = 0; register OBJREC *m; +#if MAXLOOP + static int depth = 0; /* check for infinite loop */ if (depth++ >= MAXLOOP) objerror(r->ro, USER, "modifier loop"); +#endif /* execute textures and patterns */ for ( ; mod != OVOID; mod = m->omod) { m = objptr(mod); @@ -240,10 +306,13 @@ int mod; objerror(r->ro, USER, errmsg); } } +#if MAXLOOP depth--; /* end here */ +#endif } +int raymixture(r, fore, back, coef) /* mix modifiers */ register RAY *r; OBJECT fore, back; @@ -269,9 +338,9 @@ double coef; backmat = rayshade(&br, back); /* check for transparency */ if (backmat ^ foremat) - if (backmat) + if (backmat && coef > FTINY) raytrans(&fr); - else + else if (foremat && coef < 1.0-FTINY) raytrans(&br); /* mix perturbations */ for (i = 0; i < 3; i++) @@ -344,6 +413,7 @@ register RAY *r; } +void newrayxf(r) /* get new tranformation matrix for ray */ RAY *r; { @@ -363,7 +433,7 @@ RAY *r; if (rp->rox == &xp->xf) { /* xp in use */ xp = xp->next; /* move to next */ if (xp == xflast) { /* need new one */ - xp = (struct xfn *)bmalloc(sizeof(struct xfn)); + xp = (struct xfn *)malloc(sizeof(struct xfn)); if (xp == NULL) error(SYSTEM, "out of memory in newrayxf"); @@ -380,6 +450,7 @@ RAY *r; } +void flipsurface(r) /* reverse surface orientation */ register RAY *r; { @@ -393,6 +464,7 @@ register RAY *r; } +int localhit(r, scene) /* check for hit in the octree */ register RAY *r; register CUBE *scene; @@ -540,7 +612,7 @@ register CUBE *cu; } -static +static int checkhit(r, cu, cxs) /* check for hit in full cube */ register RAY *r; CUBE *cu; @@ -554,7 +626,8 @@ OBJECT *cxs; checkset(oset, cxs); /* eliminate double-checking */ for (i = oset[0]; i > 0; i--) { o = objptr(oset[i]); - (*ofun[o->otype].funp)(o, r); + if ((*ofun[o->otype].funp)(o, r)) + r->robj = oset[i]; } if (r->ro == NULL) return(0); /* no scores yet */ @@ -563,7 +636,7 @@ OBJECT *cxs; } -static +static void checkset(os, cs) /* modify checked set and set to check */ register OBJECT *os; /* os' = os - cs */ register OBJECT *cs; /* cs' = cs + os */
