root/radiance/ray/src/rt/raypwin.c
Tue Jan 8 00:16:31 2019 UTC (6 years, 3 months ago) by greg
Made rtrace a little more efficient under Windows if -n > 1
Tue Oct 26 03:45:35 2010 UTC (14 years, 6 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 2.7: +8 -1 lines
Bug fix in l+ option of mkillum under Windows
Thu May 27 19:32:13 2010 UTC (14 years, 11 months ago) by greg
Changes since 2.6: +1 -9 lines
Tue Dec 15 19:13:45 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.5: +12 -11 lines
Update to return type of ray_psend()
Thu Apr 17 18:48:09 2008 UTC (17 years ago) by greg
Changes since 2.4: +7 -2 lines
Bug fixes
Wed Feb 13 01:06:10 2008 UTC (17 years, 2 months ago) by greg
Changes since 2.3: +5 -3 lines
Fixed call to rayvalue()
Mon Feb 11 21:17:25 2008 UTC (17 years, 2 months ago) by greg
Changes since 2.2: +2 -4 lines
Minor fixes
Sat Feb 9 00:17:51 2008 UTC (17 years, 2 months ago) by greg
Changes since 2.1: +43 -7 lines
Diff to previous 2.1
Made Windows replacement calls functional as a single process
Fri Feb 8 18:27:31 2008 UTC (17 years, 2 months ago) by greg
Created stub routines as placeholder for Windows version of raypcalls
