root/radiance/ray/src/rt/raypcalls.c
Revision: 2.28
Committed: Sat Aug 20 18:23:38 2011 UTC (12 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R2P1
Changes since 2.27: +9 -4 lines
Improved random sampling
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.28 static const char RCSid[] = "$Id: raypcalls.c,v 2.27 2011/08/20 06:05:53 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * raypcalls.c - interface for parallel rendering using Radiance
6     *
7     * External symbols declared in ray.h
8     */
9
10 greg 2.2 #include "copyright.h"
11 greg 2.1
12     /*
13     * These calls are designed similarly to the ones in raycalls.c,
14     * but allow for multiple rendering processes on the same host
15     * machine. There is no sense in specifying more child processes
16 greg 2.21 * than you have processor cores, but one child may help by allowing
17 greg 2.1 * asynchronous ray computation in an interactive program, and
18     * will protect the caller from fatal rendering errors.
19     *
20 greg 2.21 * You should first read and understand the header in raycalls.c,
21 greg 2.1 * as some things are explained there that are not repated here.
22     *
23     * The first step is opening one or more rendering processes
24     * with a call to ray_pinit(oct, nproc). Before calling fork(),
25     * ray_pinit() loads the octree and data structures into the
26 greg 2.13 * caller's memory, and ray_popen() synchronizes the ambient
27     * file, if any. Shared memory permits all sorts of queries
28 greg 2.21 * that wouldn't be possible otherwise without causing any real
29 greg 2.1 * memory overhead, since all the static data are shared
30 greg 2.21 * between processes. Rays are traced using a simple
31 greg 2.1 * queuing mechanism, explained below.
32     *
33 greg 2.14 * The ray queue buffers RAYQLEN rays before sending to
34 greg 2.21 * children, each of which may internally buffer RAYQLEN rays
35     * during evaluation. Rays are not returned in the order
36     * they are sent when multiple processes are open.
37 greg 2.14 *
38 greg 2.13 * Rays are queued and returned by a single
39 greg 2.1 * ray_pqueue() call. A ray_pqueue() return
40     * value of 0 indicates that no rays are ready
41     * and the queue is not yet full. A return value of 1
42     * indicates that a ray was returned, though it is probably
43     * not the one you just requested. Rays may be identified by
44     * the rno member of the RAY struct, which is incremented
45     * by the rayorigin() call, or may be set explicitly by
46     * the caller. Below is an example call sequence:
47     *
48     * myRay.rorg = ( ray origin point )
49     * myRay.rdir = ( normalized ray direction )
50     * myRay.rmax = ( maximum length, or zero for no limit )
51 greg 2.11 * rayorigin(&myRay, PRIMARY, NULL, NULL);
52 greg 2.1 * myRay.rno = ( my personal ray identifier )
53     * if (ray_pqueue(&myRay) == 1)
54     * { do something with results }
55     *
56     * Note the differences between this and the simpler ray_trace()
57     * call. In particular, the call may or may not return a value
58     * in the passed ray structure. Also, you need to call rayorigin()
59 greg 2.7 * yourself, which is normally called for you by ray_trace(). The
60     * benefit is that ray_pqueue() will trace rays faster in
61 greg 2.1 * proportion to the number of CPUs you have available on your
62     * system. If the ray queue is full before the call, ray_pqueue()
63     * will block until a result is ready so it can queue this one.
64 greg 2.3 * The global int ray_pnidle indicates the number of currently idle
65 greg 2.1 * children. If you want to check for completed rays without blocking,
66     * or get the results from rays that have been queued without
67     * queuing any new ones, the ray_presult() call is for you:
68     *
69     * if (ray_presult(&myRay, 1) == 1)
70     * { do something with results }
71     *
72     * If the second argument is 1, the call won't block when
73     * results aren't ready, but will immediately return 0.
74     * If the second argument is 0, the call will block
75     * until a value is available, returning 0 only if the
76 greg 2.26 * queue is completely empty. Setting the second argument
77     * to -1 returns 0 unless a ray is ready in the queue and
78     * no system calls are needed. A negative return value
79 greg 2.1 * indicates that a rendering process died. If this
80 greg 2.21 * happens, ray_pclose(0) is automatically called to close
81 greg 2.3 * all child processes, and ray_pnprocs is set to zero.
82 greg 2.1 *
83     * If you just want to fill the ray queue without checking for
84 greg 2.3 * results, check ray_pnidle and call ray_psend():
85 greg 2.1 *
86 greg 2.3 * while (ray_pnidle) {
87 greg 2.1 * ( set up ray )
88     * ray_psend(&myRay);
89     * }
90     *
91 greg 2.25 * Note that it is a mistake to call ra_psend() when
92     * ray_pnidle is zero, and nothing will be sent in
93     * this case. Otherwise, the ray_presult() and/or ray_pqueue()
94     * functions may be called subsequently to read back the results
95     * of rays queued by ray_psend().
96 greg 2.1 *
97     * When you are done, you may call ray_pdone(1) to close
98     * all child processes and clean up memory used by Radiance.
99     * Any queued ray calculations will be awaited and discarded.
100     * As with ray_done(), ray_pdone(0) hangs onto data files
101     * and fonts that are likely to be used in subsequent renderings.
102 greg 2.21 * Whether you need to clean up memory or not, you should
103     * at least call ray_pclose(0) to await the child processes.
104 greg 2.23 * The caller should define a quit() function that calls
105     * ray_pclose(0) if ray_pnprocs > 0.
106 greg 2.1 *
107     * Warning: You cannot affect any of the rendering processes
108     * by changing global parameter values onece ray_pinit() has
109     * been called. Changing global parameters will have no effect
110     * until the next call to ray_pinit(), which restarts everything.
111     * If you just want to reap children so that you can alter the
112     * rendering parameters without reloading the scene, use the
113     * ray_pclose(0) and ray_popen(nproc) calls to close
114 greg 2.7 * then restart the child processes after the changes are made.
115 greg 2.1 *
116     * Note: These routines are written to coordinate with the
117     * definitions in raycalls.c, and in fact depend on them.
118     * If you want to trace a ray and get a result synchronously,
119 greg 2.13 * use the ray_trace() call to compute it in the parent process.
120 greg 2.7 * This will not interfere with any subprocess calculations,
121     * but beware that a fatal error may end with a call to quit().
122 greg 2.1 *
123     * Note: One of the advantages of using separate processes
124     * is that it gives the calling program some immunity from
125     * fatal rendering errors. As discussed in raycalls.c,
126     * Radiance tends to throw up its hands and exit at the
127     * first sign of trouble, calling quit() to return control
128 greg 2.7 * to the top level. Although you can avoid exit() with
129 greg 2.1 * your own longjmp() in quit(), the cleanup afterwards
130     * is always suspect. Through the use of subprocesses,
131     * we avoid this pitfall by closing the processes and
132     * returning a negative value from ray_pqueue() or
133     * ray_presult(). If you get a negative value from either
134     * of these calls, you can assume that the processes have
135 greg 2.21 * been cleaned up with a call to ray_pclose(), though you
136 greg 2.1 * will have to call ray_pdone() yourself if you want to
137 greg 2.7 * free memory. Obviously, you cannot continue rendering
138     * without risking further errors, but otherwise your
139     * process should not be compromised.
140 greg 2.1 */
141
142 schorsch 2.6 #include "rtprocess.h"
143 greg 2.1 #include "ray.h"
144 schorsch 2.6 #include "ambient.h"
145 greg 2.18 #include <sys/types.h>
146     #include <sys/wait.h>
147 greg 2.1 #include "selcall.h"
148
149     #ifndef RAYQLEN
150 greg 2.13 #define RAYQLEN 12 /* # rays to send at once */
151 greg 2.1 #endif
152
153     #ifndef MAX_RPROCS
154     #if (FD_SETSIZE/2-4 < 64)
155     #define MAX_NPROCS (FD_SETSIZE/2-4)
156     #else
157     #define MAX_NPROCS 64 /* max. # rendering processes */
158     #endif
159     #endif
160
161     extern char *shm_boundary; /* boundary of shared memory */
162
163 greg 2.3 int ray_pnprocs = 0; /* number of child processes */
164     int ray_pnidle = 0; /* number of idle children */
165 greg 2.1
166     static struct child_proc {
167     int pid; /* child process id */
168     int fd_send; /* write to child here */
169     int fd_recv; /* read from child here */
170     int npending; /* # rays in process */
171 greg 2.21 RNUMBER rno[RAYQLEN]; /* working on these rays */
172 greg 2.1 } r_proc[MAX_NPROCS]; /* our child processes */
173
174     static RAY r_queue[2*RAYQLEN]; /* ray i/o buffer */
175 greg 2.23 static int r_send_next = 0; /* next send ray placement */
176     static int r_recv_first = RAYQLEN; /* position of first unreported ray */
177     static int r_recv_next = RAYQLEN; /* next received ray placement */
178 greg 2.1
179 greg 2.28 static int samplestep = 1; /* sample step size */
180
181 greg 2.1 #define sendq_full() (r_send_next >= RAYQLEN)
182
183 schorsch 2.6 static int ray_pflush(void);
184 greg 2.13 static void ray_pchild(int fd_in, int fd_out);
185 greg 2.1
186 schorsch 2.6
187 greg 2.22 void
188 schorsch 2.6 ray_pinit( /* initialize ray-tracing processes */
189     char *otnm,
190     int nproc
191     )
192 greg 2.1 {
193     if (nobjects > 0) /* close old calculation */
194     ray_pdone(0);
195
196     ray_init(otnm); /* load the shared scene */
197
198     ray_popen(nproc); /* fork children */
199     }
200
201
202     static int
203 schorsch 2.6 ray_pflush(void) /* send queued rays to idle children */
204 greg 2.1 {
205     int nc, n, nw, i, sfirst;
206
207 schorsch 2.5 if ((ray_pnidle <= 0) | (r_send_next <= 0))
208 greg 2.1 return(0); /* nothing we can send */
209
210     sfirst = 0; /* divvy up labor */
211 greg 2.3 nc = ray_pnidle;
212     for (i = ray_pnprocs; nc && i--; ) {
213 greg 2.1 if (r_proc[i].npending > 0)
214     continue; /* child looks busy */
215     n = (r_send_next - sfirst)/nc--;
216     if (!n)
217     continue;
218     /* smuggle set size in crtype */
219     r_queue[sfirst].crtype = n;
220     nw = writebuf(r_proc[i].fd_send, (char *)&r_queue[sfirst],
221     sizeof(RAY)*n);
222     if (nw != sizeof(RAY)*n)
223     return(-1); /* write error */
224     r_proc[i].npending = n;
225     while (n--) /* record ray IDs */
226     r_proc[i].rno[n] = r_queue[sfirst+n].rno;
227     sfirst += r_proc[i].npending;
228 greg 2.3 ray_pnidle--; /* now she's busy */
229 greg 2.1 }
230     if (sfirst != r_send_next)
231 greg 2.24 error(CONSISTENCY, "code screwup in ray_pflush()");
232 greg 2.1 r_send_next = 0;
233     return(sfirst); /* return total # sent */
234     }
235
236
237 greg 2.25 int
238 schorsch 2.6 ray_psend( /* add a ray to our send queue */
239     RAY *r
240     )
241 greg 2.1 {
242 greg 2.25 int rv;
243
244     if ((r == NULL) | (ray_pnidle <= 0))
245     return(0);
246 greg 2.1 /* flush output if necessary */
247 greg 2.25 if (sendq_full() && (rv = ray_pflush()) <= 0)
248     return(rv);
249 greg 2.1
250 greg 2.14 r_queue[r_send_next++] = *r;
251 greg 2.25 return(1);
252 greg 2.1 }
253
254
255 greg 2.22 int
256 schorsch 2.6 ray_pqueue( /* queue a ray for computation */
257     RAY *r
258     )
259 greg 2.1 {
260     if (r == NULL)
261     return(0);
262     /* check for full send queue */
263     if (sendq_full()) {
264 greg 2.19 RAY mySend = *r;
265 greg 2.1 /* wait for a result */
266 greg 2.19 if (ray_presult(r, 0) <= 0)
267     return(-1);
268 greg 2.1 /* put new ray in queue */
269 greg 2.14 r_queue[r_send_next++] = mySend;
270 greg 2.25
271 greg 2.19 return(1);
272 greg 2.1 }
273 greg 2.13 /* else add ray to send queue */
274 greg 2.14 r_queue[r_send_next++] = *r;
275 greg 2.1 /* check for returned ray... */
276     if (r_recv_first >= r_recv_next)
277     return(0);
278     /* ...one is sitting in queue */
279 greg 2.14 *r = r_queue[r_recv_first++];
280 greg 2.1 return(1);
281     }
282
283
284 greg 2.22 int
285 schorsch 2.6 ray_presult( /* check for a completed ray */
286     RAY *r,
287     int poll
288     )
289 greg 2.1 {
290     static struct timeval tpoll; /* zero timeval struct */
291     static fd_set readset, errset;
292     int n, ok;
293     register int pn;
294
295     if (r == NULL)
296     return(0);
297     /* check queued results first */
298     if (r_recv_first < r_recv_next) {
299 greg 2.14 *r = r_queue[r_recv_first++];
300 greg 2.1 return(1);
301     }
302 greg 2.23 if (poll < 0) /* immediate polling mode? */
303     return(0);
304
305 greg 2.3 n = ray_pnprocs - ray_pnidle; /* pending before flush? */
306 greg 2.1
307     if (ray_pflush() < 0) /* send new rays to process */
308     return(-1);
309     /* reset receive queue */
310     r_recv_first = r_recv_next = RAYQLEN;
311
312     if (!poll) /* count newly sent unless polling */
313 greg 2.3 n = ray_pnprocs - ray_pnidle;
314 greg 2.1 if (n <= 0) /* return if nothing to await */
315     return(0);
316 greg 2.16 if (!poll && ray_pnprocs == 1) /* one process -> skip select() */
317     FD_SET(r_proc[0].fd_recv, &readset);
318
319 greg 2.1 getready: /* any children waiting for us? */
320 greg 2.3 for (pn = ray_pnprocs; pn--; )
321 greg 2.1 if (FD_ISSET(r_proc[pn].fd_recv, &readset) ||
322     FD_ISSET(r_proc[pn].fd_recv, &errset))
323     break;
324 greg 2.22 /* call select() if we must */
325 greg 2.1 if (pn < 0) {
326     FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
327 greg 2.3 for (pn = ray_pnprocs; pn--; ) {
328 greg 2.1 if (r_proc[pn].npending > 0)
329     FD_SET(r_proc[pn].fd_recv, &readset);
330     FD_SET(r_proc[pn].fd_recv, &errset);
331     if (r_proc[pn].fd_recv >= n)
332     n = r_proc[pn].fd_recv + 1;
333     }
334     /* find out who is ready */
335     while ((n = select(n, &readset, (fd_set *)NULL, &errset,
336     poll ? &tpoll : (struct timeval *)NULL)) < 0)
337     if (errno != EINTR) {
338     error(WARNING,
339 greg 2.24 "select call failed in ray_presult()");
340 greg 2.1 ray_pclose(0);
341     return(-1);
342     }
343     if (n > 0) /* go back and get it */
344     goto getready;
345     return(0); /* else poll came up empty */
346     }
347     if (r_recv_next + r_proc[pn].npending > sizeof(r_queue)/sizeof(RAY))
348     error(CONSISTENCY, "buffer shortage in ray_presult()");
349
350     /* read rendered ray data */
351     n = readbuf(r_proc[pn].fd_recv, (char *)&r_queue[r_recv_next],
352     sizeof(RAY)*r_proc[pn].npending);
353     if (n > 0) {
354     r_recv_next += n/sizeof(RAY);
355     ok = (n == sizeof(RAY)*r_proc[pn].npending);
356     } else
357     ok = 0;
358     /* reset child's status */
359     FD_CLR(r_proc[pn].fd_recv, &readset);
360     if (n <= 0)
361     FD_CLR(r_proc[pn].fd_recv, &errset);
362     r_proc[pn].npending = 0;
363 greg 2.3 ray_pnidle++;
364 greg 2.1 /* check for rendering errors */
365     if (!ok) {
366     ray_pclose(0); /* process died -- clean up */
367     return(-1);
368     }
369     /* preen returned rays */
370     for (n = r_recv_next - r_recv_first; n--; ) {
371     register RAY *rp = &r_queue[r_recv_first + n];
372     rp->rno = r_proc[pn].rno[n];
373     rp->parent = NULL;
374     rp->newcset = rp->clipset = NULL;
375     rp->rox = NULL;
376     rp->slights = NULL;
377     }
378     /* return first ray received */
379 greg 2.13 *r = r_queue[r_recv_first++];
380 greg 2.1 return(1);
381     }
382
383
384 greg 2.22 void
385 schorsch 2.6 ray_pdone( /* reap children and free data */
386     int freall
387     )
388 greg 2.1 {
389     ray_pclose(0); /* close child processes */
390
391     if (shm_boundary != NULL) { /* clear shared memory boundary */
392     free((void *)shm_boundary);
393     shm_boundary = NULL;
394     }
395 greg 2.23
396 greg 2.1 ray_done(freall); /* free rendering data */
397     }
398
399
400     static void
401 schorsch 2.6 ray_pchild( /* process rays (never returns) */
402     int fd_in,
403     int fd_out
404     )
405 greg 2.1 {
406     int n;
407     register int i;
408 greg 2.15 /* flag child process for quit() */
409     ray_pnprocs = -1;
410 greg 2.1 /* read each ray request set */
411     while ((n = read(fd_in, (char *)r_queue, sizeof(r_queue))) > 0) {
412     int n2;
413 greg 2.12 if (n < sizeof(RAY))
414 greg 2.1 break;
415     /* get smuggled set length */
416 greg 2.12 n2 = sizeof(RAY)*r_queue[0].crtype - n;
417 greg 2.1 if (n2 < 0)
418 greg 2.24 error(INTERNAL, "buffer over-read in ray_pchild()");
419 greg 2.1 if (n2 > 0) { /* read the rest of the set */
420 greg 2.12 i = readbuf(fd_in, (char *)r_queue + n, n2);
421     if (i != n2)
422 greg 2.1 break;
423     n += n2;
424     }
425 greg 2.12 n /= sizeof(RAY);
426 greg 2.1 /* evaluate rays */
427     for (i = 0; i < n; i++) {
428     r_queue[i].crtype = r_queue[i].rtype;
429     r_queue[i].parent = NULL;
430     r_queue[i].clipset = NULL;
431     r_queue[i].slights = NULL;
432 greg 2.21 r_queue[i].rlvl = 0;
433 greg 2.28 samplendx += samplestep;
434 greg 2.1 rayclear(&r_queue[i]);
435     rayvalue(&r_queue[i]);
436     }
437     /* write back our results */
438     i = writebuf(fd_out, (char *)r_queue, sizeof(RAY)*n);
439     if (i != sizeof(RAY)*n)
440 greg 2.24 error(SYSTEM, "write error in ray_pchild()");
441 greg 2.1 }
442     if (n)
443 greg 2.24 error(SYSTEM, "read error in ray_pchild()");
444 greg 2.1 ambsync();
445     quit(0); /* normal exit */
446     }
447
448
449 greg 2.22 void
450 schorsch 2.6 ray_popen( /* open the specified # processes */
451     int nadd
452     )
453 greg 2.1 {
454     /* check if our table has room */
455 greg 2.3 if (ray_pnprocs + nadd > MAX_NPROCS)
456     nadd = MAX_NPROCS - ray_pnprocs;
457 greg 2.1 if (nadd <= 0)
458     return;
459 greg 2.13 ambsync(); /* load any new ambient values */
460 greg 2.20 if (shm_boundary == NULL) { /* first child process? */
461     preload_objs(); /* preload auxiliary data */
462     /* set shared memory boundary */
463     shm_boundary = (char *)malloc(16);
464     strcpy(shm_boundary, "SHM_BOUNDARY");
465     }
466 greg 2.13 fflush(NULL); /* clear pending output */
467 greg 2.28 samplestep = ray_pnprocs + nadd;
468 greg 2.1 while (nadd--) { /* fork each new process */
469     int p0[2], p1[2];
470     if (pipe(p0) < 0 || pipe(p1) < 0)
471     error(SYSTEM, "cannot create pipe");
472 greg 2.3 if ((r_proc[ray_pnprocs].pid = fork()) == 0) {
473 greg 2.1 int pn; /* close others' descriptors */
474 greg 2.3 for (pn = ray_pnprocs; pn--; ) {
475 greg 2.1 close(r_proc[pn].fd_send);
476     close(r_proc[pn].fd_recv);
477     }
478     close(p0[0]); close(p1[1]);
479 greg 2.24 close(0); /* don't share stdin */
480 greg 2.1 /* following call never returns */
481     ray_pchild(p1[0], p0[1]);
482     }
483 greg 2.3 if (r_proc[ray_pnprocs].pid < 0)
484 greg 2.1 error(SYSTEM, "cannot fork child process");
485     close(p1[0]); close(p0[1]);
486 greg 2.28 if (rand_samp) /* decorrelate random sequence */
487     srandom(random());
488     else
489     samplendx++;
490 greg 2.9 /*
491     * Close write stream on exec to avoid multiprocessing deadlock.
492     * No use in read stream without it, so set flag there as well.
493     */
494     fcntl(p1[1], F_SETFD, FD_CLOEXEC);
495     fcntl(p0[0], F_SETFD, FD_CLOEXEC);
496 greg 2.3 r_proc[ray_pnprocs].fd_send = p1[1];
497     r_proc[ray_pnprocs].fd_recv = p0[0];
498     r_proc[ray_pnprocs].npending = 0;
499     ray_pnprocs++;
500     ray_pnidle++;
501 greg 2.1 }
502     }
503
504
505 greg 2.22 void
506 schorsch 2.6 ray_pclose( /* close one or more child processes */
507     int nsub
508     )
509 greg 2.1 {
510     static int inclose = 0;
511     RAY res;
512     /* check recursion */
513     if (inclose)
514     return;
515     inclose++;
516 greg 2.26 /* check no child / in child */
517     if (ray_pnprocs <= 0)
518     return;
519 greg 2.1 /* check argument */
520 schorsch 2.5 if ((nsub <= 0) | (nsub > ray_pnprocs))
521 greg 2.3 nsub = ray_pnprocs;
522 greg 2.1 /* clear our ray queue */
523     while (ray_presult(&res,0) > 0)
524     ;
525 greg 2.23 r_send_next = 0; /* hard reset in case of error */
526     r_recv_first = r_recv_next = RAYQLEN;
527 greg 2.1 /* clean up children */
528     while (nsub--) {
529     int status;
530 greg 2.3 ray_pnprocs--;
531     close(r_proc[ray_pnprocs].fd_send);
532 greg 2.8 if (waitpid(r_proc[ray_pnprocs].pid, &status, 0) < 0)
533     status = 127<<8;
534 greg 2.24 close(r_proc[ray_pnprocs].fd_recv);
535 greg 2.1 if (status) {
536     sprintf(errmsg,
537     "rendering process %d exited with code %d",
538 greg 2.3 r_proc[ray_pnprocs].pid, status>>8);
539 greg 2.1 error(WARNING, errmsg);
540     }
541 greg 2.3 ray_pnidle--;
542 greg 2.1 }
543     inclose--;
544     }
