1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* raypcalls.c - interface for parallel rendering using Radiance |
6 |
7 |
* External symbols declared in ray.h |
8 |
9 |
10 |
11 |
* The Radiance Software License, Version 1.0 |
12 |
13 |
* Copyright (c) 1990 - 2002 The Regents of the University of California, |
14 |
* through Lawrence Berkeley National Laboratory. All rights reserved. |
15 |
16 |
* Redistribution and use in source and binary forms, with or without |
17 |
* modification, are permitted provided that the following conditions |
18 |
* are met: |
19 |
20 |
* 1. Redistributions of source code must retain the above copyright |
21 |
* notice, this list of conditions and the following disclaimer. |
22 |
23 |
* 2. Redistributions in binary form must reproduce the above copyright |
24 |
* notice, this list of conditions and the following disclaimer in |
25 |
* the documentation and/or other materials provided with the |
26 |
* distribution. |
27 |
28 |
* 3. The end-user documentation included with the redistribution, |
29 |
* if any, must include the following acknowledgment: |
30 |
* "This product includes Radiance software |
31 |
* (http://radsite.lbl.gov/) |
32 |
* developed by the Lawrence Berkeley National Laboratory |
33 |
* (http://www.lbl.gov/)." |
34 |
* Alternately, this acknowledgment may appear in the software itself, |
35 |
* if and wherever such third-party acknowledgments normally appear. |
36 |
37 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory" |
38 |
* and "The Regents of the University of California" must |
39 |
* not be used to endorse or promote products derived from this |
40 |
* software without prior written permission. For written |
41 |
* permission, please contact [email protected]. |
42 |
43 |
* 5. Products derived from this software may not be called "Radiance", |
44 |
* nor may "Radiance" appear in their name, without prior written |
45 |
* permission of Lawrence Berkeley National Laboratory. |
46 |
47 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED |
48 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES |
49 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE |
50 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR |
51 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, |
52 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT |
53 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF |
54 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND |
55 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, |
56 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT |
57 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF |
58 |
* SUCH DAMAGE. |
59 |
60 |
61 |
* This software consists of voluntary contributions made by many |
62 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more |
63 |
* information on Lawrence Berkeley National Laboratory, please see |
64 |
* <http://www.lbl.gov/>. |
65 |
66 |
67 |
68 |
* These calls are designed similarly to the ones in raycalls.c, |
69 |
* but allow for multiple rendering processes on the same host |
70 |
* machine. There is no sense in specifying more child processes |
71 |
* than you have processors, but one child may help by allowing |
72 |
* asynchronous ray computation in an interactive program, and |
73 |
* will protect the caller from fatal rendering errors. |
74 |
75 |
* You should first read and undrstand the header in raycalls.c, |
76 |
* as some things are explained there that are not repated here. |
77 |
78 |
* The first step is opening one or more rendering processes |
79 |
* with a call to ray_pinit(oct, nproc). Before calling fork(), |
80 |
* ray_pinit() loads the octree and data structures into the |
81 |
* caller's memory. This permits all sorts of queries that |
82 |
* wouldn't be possible otherwise, without causing any real |
83 |
* memory overhead, since all the static data are shared |
84 |
* between processes. Rays are then traced using a simple |
85 |
* queuing mechanism, explained below. |
86 |
87 |
* The ray queue holds as many rays as there are rendering |
88 |
* processes. Rays are queued and returned by a single |
89 |
* ray_pqueue() call. A ray_pqueue() return |
90 |
* value of 0 indicates that no rays are ready |
91 |
* and the queue is not yet full. A return value of 1 |
92 |
* indicates that a ray was returned, though it is probably |
93 |
* not the one you just requested. Rays may be identified by |
94 |
* the rno member of the RAY struct, which is incremented |
95 |
* by the rayorigin() call, or may be set explicitly by |
96 |
* the caller. Below is an example call sequence: |
97 |
98 |
* myRay.rorg = ( ray origin point ) |
99 |
* myRay.rdir = ( normalized ray direction ) |
100 |
* myRay.rmax = ( maximum length, or zero for no limit ) |
101 |
* rayorigin(&myRay, NULL, PRIMARY, 1.0); |
102 |
* myRay.rno = ( my personal ray identifier ) |
103 |
* if (ray_pqueue(&myRay) == 1) |
104 |
* { do something with results } |
105 |
106 |
* Note the differences between this and the simpler ray_trace() |
107 |
* call. In particular, the call may or may not return a value |
108 |
* in the passed ray structure. Also, you need to call rayorigin() |
109 |
* yourself, which is normally for you by ray_trace(). The |
110 |
* great thing is that ray_pqueue() will trace rays faster in |
111 |
* proportion to the number of CPUs you have available on your |
112 |
* system. If the ray queue is full before the call, ray_pqueue() |
113 |
* will block until a result is ready so it can queue this one. |
114 |
* The global int ray_idle indicates the number of currently idle |
115 |
* children. If you want to check for completed rays without blocking, |
116 |
* or get the results from rays that have been queued without |
117 |
* queuing any new ones, the ray_presult() call is for you: |
118 |
119 |
* if (ray_presult(&myRay, 1) == 1) |
120 |
121 |
122 |
* If the second argument is 1, the call won't block when |
123 |
* results aren't ready, but will immediately return 0. |
124 |
* If the second argument is 0, the call will block |
125 |
* until a value is available, returning 0 only if the |
126 |
* queue is completely empty. A negative return value |
127 |
* indicates that a rendering process died. If this |
128 |
* happens, ray_close(0) is automatically called to close |
129 |
* all child processes, and ray_nprocs is set to zero. |
130 |
131 |
* If you just want to fill the ray queue without checking for |
132 |
* results, check ray_idle and call ray_psend(): |
133 |
134 |
* while (ray_idle) { |
135 |
* ( set up ray ) |
136 |
* ray_psend(&myRay); |
137 |
138 |
139 |
* The ray_presult() and/or ray_pqueue() functions may then be |
140 |
* called to read back the results. |
141 |
142 |
* When you are done, you may call ray_pdone(1) to close |
143 |
* all child processes and clean up memory used by Radiance. |
144 |
* Any queued ray calculations will be awaited and discarded. |
145 |
* As with ray_done(), ray_pdone(0) hangs onto data files |
146 |
* and fonts that are likely to be used in subsequent renderings. |
147 |
* Whether you want to bother cleaning up memory or not, you |
148 |
* should at least call ray_pclose(0) to clean the child processes. |
149 |
150 |
* Warning: You cannot affect any of the rendering processes |
151 |
* by changing global parameter values onece ray_pinit() has |
152 |
* been called. Changing global parameters will have no effect |
153 |
* until the next call to ray_pinit(), which restarts everything. |
154 |
* If you just want to reap children so that you can alter the |
155 |
* rendering parameters without reloading the scene, use the |
156 |
* ray_pclose(0) and ray_popen(nproc) calls to close |
157 |
* then restart the child processes. |
158 |
159 |
* Note: These routines are written to coordinate with the |
160 |
* definitions in raycalls.c, and in fact depend on them. |
161 |
* If you want to trace a ray and get a result synchronously, |
162 |
* use the ray_trace() call to compute it in the parent process. |
163 |
164 |
* Note: One of the advantages of using separate processes |
165 |
* is that it gives the calling program some immunity from |
166 |
* fatal rendering errors. As discussed in raycalls.c, |
167 |
* Radiance tends to throw up its hands and exit at the |
168 |
* first sign of trouble, calling quit() to return control |
169 |
* to the system. Although you can avoid exit() with |
170 |
* your own longjmp() in quit(), the cleanup afterwards |
171 |
* is always suspect. Through the use of subprocesses, |
172 |
* we avoid this pitfall by closing the processes and |
173 |
* returning a negative value from ray_pqueue() or |
174 |
* ray_presult(). If you get a negative value from either |
175 |
* of these calls, you can assume that the processes have |
176 |
* been cleaned up with a call to ray_close(), though you |
177 |
* will have to call ray_pdone() yourself if you want to |
178 |
* free memory. Obviously, you cannot continue rendering, |
179 |
* but otherwise your process should not be compromised. |
180 |
181 |
182 |
#include "ray.h" |
183 |
184 |
#include "selcall.h" |
185 |
186 |
#ifndef RAYQLEN |
187 |
#define RAYQLEN 16 /* # rays to send at once */ |
188 |
#endif |
189 |
190 |
#ifndef MAX_RPROCS |
191 |
#if (FD_SETSIZE/2-4 < 64) |
192 |
#define MAX_NPROCS (FD_SETSIZE/2-4) |
193 |
#else |
194 |
#define MAX_NPROCS 64 /* max. # rendering processes */ |
195 |
#endif |
196 |
#endif |
197 |
198 |
extern char *shm_boundary; /* boundary of shared memory */ |
199 |
200 |
int ray_nprocs = 0; /* number of child processes */ |
201 |
int ray_idle = 0; /* number of idle children */ |
202 |
203 |
static struct child_proc { |
204 |
int pid; /* child process id */ |
205 |
int fd_send; /* write to child here */ |
206 |
int fd_recv; /* read from child here */ |
207 |
int npending; /* # rays in process */ |
208 |
unsigned long rno[RAYQLEN]; /* working on these rays */ |
209 |
} r_proc[MAX_NPROCS]; /* our child processes */ |
210 |
211 |
static RAY r_queue[2*RAYQLEN]; /* ray i/o buffer */ |
212 |
static int r_send_next; /* next send ray placement */ |
213 |
static int r_recv_first; /* position of first unreported ray */ |
214 |
static int r_recv_next; /* next receive ray placement */ |
215 |
216 |
#define sendq_full() (r_send_next >= RAYQLEN) |
217 |
218 |
219 |
void |
220 |
ray_pinit(otnm, nproc) /* initialize ray-tracing processes */ |
221 |
char *otnm; |
222 |
int nproc; |
223 |
224 |
if (nobjects > 0) /* close old calculation */ |
225 |
ray_pdone(0); |
226 |
227 |
ray_init(otnm); /* load the shared scene */ |
228 |
229 |
preload_objs(); /* preload auxiliary data */ |
230 |
231 |
/* set shared memory boundary */ |
232 |
shm_boundary = (char *)malloc(16); |
233 |
strcpy(shm_boundary, "SHM_BOUNDARY"); |
234 |
235 |
r_send_next = 0; /* set up queue */ |
236 |
r_recv_first = r_recv_next = RAYQLEN; |
237 |
238 |
ray_popen(nproc); /* fork children */ |
239 |
240 |
241 |
242 |
static int |
243 |
ray_pflush() /* send queued rays to idle children */ |
244 |
245 |
int nc, n, nw, i, sfirst; |
246 |
247 |
if ((ray_idle <= 0 | r_send_next <= 0)) |
248 |
return(0); /* nothing we can send */ |
249 |
250 |
sfirst = 0; /* divvy up labor */ |
251 |
nc = ray_idle; |
252 |
for (i = ray_nprocs; nc && i--; ) { |
253 |
if (r_proc[i].npending > 0) |
254 |
continue; /* child looks busy */ |
255 |
n = (r_send_next - sfirst)/nc--; |
256 |
if (!n) |
257 |
continue; |
258 |
/* smuggle set size in crtype */ |
259 |
r_queue[sfirst].crtype = n; |
260 |
nw = writebuf(r_proc[i].fd_send, (char *)&r_queue[sfirst], |
261 |
sizeof(RAY)*n); |
262 |
if (nw != sizeof(RAY)*n) |
263 |
return(-1); /* write error */ |
264 |
r_proc[i].npending = n; |
265 |
while (n--) /* record ray IDs */ |
266 |
r_proc[i].rno[n] = r_queue[sfirst+n].rno; |
267 |
sfirst += r_proc[i].npending; |
268 |
ray_idle--; /* now she's busy */ |
269 |
270 |
if (sfirst != r_send_next) |
271 |
error(CONSISTENCY, "code screwup in ray_pflush"); |
272 |
r_send_next = 0; |
273 |
return(sfirst); /* return total # sent */ |
274 |
275 |
276 |
277 |
void |
278 |
ray_psend(r) /* add a ray to our send queue */ |
279 |
RAY *r; |
280 |
281 |
if (r == NULL) |
282 |
return; |
283 |
/* flush output if necessary */ |
284 |
if (sendq_full() && ray_pflush() <= 0) |
285 |
error(INTERNAL, "ray_pflush failed in ray_psend"); |
286 |
287 |
copystruct(&r_queue[r_send_next], r); |
288 |
r_send_next++; |
289 |
290 |
291 |
292 |
int |
293 |
ray_pqueue(r) /* queue a ray for computation */ |
294 |
RAY *r; |
295 |
296 |
if (r == NULL) |
297 |
return(0); |
298 |
/* check for full send queue */ |
299 |
if (sendq_full()) { |
300 |
RAY mySend; |
301 |
int rval; |
302 |
copystruct(&mySend, r); |
303 |
/* wait for a result */ |
304 |
rval = ray_presult(r, 0); |
305 |
/* put new ray in queue */ |
306 |
copystruct(&r_queue[r_send_next], &mySend); |
307 |
r_send_next++; |
308 |
return(rval); /* done */ |
309 |
310 |
/* add ray to send queue */ |
311 |
312 |
r_send_next++; |
313 |
/* check for returned ray... */ |
314 |
if (r_recv_first >= r_recv_next) |
315 |
return(0); |
316 |
/* ...one is sitting in queue */ |
317 |
copystruct(r, &r_queue[r_recv_first]); |
318 |
r_recv_first++; |
319 |
return(1); |
320 |
321 |
322 |
323 |
int |
324 |
ray_presult(r, poll) /* check for a completed ray */ |
325 |
RAY *r; |
326 |
int poll; |
327 |
328 |
static struct timeval tpoll; /* zero timeval struct */ |
329 |
static fd_set readset, errset; |
330 |
int n, ok; |
331 |
register int pn; |
332 |
333 |
if (r == NULL) |
334 |
return(0); |
335 |
/* check queued results first */ |
336 |
if (r_recv_first < r_recv_next) { |
337 |
338 |
r_recv_first++; |
339 |
return(1); |
340 |
341 |
n = ray_nprocs - ray_idle; /* pending before flush? */ |
342 |
343 |
if (ray_pflush() < 0) /* send new rays to process */ |
344 |
return(-1); |
345 |
/* reset receive queue */ |
346 |
347 |
348 |
if (!poll) /* count newly sent unless polling */ |
349 |
n = ray_nprocs - ray_idle; |
350 |
if (n <= 0) /* return if nothing to await */ |
351 |
return(0); |
352 |
getready: /* any children waiting for us? */ |
353 |
for (pn = ray_nprocs; pn--; ) |
354 |
if (FD_ISSET(r_proc[pn].fd_recv, &readset) || |
355 |
FD_ISSET(r_proc[pn].fd_recv, &errset)) |
356 |
break; |
357 |
/* call select if we must */ |
358 |
if (pn < 0) { |
359 |
FD_ZERO(&readset); FD_ZERO(&errset); n = 0; |
360 |
for (pn = ray_nprocs; pn--; ) { |
361 |
if (r_proc[pn].npending > 0) |
362 |
FD_SET(r_proc[pn].fd_recv, &readset); |
363 |
FD_SET(r_proc[pn].fd_recv, &errset); |
364 |
if (r_proc[pn].fd_recv >= n) |
365 |
n = r_proc[pn].fd_recv + 1; |
366 |
367 |
/* find out who is ready */ |
368 |
while ((n = select(n, &readset, (fd_set *)NULL, &errset, |
369 |
poll ? &tpoll : (struct timeval *)NULL)) < 0) |
370 |
if (errno != EINTR) { |
371 |
error(WARNING, |
372 |
"select call failed in ray_presult"); |
373 |
ray_pclose(0); |
374 |
return(-1); |
375 |
376 |
if (n > 0) /* go back and get it */ |
377 |
goto getready; |
378 |
return(0); /* else poll came up empty */ |
379 |
380 |
if (r_recv_next + r_proc[pn].npending > sizeof(r_queue)/sizeof(RAY)) |
381 |
error(CONSISTENCY, "buffer shortage in ray_presult()"); |
382 |
383 |
/* read rendered ray data */ |
384 |
n = readbuf(r_proc[pn].fd_recv, (char *)&r_queue[r_recv_next], |
385 |
sizeof(RAY)*r_proc[pn].npending); |
386 |
if (n > 0) { |
387 |
r_recv_next += n/sizeof(RAY); |
388 |
ok = (n == sizeof(RAY)*r_proc[pn].npending); |
389 |
} else |
390 |
ok = 0; |
391 |
/* reset child's status */ |
392 |
FD_CLR(r_proc[pn].fd_recv, &readset); |
393 |
if (n <= 0) |
394 |
FD_CLR(r_proc[pn].fd_recv, &errset); |
395 |
r_proc[pn].npending = 0; |
396 |
ray_idle++; |
397 |
/* check for rendering errors */ |
398 |
if (!ok) { |
399 |
ray_pclose(0); /* process died -- clean up */ |
400 |
return(-1); |
401 |
402 |
/* preen returned rays */ |
403 |
for (n = r_recv_next - r_recv_first; n--; ) { |
404 |
register RAY *rp = &r_queue[r_recv_first + n]; |
405 |
rp->rno = r_proc[pn].rno[n]; |
406 |
rp->parent = NULL; |
407 |
rp->newcset = rp->clipset = NULL; |
408 |
rp->rox = NULL; |
409 |
rp->slights = NULL; |
410 |
411 |
/* return first ray received */ |
412 |
413 |
r_recv_first++; |
414 |
return(1); |
415 |
416 |
417 |
418 |
void |
419 |
ray_pdone(freall) /* reap children and free data */ |
420 |
int freall; |
421 |
422 |
ray_pclose(0); /* close child processes */ |
423 |
424 |
if (shm_boundary != NULL) { /* clear shared memory boundary */ |
425 |
free((void *)shm_boundary); |
426 |
shm_boundary = NULL; |
427 |
428 |
ray_done(freall); /* free rendering data */ |
429 |
430 |
431 |
432 |
static void |
433 |
ray_pchild(fd_in, fd_out) /* process rays (never returns) */ |
434 |
int fd_in; |
435 |
int fd_out; |
436 |
437 |
int n; |
438 |
register int i; |
439 |
/* read each ray request set */ |
440 |
while ((n = read(fd_in, (char *)r_queue, sizeof(r_queue))) > 0) { |
441 |
int n2; |
442 |
if (n % sizeof(RAY)) |
443 |
break; |
444 |
n /= sizeof(RAY); |
445 |
/* get smuggled set length */ |
446 |
n2 = r_queue[0].crtype - n; |
447 |
if (n2 < 0) |
448 |
error(INTERNAL, "buffer over-read in ray_pchild"); |
449 |
if (n2 > 0) { /* read the rest of the set */ |
450 |
i = readbuf(fd_in, (char *)(r_queue+n), |
451 |
sizeof(RAY)*n2); |
452 |
if (i != sizeof(RAY)*n2) |
453 |
break; |
454 |
n += n2; |
455 |
456 |
/* evaluate rays */ |
457 |
for (i = 0; i < n; i++) { |
458 |
r_queue[i].crtype = r_queue[i].rtype; |
459 |
r_queue[i].parent = NULL; |
460 |
r_queue[i].clipset = NULL; |
461 |
r_queue[i].slights = NULL; |
462 |
r_queue[i].revf = raytrace; |
463 |
samplendx++; |
464 |
rayclear(&r_queue[i]); |
465 |
rayvalue(&r_queue[i]); |
466 |
467 |
/* write back our results */ |
468 |
i = writebuf(fd_out, (char *)r_queue, sizeof(RAY)*n); |
469 |
if (i != sizeof(RAY)*n) |
470 |
error(SYSTEM, "write error in ray_pchild"); |
471 |
472 |
if (n) |
473 |
error(SYSTEM, "read error in ray_pchild"); |
474 |
ambsync(); |
475 |
quit(0); /* normal exit */ |
476 |
477 |
478 |
479 |
void |
480 |
ray_popen(nadd) /* open the specified # processes */ |
481 |
int nadd; |
482 |
483 |
/* check if our table has room */ |
484 |
if (ray_nprocs + nadd > MAX_NPROCS) |
485 |
nadd = MAX_NPROCS - ray_nprocs; |
486 |
if (nadd <= 0) |
487 |
return; |
488 |
fflush(stderr); /* clear pending output */ |
489 |
fflush(stdout); |
490 |
while (nadd--) { /* fork each new process */ |
491 |
int p0[2], p1[2]; |
492 |
if (pipe(p0) < 0 || pipe(p1) < 0) |
493 |
error(SYSTEM, "cannot create pipe"); |
494 |
if ((r_proc[ray_nprocs].pid = fork()) == 0) { |
495 |
int pn; /* close others' descriptors */ |
496 |
497 |
close(r_proc[pn].fd_send); |
498 |
close(r_proc[pn].fd_recv); |
499 |
500 |
close(p0[0]); close(p1[1]); |
501 |
/* following call never returns */ |
502 |
ray_pchild(p1[0], p0[1]); |
503 |
504 |
if (r_proc[ray_nprocs].pid < 0) |
505 |
error(SYSTEM, "cannot fork child process"); |
506 |
close(p1[0]); close(p0[1]); |
507 |
r_proc[ray_nprocs].fd_send = p1[1]; |
508 |
r_proc[ray_nprocs].fd_recv = p0[0]; |
509 |
r_proc[ray_nprocs].npending = 0; |
510 |
ray_nprocs++; |
511 |
ray_idle++; |
512 |
513 |
514 |
515 |
516 |
void |
517 |
ray_pclose(nsub) /* close one or more child processes */ |
518 |
int nsub; |
519 |
520 |
static int inclose = 0; |
521 |
RAY res; |
522 |
/* check recursion */ |
523 |
if (inclose) |
524 |
return; |
525 |
inclose++; |
526 |
/* check argument */ |
527 |
if ((nsub <= 0 | nsub > ray_nprocs)) |
528 |
nsub = ray_nprocs; |
529 |
/* clear our ray queue */ |
530 |
while (ray_presult(&res,0) > 0) |
531 |
532 |
/* clean up children */ |
533 |
while (nsub--) { |
534 |
int status; |
535 |
ray_nprocs--; |
536 |
close(r_proc[ray_nprocs].fd_recv); |
537 |
close(r_proc[ray_nprocs].fd_send); |
538 |
while (wait(&status) != r_proc[ray_nprocs].pid) |
539 |
540 |
if (status) { |
541 |
sprintf(errmsg, |
542 |
"rendering process %d exited with code %d", |
543 |
r_proc[ray_nprocs].pid, status>>8); |
544 |
error(WARNING, errmsg); |
545 |
546 |
ray_idle--; |
547 |
548 |
inclose--; |
549 |
550 |
551 |
552 |
void |
553 |
quit(ec) /* make sure exit is called */ |
554 |
int ec; |
555 |
556 |
exit(ec); |
557 |
