root/Development/ray/src/rt/raypcalls.c
Wed Aug 21 20:42:20 2024 UTC (14 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.39: +3 -13 lines
Diff to previous 2.39 , to selected 2.19
refactor: moved memory sharing routines to preload.c with common call interface
Tue Jul 2 23:54:16 2024 UTC (16 months, 1 week ago) by greg
Changes since 2.38: +4 -4 lines
Diff to previous 2.38 , to selected 2.19
feat(rpict): Made drawsources() compatible with spectral scanlines
Tue Apr 30 22:25:46 2024 UTC (18 months, 1 week ago) by greg
Changes since 2.37: +3 -1 lines
Diff to previous 2.37 , to selected 2.19
feat(rtrace): Improved diagnostic output
Sat Apr 6 00:30:30 2024 UTC (19 months ago) by greg
Changes since 2.36: +9 -4 lines
Diff to previous 2.36 , to selected 2.19
fix: Avoid infinite loop with lost child and improved lost ray warning
Sat Apr 6 00:00:22 2024 UTC (19 months ago) by greg
Changes since 2.35: +7 -3 lines
Diff to previous 2.35 , to selected 2.19
feat: Added warning messages for lost rays in ray_pclose()
Thu Feb 2 20:32:59 2023 UTC (2 years, 9 months ago) by greg
Changes since 2.34: +4 -4 lines
Diff to previous 2.34 , to selected 2.19
fix: fixed inappropriate location for recursion check
Tue Jun 16 17:58:11 2020 UTC (5 years, 4 months ago) by greg
Changes since 2.33: +2 -7 lines
Diff to previous 2.33 , to selected 2.19
Backed out last change, which actually made things worse
Mon Jun 15 15:44:03 2020 UTC (5 years, 4 months ago) by greg
Changes since 2.32: +7 -2 lines
Diff to previous 2.32 , to selected 2.19
Optimize rtrace for throughput, especially with ambient cache
Thu Apr 30 19:30:48 2020 UTC (5 years, 6 months ago) by greg
Diff to previous 2.31 , to selected 2.19
Decreased queue size again as it seems to give better performance with FIFO
Mon Apr 6 21:49:16 2020 UTC (5 years, 7 months ago) by greg
Diff to previous 2.30 , to selected 2.19
Increased queue size to improve thoughput and irradiace cache behavior
Fri Apr 19 16:28:57 2019 UTC (6 years, 6 months ago) by greg
Diff to previous 2.29 , to selected 2.19
Eliminated outdated "register" directives
Fri Mar 4 02:48:14 2016 UTC (9 years, 8 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.28: +27 -16 lines
Diff to previous 2.28 , to selected 2.19
Made quitting rvu, rholo and rcontrib quicker with multiple processes on Unix
Sat Aug 20 18:23:38 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.27: +9 -4 lines
Diff to previous 2.27 , to selected 2.19
Improved random sampling
Sat Aug 20 06:05:53 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26 , to selected 2.19
Added reinitialization of random number generator in child processes with -u+
Wed Dec 16 01:06:50 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.25: +7 -4 lines
Diff to previous 2.25 , to selected 2.19
Added check for calling ray_pclose() in child
Tue Dec 15 18:21:53 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.24: +15 -10 lines
Diff to previous 2.24 , to selected 2.19
Final fix to problem of queue overflow (I hope)
Sat Dec 12 23:08:13 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.23: +9 -8 lines
Diff to previous 2.23 , to selected 2.19
Bug fixes and performance improvements to rtrace -n option
Sat Dec 12 19:01:00 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.22: +14 -17 lines
Diff to previous 2.22 , to selected 2.19
Sat Dec 12 05:20:10 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.21: +10 -11 lines
Diff to previous 2.21 , to selected 2.19
Sat Dec 12 00:03:42 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.20: +15 -11 lines
Diff to previous 2.20 , to selected 2.19
Tue Dec 2 23:28:34 2008 UTC (16 years, 11 months ago) by greg
Changes since 2.19: +7 -7 lines
Diff to previous 2.19
Delayed loading of object data until it is needed
Revision 2.19 - (view) (download) (annotate) - [selected]
Wed Feb 20 05:21:29 2008 UTC (17 years, 8 months ago) by greg
Changes since 2.18: +6 -9 lines
Diff to previous 2.18
Changed back to old queuing behavior
Fri Feb 8 18:27:31 2008 UTC (17 years, 9 months ago) by greg
Changes since 2.17: +3 -5 lines
Diff to previous 2.17 , to selected 2.19
Created stub routines as placeholder for Windows version of raypcalls
Tue Sep 18 19:10:02 2007 UTC (18 years, 1 month ago) by greg
Diff to previous 2.16 , to selected 2.19
Fixed potential bug where send queue gets jammed in ray_pqueue()
Sat Sep 15 02:47:56 2007 UTC (18 years, 2 months ago) by greg
Changes since 2.15: +4 -1 lines
Diff to previous 2.15 , to selected 2.19
Eliminated unnecessary call to select(2) for single process
Wed Sep 12 03:57:00 2007 UTC (18 years, 2 months ago) by greg
Changes since 2.14: +5 -1 lines
Diff to previous 2.14 , to selected 2.19
Added check for parent process to close children before exit
Wed Dec 21 17:36:06 2005 UTC (19 years, 10 months ago) by greg
Changes since 2.13: +9 -13 lines
Diff to previous 2.13 , to selected 2.19
Minor cosmetic changes
Tue Dec 20 20:36:44 2005 UTC (19 years, 10 months ago) by greg
Changes since 2.12: +14 -13 lines
Diff to previous 2.12 , to selected 2.19
Added ambient file synchronization and minor fixes
Sat Dec 17 22:17:51 2005 UTC (19 years, 10 months ago) by greg
Changes since 2.11: +6 -7 lines
Diff to previous 2.11 , to selected 2.19
Fixed bug in reading of ray buffers
Tue Apr 19 01:15:06 2005 UTC (20 years, 6 months ago) by greg
Diff to previous 2.10 , to selected 2.19
Fri Apr 15 04:44:51 2005 UTC (20 years, 7 months ago) by greg
Diff to previous 2.9 , to selected 2.19
Mon Sep 20 16:26:58 2004 UTC (21 years, 1 month ago) by greg
Diff to previous 2.8 , to selected 2.19
Fri Sep 17 21:43:50 2004 UTC (21 years, 1 month ago) by greg
Diff to previous 2.7 , to selected 2.19
Fri Sep 17 14:27:33 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.6: +14 -10 lines
Diff to previous 2.6 , to selected 2.19
Fixed up comments in header
Tue Mar 30 16:13:01 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.5: +45 -29 lines
Diff to previous 2.5 , to selected 2.19
Sun Jul 27 22:12:03 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 2.4 , to selected 2.19
Mon Jul 21 22:30:19 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 2.3: +8 -8 lines
Diff to previous 2.3 , to selected 2.19
Thu Jul 3 15:00:19 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.2: +34 -34 lines
Diff to previous 2.2 , to selected 2.19
Tue Feb 25 02:47:23 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.1 , to selected 2.19
Sat Feb 22 02:07:29 2003 UTC (22 years, 8 months ago) by greg
Diff to selected 2.19
