root/radiance/ray/src/rt/raypcalls.c
Revision: 2.17
Committed: Tue Sep 18 19:10:02 2007 UTC (17 years, 11 months ago) by greg
Fixed potential bug where send queue gets jammed in ray_pqueue()
2 static const char RCSid[] = "$Id: raypcalls.c,v 2.16 2007/09/15 02:47:56 greg Exp $";
5 * raypcalls.c - interface for parallel rendering using Radiance
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These calls are designed similarly to the ones in raycalls.c,
14 * but allow for multiple rendering processes on the same host
15 * machine. There is no sense in specifying more child processes
16 * than you have processors, but one child may help by allowing
17 * asynchronous ray computation in an interactive program, and
18 * will protect the caller from fatal rendering errors.
19 *
20 * You should first read and undrstand the header in raycalls.c,
21 * as some things are explained there that are not repated here.
22 *
23 * The first step is opening one or more rendering processes
24 * with a call to ray_pinit(oct, nproc). Before calling fork(),
25 * ray_pinit() loads the octree and data structures into the
26 * caller's memory, and ray_popen() synchronizes the ambient
27 * file, if any. Shared memory permits all sorts of queries
28 * that wouldn't be possible otherwise, without causing any real
29 * memory overhead, since all the static data are shared
30 * between processes. Rays are then traced using a simple
31 * queuing mechanism, explained below.
32 *
33 * The ray queue buffers RAYQLEN rays before sending to
34 * children, each of which may internally buffer RAYQLEN rays.
35 *
36 * Rays are queued and returned by a single
37 * ray_pqueue() call. A ray_pqueue() return
38 * value of 0 indicates that no rays are ready
39 * and the queue is not yet full. A return value of 1
40 * indicates that a ray was returned, though it is probably
41 * not the one you just requested. Rays may be identified by
42 * the rno member of the RAY struct, which is incremented
43 * by the rayorigin() call, or may be set explicitly by
44 * the caller. Below is an example call sequence:
45 *
46 * myRay.rorg = ( ray origin point )
47 * myRay.rdir = ( normalized ray direction )
48 * myRay.rmax = ( maximum length, or zero for no limit )
49 * rayorigin(&myRay, PRIMARY, NULL, NULL);
50 * myRay.rno = ( my personal ray identifier )
51 * if (ray_pqueue(&myRay) == 1)
52 * { do something with results }
53 *
54 * Note the differences between this and the simpler ray_trace()
55 * call. In particular, the call may or may not return a value
56 * in the passed ray structure. Also, you need to call rayorigin()
57 * yourself, which is normally called for you by ray_trace(). The
58 * benefit is that ray_pqueue() will trace rays faster in
59 * proportion to the number of CPUs you have available on your
60 * system. If the ray queue is full before the call, ray_pqueue()
61 * will block until a result is ready so it can queue this one.
62 * The global int ray_pnidle indicates the number of currently idle
63 * children. If you want to check for completed rays without blocking,
64 * or get the results from rays that have been queued without
65 * queuing any new ones, the ray_presult() call is for you:
66 *
67 * if (ray_presult(&myRay, 1) == 1)
68 * { do something with results }
69 *
70 * If the second argument is 1, the call won't block when
71 * results aren't ready, but will immediately return 0.
72 * If the second argument is 0, the call will block
73 * until a value is available, returning 0 only if the
74 * queue is completely empty. A negative return value
75 * indicates that a rendering process died. If this
76 * happens, ray_close(0) is automatically called to close
77 * all child processes, and ray_pnprocs is set to zero.
78 *
79 * If you just want to fill the ray queue without checking for
80 * results, check ray_pnidle and call ray_psend():
81 *
82 * while (ray_pnidle) {
83 * ( set up ray )
84 * ray_psend(&myRay);
85 * }
86 *
87 * Note that it is a fatal error to call ra_psend() when
88 * ray_pnidle is zero. The ray_presult() and/or ray_pqueue()
89 * functions may be called subsequently to read back the results.
90 *
91 * When you are done, you may call ray_pdone(1) to close
92 * all child processes and clean up memory used by Radiance.
93 * Any queued ray calculations will be awaited and discarded.
94 * As with ray_done(), ray_pdone(0) hangs onto data files
95 * and fonts that are likely to be used in subsequent renderings.
96 * Whether you want to bother cleaning up memory or not, you
97 * should at least call ray_pclose(0) to clean the child processes.
98 *
99 * Warning: You cannot affect any of the rendering processes
100 * by changing global parameter values onece ray_pinit() has
101 * been called. Changing global parameters will have no effect
102 * until the next call to ray_pinit(), which restarts everything.
103 * If you just want to reap children so that you can alter the
104 * rendering parameters without reloading the scene, use the
105 * ray_pclose(0) and ray_popen(nproc) calls to close
106 * then restart the child processes after the changes are made.
107 *
108 * Note: These routines are written to coordinate with the
109 * definitions in raycalls.c, and in fact depend on them.
110 * If you want to trace a ray and get a result synchronously,
111 * use the ray_trace() call to compute it in the parent process.
112 * This will not interfere with any subprocess calculations,
113 * but beware that a fatal error may end with a call to quit().
114 *
115 * Note: One of the advantages of using separate processes
116 * is that it gives the calling program some immunity from
117 * fatal rendering errors. As discussed in raycalls.c,
118 * Radiance tends to throw up its hands and exit at the
119 * first sign of trouble, calling quit() to return control
120 * to the top level. Although you can avoid exit() with
121 * your own longjmp() in quit(), the cleanup afterwards
122 * is always suspect. Through the use of subprocesses,
123 * we avoid this pitfall by closing the processes and
124 * returning a negative value from ray_pqueue() or
125 * ray_presult(). If you get a negative value from either
126 * of these calls, you can assume that the processes have
127 * been cleaned up with a call to ray_close(), though you
128 * will have to call ray_pdone() yourself if you want to
129 * free memory. Obviously, you cannot continue rendering
130 * without risking further errors, but otherwise your
131 * process should not be compromised.
132 */
133
134 #include <stdio.h>
135 #include <sys/types.h>
136 #include <sys/wait.h> /* XXX platform */
137
138 #include "rtprocess.h"
139 #include "ray.h"
140 #include "ambient.h"
141 #include "selcall.h"
142
143 #ifndef RAYQLEN
144 #define RAYQLEN 12 /* # rays to send at once */
145 #endif
146
147 #ifndef MAX_RPROCS
148 #if (FD_SETSIZE/2-4 < 64)
149 #define MAX_NPROCS (FD_SETSIZE/2-4)
150 #else
151 #define MAX_NPROCS 64 /* max. # rendering processes */
152 #endif
153 #endif
154
155 extern char *shm_boundary; /* boundary of shared memory */
156
157 int ray_pnprocs = 0; /* number of child processes */
158 int ray_pnidle = 0; /* number of idle children */
159
160 static struct child_proc {
161 int pid; /* child process id */
162 int fd_send; /* write to child here */
163 int fd_recv; /* read from child here */
164 int npending; /* # rays in process */
165 unsigned long rno[RAYQLEN]; /* working on these rays */
166 } r_proc[MAX_NPROCS]; /* our child processes */
167
168 static RAY r_queue[2*RAYQLEN]; /* ray i/o buffer */
169 static int r_send_next; /* next send ray placement */
170 static int r_recv_first; /* position of first unreported ray */
171 static int r_recv_next; /* next receive ray placement */
172
173 #define sendq_full() (r_send_next >= RAYQLEN)
174
175 static int ray_pflush(void);
176 static void ray_pchild(int fd_in, int fd_out);
177
178
179 extern void
180 ray_pinit( /* initialize ray-tracing processes */
181 char *otnm,
182 int nproc
183 )
184 {
185 if (nobjects > 0) /* close old calculation */
186 ray_pdone(0);
187
188 ray_init(otnm); /* load the shared scene */
189
190 preload_objs(); /* preload auxiliary data */
191
192 /* set shared memory boundary */
193 shm_boundary = (char *)malloc(16);
194 strcpy(shm_boundary, "SHM_BOUNDARY");
195
196 r_send_next = 0; /* set up queue */
197 r_recv_first = r_recv_next = RAYQLEN;
198
199 ray_popen(nproc); /* fork children */
200 }
201
202
203 static int
204 ray_pflush(void) /* send queued rays to idle children */
205 {
206 int nc, n, nw, i, sfirst;
207
208 if ((ray_pnidle <= 0) | (r_send_next <= 0))
209 return(0); /* nothing we can send */
210
211 sfirst = 0; /* divvy up labor */
212 nc = ray_pnidle;
213 for (i = ray_pnprocs; nc && i--; ) {
214 if (r_proc[i].npending > 0)
215 continue; /* child looks busy */
216 n = (r_send_next - sfirst)/nc--;
217 if (!n)
218 continue;
219 /* smuggle set size in crtype */
220 r_queue[sfirst].crtype = n;
221 nw = writebuf(r_proc[i].fd_send, (char *)&r_queue[sfirst],
222 sizeof(RAY)*n);
223 if (nw != sizeof(RAY)*n)
224 return(-1); /* write error */
225 r_proc[i].npending = n;
226 while (n--) /* record ray IDs */
227 r_proc[i].rno[n] = r_queue[sfirst+n].rno;
228 sfirst += r_proc[i].npending;
229 ray_pnidle--; /* now she's busy */
230 }
231 if (sfirst != r_send_next)
232 error(CONSISTENCY, "code screwup in ray_pflush");
233 r_send_next = 0;
234 return(sfirst); /* return total # sent */
235 }
236
237
238 extern void
239 ray_psend( /* add a ray to our send queue */
240 RAY *r
241 )
242 {
243 if (r == NULL)
244 return;
245 /* flush output if necessary */
246 if (sendq_full() && ray_pflush() <= 0)
247 error(INTERNAL, "ray_pflush failed in ray_psend");
248
249 r_queue[r_send_next++] = *r;
250 }
251
252
253 extern int
254 ray_pqueue( /* queue a ray for computation */
255 RAY *r
256 )
257 {
258 if (r == NULL)
259 return(0);
260 /* check for full send queue */
261 if (sendq_full()) {
262 RAY mySend;
263 int rval;
264 mySend = *r;
265 /* wait for a result */
266 rval = ray_presult(r, 0);
267 /* put new ray in queue */
268 r_queue[r_send_next++] = mySend;
269 return(rval); /* done */
270 }
271 /* else add ray to send queue */
272 r_queue[r_send_next++] = *r;
273 /* check for returned ray... */
274 if (r_recv_first >= r_recv_next)
275 return(0);
276 /* ...one is sitting in queue */
277 *r = r_queue[r_recv_first++];
278 return(1);
279 }
280
281
282 extern int
283 ray_presult( /* check for a completed ray */
284 RAY *r,
285 int poll
286 )
287 {
288 static struct timeval tpoll; /* zero timeval struct */
289 static fd_set readset, errset;
290 int n, ok;
291 register int pn;
292
293 if (r == NULL)
294 return(0);
295 /* check queued results first */
296 if (r_recv_first < r_recv_next) {
297 *r = r_queue[r_recv_first++];
298 /* make sure send queue has room */
299 if (sendq_full() && ray_pflush() <= 0)
300 return(-1);
301 return(1);
302 }
303 n = ray_pnprocs - ray_pnidle; /* pending before flush? */
304
305 if (ray_pflush() < 0) /* send new rays to process */
306 return(-1);
307 /* reset receive queue */
308 r_recv_first = r_recv_next = RAYQLEN;
309
310 if (!poll) /* count newly sent unless polling */
311 n = ray_pnprocs - ray_pnidle;
312 if (n <= 0) /* return if nothing to await */
313 return(0);
314 if (!poll && ray_pnprocs == 1) /* one process -> skip select() */
315 FD_SET(r_proc[0].fd_recv, &readset);
316
317 getready: /* any children waiting for us? */
318 for (pn = ray_pnprocs; pn--; )
319 if (FD_ISSET(r_proc[pn].fd_recv, &readset) ||
320 FD_ISSET(r_proc[pn].fd_recv, &errset))
321 break;
322 /* call select if we must */
323 if (pn < 0) {
324 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
325 for (pn = ray_pnprocs; pn--; ) {
326 if (r_proc[pn].npending > 0)
327 FD_SET(r_proc[pn].fd_recv, &readset);
328 FD_SET(r_proc[pn].fd_recv, &errset);
329 if (r_proc[pn].fd_recv >= n)
330 n = r_proc[pn].fd_recv + 1;
331 }
332 /* find out who is ready */
333 while ((n = select(n, &readset, (fd_set *)NULL, &errset,
334 poll ? &tpoll : (struct timeval *)NULL)) < 0)
335 if (errno != EINTR) {
336 error(WARNING,
337 "select call failed in ray_presult");
338 ray_pclose(0);
339 return(-1);
340 }
341 if (n > 0) /* go back and get it */
342 goto getready;
343 return(0); /* else poll came up empty */
344 }
345 if (r_recv_next + r_proc[pn].npending > sizeof(r_queue)/sizeof(RAY))
346 error(CONSISTENCY, "buffer shortage in ray_presult()");
347
348 /* read rendered ray data */
349 n = readbuf(r_proc[pn].fd_recv, (char *)&r_queue[r_recv_next],
350 sizeof(RAY)*r_proc[pn].npending);
351 if (n > 0) {
352 r_recv_next += n/sizeof(RAY);
353 ok = (n == sizeof(RAY)*r_proc[pn].npending);
354 } else
355 ok = 0;
356 /* reset child's status */
357 FD_CLR(r_proc[pn].fd_recv, &readset);
358 if (n <= 0)
359 FD_CLR(r_proc[pn].fd_recv, &errset);
360 r_proc[pn].npending = 0;
361 ray_pnidle++;
362 /* check for rendering errors */
363 if (!ok) {
364 ray_pclose(0); /* process died -- clean up */
365 return(-1);
366 }
367 /* preen returned rays */
368 for (n = r_recv_next - r_recv_first; n--; ) {
369 register RAY *rp = &r_queue[r_recv_first + n];
370 rp->rno = r_proc[pn].rno[n];
371 rp->parent = NULL;
372 rp->newcset = rp->clipset = NULL;
373 rp->rox = NULL;
374 rp->slights = NULL;
375 }
376 /* return first ray received */
377 *r = r_queue[r_recv_first++];
378 return(1);
379 }
380
381
382 extern void
383 ray_pdone( /* reap children and free data */
384 int freall
385 )
386 {
387 ray_pclose(0); /* close child processes */
388
389 if (shm_boundary != NULL) { /* clear shared memory boundary */
390 free((void *)shm_boundary);
391 shm_boundary = NULL;
392 }
393 ray_done(freall); /* free rendering data */
394 }
395
396
397 static void
398 ray_pchild( /* process rays (never returns) */
399 int fd_in,
400 int fd_out
401 )
402 {
403 int n;
404 register int i;
405 /* flag child process for quit() */
406 ray_pnprocs = -1;
407 /* read each ray request set */
408 while ((n = read(fd_in, (char *)r_queue, sizeof(r_queue))) > 0) {
409 int n2;
410 if (n < sizeof(RAY))
411 break;
412 /* get smuggled set length */
413 n2 = sizeof(RAY)*r_queue[0].crtype - n;
414 if (n2 < 0)
415 error(INTERNAL, "buffer over-read in ray_pchild");
416 if (n2 > 0) { /* read the rest of the set */
417 i = readbuf(fd_in, (char *)r_queue + n, n2);
418 if (i != n2)
419 break;
420 n += n2;
421 }
422 n /= sizeof(RAY);
423 /* evaluate rays */
424 for (i = 0; i < n; i++) {
425 r_queue[i].crtype = r_queue[i].rtype;
426 r_queue[i].parent = NULL;
427 r_queue[i].clipset = NULL;
428 r_queue[i].slights = NULL;
429 samplendx++;
430 rayclear(&r_queue[i]);
431 rayvalue(&r_queue[i]);
432 }
433 /* write back our results */
434 i = writebuf(fd_out, (char *)r_queue, sizeof(RAY)*n);
435 if (i != sizeof(RAY)*n)
436 error(SYSTEM, "write error in ray_pchild");
437 }
438 if (n)
439 error(SYSTEM, "read error in ray_pchild");
440 ambsync();
441 quit(0); /* normal exit */
442 }
443
444
445 extern void
446 ray_popen( /* open the specified # processes */
447 int nadd
448 )
449 {
450 /* check if our table has room */
451 if (ray_pnprocs + nadd > MAX_NPROCS)
452 nadd = MAX_NPROCS - ray_pnprocs;
453 if (nadd <= 0)
454 return;
455 ambsync(); /* load any new ambient values */
456 fflush(NULL); /* clear pending output */
457 while (nadd--) { /* fork each new process */
458 int p0[2], p1[2];
459 if (pipe(p0) < 0 || pipe(p1) < 0)
460 error(SYSTEM, "cannot create pipe");
461 if ((r_proc[ray_pnprocs].pid = fork()) == 0) {
462 int pn; /* close others' descriptors */
463 for (pn = ray_pnprocs; pn--; ) {
464 close(r_proc[pn].fd_send);
465 close(r_proc[pn].fd_recv);
466 }
467 close(p0[0]); close(p1[1]);
468 /* following call never returns */
469 ray_pchild(p1[0], p0[1]);
470 }
471 if (r_proc[ray_pnprocs].pid < 0)
472 error(SYSTEM, "cannot fork child process");
473 close(p1[0]); close(p0[1]);
474 /*
475 * Close write stream on exec to avoid multiprocessing deadlock.
476 * No use in read stream without it, so set flag there as well.
477 */
478 fcntl(p1[1], F_SETFD, FD_CLOEXEC);
479 fcntl(p0[0], F_SETFD, FD_CLOEXEC);
480 r_proc[ray_pnprocs].fd_send = p1[1];
481 r_proc[ray_pnprocs].fd_recv = p0[0];
482 r_proc[ray_pnprocs].npending = 0;
483 ray_pnprocs++;
484 ray_pnidle++;
485 }
486 }
487
488
489 extern void
490 ray_pclose( /* close one or more child processes */
491 int nsub
492 )
493 {
494 static int inclose = 0;
495 RAY res;
496 /* check recursion */
497 if (inclose)
498 return;
499 inclose++;
500 /* check argument */
501 if ((nsub <= 0) | (nsub > ray_pnprocs))
502 nsub = ray_pnprocs;
503 /* clear our ray queue */
504 while (ray_presult(&res,0) > 0)
505 ;
506 /* clean up children */
507 while (nsub--) {
508 int status;
509 ray_pnprocs--;
510 close(r_proc[ray_pnprocs].fd_recv);
511 close(r_proc[ray_pnprocs].fd_send);
512 if (waitpid(r_proc[ray_pnprocs].pid, &status, 0) < 0)
513 status = 127<<8;
514 if (status) {
515 sprintf(errmsg,
516 "rendering process %d exited with code %d",
517 r_proc[ray_pnprocs].pid, status>>8);
518 error(WARNING, errmsg);
519 }
520 ray_pnidle--;
521 }
522 inclose--;
523 }
524
525
526 void
527 quit(ec) /* make sure exit is called */
528 int ec;
529 {
530 if (ray_pnprocs > 0) /* close children if any */
531 ray_pclose(0);
532 exit(ec);
533 }
