Backed out last change, which actually made things worse
Optimize rtrace for throughput, especially with ambient cache
Decreased queue size again as it seems to give better performance with FIFO
Increased queue size to improve thoughput and irradiace cache behavior
Eliminated outdated "register" directives
Made quitting rvu, rholo and rcontrib quicker with multiple processes on Unix
Improved random sampling
Added reinitialization of random number generator in child processes with -u+
Added check for calling ray_pclose() in child
Final fix to problem of queue overflow (I hope)
Bug fixes and performance improvements to rtrace -n option
Delayed loading of object data until it is needed
Changed back to old queuing behavior
Created stub routines as placeholder for Windows version of raypcalls
Fixed potential bug where send queue gets jammed in ray_pqueue()
Eliminated unnecessary call to select(2) for single process
Added check for parent process to close children before exit
Minor cosmetic changes
Added ambient file synchronization and minor fixes
Fixed bug in reading of ray buffers
Fixed up comments in header
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
