root/radiance/ray/src/rt/raypcalls.c
Sat Aug 20 18:23:38 2011 UTC (12 years, 9 months ago) by greg
Changes since 2.27: +9 -4 lines
Diff to previous 2.27
Improved random sampling
Sat Aug 20 06:05:53 2011 UTC (12 years, 9 months ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26
Added reinitialization of random number generator in child processes with -u+
Wed Dec 16 01:06:50 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.25: +7 -4 lines
Diff to previous 2.25
Added check for calling ray_pclose() in child
Tue Dec 15 18:21:53 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.24: +15 -10 lines
Diff to previous 2.24
Final fix to problem of queue overflow (I hope)
Sat Dec 12 23:08:13 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.23: +9 -8 lines
Diff to previous 2.23
Bug fixes and performance improvements to rtrace -n option
Sat Dec 12 19:01:00 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.22: +14 -17 lines
Diff to previous 2.22
Sat Dec 12 05:20:10 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.21: +10 -11 lines
Diff to previous 2.21
Sat Dec 12 00:03:42 2009 UTC (14 years, 5 months ago) by greg
Changes since 2.20: +15 -11 lines
Diff to previous 2.20
Tue Dec 2 23:28:34 2008 UTC (15 years, 5 months ago) by greg
Changes since 2.19: +7 -7 lines
Diff to previous 2.19
Delayed loading of object data until it is needed
Wed Feb 20 05:21:29 2008 UTC (16 years, 3 months ago) by greg
Changes since 2.18: +6 -9 lines
Diff to previous 2.18
Changed back to old queuing behavior
Fri Feb 8 18:27:31 2008 UTC (16 years, 3 months ago) by greg
Changes since 2.17: +3 -5 lines
Diff to previous 2.17
Created stub routines as placeholder for Windows version of raypcalls
Tue Sep 18 19:10:02 2007 UTC (16 years, 8 months ago) by greg
Diff to previous 2.16
Fixed potential bug where send queue gets jammed in ray_pqueue()
Sat Sep 15 02:47:56 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.15: +4 -1 lines
Diff to previous 2.15
Eliminated unnecessary call to select(2) for single process
Wed Sep 12 03:57:00 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.14: +5 -1 lines
Diff to previous 2.14
Added check for parent process to close children before exit
Wed Dec 21 17:36:06 2005 UTC (18 years, 5 months ago) by greg
Changes since 2.13: +9 -13 lines
Diff to previous 2.13
Minor cosmetic changes
Tue Dec 20 20:36:44 2005 UTC (18 years, 5 months ago) by greg
Changes since 2.12: +14 -13 lines
Diff to previous 2.12
Added ambient file synchronization and minor fixes
Sat Dec 17 22:17:51 2005 UTC (18 years, 5 months ago) by greg
Changes since 2.11: +6 -7 lines
Fixed bug in reading of ray buffers
Fri Apr 15 04:44:51 2005 UTC (19 years, 1 month ago) by greg
Mon Sep 20 16:26:58 2004 UTC (19 years, 8 months ago) by greg
Fri Sep 17 14:27:33 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.6: +14 -10 lines
Fixed up comments in header
Changes since 2.5: +45 -29 lines
Changes since 2.3: +8 -8 lines
Changes since 2.2: +34 -34 lines
