--- ray/src/rt/raypcalls.c 2003/02/25 02:47:23 2.2 +++ ray/src/rt/raypcalls.c 2009/12/12 00:03:42 2.21 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: raypcalls.c,v 2.2 2003/02/25 02:47:23 greg Exp $"; +static const char RCSid[] = "$Id: raypcalls.c,v 2.21 2009/12/12 00:03:42 greg Exp $"; #endif /* * raypcalls.c - interface for parallel rendering using Radiance @@ -13,24 +13,29 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 * These calls are designed similarly to the ones in raycalls.c, * but allow for multiple rendering processes on the same host * machine. There is no sense in specifying more child processes - * than you have processors, but one child may help by allowing + * than you have processor cores, but one child may help by allowing * asynchronous ray computation in an interactive program, and * will protect the caller from fatal rendering errors. * - * You should first read and undrstand the header in raycalls.c, + * You should first read and understand the header in raycalls.c, * as some things are explained there that are not repated here. * * The first step is opening one or more rendering processes * with a call to ray_pinit(oct, nproc). Before calling fork(), * ray_pinit() loads the octree and data structures into the - * caller's memory. This permits all sorts of queries that - * wouldn't be possible otherwise, without causing any real + * caller's memory, and ray_popen() synchronizes the ambient + * file, if any. Shared memory permits all sorts of queries + * that wouldn't be possible otherwise without causing any real * memory overhead, since all the static data are shared - * between processes. Rays are then traced using a simple + * between processes. Rays are traced using a simple * queuing mechanism, explained below. * - * The ray queue holds as many rays as there are rendering - * processes. Rays are queued and returned by a single + * The ray queue buffers RAYQLEN rays before sending to + * children, each of which may internally buffer RAYQLEN rays + * during evaluation. Rays are not returned in the order + * they are sent when multiple processes are open. + * + * Rays are queued and returned by a single * ray_pqueue() call. A ray_pqueue() return * value of 0 indicates that no rays are ready * and the queue is not yet full. A return value of 1 @@ -43,7 +48,7 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 * myRay.rorg = ( ray origin point ) * myRay.rdir = ( normalized ray direction ) * myRay.rmax = ( maximum length, or zero for no limit ) - * rayorigin(&myRay, NULL, PRIMARY, 1.0); + * rayorigin(&myRay, PRIMARY, NULL, NULL); * myRay.rno = ( my personal ray identifier ) * if (ray_pqueue(&myRay) == 1) * { do something with results } @@ -51,12 +56,12 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 * Note the differences between this and the simpler ray_trace() * call. In particular, the call may or may not return a value * in the passed ray structure. Also, you need to call rayorigin() - * yourself, which is normally for you by ray_trace(). The - * great thing is that ray_pqueue() will trace rays faster in + * yourself, which is normally called for you by ray_trace(). The + * benefit is that ray_pqueue() will trace rays faster in * proportion to the number of CPUs you have available on your * system. If the ray queue is full before the call, ray_pqueue() * will block until a result is ready so it can queue this one. - * The global int ray_idle indicates the number of currently idle + * The global int ray_pnidle indicates the number of currently idle * children. If you want to check for completed rays without blocking, * or get the results from rays that have been queued without * queuing any new ones, the ray_presult() call is for you: @@ -70,27 +75,28 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 * until a value is available, returning 0 only if the * queue is completely empty. A negative return value * indicates that a rendering process died. If this - * happens, ray_close(0) is automatically called to close - * all child processes, and ray_nprocs is set to zero. + * happens, ray_pclose(0) is automatically called to close + * all child processes, and ray_pnprocs is set to zero. * * If you just want to fill the ray queue without checking for - * results, check ray_idle and call ray_psend(): + * results, check ray_pnidle and call ray_psend(): * - * while (ray_idle) { + * while (ray_pnidle) { * ( set up ray ) * ray_psend(&myRay); * } * - * The ray_presult() and/or ray_pqueue() functions may then be - * called to read back the results. + * Note that it is a fatal error to call ra_psend() when + * ray_pnidle is zero. The ray_presult() and/or ray_pqueue() + * functions may be called subsequently to read back the results. * * When you are done, you may call ray_pdone(1) to close * all child processes and clean up memory used by Radiance. * Any queued ray calculations will be awaited and discarded. * As with ray_done(), ray_pdone(0) hangs onto data files * and fonts that are likely to be used in subsequent renderings. - * Whether you want to bother cleaning up memory or not, you - * should at least call ray_pclose(0) to clean the child processes. + * Whether you need to clean up memory or not, you should + * at least call ray_pclose(0) to await the child processes. * * Warning: You cannot affect any of the rendering processes * by changing global parameter values onece ray_pinit() has @@ -99,37 +105,43 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 * If you just want to reap children so that you can alter the * rendering parameters without reloading the scene, use the * ray_pclose(0) and ray_popen(nproc) calls to close - * then restart the child processes. + * then restart the child processes after the changes are made. * * Note: These routines are written to coordinate with the * definitions in raycalls.c, and in fact depend on them. * If you want to trace a ray and get a result synchronously, * use the ray_trace() call to compute it in the parent process. + * This will not interfere with any subprocess calculations, + * but beware that a fatal error may end with a call to quit(). * * Note: One of the advantages of using separate processes * is that it gives the calling program some immunity from * fatal rendering errors. As discussed in raycalls.c, * Radiance tends to throw up its hands and exit at the * first sign of trouble, calling quit() to return control - * to the system. Although you can avoid exit() with + * to the top level. Although you can avoid exit() with * your own longjmp() in quit(), the cleanup afterwards * is always suspect. Through the use of subprocesses, * we avoid this pitfall by closing the processes and * returning a negative value from ray_pqueue() or * ray_presult(). If you get a negative value from either * of these calls, you can assume that the processes have - * been cleaned up with a call to ray_close(), though you + * been cleaned up with a call to ray_pclose(), though you * will have to call ray_pdone() yourself if you want to - * free memory. Obviously, you cannot continue rendering, - * but otherwise your process should not be compromised. + * free memory. Obviously, you cannot continue rendering + * without risking further errors, but otherwise your + * process should not be compromised. */ +#include "rtprocess.h" #include "ray.h" - +#include "ambient.h" +#include +#include #include "selcall.h" #ifndef RAYQLEN -#define RAYQLEN 16 /* # rays to send at once */ +#define RAYQLEN 12 /* # rays to send at once */ #endif #ifndef MAX_RPROCS @@ -142,15 +154,16 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 extern char *shm_boundary; /* boundary of shared memory */ -int ray_nprocs = 0; /* number of child processes */ -int ray_idle = 0; /* number of idle children */ +int ray_pfifo = 0; /* maintain ray call order? */ +int ray_pnprocs = 0; /* number of child processes */ +int ray_pnidle = 0; /* number of idle children */ static struct child_proc { int pid; /* child process id */ int fd_send; /* write to child here */ int fd_recv; /* read from child here */ int npending; /* # rays in process */ - unsigned long rno[RAYQLEN]; /* working on these rays */ + RNUMBER rno[RAYQLEN]; /* working on these rays */ } r_proc[MAX_NPROCS]; /* our child processes */ static RAY r_queue[2*RAYQLEN]; /* ray i/o buffer */ @@ -160,23 +173,21 @@ static int r_recv_next; /* next receive ray placement #define sendq_full() (r_send_next >= RAYQLEN) +static int ray_pflush(void); +static void ray_pchild(int fd_in, int fd_out); -void -ray_pinit(otnm, nproc) /* initialize ray-tracing processes */ -char *otnm; -int nproc; + +extern void +ray_pinit( /* initialize ray-tracing processes */ + char *otnm, + int nproc +) { if (nobjects > 0) /* close old calculation */ ray_pdone(0); ray_init(otnm); /* load the shared scene */ - preload_objs(); /* preload auxiliary data */ - - /* set shared memory boundary */ - shm_boundary = (char *)malloc(16); - strcpy(shm_boundary, "SHM_BOUNDARY"); - r_send_next = 0; /* set up queue */ r_recv_first = r_recv_next = RAYQLEN; @@ -185,16 +196,16 @@ int nproc; static int -ray_pflush() /* send queued rays to idle children */ +ray_pflush(void) /* send queued rays to idle children */ { int nc, n, nw, i, sfirst; - if ((ray_idle <= 0 | r_send_next <= 0)) + if ((ray_pnidle <= 0) | (r_send_next <= 0)) return(0); /* nothing we can send */ sfirst = 0; /* divvy up labor */ - nc = ray_idle; - for (i = ray_nprocs; nc && i--; ) { + nc = ray_pnidle; + for (i = ray_pnprocs; nc && i--; ) { if (r_proc[i].npending > 0) continue; /* child looks busy */ n = (r_send_next - sfirst)/nc--; @@ -210,7 +221,7 @@ ray_pflush() /* send queued rays to idle children */ while (n--) /* record ray IDs */ r_proc[i].rno[n] = r_queue[sfirst+n].rno; sfirst += r_proc[i].npending; - ray_idle--; /* now she's busy */ + ray_pnidle--; /* now she's busy */ } if (sfirst != r_send_next) error(CONSISTENCY, "code screwup in ray_pflush"); @@ -219,9 +230,10 @@ ray_pflush() /* send queued rays to idle children */ } -void -ray_psend(r) /* add a ray to our send queue */ -RAY *r; +extern void +ray_psend( /* add a ray to our send queue */ + RAY *r +) { if (r == NULL) return; @@ -229,46 +241,44 @@ RAY *r; if (sendq_full() && ray_pflush() <= 0) error(INTERNAL, "ray_pflush failed in ray_psend"); - copystruct(&r_queue[r_send_next], r); - r_send_next++; + r_queue[r_send_next++] = *r; } -int -ray_pqueue(r) /* queue a ray for computation */ -RAY *r; +extern int +ray_pqueue( /* queue a ray for computation */ + RAY *r +) { if (r == NULL) return(0); /* check for full send queue */ if (sendq_full()) { - RAY mySend; - int rval; - copystruct(&mySend, r); + RAY mySend = *r; /* wait for a result */ - rval = ray_presult(r, 0); + if (ray_presult(r, 0) <= 0) + return(-1); /* put new ray in queue */ - copystruct(&r_queue[r_send_next], &mySend); - r_send_next++; - return(rval); /* done */ + r_queue[r_send_next++] = mySend; + /* XXX r_send_next may now be > RAYQLEN */ + return(1); } - /* add ray to send queue */ - copystruct(&r_queue[r_send_next], r); - r_send_next++; + /* else add ray to send queue */ + r_queue[r_send_next++] = *r; /* check for returned ray... */ if (r_recv_first >= r_recv_next) return(0); /* ...one is sitting in queue */ - copystruct(r, &r_queue[r_recv_first]); - r_recv_first++; + *r = r_queue[r_recv_first++]; return(1); } -int -ray_presult(r, poll) /* check for a completed ray */ -RAY *r; -int poll; +extern int +ray_presult( /* check for a completed ray */ + RAY *r, + int poll +) { static struct timeval tpoll; /* zero timeval struct */ static fd_set readset, errset; @@ -279,11 +289,10 @@ int poll; return(0); /* check queued results first */ if (r_recv_first < r_recv_next) { - copystruct(r, &r_queue[r_recv_first]); - r_recv_first++; + *r = r_queue[r_recv_first++]; return(1); } - n = ray_nprocs - ray_idle; /* pending before flush? */ + n = ray_pnprocs - ray_pnidle; /* pending before flush? */ if (ray_pflush() < 0) /* send new rays to process */ return(-1); @@ -291,18 +300,21 @@ int poll; r_recv_first = r_recv_next = RAYQLEN; if (!poll) /* count newly sent unless polling */ - n = ray_nprocs - ray_idle; + n = ray_pnprocs - ray_pnidle; if (n <= 0) /* return if nothing to await */ return(0); + if (!poll && ray_pnprocs == 1) /* one process -> skip select() */ + FD_SET(r_proc[0].fd_recv, &readset); + getready: /* any children waiting for us? */ - for (pn = ray_nprocs; pn--; ) + for (pn = ray_pnprocs; pn--; ) if (FD_ISSET(r_proc[pn].fd_recv, &readset) || FD_ISSET(r_proc[pn].fd_recv, &errset)) break; /* call select if we must */ if (pn < 0) { FD_ZERO(&readset); FD_ZERO(&errset); n = 0; - for (pn = ray_nprocs; pn--; ) { + for (pn = ray_pnprocs; pn--; ) { if (r_proc[pn].npending > 0) FD_SET(r_proc[pn].fd_recv, &readset); FD_SET(r_proc[pn].fd_recv, &errset); @@ -338,7 +350,7 @@ getready: /* any children waiting for us? */ if (n <= 0) FD_CLR(r_proc[pn].fd_recv, &errset); r_proc[pn].npending = 0; - ray_idle++; + ray_pnidle++; /* check for rendering errors */ if (!ok) { ray_pclose(0); /* process died -- clean up */ @@ -354,15 +366,15 @@ getready: /* any children waiting for us? */ rp->slights = NULL; } /* return first ray received */ - copystruct(r, &r_queue[r_recv_first]); - r_recv_first++; + *r = r_queue[r_recv_first++]; return(1); } -void -ray_pdone(freall) /* reap children and free data */ -int freall; +extern void +ray_pdone( /* reap children and free data */ + int freall +) { ray_pclose(0); /* close child processes */ @@ -375,36 +387,38 @@ int freall; static void -ray_pchild(fd_in, fd_out) /* process rays (never returns) */ -int fd_in; -int fd_out; +ray_pchild( /* process rays (never returns) */ + int fd_in, + int fd_out +) { int n; register int i; + /* flag child process for quit() */ + ray_pnprocs = -1; /* read each ray request set */ while ((n = read(fd_in, (char *)r_queue, sizeof(r_queue))) > 0) { int n2; - if (n % sizeof(RAY)) + if (n < sizeof(RAY)) break; - n /= sizeof(RAY); /* get smuggled set length */ - n2 = r_queue[0].crtype - n; + n2 = sizeof(RAY)*r_queue[0].crtype - n; if (n2 < 0) error(INTERNAL, "buffer over-read in ray_pchild"); if (n2 > 0) { /* read the rest of the set */ - i = readbuf(fd_in, (char *)(r_queue+n), - sizeof(RAY)*n2); - if (i != sizeof(RAY)*n2) + i = readbuf(fd_in, (char *)r_queue + n, n2); + if (i != n2) break; n += n2; } + n /= sizeof(RAY); /* evaluate rays */ for (i = 0; i < n; i++) { r_queue[i].crtype = r_queue[i].rtype; r_queue[i].parent = NULL; r_queue[i].clipset = NULL; r_queue[i].slights = NULL; - r_queue[i].revf = raytrace; + r_queue[i].rlvl = 0; samplendx++; rayclear(&r_queue[i]); rayvalue(&r_queue[i]); @@ -421,24 +435,31 @@ int fd_out; } -void -ray_popen(nadd) /* open the specified # processes */ -int nadd; +extern void +ray_popen( /* open the specified # processes */ + int nadd +) { /* check if our table has room */ - if (ray_nprocs + nadd > MAX_NPROCS) - nadd = MAX_NPROCS - ray_nprocs; + if (ray_pnprocs + nadd > MAX_NPROCS) + nadd = MAX_NPROCS - ray_pnprocs; if (nadd <= 0) return; - fflush(stderr); /* clear pending output */ - fflush(stdout); + ambsync(); /* load any new ambient values */ + if (shm_boundary == NULL) { /* first child process? */ + preload_objs(); /* preload auxiliary data */ + /* set shared memory boundary */ + shm_boundary = (char *)malloc(16); + strcpy(shm_boundary, "SHM_BOUNDARY"); + } + fflush(NULL); /* clear pending output */ while (nadd--) { /* fork each new process */ int p0[2], p1[2]; if (pipe(p0) < 0 || pipe(p1) < 0) error(SYSTEM, "cannot create pipe"); - if ((r_proc[ray_nprocs].pid = fork()) == 0) { + if ((r_proc[ray_pnprocs].pid = fork()) == 0) { int pn; /* close others' descriptors */ - for (pn = ray_nprocs; pn--; ) { + for (pn = ray_pnprocs; pn--; ) { close(r_proc[pn].fd_send); close(r_proc[pn].fd_recv); } @@ -446,21 +467,28 @@ int nadd; /* following call never returns */ ray_pchild(p1[0], p0[1]); } - if (r_proc[ray_nprocs].pid < 0) + if (r_proc[ray_pnprocs].pid < 0) error(SYSTEM, "cannot fork child process"); close(p1[0]); close(p0[1]); - r_proc[ray_nprocs].fd_send = p1[1]; - r_proc[ray_nprocs].fd_recv = p0[0]; - r_proc[ray_nprocs].npending = 0; - ray_nprocs++; - ray_idle++; + /* + * Close write stream on exec to avoid multiprocessing deadlock. + * No use in read stream without it, so set flag there as well. + */ + fcntl(p1[1], F_SETFD, FD_CLOEXEC); + fcntl(p0[0], F_SETFD, FD_CLOEXEC); + r_proc[ray_pnprocs].fd_send = p1[1]; + r_proc[ray_pnprocs].fd_recv = p0[0]; + r_proc[ray_pnprocs].npending = 0; + ray_pnprocs++; + ray_pnidle++; } } -void -ray_pclose(nsub) /* close one or more child processes */ -int nsub; +extern void +ray_pclose( /* close one or more child processes */ + int nsub +) { static int inclose = 0; RAY res; @@ -469,26 +497,26 @@ int nsub; return; inclose++; /* check argument */ - if ((nsub <= 0 | nsub > ray_nprocs)) - nsub = ray_nprocs; + if ((nsub <= 0) | (nsub > ray_pnprocs)) + nsub = ray_pnprocs; /* clear our ray queue */ while (ray_presult(&res,0) > 0) ; /* clean up children */ while (nsub--) { int status; - ray_nprocs--; - close(r_proc[ray_nprocs].fd_recv); - close(r_proc[ray_nprocs].fd_send); - while (wait(&status) != r_proc[ray_nprocs].pid) - ; + ray_pnprocs--; + close(r_proc[ray_pnprocs].fd_recv); + close(r_proc[ray_pnprocs].fd_send); + if (waitpid(r_proc[ray_pnprocs].pid, &status, 0) < 0) + status = 127<<8; if (status) { sprintf(errmsg, "rendering process %d exited with code %d", - r_proc[ray_nprocs].pid, status>>8); + r_proc[ray_pnprocs].pid, status>>8); error(WARNING, errmsg); } - ray_idle--; + ray_pnidle--; } inclose--; } @@ -498,5 +526,7 @@ void quit(ec) /* make sure exit is called */ int ec; { + if (ray_pnprocs > 0) /* close children if any */ + ray_pclose(0); exit(ec); }
