root/radiance/ray/src/rt/raypcalls.c
Sat Aug 20 18:23:38 2011 UTC (13 years, 8 months ago) by greg
Changes since 2.27: +9 -4 lines
Diff to previous 2.27 , to selected 2.10
Improved random sampling
Sat Aug 20 06:05:53 2011 UTC (13 years, 8 months ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26 , to selected 2.10
Added reinitialization of random number generator in child processes with -u+
Wed Dec 16 01:06:50 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.25: +7 -4 lines
Diff to previous 2.25 , to selected 2.10
Added check for calling ray_pclose() in child
Tue Dec 15 18:21:53 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.24: +15 -10 lines
Diff to previous 2.24 , to selected 2.10
Final fix to problem of queue overflow (I hope)
Sat Dec 12 23:08:13 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.23: +9 -8 lines
Diff to previous 2.23 , to selected 2.10
Bug fixes and performance improvements to rtrace -n option
Sat Dec 12 19:01:00 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.22: +14 -17 lines
Diff to previous 2.22 , to selected 2.10
Sat Dec 12 05:20:10 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.21: +10 -11 lines
Diff to previous 2.21 , to selected 2.10
Sat Dec 12 00:03:42 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.20: +15 -11 lines
Diff to previous 2.20 , to selected 2.10
Tue Dec 2 23:28:34 2008 UTC (16 years, 5 months ago) by greg
Changes since 2.19: +7 -7 lines
Diff to previous 2.19 , to selected 2.10
Delayed loading of object data until it is needed
Wed Feb 20 05:21:29 2008 UTC (17 years, 2 months ago) by greg
Changes since 2.18: +6 -9 lines
Diff to previous 2.18 , to selected 2.10
Changed back to old queuing behavior
Fri Feb 8 18:27:31 2008 UTC (17 years, 2 months ago) by greg
Changes since 2.17: +3 -5 lines
Diff to previous 2.17 , to selected 2.10
Created stub routines as placeholder for Windows version of raypcalls
Tue Sep 18 19:10:02 2007 UTC (17 years, 7 months ago) by greg
Diff to previous 2.16 , to selected 2.10
Fixed potential bug where send queue gets jammed in ray_pqueue()
Sat Sep 15 02:47:56 2007 UTC (17 years, 7 months ago) by greg
Changes since 2.15: +4 -1 lines
Diff to previous 2.15 , to selected 2.10
Eliminated unnecessary call to select(2) for single process
Wed Sep 12 03:57:00 2007 UTC (17 years, 7 months ago) by greg
Changes since 2.14: +5 -1 lines
Added check for parent process to close children before exit
Wed Dec 21 17:36:06 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.13: +9 -13 lines
Minor cosmetic changes
Tue Dec 20 20:36:44 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.12: +14 -13 lines
Added ambient file synchronization and minor fixes
Sat Dec 17 22:17:51 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.11: +6 -7 lines
Fixed bug in reading of ray buffers
Tue Apr 19 01:15:06 2005 UTC (20 years ago) by greg
Fri Apr 15 04:44:51 2005 UTC (20 years ago) by greg
Mon Sep 20 16:26:58 2004 UTC (20 years, 7 months ago) by greg
Fri Sep 17 21:43:50 2004 UTC (20 years, 7 months ago) by greg
Fri Sep 17 14:27:33 2004 UTC (20 years, 7 months ago) by greg
Changes since 2.6: +14 -10 lines
Fixed up comments in header
Changes since 2.5: +45 -29 lines
Sun Jul 27 22:12:03 2003 UTC (21 years, 9 months ago) by schorsch
Mon Jul 21 22:30:19 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.3: +8 -8 lines
Thu Jul 3 15:00:19 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.2: +34 -34 lines
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Diff to selected 2.10
