--- ray/src/rt/raypcalls.c 2003/07/03 15:00:19 2.3 +++ ray/src/rt/raypcalls.c 2008/02/20 05:21:29 2.19 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: raypcalls.c,v 2.3 2003/07/03 15:00:19 greg Exp $"; +static const char RCSid[] = "$Id: raypcalls.c,v 2.19 2008/02/20 05:21:29 greg Exp $"; #endif /* * raypcalls.c - interface for parallel rendering using Radiance @@ -23,14 +23,17 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.3 20 * The first step is opening one or more rendering processes * with a call to ray_pinit(oct, nproc). Before calling fork(), * ray_pinit() loads the octree and data structures into the - * caller's memory. This permits all sorts of queries that - * wouldn't be possible otherwise, without causing any real + * caller's memory, and ray_popen() synchronizes the ambient + * file, if any. Shared memory permits all sorts of queries + * that wouldn't be possible otherwise, without causing any real * memory overhead, since all the static data are shared * between processes. Rays are then traced using a simple * queuing mechanism, explained below. * - * The ray queue holds as many rays as there are rendering - * processes. Rays are queued and returned by a single + * The ray queue buffers RAYQLEN rays before sending to + * children, each of which may internally buffer RAYQLEN rays. + * + * Rays are queued and returned by a single * ray_pqueue() call. A ray_pqueue() return * value of 0 indicates that no rays are ready * and the queue is not yet full. A return value of 1 @@ -43,7 +46,7 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.3 20 * myRay.rorg = ( ray origin point ) * myRay.rdir = ( normalized ray direction ) * myRay.rmax = ( maximum length, or zero for no limit ) - * rayorigin(&myRay, NULL, PRIMARY, 1.0); + * rayorigin(&myRay, PRIMARY, NULL, NULL); * myRay.rno = ( my personal ray identifier ) * if (ray_pqueue(&myRay) == 1) * { do something with results } @@ -51,8 +54,8 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.3 20 * Note the differences between this and the simpler ray_trace() * call. In particular, the call may or may not return a value * in the passed ray structure. Also, you need to call rayorigin() - * yourself, which is normally for you by ray_trace(). The - * great thing is that ray_pqueue() will trace rays faster in + * yourself, which is normally called for you by ray_trace(). The + * benefit is that ray_pqueue() will trace rays faster in * proportion to the number of CPUs you have available on your * system. If the ray queue is full before the call, ray_pqueue() * will block until a result is ready so it can queue this one. @@ -81,8 +84,9 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.3 20 * ray_psend(&myRay); * } * - * The ray_presult() and/or ray_pqueue() functions may then be - * called to read back the results. + * Note that it is a fatal error to call ra_psend() when + * ray_pnidle is zero. The ray_presult() and/or ray_pqueue() + * functions may be called subsequently to read back the results. * * When you are done, you may call ray_pdone(1) to close * all child processes and clean up memory used by Radiance. @@ -99,19 +103,21 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.3 20 * If you just want to reap children so that you can alter the * rendering parameters without reloading the scene, use the * ray_pclose(0) and ray_popen(nproc) calls to close - * then restart the child processes. + * then restart the child processes after the changes are made. * * Note: These routines are written to coordinate with the * definitions in raycalls.c, and in fact depend on them. * If you want to trace a ray and get a result synchronously, * use the ray_trace() call to compute it in the parent process. + * This will not interfere with any subprocess calculations, + * but beware that a fatal error may end with a call to quit(). * * Note: One of the advantages of using separate processes * is that it gives the calling program some immunity from * fatal rendering errors. As discussed in raycalls.c, * Radiance tends to throw up its hands and exit at the * first sign of trouble, calling quit() to return control - * to the system. Although you can avoid exit() with + * to the top level. Although you can avoid exit() with * your own longjmp() in quit(), the cleanup afterwards * is always suspect. Through the use of subprocesses, * we avoid this pitfall by closing the processes and @@ -120,16 +126,20 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.3 20 * of these calls, you can assume that the processes have * been cleaned up with a call to ray_close(), though you * will have to call ray_pdone() yourself if you want to - * free memory. Obviously, you cannot continue rendering, - * but otherwise your process should not be compromised. + * free memory. Obviously, you cannot continue rendering + * without risking further errors, but otherwise your + * process should not be compromised. */ +#include "rtprocess.h" #include "ray.h" - +#include "ambient.h" +#include +#include #include "selcall.h" #ifndef RAYQLEN -#define RAYQLEN 16 /* # rays to send at once */ +#define RAYQLEN 12 /* # rays to send at once */ #endif #ifndef MAX_RPROCS @@ -160,11 +170,15 @@ static int r_recv_next; /* next receive ray placement #define sendq_full() (r_send_next >= RAYQLEN) +static int ray_pflush(void); +static void ray_pchild(int fd_in, int fd_out); -void -ray_pinit(otnm, nproc) /* initialize ray-tracing processes */ -char *otnm; -int nproc; + +extern void +ray_pinit( /* initialize ray-tracing processes */ + char *otnm, + int nproc +) { if (nobjects > 0) /* close old calculation */ ray_pdone(0); @@ -185,11 +199,11 @@ int nproc; static int -ray_pflush() /* send queued rays to idle children */ +ray_pflush(void) /* send queued rays to idle children */ { int nc, n, nw, i, sfirst; - if ((ray_pnidle <= 0 | r_send_next <= 0)) + if ((ray_pnidle <= 0) | (r_send_next <= 0)) return(0); /* nothing we can send */ sfirst = 0; /* divvy up labor */ @@ -219,9 +233,10 @@ ray_pflush() /* send queued rays to idle children */ } -void -ray_psend(r) /* add a ray to our send queue */ -RAY *r; +extern void +ray_psend( /* add a ray to our send queue */ + RAY *r +) { if (r == NULL) return; @@ -229,46 +244,44 @@ RAY *r; if (sendq_full() && ray_pflush() <= 0) error(INTERNAL, "ray_pflush failed in ray_psend"); - copystruct(&r_queue[r_send_next], r); - r_send_next++; + r_queue[r_send_next++] = *r; } -int -ray_pqueue(r) /* queue a ray for computation */ -RAY *r; +extern int +ray_pqueue( /* queue a ray for computation */ + RAY *r +) { if (r == NULL) return(0); /* check for full send queue */ if (sendq_full()) { - RAY mySend; - int rval; - copystruct(&mySend, r); + RAY mySend = *r; /* wait for a result */ - rval = ray_presult(r, 0); + if (ray_presult(r, 0) <= 0) + return(-1); /* put new ray in queue */ - copystruct(&r_queue[r_send_next], &mySend); - r_send_next++; - return(rval); /* done */ + r_queue[r_send_next++] = mySend; + /* XXX r_send_next may now be > RAYQLEN */ + return(1); } - /* add ray to send queue */ - copystruct(&r_queue[r_send_next], r); - r_send_next++; + /* else add ray to send queue */ + r_queue[r_send_next++] = *r; /* check for returned ray... */ if (r_recv_first >= r_recv_next) return(0); /* ...one is sitting in queue */ - copystruct(r, &r_queue[r_recv_first]); - r_recv_first++; + *r = r_queue[r_recv_first++]; return(1); } -int -ray_presult(r, poll) /* check for a completed ray */ -RAY *r; -int poll; +extern int +ray_presult( /* check for a completed ray */ + RAY *r, + int poll +) { static struct timeval tpoll; /* zero timeval struct */ static fd_set readset, errset; @@ -279,8 +292,7 @@ int poll; return(0); /* check queued results first */ if (r_recv_first < r_recv_next) { - copystruct(r, &r_queue[r_recv_first]); - r_recv_first++; + *r = r_queue[r_recv_first++]; return(1); } n = ray_pnprocs - ray_pnidle; /* pending before flush? */ @@ -294,6 +306,9 @@ int poll; n = ray_pnprocs - ray_pnidle; if (n <= 0) /* return if nothing to await */ return(0); + if (!poll && ray_pnprocs == 1) /* one process -> skip select() */ + FD_SET(r_proc[0].fd_recv, &readset); + getready: /* any children waiting for us? */ for (pn = ray_pnprocs; pn--; ) if (FD_ISSET(r_proc[pn].fd_recv, &readset) || @@ -354,15 +369,15 @@ getready: /* any children waiting for us? */ rp->slights = NULL; } /* return first ray received */ - copystruct(r, &r_queue[r_recv_first]); - r_recv_first++; + *r = r_queue[r_recv_first++]; return(1); } -void -ray_pdone(freall) /* reap children and free data */ -int freall; +extern void +ray_pdone( /* reap children and free data */ + int freall +) { ray_pclose(0); /* close child processes */ @@ -375,36 +390,37 @@ int freall; static void -ray_pchild(fd_in, fd_out) /* process rays (never returns) */ -int fd_in; -int fd_out; +ray_pchild( /* process rays (never returns) */ + int fd_in, + int fd_out +) { int n; register int i; + /* flag child process for quit() */ + ray_pnprocs = -1; /* read each ray request set */ while ((n = read(fd_in, (char *)r_queue, sizeof(r_queue))) > 0) { int n2; - if (n % sizeof(RAY)) + if (n < sizeof(RAY)) break; - n /= sizeof(RAY); /* get smuggled set length */ - n2 = r_queue[0].crtype - n; + n2 = sizeof(RAY)*r_queue[0].crtype - n; if (n2 < 0) error(INTERNAL, "buffer over-read in ray_pchild"); if (n2 > 0) { /* read the rest of the set */ - i = readbuf(fd_in, (char *)(r_queue+n), - sizeof(RAY)*n2); - if (i != sizeof(RAY)*n2) + i = readbuf(fd_in, (char *)r_queue + n, n2); + if (i != n2) break; n += n2; } + n /= sizeof(RAY); /* evaluate rays */ for (i = 0; i < n; i++) { r_queue[i].crtype = r_queue[i].rtype; r_queue[i].parent = NULL; r_queue[i].clipset = NULL; r_queue[i].slights = NULL; - r_queue[i].revf = raytrace; samplendx++; rayclear(&r_queue[i]); rayvalue(&r_queue[i]); @@ -421,17 +437,18 @@ int fd_out; } -void -ray_popen(nadd) /* open the specified # processes */ -int nadd; +extern void +ray_popen( /* open the specified # processes */ + int nadd +) { /* check if our table has room */ if (ray_pnprocs + nadd > MAX_NPROCS) nadd = MAX_NPROCS - ray_pnprocs; if (nadd <= 0) return; - fflush(stderr); /* clear pending output */ - fflush(stdout); + ambsync(); /* load any new ambient values */ + fflush(NULL); /* clear pending output */ while (nadd--) { /* fork each new process */ int p0[2], p1[2]; if (pipe(p0) < 0 || pipe(p1) < 0) @@ -449,6 +466,12 @@ int nadd; if (r_proc[ray_pnprocs].pid < 0) error(SYSTEM, "cannot fork child process"); close(p1[0]); close(p0[1]); + /* + * Close write stream on exec to avoid multiprocessing deadlock. + * No use in read stream without it, so set flag there as well. + */ + fcntl(p1[1], F_SETFD, FD_CLOEXEC); + fcntl(p0[0], F_SETFD, FD_CLOEXEC); r_proc[ray_pnprocs].fd_send = p1[1]; r_proc[ray_pnprocs].fd_recv = p0[0]; r_proc[ray_pnprocs].npending = 0; @@ -458,9 +481,10 @@ int nadd; } -void -ray_pclose(nsub) /* close one or more child processes */ -int nsub; +extern void +ray_pclose( /* close one or more child processes */ + int nsub +) { static int inclose = 0; RAY res; @@ -469,7 +493,7 @@ int nsub; return; inclose++; /* check argument */ - if ((nsub <= 0 | nsub > ray_pnprocs)) + if ((nsub <= 0) | (nsub > ray_pnprocs)) nsub = ray_pnprocs; /* clear our ray queue */ while (ray_presult(&res,0) > 0) @@ -480,8 +504,8 @@ int nsub; ray_pnprocs--; close(r_proc[ray_pnprocs].fd_recv); close(r_proc[ray_pnprocs].fd_send); - while (wait(&status) != r_proc[ray_pnprocs].pid) - ; + if (waitpid(r_proc[ray_pnprocs].pid, &status, 0) < 0) + status = 127<<8; if (status) { sprintf(errmsg, "rendering process %d exited with code %d", @@ -498,5 +522,7 @@ void quit(ec) /* make sure exit is called */ int ec; { + if (ray_pnprocs > 0) /* close children if any */ + ray_pclose(0); exit(ec); }
