root/radiance/ray/src/rt/raypcalls.c
Wed Feb 20 05:21:29 2008 UTC (16 years, 3 months ago) by greg
Changes since 2.18: +6 -9 lines
Diff to previous 2.18 , to selected 2.1
Changed back to old queuing behavior
Fri Feb 8 18:27:31 2008 UTC (16 years, 3 months ago) by greg
Changes since 2.17: +3 -5 lines
Diff to previous 2.17 , to selected 2.1
Created stub routines as placeholder for Windows version of raypcalls
Tue Sep 18 19:10:02 2007 UTC (16 years, 8 months ago) by greg
Diff to previous 2.16 , to selected 2.1
Fixed potential bug where send queue gets jammed in ray_pqueue()
Sat Sep 15 02:47:56 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.15: +4 -1 lines
Eliminated unnecessary call to select(2) for single process
Wed Sep 12 03:57:00 2007 UTC (16 years, 8 months ago) by greg
Changes since 2.14: +5 -1 lines
Added check for parent process to close children before exit
Wed Dec 21 17:36:06 2005 UTC (18 years, 5 months ago) by greg
Changes since 2.13: +9 -13 lines
Minor cosmetic changes
Tue Dec 20 20:36:44 2005 UTC (18 years, 5 months ago) by greg
Changes since 2.12: +14 -13 lines
Added ambient file synchronization and minor fixes
Sat Dec 17 22:17:51 2005 UTC (18 years, 5 months ago) by greg
Changes since 2.11: +6 -7 lines
Fixed bug in reading of ray buffers
Fri Apr 15 04:44:51 2005 UTC (19 years, 1 month ago) by greg
Mon Sep 20 16:26:58 2004 UTC (19 years, 8 months ago) by greg
Fri Sep 17 14:27:33 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.6: +14 -10 lines
Fixed up comments in header
Changes since 2.5: +45 -29 lines
Changes since 2.3: +8 -8 lines
Thu Jul 3 15:00:19 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.2: +34 -34 lines
