--- ray/src/rt/raypcalls.c 2003/02/25 02:47:23 2.2 +++ ray/src/rt/raypcalls.c 2004/03/30 16:13:01 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: raypcalls.c,v 2.2 2003/02/25 02:47:23 greg Exp $"; +static const char RCSid[] = "$Id: raypcalls.c,v 2.6 2004/03/30 16:13:01 schorsch Exp $"; #endif /* * raypcalls.c - interface for parallel rendering using Radiance @@ -56,7 +56,7 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 * proportion to the number of CPUs you have available on your * system. If the ray queue is full before the call, ray_pqueue() * will block until a result is ready so it can queue this one. - * The global int ray_idle indicates the number of currently idle + * The global int ray_pnidle indicates the number of currently idle * children. If you want to check for completed rays without blocking, * or get the results from rays that have been queued without * queuing any new ones, the ray_presult() call is for you: @@ -71,12 +71,12 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 * queue is completely empty. A negative return value * indicates that a rendering process died. If this * happens, ray_close(0) is automatically called to close - * all child processes, and ray_nprocs is set to zero. + * all child processes, and ray_pnprocs is set to zero. * * If you just want to fill the ray queue without checking for - * results, check ray_idle and call ray_psend(): + * results, check ray_pnidle and call ray_psend(): * - * while (ray_idle) { + * while (ray_pnidle) { * ( set up ray ) * ray_psend(&myRay); * } @@ -124,8 +124,13 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 * but otherwise your process should not be compromised. */ -#include "ray.h" +#include +#include +#include /* XXX platform */ +#include "rtprocess.h" +#include "ray.h" +#include "ambient.h" #include "selcall.h" #ifndef RAYQLEN @@ -142,8 +147,8 @@ static const char RCSid[] = "$Id: raypcalls.c,v 2.2 20 extern char *shm_boundary; /* boundary of shared memory */ -int ray_nprocs = 0; /* number of child processes */ -int ray_idle = 0; /* number of idle children */ +int ray_pnprocs = 0; /* number of child processes */ +int ray_pnidle = 0; /* number of idle children */ static struct child_proc { int pid; /* child process id */ @@ -160,11 +165,15 @@ static int r_recv_next; /* next receive ray placement #define sendq_full() (r_send_next >= RAYQLEN) +static int ray_pflush(void); +static void ray_pchild(int fd_in, int fd_out); -void -ray_pinit(otnm, nproc) /* initialize ray-tracing processes */ -char *otnm; -int nproc; + +extern void +ray_pinit( /* initialize ray-tracing processes */ + char *otnm, + int nproc +) { if (nobjects > 0) /* close old calculation */ ray_pdone(0); @@ -185,16 +194,16 @@ int nproc; static int -ray_pflush() /* send queued rays to idle children */ +ray_pflush(void) /* send queued rays to idle children */ { int nc, n, nw, i, sfirst; - if ((ray_idle <= 0 | r_send_next <= 0)) + if ((ray_pnidle <= 0) | (r_send_next <= 0)) return(0); /* nothing we can send */ sfirst = 0; /* divvy up labor */ - nc = ray_idle; - for (i = ray_nprocs; nc && i--; ) { + nc = ray_pnidle; + for (i = ray_pnprocs; nc && i--; ) { if (r_proc[i].npending > 0) continue; /* child looks busy */ n = (r_send_next - sfirst)/nc--; @@ -210,7 +219,7 @@ ray_pflush() /* send queued rays to idle children */ while (n--) /* record ray IDs */ r_proc[i].rno[n] = r_queue[sfirst+n].rno; sfirst += r_proc[i].npending; - ray_idle--; /* now she's busy */ + ray_pnidle--; /* now she's busy */ } if (sfirst != r_send_next) error(CONSISTENCY, "code screwup in ray_pflush"); @@ -219,9 +228,10 @@ ray_pflush() /* send queued rays to idle children */ } -void -ray_psend(r) /* add a ray to our send queue */ -RAY *r; +extern void +ray_psend( /* add a ray to our send queue */ + RAY *r +) { if (r == NULL) return; @@ -229,14 +239,15 @@ RAY *r; if (sendq_full() && ray_pflush() <= 0) error(INTERNAL, "ray_pflush failed in ray_psend"); - copystruct(&r_queue[r_send_next], r); + r_queue[r_send_next] = *r; r_send_next++; } -int -ray_pqueue(r) /* queue a ray for computation */ -RAY *r; +extern int +ray_pqueue( /* queue a ray for computation */ + RAY *r +) { if (r == NULL) return(0); @@ -244,31 +255,32 @@ RAY *r; if (sendq_full()) { RAY mySend; int rval; - copystruct(&mySend, r); + mySend = *r; /* wait for a result */ rval = ray_presult(r, 0); /* put new ray in queue */ - copystruct(&r_queue[r_send_next], &mySend); + r_queue[r_send_next] = mySend; r_send_next++; return(rval); /* done */ } /* add ray to send queue */ - copystruct(&r_queue[r_send_next], r); + r_queue[r_send_next] = *r; r_send_next++; /* check for returned ray... */ if (r_recv_first >= r_recv_next) return(0); /* ...one is sitting in queue */ - copystruct(r, &r_queue[r_recv_first]); + *r = r_queue[r_recv_first]; r_recv_first++; return(1); } -int -ray_presult(r, poll) /* check for a completed ray */ -RAY *r; -int poll; +extern int +ray_presult( /* check for a completed ray */ + RAY *r, + int poll +) { static struct timeval tpoll; /* zero timeval struct */ static fd_set readset, errset; @@ -279,11 +291,11 @@ int poll; return(0); /* check queued results first */ if (r_recv_first < r_recv_next) { - copystruct(r, &r_queue[r_recv_first]); + *r = r_queue[r_recv_first]; r_recv_first++; return(1); } - n = ray_nprocs - ray_idle; /* pending before flush? */ + n = ray_pnprocs - ray_pnidle; /* pending before flush? */ if (ray_pflush() < 0) /* send new rays to process */ return(-1); @@ -291,18 +303,18 @@ int poll; r_recv_first = r_recv_next = RAYQLEN; if (!poll) /* count newly sent unless polling */ - n = ray_nprocs - ray_idle; + n = ray_pnprocs - ray_pnidle; if (n <= 0) /* return if nothing to await */ return(0); getready: /* any children waiting for us? */ - for (pn = ray_nprocs; pn--; ) + for (pn = ray_pnprocs; pn--; ) if (FD_ISSET(r_proc[pn].fd_recv, &readset) || FD_ISSET(r_proc[pn].fd_recv, &errset)) break; /* call select if we must */ if (pn < 0) { FD_ZERO(&readset); FD_ZERO(&errset); n = 0; - for (pn = ray_nprocs; pn--; ) { + for (pn = ray_pnprocs; pn--; ) { if (r_proc[pn].npending > 0) FD_SET(r_proc[pn].fd_recv, &readset); FD_SET(r_proc[pn].fd_recv, &errset); @@ -338,7 +350,7 @@ getready: /* any children waiting for us? */ if (n <= 0) FD_CLR(r_proc[pn].fd_recv, &errset); r_proc[pn].npending = 0; - ray_idle++; + ray_pnidle++; /* check for rendering errors */ if (!ok) { ray_pclose(0); /* process died -- clean up */ @@ -354,15 +366,16 @@ getready: /* any children waiting for us? */ rp->slights = NULL; } /* return first ray received */ - copystruct(r, &r_queue[r_recv_first]); + *r = r_queue[r_recv_first]; r_recv_first++; return(1); } -void -ray_pdone(freall) /* reap children and free data */ -int freall; +extern void +ray_pdone( /* reap children and free data */ + int freall +) { ray_pclose(0); /* close child processes */ @@ -375,9 +388,10 @@ int freall; static void -ray_pchild(fd_in, fd_out) /* process rays (never returns) */ -int fd_in; -int fd_out; +ray_pchild( /* process rays (never returns) */ + int fd_in, + int fd_out +) { int n; register int i; @@ -421,13 +435,14 @@ int fd_out; } -void -ray_popen(nadd) /* open the specified # processes */ -int nadd; +extern void +ray_popen( /* open the specified # processes */ + int nadd +) { /* check if our table has room */ - if (ray_nprocs + nadd > MAX_NPROCS) - nadd = MAX_NPROCS - ray_nprocs; + if (ray_pnprocs + nadd > MAX_NPROCS) + nadd = MAX_NPROCS - ray_pnprocs; if (nadd <= 0) return; fflush(stderr); /* clear pending output */ @@ -436,9 +451,9 @@ int nadd; int p0[2], p1[2]; if (pipe(p0) < 0 || pipe(p1) < 0) error(SYSTEM, "cannot create pipe"); - if ((r_proc[ray_nprocs].pid = fork()) == 0) { + if ((r_proc[ray_pnprocs].pid = fork()) == 0) { int pn; /* close others' descriptors */ - for (pn = ray_nprocs; pn--; ) { + for (pn = ray_pnprocs; pn--; ) { close(r_proc[pn].fd_send); close(r_proc[pn].fd_recv); } @@ -446,21 +461,22 @@ int nadd; /* following call never returns */ ray_pchild(p1[0], p0[1]); } - if (r_proc[ray_nprocs].pid < 0) + if (r_proc[ray_pnprocs].pid < 0) error(SYSTEM, "cannot fork child process"); close(p1[0]); close(p0[1]); - r_proc[ray_nprocs].fd_send = p1[1]; - r_proc[ray_nprocs].fd_recv = p0[0]; - r_proc[ray_nprocs].npending = 0; - ray_nprocs++; - ray_idle++; + r_proc[ray_pnprocs].fd_send = p1[1]; + r_proc[ray_pnprocs].fd_recv = p0[0]; + r_proc[ray_pnprocs].npending = 0; + ray_pnprocs++; + ray_pnidle++; } } -void -ray_pclose(nsub) /* close one or more child processes */ -int nsub; +extern void +ray_pclose( /* close one or more child processes */ + int nsub +) { static int inclose = 0; RAY res; @@ -469,26 +485,26 @@ int nsub; return; inclose++; /* check argument */ - if ((nsub <= 0 | nsub > ray_nprocs)) - nsub = ray_nprocs; + if ((nsub <= 0) | (nsub > ray_pnprocs)) + nsub = ray_pnprocs; /* clear our ray queue */ while (ray_presult(&res,0) > 0) ; /* clean up children */ while (nsub--) { int status; - ray_nprocs--; - close(r_proc[ray_nprocs].fd_recv); - close(r_proc[ray_nprocs].fd_send); - while (wait(&status) != r_proc[ray_nprocs].pid) + ray_pnprocs--; + close(r_proc[ray_pnprocs].fd_recv); + close(r_proc[ray_pnprocs].fd_send); + while (wait(&status) != r_proc[ray_pnprocs].pid) ; if (status) { sprintf(errmsg, "rendering process %d exited with code %d", - r_proc[ray_nprocs].pid, status>>8); + r_proc[ray_pnprocs].pid, status>>8); error(WARNING, errmsg); } - ray_idle--; + ray_pnidle--; } inclose--; }
