--- ray/src/rt/rayinit.cal 1991/11/12 17:10:31 2.1 +++ ray/src/rt/rayinit.cal 2018/01/18 19:43:43 2.17 @@ -1,5 +1,4 @@ -{ SCCSid "$SunId$ LBL" } - +{ RCSid $Id: rayinit.cal,v 2.17 2018/01/18 19:43:43 greg Exp $ } { Initialization file for Radiance. @@ -9,6 +8,7 @@ Nx, Ny, Nz - surface normal Px, Py, Pz - intersection point T - distance from start + Ts - single ray (shadow) distance Rdot - ray dot product S - world scale Tx, Ty, Tz - world origin @@ -17,12 +17,20 @@ Kx, Ky, Kz - world k unit vector arg(n) - real arguments, arg(0) is count - For brdf functions, the following are also available: + For mesh objects, the following are available: + Lu, Lv - local (u,v) coordinates + + For *func & *data materials, the following are also available: + NxP, NyP, NzP - perturbed surface normal RdotP - perturbed ray dot product CrP, CgP, CbP - perturbed material color + For prism1 and prism2 types, the following are available: + + DxA, DyA, DzA - direction to target light source + Library functions: if(a, b, c) - if a positive, return b, else c @@ -33,7 +41,7 @@ sin(x), cos(x), tan(x), asin(x), acos(x), - atan(x), atan2(y,x) - standard trig functions + atan(x), atan2(y,x) - standard trig functions (radians) floor(x), ceil(x) - g.l.b. & l.u.b. @@ -43,11 +51,9 @@ rand(x) - pseudo-random function (0 to 1) - hermite(p0,p1,r0,r1,t) - 1-dimensional hermite polynomial + noise3(x,y,z), noise3x(x,y,z), + noise3y(x,y,z), noise3z(x,y,z) - noise function with gradient (-1 to 1) - noise3(x,y,z), noise3a(x,y,z), - noise3b(x,y,z), noise3c(x,y,z) - noise function with gradient (-1 to 1) - fnoise3(x,y,z) - fractal noise function (-1 to 1) } @@ -56,17 +62,22 @@ AC = arg(0); A1 = arg(1); A2 = arg(2); A3 = arg(3); A4 = arg(4); A5 = arg(5); A6 = arg(6); A7 = arg(7); A8 = arg(8); A9 = arg(9); A10 = arg(10); +noise3a(x,y,z) : noise3x(x,y,z); +noise3b(x,y,z) : noise3y(x,y,z); +noise3c(x,y,z) : noise3z(x,y,z); + { Forward compatibility (?) } D(i) = select(i, Dx, Dy, Dz); N(i) = select(i, Nx, Ny, Nz); P(i) = select(i, Px, Py, Pz); -noise3d(i,x,y,z) = select(i, noise3a(x,y,z), noise3b(x,y,z), noise3c(x,y,z)); +noise3d(i,x,y,z) : select(i, noise3x(x,y,z), noise3y(x,y,z), noise3z(x,y,z)); { More robust versions of library functions } bound(a,x,b) : if(a-x, a, if(x-b, b, x)); Acos(x) : acos(bound(-1,x,1)); Asin(x) : asin(bound(-1,x,1)); -Exp(x) : if(-x-60, 0, exp(x)); +Atan2(y,x) : if(x*x+y*y, atan2(y,x), 0); +Exp(x) : if(-x-100, 0, exp(x)); Sqrt(x) : if(x, sqrt(x), 0); { Useful constants } @@ -78,6 +89,7 @@ FTINY : 1e-7; and(a,b) : if( a, b, a ); or(a,b) : if( a, a, b ); not(a) : if( a, -1, 1 ); +xor(a,b) : if( a, not(b), b ); abs(x) : if( x, x, -x ); sgn(x) : if( x, 1, if(-x, -1, 0) ); sq(x) : x*x; @@ -89,65 +101,70 @@ mod(n,d) : n - floor(n/d)*d; tri(n,d) : abs( d - mod(n-d,2*d) ); linterp(t,p0,p1) : (1-t)*p0 + t*p1; -noop(v) = v; -clip(v) = bound(0,v,1); -noneg(v) = if(v,v,0); -red(r,g,b) = if(r,r,0); -green(r,g,b) = if(g,g,0); -blue(r,g,b) = if(b,b,0); -grey(r,g,b) = .3*r + .59*g + .11*b; -clip_r(r,g,b) = bound(0,r,1); -clip_g(r,g,b) = bound(0,g,1); -clip_b(r,g,b) = bound(0,b,1); -clipgrey(r,g,b) = bound(0,grey(r,g,b),1); +noop(v) : v; +clip(v) : bound(0,v,1); +noneg(v) : if(v,v,0); +red(r,g,b) : if(r,r,0); +green(r,g,b) : if(g,g,0); +blue(r,g,b) : if(b,b,0); +grey(r,g,b) : noneg(.265074126*r + .670114631*g + .064811243*b); +clip_r(r,g,b) : bound(0,r,1); +clip_g(r,g,b) : bound(0,g,1); +clip_b(r,g,b) : bound(0,b,1); +clipgrey(r,g,b) : min(grey(r,g,b),1); dot(v1,v2) : v1(1)*v2(1) + v1(2)*v2(2) + v1(3)*v2(3); cross(i,v1,v2) : select(i, v1(2)*v2(3) - v1(3)*v2(2), v1(3)*v2(1) - v1(1)*v2(3), v1(1)*v2(2) - v1(2)*v2(1)); -fade(near_val,far_val,dist) = far_val + +fade(near_val,far_val,dist) : far_val + if (16-dist, (near_val-far_val)/(1+dist*dist), 0); -bezier(p1, p2, p3, p4, t) = p1 * (1+t*(-3+t*(3-t))) + +hermite(p0,p1,r0,r1,t) : p0 * ((2*t-3)*t*t+1) + + p1 * (-2*t+3)*t*t + + r0 * (((t-2)*t+1)*t) + + r1 * ((t-1)*t*t); + +bezier(p1, p2, p3, p4, t) : p1 * (1+t*(-3+t*(3-t))) + p2 * 3*t*(1+t*(-2+t)) + p3 * 3*t*t*(1-t) + p4 * t*t*t ; -bspline(pp, p0, p1, pn, t) = pp * (1/6+t*(-.5+t*(.5-1/6*t))) + +bspline(pp, p0, p1, pn, t) : pp * (1/6+t*(-.5+t*(.5-1/6*t))) + p0 * (2/3+t*t*(-1+.5*t)) + p1 * (1/6+t*(.5+t*(.5-.5*t))) + pn * (1/6*t*t*t) ; -turbulence(x,y,z,s) = if( s-1.01, 0, abs(noise3(x/s,y/s,z/s)*s) + +turbulence(x,y,z,s) : if( s-1.01, 0, abs(noise3(x/s,y/s,z/s)*s) + turbulence(x,y,z,2*s) ); -turbulencea(x,y,z,s) = if( s-1.01, 0, - sgn(noise3(x/s,y/s,z/s))*noise3a(x/s,y/s,z/s) + - turbulencea(x,y,z,2*s) ); -turbulenceb(x,y,z,s) = if( s-1.01, 0, - sgn(noise3(x/s,y/s,z/s))*noise3b(x/s,y/s,z/s) + - turbulenceb(x,y,z,2*s) ); -turbulencec(x,y,z,s) = if( s-1.01, 0, - sgn(noise3(x/s,y/s,z/s))*noise3c(x/s,y/s,z/s) + - turbulencec(x,y,z,2*s) ); +turbulencex(x,y,z,s) : if( s-1.01, 0, + sgn(noise3(x/s,y/s,z/s))*noise3x(x/s,y/s,z/s) + + turbulencex(x,y,z,2*s) ); +turbulencey(x,y,z,s) : if( s-1.01, 0, + sgn(noise3(x/s,y/s,z/s))*noise3y(x/s,y/s,z/s) + + turbulencey(x,y,z,2*s) ); +turbulencez(x,y,z,s) : if( s-1.01, 0, + sgn(noise3(x/s,y/s,z/s))*noise3z(x/s,y/s,z/s) + + turbulencez(x,y,z,2*s) ); { Normal distribution from uniform range (0,1) } -un2`private(t) : t - (2.515517+t*(.802853+t*.010328))/ +un2`P.(t) : t - (2.515517+t*(.802853+t*.010328))/ (1+t*(1.432788+t*(.189269+t*.001308))) ; -un1`private(p) : un2`private(sqrt(log(1/p/p))) ; +un1`P.(p) : un2`P.(sqrt(-2*log(p))) ; -unif2norm(p) : if( .5-p, un1`private(p), -un1`private(1-p) ) ; +unif2norm(p) : if( .5-p, -un1`P.(p), un1`P.(1-p) ) ; nrand(x) = unif2norm(rand(x)); { Local (u,v) coordinates for planar surfaces } -crosslen`private = Nx*Nx + Ny*Ny; - { U is distance from origin in XY-plane } -U = if( crosslen`private - FTINY, - (Py*Nx - Px*Ny)/crosslen`private, +crosslen`P. = Nx*Nx + Ny*Ny; + { U is distance from projected Z-axis } +U = if( crosslen`P. - FTINY, + (Py*Nx - Px*Ny)/crosslen`P., Px); { V is defined so that N = U x V } -V = if( crosslen`private - FTINY, - Pz - Nz*(Px*Nx + Py*Ny)/crosslen`private, +V = if( crosslen`P. - FTINY, + Pz - Nz*(Px*Nx + Py*Ny)/crosslen`P., Py);
