root/radiance/ray/src/rt/rayinit.cal
Tue Mar 11 19:29:05 2003 UTC (21 years, 3 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1
Diff to previous 2.13 , to selected 1.1
Diff to previous 2.12 , to selected 1.1
Mon Oct 19 15:45:30 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 2.11: +29 -29 lines
Diff to previous 2.11 , to selected 1.1
changed turbulence{a,b,c} to turbulence{x,y,z}
gave more functions the constant attribute
changed use of `private context to simply `P
Thu Oct 31 11:05:35 1996 UTC (27 years, 7 months ago) by greg
Changes since 2.10: +10 -6 lines
Diff to previous 2.10 , to selected 1.1
renamed noise3{a,b,c} to noise3{x,y,z}
Thu Feb 29 11:13:34 1996 UTC (28 years, 3 months ago) by greg
Diff to previous 2.9 , to selected 1.1
updated grey calculation for standard colors
Fri Aug 25 11:43:29 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.8: +4 -0 lines
Diff to previous 2.8 , to selected 1.1
added comment about DxA, DyA and DzA for prism1 and prism2 types
Thu Dec 9 16:56:28 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.7 , to selected 1.1
added Atan2(y,x) function for machines that barf on atan2(0,0)
Wed Jun 2 10:23:20 1993 UTC (31 years ago) by greg
Diff to previous 2.6 , to selected 1.1
fixed comment on U definition
Thu Mar 18 12:36:03 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.5 , to selected 1.1
changed unif2norm to preserve sense
Wed Oct 21 11:20:26 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.4 , to selected 1.1
minor optimization of clipgrey(r,g,b)
Mon Aug 17 16:01:24 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.3 , to selected 1.1
improved definition of grey(r,g,b)
Tue Mar 3 13:58:11 1992 UTC (32 years, 3 months ago) by greg
Diff to previous 2.2 , to selected 1.1
added Ts variable for single ray (or shadow ray) distance
Mon Nov 25 09:51:57 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 2.1 , to selected 1.1
extended range of Exp(x) function
Tue Nov 12 17:10:31 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 1.1
Wed Oct 23 08:50:27 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.3 , to selected 1.1
added nonzero guarantee to red(), green() and blue()
Wed Oct 9 11:36:45 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.2: +10 -0 lines
Diff to previous 1.2 , to selected 1.1
added normally distributed random variable nrand(x)
Tue Sep 3 12:28:05 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.1: +11 -4 lines
Diff to previous 1.1
added local (u,v) coordinates for planar surfaces
Revision 1.1 - (view) (download) (annotate) - [selected]
Thu Aug 22 08:57:19 1991 UTC (32 years, 10 months ago) by greg
