1 |
{ SCCSid "$SunId$ LBL" } |
2 |
3 |
4 |
Initialization file for Radiance. |
5 |
6 |
The following are predefined: |
7 |
8 |
Dx, Dy, Dz - ray direction |
9 |
Nx, Ny, Nz - surface normal |
10 |
Px, Py, Pz - intersection point |
11 |
T - distance from start |
12 |
Ts - single ray (shadow) distance |
13 |
Rdot - ray dot product |
14 |
S - world scale |
15 |
Tx, Ty, Tz - world origin |
16 |
Ix, Iy, Iz - world i unit vector |
17 |
Jx, Jy, Jz - world j unit vector |
18 |
Kx, Ky, Kz - world k unit vector |
19 |
arg(n) - real arguments, arg(0) is count |
20 |
21 |
For brdf functions, the following are also available: |
22 |
23 |
NxP, NyP, NzP - perturbed surface normal |
24 |
RdotP - perturbed ray dot product |
25 |
CrP, CgP, CbP - perturbed material color |
26 |
27 |
For prism1 and prism2 types, the following are available: |
28 |
29 |
DxA, DyA, DzA - direction to target light source |
30 |
31 |
Library functions: |
32 |
33 |
if(a, b, c) - if a positive, return b, else c |
34 |
35 |
select(N, a1, a2, ..) - return aN |
36 |
37 |
sqrt(x) - square root function |
38 |
39 |
sin(x), cos(x), tan(x), |
40 |
asin(x), acos(x), |
41 |
atan(x), atan2(y,x) - standard trig functions |
42 |
43 |
floor(x), ceil(x) - g.l.b. & l.u.b. |
44 |
45 |
exp(x), log(x), log10(x) - exponent and log functions |
46 |
47 |
erf(z), erfc(z) - error functions |
48 |
49 |
rand(x) - pseudo-random function (0 to 1) |
50 |
51 |
hermite(p0,p1,r0,r1,t) - 1-dimensional hermite polynomial |
52 |
53 |
noise3(x,y,z), noise3x(x,y,z), |
54 |
noise3y(x,y,z), noise3z(x,y,z) - noise function with gradient (-1 to 1) |
55 |
56 |
fnoise3(x,y,z) - fractal noise function (-1 to 1) |
57 |
58 |
59 |
{ Backward compatibility } |
60 |
AC = arg(0); |
61 |
A1 = arg(1); A2 = arg(2); A3 = arg(3); A4 = arg(4); A5 = arg(5); |
62 |
A6 = arg(6); A7 = arg(7); A8 = arg(8); A9 = arg(9); A10 = arg(10); |
63 |
64 |
noise3a(x,y,z) : noise3x(x,y,z); |
65 |
noise3b(x,y,z) : noise3y(x,y,z); |
66 |
noise3c(x,y,z) : noise3z(x,y,z); |
67 |
68 |
{ Forward compatibility (?) } |
69 |
D(i) = select(i, Dx, Dy, Dz); |
70 |
N(i) = select(i, Nx, Ny, Nz); |
71 |
P(i) = select(i, Px, Py, Pz); |
72 |
noise3d(i,x,y,z) : select(i, noise3x(x,y,z), noise3y(x,y,z), noise3z(x,y,z)); |
73 |
74 |
{ More robust versions of library functions } |
75 |
bound(a,x,b) : if(a-x, a, if(x-b, b, x)); |
76 |
Acos(x) : acos(bound(-1,x,1)); |
77 |
Asin(x) : asin(bound(-1,x,1)); |
78 |
Atan2(y,x) : if(x*x+y*y, atan2(y,x), 0); |
79 |
Exp(x) : if(-x-100, 0, exp(x)); |
80 |
Sqrt(x) : if(x, sqrt(x), 0); |
81 |
82 |
{ Useful constants } |
83 |
PI : 3.14159265358979323846; |
84 |
DEGREE : PI/180; |
85 |
FTINY : 1e-7; |
86 |
87 |
{ Useful functions } |
88 |
and(a,b) : if( a, b, a ); |
89 |
or(a,b) : if( a, a, b ); |
90 |
not(a) : if( a, -1, 1 ); |
91 |
abs(x) : if( x, x, -x ); |
92 |
sgn(x) : if( x, 1, if(-x, -1, 0) ); |
93 |
sq(x) : x*x; |
94 |
max(a,b) : if( a-b, a, b ); |
95 |
min(a,b) : if( a-b, b, a ); |
96 |
inside(a,x,b) : and(x-a,b-x); |
97 |
frac(x) : x - floor(x); |
98 |
mod(n,d) : n - floor(n/d)*d; |
99 |
tri(n,d) : abs( d - mod(n-d,2*d) ); |
100 |
linterp(t,p0,p1) : (1-t)*p0 + t*p1; |
101 |
102 |
noop(v) : v; |
103 |
clip(v) : bound(0,v,1); |
104 |
noneg(v) : if(v,v,0); |
105 |
red(r,g,b) : if(r,r,0); |
106 |
green(r,g,b) : if(g,g,0); |
107 |
blue(r,g,b) : if(b,b,0); |
108 |
grey(r,g,b) : noneg(.265074126*r + .670114631*g + .064811243*b); |
109 |
clip_r(r,g,b) : bound(0,r,1); |
110 |
clip_g(r,g,b) : bound(0,g,1); |
111 |
clip_b(r,g,b) : bound(0,b,1); |
112 |
clipgrey(r,g,b) : min(grey(r,g,b),1); |
113 |
114 |
dot(v1,v2) : v1(1)*v2(1) + v1(2)*v2(2) + v1(3)*v2(3); |
115 |
cross(i,v1,v2) : select(i, v1(2)*v2(3) - v1(3)*v2(2), |
116 |
v1(3)*v2(1) - v1(1)*v2(3), |
117 |
v1(1)*v2(2) - v1(2)*v2(1)); |
118 |
119 |
fade(near_val,far_val,dist) : far_val + |
120 |
if (16-dist, (near_val-far_val)/(1+dist*dist), 0); |
121 |
122 |
bezier(p1, p2, p3, p4, t) : p1 * (1+t*(-3+t*(3-t))) + |
123 |
p2 * 3*t*(1+t*(-2+t)) + |
124 |
p3 * 3*t*t*(1-t) + |
125 |
p4 * t*t*t ; |
126 |
127 |
bspline(pp, p0, p1, pn, t) : pp * (1/6+t*(-.5+t*(.5-1/6*t))) + |
128 |
p0 * (2/3+t*t*(-1+.5*t)) + |
129 |
p1 * (1/6+t*(.5+t*(.5-.5*t))) + |
130 |
pn * (1/6*t*t*t) ; |
131 |
132 |
turbulence(x,y,z,s) : if( s-1.01, 0, abs(noise3(x/s,y/s,z/s)*s) + |
133 |
turbulence(x,y,z,2*s) ); |
134 |
turbulencex(x,y,z,s) : if( s-1.01, 0, |
135 |
sgn(noise3(x/s,y/s,z/s))*noise3x(x/s,y/s,z/s) + |
136 |
turbulencex(x,y,z,2*s) ); |
137 |
turbulencey(x,y,z,s) : if( s-1.01, 0, |
138 |
sgn(noise3(x/s,y/s,z/s))*noise3y(x/s,y/s,z/s) + |
139 |
turbulencey(x,y,z,2*s) ); |
140 |
turbulencez(x,y,z,s) : if( s-1.01, 0, |
141 |
sgn(noise3(x/s,y/s,z/s))*noise3z(x/s,y/s,z/s) + |
142 |
turbulencez(x,y,z,2*s) ); |
143 |
144 |
{ Normal distribution from uniform range (0,1) } |
145 |
146 |
un2`P(t) : t - (2.515517+t*(.802853+t*.010328))/ |
147 |
(1+t*(1.432788+t*(.189269+t*.001308))) ; |
148 |
un1`P(p) : un2`P(sqrt(-2*log(p))) ; |
149 |
150 |
unif2norm(p) : if( .5-p, -un1`P(p), un1`P(1-p) ) ; |
151 |
152 |
nrand(x) = unif2norm(rand(x)); |
153 |
154 |
{ Local (u,v) coordinates for planar surfaces } |
155 |
crosslen`P = Nx*Nx + Ny*Ny; |
156 |
{ U is distance from projected Z-axis } |
157 |
U = if( crosslen`P - FTINY, |
158 |
(Py*Nx - Px*Ny)/crosslen`P, |
159 |
Px); |
160 |
{ V is defined so that N = U x V } |
161 |
V = if( crosslen`P - FTINY, |
162 |
Pz - Nz*(Px*Nx + Py*Ny)/crosslen`P, |
163 |
Py); |
