| 1 |
{ RCSid $Id: rayinit.cal,v 2.19 2019/06/10 13:56:52 greg Exp $ }
| 2 |
| 3 |
Initialization file for Radiance.
| 4 |
| 5 |
The following are predefined:
| 6 |
| 7 |
Dx, Dy, Dz - ray direction
| 8 |
Nx, Ny, Nz - surface normal
| 9 |
Px, Py, Pz - intersection point
| 10 |
T - distance from start
| 11 |
Ts - single ray (shadow) distance
| 12 |
Rdot - ray dot product
| 13 |
S - world scale
| 14 |
Tx, Ty, Tz - world origin
| 15 |
Ix, Iy, Iz - world i unit vector
| 16 |
Jx, Jy, Jz - world j unit vector
| 17 |
Kx, Ky, Kz - world k unit vector
| 18 |
arg(n) - real arguments, arg(0) is count
| 19 |
| 20 |
For mesh objects, the following are available:
| 21 |
| 22 |
Lu, Lv - local (u,v) coordinates
| 23 |
| 24 |
For *func & *data materials, the following are also available:
| 25 |
| 26 |
NxP, NyP, NzP - perturbed surface normal
| 27 |
RdotP - perturbed ray dot product
| 28 |
CrP, CgP, CbP - perturbed material color
| 29 |
| 30 |
For prism1 and prism2 types, the following are available:
| 31 |
| 32 |
DxA, DyA, DzA - direction to target light source
| 33 |
| 34 |
Library functions:
| 35 |
| 36 |
if(a, b, c) - if a positive, return b, else c
| 37 |
| 38 |
select(N, a1, a2, ..) - return aN
| 39 |
| 40 |
min(a1, a2, ..) - return minimum argument
| 41 |
max(a1, a2, ..) - return maximum argument
| 42 |
| 43 |
sqrt(x) - square root function
| 44 |
| 45 |
sin(x), cos(x), tan(x),
| 46 |
asin(x), acos(x),
| 47 |
atan(x), atan2(y,x) - standard trig functions (radians)
| 48 |
| 49 |
floor(x), ceil(x) - g.l.b. & l.u.b.
| 50 |
| 51 |
exp(x), log(x), log10(x) - exponent and log functions
| 52 |
| 53 |
erf(z), erfc(z) - error functions
| 54 |
| 55 |
rand(x) - pseudo-random function (0 to 1)
| 56 |
| 57 |
noise3(x,y,z), noise3x(x,y,z),
| 58 |
noise3y(x,y,z), noise3z(x,y,z) - noise function with gradient (-1 to 1)
| 59 |
| 60 |
fnoise3(x,y,z) - fractal noise function (-1 to 1)
| 61 |
| 62 |
| 63 |
{ Backward compatibility }
| 64 |
AC = arg(0);
| 65 |
A1 = arg(1); A2 = arg(2); A3 = arg(3); A4 = arg(4); A5 = arg(5);
| 66 |
A6 = arg(6); A7 = arg(7); A8 = arg(8); A9 = arg(9); A10 = arg(10);
| 67 |
| 68 |
noise3a(x,y,z) : noise3x(x,y,z);
| 69 |
noise3b(x,y,z) : noise3y(x,y,z);
| 70 |
noise3c(x,y,z) : noise3z(x,y,z);
| 71 |
| 72 |
{ Forward compatibility (?) }
| 73 |
D(i) = select(i, Dx, Dy, Dz);
| 74 |
N(i) = select(i, Nx, Ny, Nz);
| 75 |
P(i) = select(i, Px, Py, Pz);
| 76 |
noise3d(i,x,y,z) : select(i, noise3x(x,y,z), noise3y(x,y,z), noise3z(x,y,z));
| 77 |
| 78 |
{ More robust versions of library functions }
| 79 |
bound(a,x,b) : if(a-x, a, if(x-b, b, x));
| 80 |
Acos(x) : acos(bound(-1,x,1));
| 81 |
Asin(x) : asin(bound(-1,x,1));
| 82 |
Atan2(y,x) : if(x*x+y*y, atan2(y,x), 0);
| 83 |
Exp(x) : if(-x-100, 0, exp(x));
| 84 |
Sqrt(x) : if(x, sqrt(x), 0);
| 85 |
| 86 |
{ Useful constants }
| 87 |
PI : 3.14159265358979323846;
| 88 |
DEGREE : PI/180;
| 89 |
FTINY : 1e-7;
| 90 |
| 91 |
{ Useful functions }
| 92 |
and(a,b) : if( a, b, a );
| 93 |
or(a,b) : if( a, a, b );
| 94 |
not(a) : if( a, -1, 1 );
| 95 |
xor(a,b) : if( a, not(b), b );
| 96 |
abs(x) : max(x, -x);
| 97 |
sgn(x) : if( x, 1, if(-x, -1, 0) );
| 98 |
sq(x) : x*x;
| 99 |
inside(a,x,b) : and(x-a,b-x);
| 100 |
frac(x) : x - floor(x);
| 101 |
mod(n,d) : n - floor(n/d)*d;
| 102 |
tri(n,d) : abs( d - mod(n-d,2*d) );
| 103 |
linterp(t,p0,p1) : (1-t)*p0 + t*p1;
| 104 |
| 105 |
noop(v) : v;
| 106 |
clip(v) : bound(0,v,1);
| 107 |
noneg(v) : max(v,0);
| 108 |
red(r,g,b) : max(r,0);
| 109 |
green(r,g,b) : max(g,0);
| 110 |
blue(r,g,b) : max(b,0);
| 111 |
grey(r,g,b) : noneg(.265074126*r + .670114631*g + .064811243*b);
| 112 |
clip_r(r,g,b) : bound(0,r,1);
| 113 |
clip_g(r,g,b) : bound(0,g,1);
| 114 |
clip_b(r,g,b) : bound(0,b,1);
| 115 |
clipgrey(r,g,b) : min(grey(r,g,b),1);
| 116 |
| 117 |
dot(v1,v2) : v1(1)*v2(1) + v1(2)*v2(2) + v1(3)*v2(3);
| 118 |
cross(i,v1,v2) : select(i, v1(2)*v2(3) - v1(3)*v2(2),
| 119 |
v1(3)*v2(1) - v1(1)*v2(3),
| 120 |
v1(1)*v2(2) - v1(2)*v2(1));
| 121 |
| 122 |
fade(near_val,far_val,dist) : far_val +
| 123 |
if (16-dist, (near_val-far_val)/(1+dist*dist), 0);
| 124 |
| 125 |
hermite(p0,p1,r0,r1,t) : p0 * ((2*t-3)*t*t+1) +
| 126 |
p1 * (-2*t+3)*t*t +
| 127 |
r0 * (((t-2)*t+1)*t) +
| 128 |
r1 * ((t-1)*t*t);
| 129 |
| 130 |
bezier(p1, p2, p3, p4, t) : p1 * (1+t*(-3+t*(3-t))) +
| 131 |
p2 * 3*t*(1+t*(-2+t)) +
| 132 |
p3 * 3*t*t*(1-t) +
| 133 |
p4 * t*t*t ;
| 134 |
| 135 |
bspline(pp, p0, p1, pn, t) : pp * (1/6+t*(-.5+t*(.5-1/6*t))) +
| 136 |
p0 * (2/3+t*t*(-1+.5*t)) +
| 137 |
p1 * (1/6+t*(.5+t*(.5-.5*t))) +
| 138 |
pn * (1/6*t*t*t) ;
| 139 |
| 140 |
turbulence(x,y,z,s) : if( s-1.01, 0, abs(noise3(x/s,y/s,z/s)*s) +
| 141 |
turbulence(x,y,z,2*s) );
| 142 |
turbulencex(x,y,z,s) : if( s-1.01, 0,
| 143 |
sgn(noise3(x/s,y/s,z/s))*noise3x(x/s,y/s,z/s) +
| 144 |
turbulencex(x,y,z,2*s) );
| 145 |
turbulencey(x,y,z,s) : if( s-1.01, 0,
| 146 |
sgn(noise3(x/s,y/s,z/s))*noise3y(x/s,y/s,z/s) +
| 147 |
turbulencey(x,y,z,2*s) );
| 148 |
turbulencez(x,y,z,s) : if( s-1.01, 0,
| 149 |
sgn(noise3(x/s,y/s,z/s))*noise3z(x/s,y/s,z/s) +
| 150 |
turbulencez(x,y,z,2*s) );
| 151 |
| 152 |
{ Normal distribution from uniform range (0,1) }
| 153 |
| 154 |
un2`P.(t) : t - (2.515517+t*(.802853+t*.010328))/
| 155 |
(1+t*(1.432788+t*(.189269+t*.001308))) ;
| 156 |
un1`P.(p) : un2`P.(sqrt(-2*log(p))) ;
| 157 |
| 158 |
unif2norm(p) : if( .5-p, -un1`P.(p), un1`P.(1-p) ) ;
| 159 |
| 160 |
nrand(x) = unif2norm(rand(x));
| 161 |
| 162 |
{ Local (u,v) coordinates for planar surfaces }
| 163 |
crosslen`P. = Nx*Nx + Ny*Ny;
| 164 |
{ U is distance from projected Z-axis }
| 165 |
U = if( crosslen`P. - FTINY,
| 166 |
(Py*Nx - Px*Ny)/crosslen`P.,
| 167 |
Px);
| 168 |
{ V is defined so that N = U x V }
| 169 |
V = if( crosslen`P. - FTINY,
| 170 |
Pz - Nz*(Px*Nx + Py*Ny)/crosslen`P.,
| 171 |
Py);
| 172 |
| 173 |
{ Local hemisphere direction for *func & *data types }
| 174 |
{ last 3 real args = unnormalized up-vector }
| 175 |
Vux`P. = arg(AC-1)*NzP - arg(AC)*NyP;
| 176 |
Vuy`P. = arg(AC)*NxP - arg(AC-2)*NzP;
| 177 |
Vuz`P. = arg(AC-2)*NyP - arg(AC-1)*NxP;
| 178 |
vnorm`P. = 1/sqrt(Vux`P.*Vux`P. + Vuy`P.*Vuy`P. + Vuz`P.*Vuz`P.);
| 179 |
Vnx`P. = Vux`P.*vnorm`P.;
| 180 |
Vny`P. = Vuy`P.*vnorm`P.;
| 181 |
Vnz`P. = Vuz`P.*vnorm`P.;
| 182 |
Unx`P. = NyP*Vnz`P. - NzP*Vny`P.;
| 183 |
Uny`P. = NzP*Vnx`P. - NxP*Vnz`P.;
| 184 |
Unz`P. = NxP*Vny`P. - NyP*Vnx`P.;
| 185 |
{ Transform vectors, normalized (dx,dy,dz) away from surf }
| 186 |
Ldx(dx,dy,dz) = dx*Unx`P. + dy*Uny`P. + dz*Unz`P.;
| 187 |
Ldy(dx,dy,dz) = dx*Vnx`P. + dy*Vny`P. + dz*Vnz`P.;
| 188 |
Ldz(dx,dy,dz) = dx*NxP + dy*NyP + dz*NzP;
| 189 |
{ Incident vector transformed to our coords }
| 190 |
Idx = Ldx(-Dx,-Dy,-Dz);
| 191 |
Idy = Ldy(-Dx,-Dy,-Dz);
| 192 |
Idz = RdotP;
