root/radiance/ray/src/rt/rayfifo.c
Revision: 2.2
Committed: Sat Dec 12 19:01:00 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.1: +15 -7 lines
2 static const char RCSid[] = "$Id: rayfifo.c,v 2.1 2009/12/12 05:20:10 greg Exp $";
5 * rayfifo.c - parallelize ray queue that respects order
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are essentially an adjunct to raypcalls.c, providing
14 * a convenient means to get first-in/first-out behavior from multiple
15 * processor cores. The interface is quite simple, with two functions
16 * and a callback, which must be defined by the calling program. The
17 * hand-off for finished rays is assigned to ray_fifo_out, which takes
18 * a single pointer to the finished ray and returns a non-negative
19 * integer. If there is an exceptional condition where termination
20 * is desired, a negative value may be returned.
21 *
22 * The ray_fifo_in() call takes a ray that has been initialized in
23 * the same manner as for the ray_trace() call, i.e., the origin,
24 * direction, and maximum length have been assigned. The ray number
25 * will be set according to the number of rays traced since the
26 * last call to ray_fifo_flush(). This final call completes all
27 * pending ray calculations and frees the FIFO buffer. If any of
28 * the automatic calls to the ray_fifo_out callback return a
29 * negative value, processing stops and -1 is returned.
30 *
31 * Note: The ray passed to ray_fifo_in() may be overwritten
32 * arbitrarily, since it is passed to ray_pqueue().
33 */
34
35 #include "ray.h"
36 #include <string.h>
37
38 int (*ray_fifo_out)(RAY *r) = NULL; /* ray output callback */
39
40 static RAY *r_fifo_buf = NULL; /* circular FIFO out buffer */
41 static int r_fifo_len = 0; /* allocated FIFO length */
42 static RNUMBER r_fifo_start = 1; /* first awaited ray */
43 static RNUMBER r_fifo_end = 1; /* one past FIFO last */
44
45 #define r_fifo(rn) (&r_fifo_buf[(rn)&(r_fifo_len-1)])
46
47
48 static void
49 ray_fifo_growbuf(void) /* double buffer size (or set to minimum if NULL) */
50 {
51 RAY *old_buf = r_fifo_buf;
52 int old_len = r_fifo_len;
53 int i;
54
55 if (r_fifo_buf == NULL)
56 r_fifo_len = 1<<4;
57 else
58 r_fifo_len <<= 1;
59 /* allocate new */
60 r_fifo_buf = (RAY *)calloc(r_fifo_len, sizeof(RAY));
61 if (r_fifo_buf == NULL)
62 error(SYSTEM, "out of memory in ray_fifo_growbuf");
63 if (old_buf == NULL)
64 return;
65 /* copy old & free */
66 for (i = r_fifo_start; i < r_fifo_end; i++)
67 *r_fifo(i) = old_buf[i&(old_len-1)];
68
69 free(old_buf);
70 }
71
72
73 static int
74 ray_fifo_push( /* send finished ray to output (or queue it) */
75 RAY *r
76 )
77 {
78 int rv, nsent = 0;
79
80 if (ray_fifo_out == NULL)
81 error(INTERNAL, "ray_fifo_out is NULL");
82 if ((r->rno < r_fifo_start) | (r->rno >= r_fifo_end))
83 error(INTERNAL, "unexpected ray number in ray_fifo_push");
84
85 if (r->rno - r_fifo_start >= r_fifo_len)
86 ray_fifo_growbuf(); /* need more space */
87
88 if (r->rno > r_fifo_start) { /* insert into output queue */
89 *r_fifo(r->rno) = *r;
90 return(0);
91 }
92 /* r->rno == r_fifo_start, so transfer ray(s) */
93 do {
94 if ((rv = (*ray_fifo_out)(r)) < 0)
95 return(-1);
96 nsent += rv;
97 if (++r_fifo_start < r_fifo_end)
98 r = r_fifo(r_fifo_start);
99 } while (r->rno == r_fifo_start);
100
101 return(nsent);
102 }
103
104
105 int
106 ray_fifo_in( /* add ray to FIFO */
107 RAY *r
108 )
109 {
110 int rv, rval = 0;
111
112 if (r_fifo_start >= 1L<<30) { /* reset our counter */
113 if ((rv = ray_fifo_flush()) < 0)
114 return(-1);
115 rval += rv;
116 }
117 /* queue ray */
118 rayorigin(r, PRIMARY, NULL, NULL);
119 r->rno = r_fifo_end++;
120 if ((rv = ray_pqueue(r)) < 0)
121 return(-1);
122
123 if (!rv) /* no result this time? */
124 return(rval);
125
126 do { /* else send/queue result */
127 if ((rv = ray_fifo_push(r)) < 0)
128 return(-1);
129 rval += rv;
130
131 } while (ray_presult(r, -1) > 0); /* empty in-core queue */
132
133 return(rval);
134 }
135
136
137 int
138 ray_fifo_flush(void) /* flush everything and release buffer */
139 {
140 RAY myRay;
141 int rv, rval = 0;
142 /* clear parallel queue */
143 while ((rv = ray_presult(&myRay, 0)) > 0 &&
144 (rv = ray_fifo_push(&myRay)) >= 0)
145 rval += rv;
146
147 if (rv < 0) /* check for error */
148 return(-1);
149
150 if (r_fifo_start != r_fifo_end)
151 error(INTERNAL, "could not empty queue in ray_fifo_flush");
152
153 free(r_fifo_buf);
154 r_fifo_buf = NULL;
155 r_fifo_len = 0;
156 r_fifo_end = r_fifo_start = 1;
157
158 return(rval);
159 }
