root/radiance/ray/src/rt/rayfifo.c
Revision: 2.6
Committed: Wed May 2 20:42:21 2018 UTC (7 years, 3 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Corrected bug introduced in last change
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.6 static const char RCSid[] = "$Id: rayfifo.c,v 2.5 2018/04/26 18:09:55 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * rayfifo.c - parallelize ray queue that respects order
6     *
7     * External symbols declared in ray.h
8     */
9
10     #include "copyright.h"
11
12     /*
13     * These routines are essentially an adjunct to raypcalls.c, providing
14     * a convenient means to get first-in/first-out behavior from multiple
15     * processor cores. The interface is quite simple, with two functions
16     * and a callback, which must be defined by the calling program. The
17     * hand-off for finished rays is assigned to ray_fifo_out, which takes
18     * a single pointer to the finished ray and returns a non-negative
19     * integer. If there is an exceptional condition where termination
20     * is desired, a negative value may be returned.
21     *
22     * The ray_fifo_in() call takes a ray that has been initialized in
23 greg 2.4 * the same manner as for the ray_pqueue() call, i.e., rayorigin()
24     * has been called and the origin, direction and maximum distance
25     * have all been assigned. However, the ray number will be reset
26     * by ray_fifo_in() according to the number of rays traced since the
27 greg 2.1 * last call to ray_fifo_flush(). This final call completes all
28     * pending ray calculations and frees the FIFO buffer. If any of
29     * the automatic calls to the ray_fifo_out callback return a
30     * negative value, processing stops and -1 is returned.
31 greg 2.2 *
32     * Note: The ray passed to ray_fifo_in() may be overwritten
33     * arbitrarily, since it is passed to ray_pqueue().
34 greg 2.1 */
35
36     #include "ray.h"
37     #include <string.h>
38
39 greg 2.5 #ifndef MAXFIFO
40     #define MAXFIFO 4096 /* clear FIFO past this */
41     #endif
42
43 greg 2.1 int (*ray_fifo_out)(RAY *r) = NULL; /* ray output callback */
44
45     static RAY *r_fifo_buf = NULL; /* circular FIFO out buffer */
46     static int r_fifo_len = 0; /* allocated FIFO length */
47     static RNUMBER r_fifo_start = 1; /* first awaited ray */
48     static RNUMBER r_fifo_end = 1; /* one past FIFO last */
49 greg 2.3 static RNUMBER r_fifo_next = 1; /* next ray assignment */
50 greg 2.1
51     #define r_fifo(rn) (&r_fifo_buf[(rn)&(r_fifo_len-1)])
52
53
54     static void
55     ray_fifo_growbuf(void) /* double buffer size (or set to minimum if NULL) */
56     {
57     RAY *old_buf = r_fifo_buf;
58     int old_len = r_fifo_len;
59     int i;
60
61     if (r_fifo_buf == NULL)
62 greg 2.6 r_fifo_len = 1<<5; /* must be power of two */
63 greg 2.1 else
64 greg 2.6 r_fifo_len <<= 1;
65 greg 2.1 /* allocate new */
66     r_fifo_buf = (RAY *)calloc(r_fifo_len, sizeof(RAY));
67     if (r_fifo_buf == NULL)
68     error(SYSTEM, "out of memory in ray_fifo_growbuf");
69     if (old_buf == NULL)
70     return;
71     /* copy old & free */
72     for (i = r_fifo_start; i < r_fifo_end; i++)
73     *r_fifo(i) = old_buf[i&(old_len-1)];
74
75     free(old_buf);
76     }
77
78
79     static int
80     ray_fifo_push( /* send finished ray to output (or queue it) */
81     RAY *r
82     )
83     {
84     int rv, nsent = 0;
85
86     if (ray_fifo_out == NULL)
87     error(INTERNAL, "ray_fifo_out is NULL");
88 greg 2.3 if ((r->rno < r_fifo_start) | (r->rno >= r_fifo_next))
89     error(INTERNAL, "unexpected ray number in ray_fifo_push()");
90 greg 2.2
91 greg 2.1 if (r->rno > r_fifo_start) { /* insert into output queue */
92 greg 2.4 while (r->rno - r_fifo_start >= r_fifo_len)
93 greg 2.3 ray_fifo_growbuf(); /* need more space */
94 greg 2.1 *r_fifo(r->rno) = *r;
95 greg 2.3 if (r->rno >= r_fifo_end)
96     r_fifo_end = r->rno + 1;
97 greg 2.1 return(0);
98     }
99     /* r->rno == r_fifo_start, so transfer ray(s) */
100     do {
101 greg 2.3 rv = (*ray_fifo_out)(r);
102     r->rno = 0; /* flag this entry complete */
103     if (rv < 0)
104 greg 2.1 return(-1);
105     nsent += rv;
106     if (++r_fifo_start < r_fifo_end)
107     r = r_fifo(r_fifo_start);
108 greg 2.3 else if (r_fifo_start > r_fifo_end)
109     r_fifo_end = r_fifo_start;
110 greg 2.1 } while (r->rno == r_fifo_start);
111
112     return(nsent);
113     }
114
115
116     int
117     ray_fifo_in( /* add ray to FIFO */
118     RAY *r
119     )
120     {
121 greg 2.3 static int incall = 0; /* prevent recursion */
122     int rv, rval = 0;
123
124     if (incall++)
125     error(INTERNAL, "recursive call to ray_fifo_in()");
126 greg 2.1
127 greg 2.5 /* need to reset our FIFO? */
128     if ((r_fifo_start >= 1L<<30) | (r_fifo_len > MAXFIFO)) {
129 greg 2.1 if ((rv = ray_fifo_flush()) < 0)
130 greg 2.3 {--incall; return(-1);}
131 greg 2.1 rval += rv;
132     }
133     /* queue ray */
134 greg 2.3 r->rno = r_fifo_next++;
135 greg 2.1 if ((rv = ray_pqueue(r)) < 0)
136 greg 2.3 {--incall; return(-1);}
137 greg 2.1
138     if (!rv) /* no result this time? */
139 greg 2.3 {--incall; return(rval);}
140 greg 2.2
141     do { /* else send/queue result */
142     if ((rv = ray_fifo_push(r)) < 0)
143 greg 2.3 {--incall; return(-1);}
144 greg 2.2 rval += rv;
145
146     } while (ray_presult(r, -1) > 0); /* empty in-core queue */
147
148 greg 2.3 --incall; return(rval);
149 greg 2.1 }
150
151
152     int
153     ray_fifo_flush(void) /* flush everything and release buffer */
154     {
155     RAY myRay;
156     int rv, rval = 0;
157     /* clear parallel queue */
158     while ((rv = ray_presult(&myRay, 0)) > 0 &&
159     (rv = ray_fifo_push(&myRay)) >= 0)
160     rval += rv;
161
162 greg 2.3 if (rv < 0) /* check for exception */
163 greg 2.1 return(-1);
164
165     if (r_fifo_start != r_fifo_end)
166 greg 2.3 error(INTERNAL, "could not empty queue in ray_fifo_flush()");
167 greg 2.1
168 greg 2.3 if (r_fifo_buf != NULL) {
169     free(r_fifo_buf);
170     r_fifo_buf = NULL; r_fifo_len = 0;
171     }
172     r_fifo_next = r_fifo_end = r_fifo_start = 1;
173 greg 2.1
174     return(rval);
175     }
