--- ray/src/rt/rayfifo.c 2009/12/12 19:01:00 2.2 +++ ray/src/rt/rayfifo.c 2009/12/13 19:13:04 2.4 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rayfifo.c,v 2.2 2009/12/12 19:01:00 greg Exp $"; +static const char RCSid[] = "$Id: rayfifo.c,v 2.4 2009/12/13 19:13:04 greg Exp $"; #endif /* * rayfifo.c - parallelize ray queue that respects order @@ -20,9 +20,10 @@ static const char RCSid[] = "$Id: rayfifo.c,v 2.2 2009 * is desired, a negative value may be returned. * * The ray_fifo_in() call takes a ray that has been initialized in - * the same manner as for the ray_trace() call, i.e., the origin, - * direction, and maximum length have been assigned. The ray number - * will be set according to the number of rays traced since the + * the same manner as for the ray_pqueue() call, i.e., rayorigin() + * has been called and the origin, direction and maximum distance + * have all been assigned. However, the ray number will be reset + * by ray_fifo_in() according to the number of rays traced since the * last call to ray_fifo_flush(). This final call completes all * pending ray calculations and frees the FIFO buffer. If any of * the automatic calls to the ray_fifo_out callback return a @@ -41,6 +42,7 @@ static RAY *r_fifo_buf = NULL; /* circular FIFO out b static int r_fifo_len = 0; /* allocated FIFO length */ static RNUMBER r_fifo_start = 1; /* first awaited ray */ static RNUMBER r_fifo_end = 1; /* one past FIFO last */ +static RNUMBER r_fifo_next = 1; /* next ray assignment */ #define r_fifo(rn) (&r_fifo_buf[(rn)&(r_fifo_len-1)]) @@ -53,7 +55,7 @@ ray_fifo_growbuf(void) /* double buffer size (or set t int i; if (r_fifo_buf == NULL) - r_fifo_len = 1<<4; + r_fifo_len = 1<<5; else r_fifo_len <<= 1; /* allocate new */ @@ -79,23 +81,28 @@ ray_fifo_push( /* send finished ray to output (or que if (ray_fifo_out == NULL) error(INTERNAL, "ray_fifo_out is NULL"); - if ((r->rno < r_fifo_start) | (r->rno >= r_fifo_end)) - error(INTERNAL, "unexpected ray number in ray_fifo_push"); + if ((r->rno < r_fifo_start) | (r->rno >= r_fifo_next)) + error(INTERNAL, "unexpected ray number in ray_fifo_push()"); - if (r->rno - r_fifo_start >= r_fifo_len) - ray_fifo_growbuf(); /* need more space */ - if (r->rno > r_fifo_start) { /* insert into output queue */ + while (r->rno - r_fifo_start >= r_fifo_len) + ray_fifo_growbuf(); /* need more space */ *r_fifo(r->rno) = *r; + if (r->rno >= r_fifo_end) + r_fifo_end = r->rno + 1; return(0); } /* r->rno == r_fifo_start, so transfer ray(s) */ do { - if ((rv = (*ray_fifo_out)(r)) < 0) + rv = (*ray_fifo_out)(r); + r->rno = 0; /* flag this entry complete */ + if (rv < 0) return(-1); nsent += rv; if (++r_fifo_start < r_fifo_end) r = r_fifo(r_fifo_start); + else if (r_fifo_start > r_fifo_end) + r_fifo_end = r_fifo_start; } while (r->rno == r_fifo_start); return(nsent); @@ -107,30 +114,33 @@ ray_fifo_in( /* add ray to FIFO */ RAY *r ) { - int rv, rval = 0; + static int incall = 0; /* prevent recursion */ + int rv, rval = 0; - if (r_fifo_start >= 1L<<30) { /* reset our counter */ + if (incall++) + error(INTERNAL, "recursive call to ray_fifo_in()"); + + if (r_fifo_start >= 1L<<30) { /* reset our counters */ if ((rv = ray_fifo_flush()) < 0) - return(-1); + {--incall; return(-1);} rval += rv; } /* queue ray */ - rayorigin(r, PRIMARY, NULL, NULL); - r->rno = r_fifo_end++; + r->rno = r_fifo_next++; if ((rv = ray_pqueue(r)) < 0) - return(-1); + {--incall; return(-1);} if (!rv) /* no result this time? */ - return(rval); + {--incall; return(rval);} do { /* else send/queue result */ if ((rv = ray_fifo_push(r)) < 0) - return(-1); + {--incall; return(-1);} rval += rv; } while (ray_presult(r, -1) > 0); /* empty in-core queue */ - return(rval); + --incall; return(rval); } @@ -144,16 +154,17 @@ ray_fifo_flush(void) /* flush everything and release b (rv = ray_fifo_push(&myRay)) >= 0) rval += rv; - if (rv < 0) /* check for error */ + if (rv < 0) /* check for exception */ return(-1); if (r_fifo_start != r_fifo_end) - error(INTERNAL, "could not empty queue in ray_fifo_flush"); + error(INTERNAL, "could not empty queue in ray_fifo_flush()"); - free(r_fifo_buf); - r_fifo_buf = NULL; - r_fifo_len = 0; - r_fifo_end = r_fifo_start = 1; + if (r_fifo_buf != NULL) { + free(r_fifo_buf); + r_fifo_buf = NULL; r_fifo_len = 0; + } + r_fifo_next = r_fifo_end = r_fifo_start = 1; return(rval); }
