root/radiance/ray/src/rt/rayfifo.c
Revision: 2.3
Committed: Sat Dec 12 23:08:13 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.2: +32 -21 lines
Bug fixes and performance improvements to rtrace -n option
2 static const char RCSid[] = "$Id: rayfifo.c,v 2.2 2009/12/12 19:01:00 greg Exp $";
5 * rayfifo.c - parallelize ray queue that respects order
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are essentially an adjunct to raypcalls.c, providing
14 * a convenient means to get first-in/first-out behavior from multiple
15 * processor cores. The interface is quite simple, with two functions
16 * and a callback, which must be defined by the calling program. The
17 * hand-off for finished rays is assigned to ray_fifo_out, which takes
18 * a single pointer to the finished ray and returns a non-negative
19 * integer. If there is an exceptional condition where termination
20 * is desired, a negative value may be returned.
21 *
22 * The ray_fifo_in() call takes a ray that has been initialized in
23 * the same manner as for the ray_trace() call, i.e., the origin,
24 * direction, and maximum length have been assigned. The ray number
25 * will be set according to the number of rays traced since the
26 * last call to ray_fifo_flush(). This final call completes all
27 * pending ray calculations and frees the FIFO buffer. If any of
28 * the automatic calls to the ray_fifo_out callback return a
29 * negative value, processing stops and -1 is returned.
30 *
31 * Note: The ray passed to ray_fifo_in() may be overwritten
32 * arbitrarily, since it is passed to ray_pqueue().
33 */
34
35 #include "ray.h"
36 #include <string.h>
37
38 int (*ray_fifo_out)(RAY *r) = NULL; /* ray output callback */
39
40 static RAY *r_fifo_buf = NULL; /* circular FIFO out buffer */
41 static int r_fifo_len = 0; /* allocated FIFO length */
42 static RNUMBER r_fifo_start = 1; /* first awaited ray */
43 static RNUMBER r_fifo_end = 1; /* one past FIFO last */
44 static RNUMBER r_fifo_next = 1; /* next ray assignment */
45
46 #define r_fifo(rn) (&r_fifo_buf[(rn)&(r_fifo_len-1)])
47
48
49 static void
50 ray_fifo_growbuf(void) /* double buffer size (or set to minimum if NULL) */
51 {
52 RAY *old_buf = r_fifo_buf;
53 int old_len = r_fifo_len;
54 int i;
55
56 if (r_fifo_buf == NULL)
57 r_fifo_len = 1<<4;
58 else
59 r_fifo_len <<= 1;
60 /* allocate new */
61 r_fifo_buf = (RAY *)calloc(r_fifo_len, sizeof(RAY));
62 if (r_fifo_buf == NULL)
63 error(SYSTEM, "out of memory in ray_fifo_growbuf");
64 if (old_buf == NULL)
65 return;
66 /* copy old & free */
67 for (i = r_fifo_start; i < r_fifo_end; i++)
68 *r_fifo(i) = old_buf[i&(old_len-1)];
69
70 free(old_buf);
71 }
72
73
74 static int
75 ray_fifo_push( /* send finished ray to output (or queue it) */
76 RAY *r
77 )
78 {
79 int rv, nsent = 0;
80
81 if (ray_fifo_out == NULL)
82 error(INTERNAL, "ray_fifo_out is NULL");
83 if ((r->rno < r_fifo_start) | (r->rno >= r_fifo_next))
84 error(INTERNAL, "unexpected ray number in ray_fifo_push()");
85
86 if (r->rno > r_fifo_start) { /* insert into output queue */
87 if (r->rno - r_fifo_start >= r_fifo_len)
88 ray_fifo_growbuf(); /* need more space */
89 *r_fifo(r->rno) = *r;
90 if (r->rno >= r_fifo_end)
91 r_fifo_end = r->rno + 1;
92 return(0);
93 }
94 /* r->rno == r_fifo_start, so transfer ray(s) */
95 do {
96 rv = (*ray_fifo_out)(r);
97 r->rno = 0; /* flag this entry complete */
98 if (rv < 0)
99 return(-1);
100 nsent += rv;
101 if (++r_fifo_start < r_fifo_end)
102 r = r_fifo(r_fifo_start);
103 else if (r_fifo_start > r_fifo_end)
104 r_fifo_end = r_fifo_start;
105 } while (r->rno == r_fifo_start);
106
107 return(nsent);
108 }
109
110
111 int
112 ray_fifo_in( /* add ray to FIFO */
113 RAY *r
114 )
115 {
116 static int incall = 0; /* prevent recursion */
117 int rv, rval = 0;
118
119 if (incall++)
120 error(INTERNAL, "recursive call to ray_fifo_in()");
121
122 if (r_fifo_start >= 1L<<30) { /* reset our counters */
123 if ((rv = ray_fifo_flush()) < 0)
124 {--incall; return(-1);}
125 rval += rv;
126 }
127 /* queue ray */
128 rayorigin(r, PRIMARY, NULL, NULL);
129 r->rno = r_fifo_next++;
130 if ((rv = ray_pqueue(r)) < 0)
131 {--incall; return(-1);}
132
133 if (!rv) /* no result this time? */
134 {--incall; return(rval);}
135
136 do { /* else send/queue result */
137 if ((rv = ray_fifo_push(r)) < 0)
138 {--incall; return(-1);}
139 rval += rv;
140
141 } while (ray_presult(r, -1) > 0); /* empty in-core queue */
142
143 --incall; return(rval);
144 }
145
146
147 int
148 ray_fifo_flush(void) /* flush everything and release buffer */
149 {
150 RAY myRay;
151 int rv, rval = 0;
152 /* clear parallel queue */
153 while ((rv = ray_presult(&myRay, 0)) > 0 &&
154 (rv = ray_fifo_push(&myRay)) >= 0)
155 rval += rv;
156
157 if (rv < 0) /* check for exception */
158 return(-1);
159
160 if (r_fifo_start != r_fifo_end)
161 error(INTERNAL, "could not empty queue in ray_fifo_flush()");
162
163 if (r_fifo_buf != NULL) {
164 free(r_fifo_buf);
165 r_fifo_buf = NULL; r_fifo_len = 0;
166 }
167 r_fifo_next = r_fifo_end = r_fifo_start = 1;
168
169 return(rval);
170 }
