root/radiance/ray/src/rt/rayfifo.c
Revision: 2.1
Committed: Sat Dec 12 05:20:10 2009 UTC (14 years, 6 months ago) by greg
5 * rayfifo.c - parallelize ray queue that respects order
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are essentially an adjunct to raypcalls.c, providing
14 * a convenient means to get first-in/first-out behavior from multiple
15 * processor cores. The interface is quite simple, with two functions
16 * and a callback, which must be defined by the calling program. The
17 * hand-off for finished rays is assigned to ray_fifo_out, which takes
18 * a single pointer to the finished ray and returns a non-negative
19 * integer. If there is an exceptional condition where termination
20 * is desired, a negative value may be returned.
21 *
22 * The ray_fifo_in() call takes a ray that has been initialized in
23 * the same manner as for the ray_trace() call, i.e., the origin,
24 * direction, and maximum length have been assigned. The ray number
25 * will be set according to the number of rays traced since the
26 * last call to ray_fifo_flush(). This final call completes all
27 * pending ray calculations and frees the FIFO buffer. If any of
28 * the automatic calls to the ray_fifo_out callback return a
29 * negative value, processing stops and -1 is returned.
30 */
31
32 #include "ray.h"
33 #include <string.h>
34
35 int (*ray_fifo_out)(RAY *r) = NULL; /* ray output callback */
36
37 static RAY *r_fifo_buf = NULL; /* circular FIFO out buffer */
38 static int r_fifo_len = 0; /* allocated FIFO length */
39 static RNUMBER r_fifo_start = 1; /* first awaited ray */
40 static RNUMBER r_fifo_end = 1; /* one past FIFO last */
41
42 #define r_fifo(rn) (&r_fifo_buf[(rn)&(r_fifo_len-1)])
43
44
45 static void
46 ray_fifo_growbuf(void) /* double buffer size (or set to minimum if NULL) */
47 {
48 RAY *old_buf = r_fifo_buf;
49 int old_len = r_fifo_len;
50 int i;
51
52 if (r_fifo_buf == NULL)
53 r_fifo_len = 1<<4;
54 else
55 r_fifo_len <<= 1;
56 /* allocate new */
57 r_fifo_buf = (RAY *)calloc(r_fifo_len, sizeof(RAY));
58 if (r_fifo_buf == NULL)
59 error(SYSTEM, "out of memory in ray_fifo_growbuf");
60 if (old_buf == NULL)
61 return;
62 /* copy old & free */
63 for (i = r_fifo_start; i < r_fifo_end; i++)
64 *r_fifo(i) = old_buf[i&(old_len-1)];
65
66 free(old_buf);
67 }
68
69
70 static int
71 ray_fifo_push( /* send finished ray to output (or queue it) */
72 RAY *r
73 )
74 {
75 int rv, nsent = 0;
76
77 if (ray_fifo_out == NULL)
78 error(INTERNAL, "ray_fifo_out is NULL");
79 if ((r->rno < r_fifo_start) | (r->rno >= r_fifo_end))
80 error(INTERNAL, "unexpected ray number in ray_fifo_push");
81
82 if (r->rno > r_fifo_start) { /* insert into output queue */
83 if (r->rno - r_fifo_start >= r_fifo_len)
84 ray_fifo_growbuf();
85 *r_fifo(r->rno) = *r;
86 return(0);
87 }
88 /* r->rno == r_fifo_start, so transfer ray(s) */
89 do {
90 if ((rv = (*ray_fifo_out)(r)) < 0)
91 return(-1);
92 nsent += rv;
93 if (++r_fifo_start < r_fifo_end)
94 r = r_fifo(r_fifo_start);
95 } while (r->rno == r_fifo_start);
96
97 return(nsent);
98 }
99
100
101 int
102 ray_fifo_in( /* add ray to FIFO */
103 RAY *r
104 )
105 {
106 int rv, rval = 0;
107
108 if (r_fifo_start >= 1L<<30) { /* reset our counter */
109 if ((rv = ray_fifo_flush()) < 0)
110 return(-1);
111 rval += rv;
112 }
113 /* queue ray */
114 rayorigin(r, PRIMARY, NULL, NULL);
115 r->rno = r_fifo_end++;
116 if ((rv = ray_pqueue(r)) < 0)
117 return(-1);
118
119 if (!rv) /* no result this time? */
120 return(rval);
121 /* else send/queue result */
122 if ((rv = ray_fifo_push(r)) < 0)
123 return(-1);
124 rval += rv;
125 return(rval);
126 }
127
128
129 int
130 ray_fifo_flush(void) /* flush everything and release buffer */
131 {
132 RAY myRay;
133 int rv, rval = 0;
134 /* clear parallel queue */
135 while ((rv = ray_presult(&myRay, 0)) > 0 &&
136 (rv = ray_fifo_push(&myRay)) >= 0)
137 rval += rv;
138
139 if (rv < 0) /* check for error */
140 return(-1);
141
142 if (r_fifo_start != r_fifo_end)
143 error(INTERNAL, "could not empty queue in ray_fifo_flush");
144
145 free(r_fifo_buf);
146 r_fifo_buf = NULL;
147 r_fifo_len = 0;
148 r_fifo_end = r_fifo_start = 1;
149
150 return(rval);
151 }
