root/radiance/ray/src/rt/rayfifo.c
Revision: 2.5
Committed: Thu Apr 26 18:09:55 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.4: +9 -4 lines
Keep FIFO buffer from growing out of control
2 static const char RCSid[] = "$Id: rayfifo.c,v 2.4 2009/12/13 19:13:04 greg Exp $";
5 * rayfifo.c - parallelize ray queue that respects order
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are essentially an adjunct to raypcalls.c, providing
14 * a convenient means to get first-in/first-out behavior from multiple
15 * processor cores. The interface is quite simple, with two functions
16 * and a callback, which must be defined by the calling program. The
17 * hand-off for finished rays is assigned to ray_fifo_out, which takes
18 * a single pointer to the finished ray and returns a non-negative
19 * integer. If there is an exceptional condition where termination
20 * is desired, a negative value may be returned.
21 *
22 * The ray_fifo_in() call takes a ray that has been initialized in
23 * the same manner as for the ray_pqueue() call, i.e., rayorigin()
24 * has been called and the origin, direction and maximum distance
25 * have all been assigned. However, the ray number will be reset
26 * by ray_fifo_in() according to the number of rays traced since the
27 * last call to ray_fifo_flush(). This final call completes all
28 * pending ray calculations and frees the FIFO buffer. If any of
29 * the automatic calls to the ray_fifo_out callback return a
30 * negative value, processing stops and -1 is returned.
31 *
32 * Note: The ray passed to ray_fifo_in() may be overwritten
33 * arbitrarily, since it is passed to ray_pqueue().
34 */
35
36 #include "ray.h"
37 #include <string.h>
38
39 #ifndef MAXFIFO
40 #define MAXFIFO 4096 /* clear FIFO past this */
41 #endif
42
43 int (*ray_fifo_out)(RAY *r) = NULL; /* ray output callback */
44
45 static RAY *r_fifo_buf = NULL; /* circular FIFO out buffer */
46 static int r_fifo_len = 0; /* allocated FIFO length */
47 static RNUMBER r_fifo_start = 1; /* first awaited ray */
48 static RNUMBER r_fifo_end = 1; /* one past FIFO last */
49 static RNUMBER r_fifo_next = 1; /* next ray assignment */
50
51 #define r_fifo(rn) (&r_fifo_buf[(rn)&(r_fifo_len-1)])
52
53
54 static void
55 ray_fifo_growbuf(void) /* double buffer size (or set to minimum if NULL) */
56 {
57 RAY *old_buf = r_fifo_buf;
58 int old_len = r_fifo_len;
59 int i;
60
61 if (r_fifo_buf == NULL)
62 r_fifo_len = 32;
63 else
64 r_fifo_len = r_fifo_len*3/2;
65 /* allocate new */
66 r_fifo_buf = (RAY *)calloc(r_fifo_len, sizeof(RAY));
67 if (r_fifo_buf == NULL)
68 error(SYSTEM, "out of memory in ray_fifo_growbuf");
69 if (old_buf == NULL)
70 return;
71 /* copy old & free */
72 for (i = r_fifo_start; i < r_fifo_end; i++)
73 *r_fifo(i) = old_buf[i&(old_len-1)];
74
75 free(old_buf);
76 }
77
78
79 static int
80 ray_fifo_push( /* send finished ray to output (or queue it) */
81 RAY *r
82 )
83 {
84 int rv, nsent = 0;
85
86 if (ray_fifo_out == NULL)
87 error(INTERNAL, "ray_fifo_out is NULL");
88 if ((r->rno < r_fifo_start) | (r->rno >= r_fifo_next))
89 error(INTERNAL, "unexpected ray number in ray_fifo_push()");
90
91 if (r->rno > r_fifo_start) { /* insert into output queue */
92 while (r->rno - r_fifo_start >= r_fifo_len)
93 ray_fifo_growbuf(); /* need more space */
94 *r_fifo(r->rno) = *r;
95 if (r->rno >= r_fifo_end)
96 r_fifo_end = r->rno + 1;
97 return(0);
98 }
99 /* r->rno == r_fifo_start, so transfer ray(s) */
100 do {
101 rv = (*ray_fifo_out)(r);
102 r->rno = 0; /* flag this entry complete */
103 if (rv < 0)
104 return(-1);
105 nsent += rv;
106 if (++r_fifo_start < r_fifo_end)
107 r = r_fifo(r_fifo_start);
108 else if (r_fifo_start > r_fifo_end)
109 r_fifo_end = r_fifo_start;
110 } while (r->rno == r_fifo_start);
111
112 return(nsent);
113 }
114
115
116 int
117 ray_fifo_in( /* add ray to FIFO */
118 RAY *r
119 )
120 {
121 static int incall = 0; /* prevent recursion */
122 int rv, rval = 0;
123
124 if (incall++)
125 error(INTERNAL, "recursive call to ray_fifo_in()");
126
127 /* need to reset our FIFO? */
128 if ((r_fifo_start >= 1L<<30) | (r_fifo_len > MAXFIFO)) {
129 if ((rv = ray_fifo_flush()) < 0)
130 {--incall; return(-1);}
131 rval += rv;
132 }
133 /* queue ray */
134 r->rno = r_fifo_next++;
135 if ((rv = ray_pqueue(r)) < 0)
136 {--incall; return(-1);}
137
138 if (!rv) /* no result this time? */
139 {--incall; return(rval);}
140
141 do { /* else send/queue result */
142 if ((rv = ray_fifo_push(r)) < 0)
143 {--incall; return(-1);}
144 rval += rv;
145
146 } while (ray_presult(r, -1) > 0); /* empty in-core queue */
147
148 --incall; return(rval);
149 }
150
151
152 int
153 ray_fifo_flush(void) /* flush everything and release buffer */
154 {
155 RAY myRay;
156 int rv, rval = 0;
157 /* clear parallel queue */
158 while ((rv = ray_presult(&myRay, 0)) > 0 &&
159 (rv = ray_fifo_push(&myRay)) >= 0)
160 rval += rv;
161
162 if (rv < 0) /* check for exception */
163 return(-1);
164
165 if (r_fifo_start != r_fifo_end)
166 error(INTERNAL, "could not empty queue in ray_fifo_flush()");
167
168 if (r_fifo_buf != NULL) {
169 free(r_fifo_buf);
170 r_fifo_buf = NULL; r_fifo_len = 0;
171 }
172 r_fifo_next = r_fifo_end = r_fifo_start = 1;
173
174 return(rval);
175 }
