| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: raycalls.c,v 2.8 2003/10/04 14:39:53 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* raycalls.c - interface for running Radiance rendering as a library
| 6 |
| 7 |
* External symbols declared in ray.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
| 13 |
* These routines are designed to aid the programmer who wishes
| 14 |
* to call Radiance as a library. Unfortunately, the system was
| 15 |
* not originally intended to be run this way, and there are some
| 16 |
* awkward limitations to contend with. The most irritating
| 17 |
* perhaps is that the global variables and functions do not have
| 18 |
* a prefix, and the symbols are a bit generic. This results in a
| 19 |
* serious invasion of the calling application's name-space, and
| 20 |
* you may need to rename either some Radiance routines or some
| 21 |
* of your routines to avoid conflicts. Another limitation is
| 22 |
* that the global variables are not gathered together into any
| 23 |
* sort of context, so it is impossible to simultaneously run
| 24 |
* this library on multiple scenes or in multiple threads.
| 25 |
* You get one scene and one thread, and if you want more, you
| 26 |
* will have to go with the process model used by the programs
| 27 |
* gen/mkillum, hd/rholo, and px/pinterp. Finally, unrecoverable
| 28 |
* errors result in a call to the application-defined function
| 29 |
* quit(). The usual thing to do is to call exit().
| 30 |
* You might want to do something else instead, like
| 31 |
* call setjmp()/longjmp() to bring you back to the calling
| 32 |
* function for recovery. You may also wish to define your own
| 33 |
* wputs(s) and eputs(s) functions to output warning and error
| 34 |
* messages, respectively.
| 35 |
| 36 |
* With those caveats, we have attempted to make the interface
| 37 |
* as simple as we can. Global variables and their defaults
| 38 |
* are defined below, and including "ray.h" declares these
| 39 |
* along with all the routines you are likely to need. First,
| 40 |
* assign the global variable progname to your argv[0], then
| 41 |
* change the rendering parameters as you like. If you have a set
| 42 |
* of option arguments you are working from, the getrenderopt(ac,av)
| 43 |
* call should be very useful. Before tracing any rays, you
| 44 |
* must read in the octree with a call to ray_init(oct).
| 45 |
* Passing NULL for the file name causes ray_init() to read
| 46 |
* the octree from the standard input -- rarely a good idea.
| 47 |
* However, one may read an octree from a program (such as
| 48 |
* oconv) by preceding a shell command by a '!' character.
| 49 |
| 50 |
* To trace a ray, define a RAY object myRay and assign:
| 51 |
| 52 |
* myRay.rorg = ( ray origin point )
| 53 |
* myRay.rdir = ( normalized ray direction )
| 54 |
* myRay.rmax = ( maximum length, or zero for no limit )
| 55 |
| 56 |
* If you are rendering from a VIEW structure, this can be
| 57 |
* accomplished with a single call for the ray at (x,y):
| 58 |
| 59 |
* myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
| 60 |
| 61 |
* Then, trace the primary ray with:
| 62 |
| 63 |
* ray_trace(&myRay);
| 64 |
| 65 |
* The resulting contents of myRay should provide you with
| 66 |
* more than enough information about what the ray hit,
| 67 |
* the computed value, etc. For further clues of how to
| 68 |
* compute irradiance, how to get callbacks on the evaluated
| 69 |
* ray tree, etc., see the contents of rtrace.c. See
| 70 |
* also the rpmain.c, rtmain.c, and rvmain.c modules
| 71 |
* to learn more how rendering options are processed.
| 72 |
| 73 |
* When you are done, you may call ray_done(1) to clean
| 74 |
* up memory used by Radiance. It doesn't free everything,
| 75 |
* but it makes a valiant effort. If you call ray_done(0),
| 76 |
* it leaves data that is likely to be reused, including
| 77 |
* loaded data files and fonts. The library may be
| 78 |
* restarted at any point by calling ray_init() on a new
| 79 |
* octree.
| 80 |
| 81 |
* The call ray_save(rp) fills a parameter structure
| 82 |
* with the current global parameter settings, which may be
| 83 |
* restored at any time with a call to ray_restore(rp).
| 84 |
* This buffer contains no linked information, and thus
| 85 |
* may be passed between processes using write() and
| 86 |
* read() calls, so long as byte order is maintained.
| 87 |
* Calling ray_restore(NULL) restores the original
| 88 |
* default parameters, which is also retrievable with
| 89 |
* the call ray_defaults(rp). (These should be the
| 90 |
* same as the defaults for rtrace.)
| 91 |
| 92 |
| 93 |
#include <string.h>
| 94 |
| 95 |
#include "ray.h"
| 96 |
#include "source.h"
| 97 |
#include "ambient.h"
| 98 |
#include "otypes.h"
| 99 |
#include "random.h"
| 100 |
#include "data.h"
| 101 |
#include "font.h"
| 102 |
| 103 |
char *progname = "unknown_app"; /* caller sets to argv[0] */
| 104 |
| 105 |
char *octname; /* octree name we are given */
| 106 |
| 107 |
char *shm_boundary = NULL; /* boundary of shared memory */
| 108 |
| 109 |
CUBE thescene; /* our scene */
| 110 |
OBJECT nsceneobjs; /* number of objects in our scene */
| 111 |
| 112 |
int dimlist[MAXDIM]; /* sampling dimensions */
| 113 |
int ndims = 0; /* number of sampling dimensions */
| 114 |
int samplendx = 0; /* index for this sample */
| 115 |
| 116 |
void (*trace)() = NULL; /* trace call */
| 117 |
| 118 |
void (*addobjnotify[8])() = {ambnotify, NULL};
| 119 |
| 120 |
int do_irrad = 0; /* compute irradiance? */
| 121 |
| 122 |
double dstrsrc = 0.0; /* square source distribution */
| 123 |
double shadthresh = .03; /* shadow threshold */
| 124 |
double shadcert = .75; /* shadow certainty */
| 125 |
int directrelay = 2; /* number of source relays */
| 126 |
int vspretest = 512; /* virtual source pretest density */
| 127 |
int directvis = 1; /* sources visible? */
| 128 |
double srcsizerat = .2; /* maximum ratio source size/dist. */
| 129 |
| 130 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
| 131 |
COLOR salbedo = BLKCOLOR; /* global scattering albedo */
| 132 |
double seccg = 0.; /* global scattering eccentricity */
| 133 |
double ssampdist = 0.; /* scatter sampling distance */
| 134 |
| 135 |
double specthresh = .15; /* specular sampling threshold */
| 136 |
double specjitter = 1.; /* specular sampling jitter */
| 137 |
| 138 |
int backvis = 1; /* back face visibility */
| 139 |
| 140 |
int maxdepth = 8; /* maximum recursion depth */
| 141 |
double minweight = 2e-3; /* minimum ray weight */
| 142 |
| 143 |
char *ambfile = NULL; /* ambient file name */
| 144 |
COLOR ambval = BLKCOLOR; /* ambient value */
| 145 |
int ambvwt = 0; /* initial weight for ambient value */
| 146 |
double ambacc = 0.1; /* ambient accuracy */
| 147 |
int ambres = 256; /* ambient resolution */
| 148 |
int ambdiv = 1024; /* ambient divisions */
| 149 |
int ambssamp = 512; /* ambient super-samples */
| 150 |
int ambounce = 0; /* ambient bounces */
| 151 |
char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
| 152 |
int ambincl = -1; /* include == 1, exclude == 0 */
| 153 |
| 154 |
| 155 |
extern void
| 156 |
ray_init( /* initialize ray-tracing calculation */
| 157 |
char *otnm
| 158 |
| 159 |
| 160 |
if (nobjects > 0) /* free old scene data */
| 161 |
ray_done(0);
| 162 |
/* initialize object types */
| 163 |
if (ofun[OBJ_SPHERE].funp == o_default)
| 164 |
initotypes();
| 165 |
/* initialize urand */
| 166 |
initurand(2048);
| 167 |
/* read scene octree */
| 168 |
readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
| 169 |
nsceneobjs = nobjects;
| 170 |
/* find and mark sources */
| 171 |
marksources();
| 172 |
/* initialize ambient calculation */
| 173 |
setambient();
| 174 |
/* ready to go... */
| 175 |
| 176 |
| 177 |
extern void
| 178 |
ray_trace( /* trace a primary ray */
| 179 |
RAY *r
| 180 |
| 181 |
| 182 |
rayorigin(r, NULL, PRIMARY, 1.0);
| 183 |
samplendx++;
| 184 |
rayvalue(r); /* assumes origin and direction are set */
| 185 |
| 186 |
| 187 |
| 188 |
extern void
| 189 |
ray_done( /* free ray-tracing data */
| 190 |
int freall
| 191 |
| 192 |
| 193 |
retainfonts = 1;
| 194 |
ambdone();
| 195 |
ambnotify(OVOID);
| 196 |
freesources();
| 197 |
freeobjects(0, nobjects);
| 198 |
donesets();
| 199 |
octdone();
| 200 |
thescene.cutree = EMPTY;
| 201 |
octname = NULL;
| 202 |
if (freall) {
| 203 |
retainfonts = 0;
| 204 |
freefont(NULL);
| 205 |
freedata(NULL);
| 206 |
initurand(0);
| 207 |
| 208 |
if (nobjects > 0) {
| 209 |
sprintf(errmsg, "%ld objects left after call to ray_done()",
| 210 |
nobjects);
| 211 |
error(WARNING, errmsg);
| 212 |
| 213 |
| 214 |
| 215 |
| 216 |
extern void
| 217 |
ray_save( /* save current parameter settings */
| 218 |
RAYPARAMS *rp
| 219 |
| 220 |
| 221 |
int i, ndx;
| 222 |
| 223 |
if (rp == NULL)
| 224 |
return;
| 225 |
rp->do_irrad = do_irrad;
| 226 |
rp->dstrsrc = dstrsrc;
| 227 |
rp->shadthresh = shadthresh;
| 228 |
rp->shadcert = shadcert;
| 229 |
rp->directrelay = directrelay;
| 230 |
rp->vspretest = vspretest;
| 231 |
rp->directvis = directvis;
| 232 |
rp->srcsizerat = srcsizerat;
| 233 |
copycolor(rp->cextinction, cextinction);
| 234 |
copycolor(rp->salbedo, salbedo);
| 235 |
rp->seccg = seccg;
| 236 |
rp->ssampdist = ssampdist;
| 237 |
rp->specthresh = specthresh;
| 238 |
rp->specjitter = specjitter;
| 239 |
rp->backvis = backvis;
| 240 |
rp->maxdepth = maxdepth;
| 241 |
rp->minweight = minweight;
| 242 |
copycolor(rp->ambval, ambval);
| 243 |
memset(rp->ambfile, '\0', sizeof(rp->ambfile));
| 244 |
if (ambfile != NULL)
| 245 |
strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
| 246 |
rp->ambvwt = ambvwt;
| 247 |
rp->ambacc = ambacc;
| 248 |
rp->ambres = ambres;
| 249 |
rp->ambdiv = ambdiv;
| 250 |
rp->ambssamp = ambssamp;
| 251 |
rp->ambounce = ambounce;
| 252 |
rp->ambincl = ambincl;
| 253 |
memset(rp->amblval, '\0', sizeof(rp->amblval));
| 254 |
ndx = 0;
| 255 |
for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
| 256 |
int len = strlen(amblist[i]);
| 257 |
if (ndx+len >= sizeof(rp->amblval))
| 258 |
break;
| 259 |
strcpy(rp->amblval+ndx, amblist[i]);
| 260 |
ndx += len+1;
| 261 |
| 262 |
while (i <= AMBLLEN)
| 263 |
rp->amblndx[i++] = -1;
| 264 |
| 265 |
| 266 |
| 267 |
extern void
| 268 |
ray_restore( /* restore parameter settings */
| 269 |
RAYPARAMS *rp
| 270 |
| 271 |
| 272 |
register int i;
| 273 |
| 274 |
if (rp == NULL) { /* restore defaults */
| 275 |
RAYPARAMS dflt;
| 276 |
ray_defaults(&dflt);
| 277 |
ray_restore(&dflt);
| 278 |
return;
| 279 |
| 280 |
/* restore saved settings */
| 281 |
do_irrad = rp->do_irrad;
| 282 |
dstrsrc = rp->dstrsrc;
| 283 |
shadthresh = rp->shadthresh;
| 284 |
shadcert = rp->shadcert;
| 285 |
directrelay = rp->directrelay;
| 286 |
vspretest = rp->vspretest;
| 287 |
directvis = rp->directvis;
| 288 |
srcsizerat = rp->srcsizerat;
| 289 |
copycolor(cextinction, rp->cextinction);
| 290 |
copycolor(salbedo, rp->salbedo);
| 291 |
seccg = rp->seccg;
| 292 |
ssampdist = rp->ssampdist;
| 293 |
specthresh = rp->specthresh;
| 294 |
specjitter = rp->specjitter;
| 295 |
backvis = rp->backvis;
| 296 |
maxdepth = rp->maxdepth;
| 297 |
minweight = rp->minweight;
| 298 |
copycolor(ambval, rp->ambval);
| 299 |
ambvwt = rp->ambvwt;
| 300 |
ambdiv = rp->ambdiv;
| 301 |
ambssamp = rp->ambssamp;
| 302 |
ambounce = rp->ambounce;
| 303 |
for (i = 0; rp->amblndx[i] >= 0; i++)
| 304 |
amblist[i] = rp->amblval + rp->amblndx[i];
| 305 |
| 306 |
amblist[i++] = NULL;
| 307 |
ambincl = rp->ambincl;
| 308 |
/* update ambient calculation */
| 309 |
ambnotify(OVOID);
| 310 |
if (thescene.cutree != EMPTY) {
| 311 |
int newamb = (ambfile == NULL) ? rp->ambfile[0] :
| 312 |
strcmp(ambfile, rp->ambfile) ;
| 313 |
| 314 |
if (amblist[0] != NULL)
| 315 |
for (i = 0; i < nobjects; i++)
| 316 |
ambnotify(i);
| 317 |
| 318 |
ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
| 319 |
if (newamb) {
| 320 |
ambres = rp->ambres;
| 321 |
ambacc = rp->ambacc;
| 322 |
setambient();
| 323 |
} else {
| 324 |
setambres(rp->ambres);
| 325 |
setambacc(rp->ambacc);
| 326 |
| 327 |
} else {
| 328 |
| 329 |
| 330 |
| 331 |
| 332 |
| 333 |
| 334 |
| 335 |
extern void
| 336 |
ray_defaults( /* get default parameter values */
| 337 |
RAYPARAMS *rp
| 338 |
| 339 |
| 340 |
int i;
| 341 |
| 342 |
if (rp == NULL)
| 343 |
return;
| 344 |
| 345 |
rp->do_irrad = 0;
| 346 |
rp->dstrsrc = 0.0;
| 347 |
rp->shadthresh = .03;
| 348 |
rp->shadcert = .75;
| 349 |
rp->directrelay = 2;
| 350 |
rp->vspretest = 512;
| 351 |
rp->directvis = 1;
| 352 |
rp->srcsizerat = .2;
| 353 |
setcolor(rp->cextinction, 0., 0., 0.);
| 354 |
setcolor(rp->salbedo, 0., 0., 0.);
| 355 |
rp->seccg = 0.;
| 356 |
rp->ssampdist = 0.;
| 357 |
rp->specthresh = .15;
| 358 |
rp->specjitter = 1.;
| 359 |
rp->backvis = 1;
| 360 |
rp->maxdepth = 8;
| 361 |
rp->minweight = 2e-3;
| 362 |
setcolor(rp->ambval, 0., 0., 0.);
| 363 |
| 364 |
rp->ambvwt = 0;
| 365 |
rp->ambres = 256;
| 366 |
rp->ambacc = 0.1;
| 367 |
rp->ambdiv = 1024;
| 368 |
rp->ambssamp = 512;
| 369 |
rp->ambounce = 0;
| 370 |
rp->ambincl = -1;
| 371 |
| 372 |
for (i = AMBLLEN+1; i--; )
| 373 |
rp->amblndx[i] = -1;
| 374 |
