root/radiance/ray/src/rt/raycalls.c
Revision: 2.26
Committed: Tue Jan 24 21:54:49 2023 UTC (2 years, 4 months ago) by greg
2 static const char RCSid[] = "$Id: raycalls.c,v 2.25 2019/04/19 16:29:10 greg Exp $";
5 * raycalls.c - interface for running Radiance rendering as a library
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are designed to aid the programmer who wishes
14 * to call Radiance as a library. Unfortunately, the system was
15 * not originally intended to be run this way, and there are some
16 * awkward limitations to contend with. The most irritating
17 * perhaps is that the global variables and functions do not have
18 * a prefix, and the symbols are a bit generic. This results in a
19 * serious invasion of the calling application's name-space, and
20 * you may need to rename either some Radiance routines or some
21 * of your routines to avoid conflicts. Another limitation is
22 * that the global variables are not gathered together into any
23 * sort of context, so it is impossible to simultaneously run
24 * this library on multiple scenes or in multiple threads.
25 * You get one scene and one thread, and if you want more, you
26 * will have to go with the process model defined in raypcalls.c.
27 * Finally, unrecoverable errors result in a call to the application-
28 * defined function quit(). The usual thing to do is to call exit().
29 * You might want to do something else instead, like
30 * call setjmp()/longjmp() to bring you back to the calling
31 * function for recovery. You may also wish to define your own
32 * wputs(s) and eputs(s) functions to output warning and error
33 * messages, respectively.
34 *
35 * With those caveats, we have attempted to make the interface
36 * as simple as we can. Global variables and their defaults
37 * are defined below, and including "ray.h" declares these
38 * along with all the routines you are likely to need. First,
39 * assign the global variable progname to your argv[0], then
40 * change the rendering parameters as you like. If you have a set
41 * of option arguments you are working from, the getrenderopt(ac,av)
42 * call should be very useful. Before tracing any rays, you
43 * must read in the octree with a call to ray_init(oct).
44 * Passing NULL for the file name causes ray_init() to read
45 * the octree from the standard input -- rarely a good idea.
46 * However, one may read an octree from a program (such as
47 * oconv) by preceding a shell command by a '!' character.
48 *
49 * To trace a ray, define a RAY object myRay and assign:
50 *
51 * myRay.rorg = ( ray origin point )
52 * myRay.rdir = ( normalized ray direction )
53 * myRay.rmax = ( maximum length, or zero for no limit )
54 *
55 * If you are rendering from a VIEW structure, this can be
56 * accomplished with a single call for the ray at (x,y):
57 *
58 * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59 *
60 * Then, trace the primary ray with:
61 *
62 * ray_trace(&myRay);
63 *
64 * The resulting contents of myRay should provide you with
65 * more than enough information about what the ray hit,
66 * the computed value, etc. For further clues of how to
67 * compute irradiance, how to get callbacks on the evaluated
68 * ray tree, etc., see the contents of rtrace.c. See
69 * also the rpmain.c, rtmain.c, and rvmain.c modules
70 * to learn more how rendering options are processed.
71 *
72 * When you are done, you may call ray_done(1) to clean
73 * up memory used by Radiance. It doesn't free everything,
74 * but it makes a valiant effort. If you call ray_done(0),
75 * it leaves data that is likely to be reused, including
76 * loaded data files and fonts. The library may be
77 * restarted at any point by calling ray_init() on a new
78 * octree.
79 *
80 * The call ray_save(rp) fills a parameter structure
81 * with the current global parameter settings, which may be
82 * restored at any time with a call to ray_restore(rp).
83 * This buffer contains no linked information, and thus
84 * may be passed between processes using write() and
85 * read() calls, so long as byte order is maintained.
86 * Calling ray_restore(NULL) restores the original
87 * default parameters, which is also retrievable with
88 * the call ray_defaults(rp). (These should be the
89 * same as the defaults for rtrace.)
90 */
91
92 #include <string.h>
93 #include <time.h>
94
95 #include "ray.h"
96 #include "source.h"
97 #include "bsdf.h"
98 #include "ambient.h"
99 #include "otypes.h"
100 #include "random.h"
101 #include "data.h"
102 #include "font.h"
103 #include "pmapray.h"
104
105 char *progname = "unknown_app"; /* caller sets to argv[0] */
106
107 char *octname; /* octree name we are given */
108
109 char *shm_boundary = NULL; /* boundary of shared memory */
110
111 CUBE thescene; /* our scene */
112 OBJECT nsceneobjs; /* number of objects in our scene */
113
114 int dimlist[MAXDIM]; /* sampling dimensions */
115 int ndims = 0; /* number of sampling dimensions */
116 int samplendx = 0; /* index for this sample */
117
118 void (*trace)() = NULL; /* trace call */
119
120 void (*addobjnotify[8])() = {ambnotify, NULL};
121
122 int do_irrad = 0; /* compute irradiance? */
123
124 int rand_samp = 1; /* pure Monte Carlo sampling? */
125
126 double dstrsrc = 0.0; /* square source distribution */
127 double shadthresh = .03; /* shadow threshold */
128 double shadcert = .75; /* shadow certainty */
129 int directrelay = 2; /* number of source relays */
130 int vspretest = 512; /* virtual source pretest density */
131 int directvis = 1; /* sources visible? */
132 double srcsizerat = .2; /* maximum ratio source size/dist. */
133
134 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
135 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
136 double seccg = 0.; /* global scattering eccentricity */
137 double ssampdist = 0.; /* scatter sampling distance */
138
139 double specthresh = .15; /* specular sampling threshold */
140 double specjitter = 1.; /* specular sampling jitter */
141
142 int backvis = 1; /* back face visibility */
143
144 int maxdepth = -10; /* maximum recursion depth */
145 double minweight = 1e-4; /* minimum ray weight */
146
147 char *ambfile = NULL; /* ambient file name */
148 COLOR ambval = BLKCOLOR; /* ambient value */
149 int ambvwt = 0; /* initial weight for ambient value */
150 double ambacc = 0.1; /* ambient accuracy */
151 int ambres = 256; /* ambient resolution */
152 int ambdiv = 1024; /* ambient divisions */
153 int ambssamp = 512; /* ambient super-samples */
154 int ambounce = 0; /* ambient bounces */
155 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
156 int ambincl = -1; /* include == 1, exclude == 0 */
157
158
159 static void
160 reset_random(void) /* re-initialize random number generator */
161 {
162 if (rand_samp) {
163 srandom((long)time(0));
164 initurand(0);
165 } else {
166 srandom(0L);
167 initurand(2048);
168 }
169 }
170
171
172 void
173 ray_init( /* initialize ray-tracing calculation */
174 char *otnm
175 )
176 {
177 if (nobjects > 0) /* free old scene data */
178 ray_done(0);
179 /* initialize object types */
180 if (ofun[OBJ_SPHERE].funp == o_default)
181 initotypes();
182 /* initialize urand */
183 reset_random();
184 /* read scene octree */
185 readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
186 nsceneobjs = nobjects;
187 /* PMAP: Init & load photon maps */
188 ray_init_pmap();
189 /* find and mark sources */
190 marksources();
191 /* initialize ambient calculation */
192 setambient();
193 /* ready to go... (almost) */
194 }
195
196
197 void
198 ray_trace( /* trace a primary ray */
199 RAY *r
200 )
201 {
202 rayorigin(r, PRIMARY, NULL, NULL);
203 samplendx++;
204 rayvalue(r); /* assumes origin and direction are set */
205 }
206
207
208 void
209 ray_done( /* free ray-tracing data */
210 int freall
211 )
212 {
213 retainfonts = 1;
214 ambdone();
215 ambnotify(OVOID);
216 freesources();
217 freeobjects(0, nobjects);
218 donesets();
219 octdone();
220 thescene.cutree = EMPTY;
221 octname = NULL;
222 retainfonts = 0;
223 if (freall) {
224 freefont(NULL);
225 freedata(NULL);
226 SDfreeCache(NULL);
227 initurand(0);
228 }
229 if (nobjects > 0) {
230 sprintf(errmsg, "%ld objects left after call to ray_done()",
231 (long)nobjects);
232 error(WARNING, errmsg);
233 }
234
235 ray_done_pmap();
236 }
237
238
239 void
240 ray_save( /* save current parameter settings */
241 RAYPARAMS *rp
242 )
243 {
244 int i, ndx;
245
246 if (rp == NULL)
247 return;
248 rp->do_irrad = do_irrad;
249 rp->rand_samp = rand_samp;
250 rp->dstrsrc = dstrsrc;
251 rp->shadthresh = shadthresh;
252 rp->shadcert = shadcert;
253 rp->directrelay = directrelay;
254 rp->vspretest = vspretest;
255 rp->directvis = directvis;
256 rp->srcsizerat = srcsizerat;
257 copycolor(rp->cextinction, cextinction);
258 copycolor(rp->salbedo, salbedo);
259 rp->seccg = seccg;
260 rp->ssampdist = ssampdist;
261 rp->specthresh = specthresh;
262 rp->specjitter = specjitter;
263 rp->backvis = backvis;
264 rp->maxdepth = maxdepth;
265 rp->minweight = minweight;
266 if (ambfile != NULL)
267 strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
268 else
269 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
270 copycolor(rp->ambval, ambval);
271 rp->ambvwt = ambvwt;
272 rp->ambacc = ambacc;
273 rp->ambres = ambres;
274 rp->ambdiv = ambdiv;
275 rp->ambssamp = ambssamp;
276 rp->ambounce = ambounce;
277 rp->ambincl = ambincl;
278 memset(rp->amblval, '\0', sizeof(rp->amblval));
279 ndx = 0;
280 for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
281 int len = strlen(amblist[i]);
282 if (ndx+len >= sizeof(rp->amblval))
283 break;
284 strcpy(rp->amblval+ndx, amblist[i]);
285 rp->amblndx[i] = ndx;
286 ndx += len+1;
287 }
288 while (i <= AMBLLEN)
289 rp->amblndx[i++] = -1;
290
291 /* PMAP: save photon mapping params */
292 ray_save_pmap(rp);
293 }
294
295
296 void
297 ray_restore( /* restore parameter settings */
298 RAYPARAMS *rp
299 )
300 {
301 int i;
302
303 if (rp == NULL) { /* restore defaults */
304 RAYPARAMS dflt;
305 ray_defaults(&dflt);
306 ray_restore(&dflt);
307 return;
308 }
309 /* restore saved settings */
310 do_irrad = rp->do_irrad;
311 if (!rand_samp != !rp->rand_samp) {
312 rand_samp = rp->rand_samp;
313 reset_random();
314 }
315 dstrsrc = rp->dstrsrc;
316 shadthresh = rp->shadthresh;
317 shadcert = rp->shadcert;
318 directrelay = rp->directrelay;
319 vspretest = rp->vspretest;
320 directvis = rp->directvis;
321 srcsizerat = rp->srcsizerat;
322 copycolor(cextinction, rp->cextinction);
323 copycolor(salbedo, rp->salbedo);
324 seccg = rp->seccg;
325 ssampdist = rp->ssampdist;
326 specthresh = rp->specthresh;
327 specjitter = rp->specjitter;
328 backvis = rp->backvis;
329 maxdepth = rp->maxdepth;
330 minweight = rp->minweight;
331 copycolor(ambval, rp->ambval);
332 ambvwt = rp->ambvwt;
333 ambdiv = rp->ambdiv;
334 ambssamp = rp->ambssamp;
335 ambounce = rp->ambounce;
336 /* a bit dangerous if not static */
337 for (i = 0; rp->amblndx[i] >= 0; i++)
338 amblist[i] = rp->amblval + rp->amblndx[i];
339 while (i <= AMBLLEN)
340 amblist[i++] = NULL;
341 ambincl = rp->ambincl;
342 /* update ambient calculation */
343 ambnotify(OVOID);
344 if (thescene.cutree != EMPTY) {
345 int newamb = (ambfile == NULL) ? rp->ambfile[0] :
346 strcmp(ambfile, rp->ambfile) ;
347
348 if (amblist[0] != NULL)
349 for (i = 0; i < nobjects; i++)
350 ambnotify(i);
351
352 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
353 if (newamb) {
354 ambres = rp->ambres;
355 ambacc = rp->ambacc;
356 setambient();
357 } else {
358 setambres(rp->ambres);
359 setambacc(rp->ambacc);
360 }
361 } else {
362 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
363 ambres = rp->ambres;
364 ambacc = rp->ambacc;
365 }
366
367 /* PMAP: restore photon mapping params */
368 ray_restore_pmap(rp);
369 }
370
371
372 void
373 ray_defaults( /* get default parameter values */
374 RAYPARAMS *rp
375 )
376 {
377 int i;
378
379 if (rp == NULL)
380 return;
381
382 rp->do_irrad = 0;
383 rp->rand_samp = 1;
384 rp->dstrsrc = 0.0;
385 rp->shadthresh = .03;
386 rp->shadcert = .75;
387 rp->directrelay = 2;
388 rp->vspretest = 512;
389 rp->directvis = 1;
390 rp->srcsizerat = .2;
391 setcolor(rp->cextinction, 0., 0., 0.);
392 setcolor(rp->salbedo, 0., 0., 0.);
393 rp->seccg = 0.;
394 rp->ssampdist = 0.;
395 rp->specthresh = .15;
396 rp->specjitter = 1.;
397 rp->backvis = 1;
398 rp->maxdepth = -10;
399 rp->minweight = 2e-3;
400 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
401 setcolor(rp->ambval, 0., 0., 0.);
402 rp->ambvwt = 0;
403 rp->ambres = 256;
404 rp->ambacc = 0.15;
405 rp->ambdiv = 1024;
406 rp->ambssamp = 512;
407 rp->ambounce = 0;
408 rp->ambincl = -1;
409 memset(rp->amblval, '\0', sizeof(rp->amblval));
410 for (i = AMBLLEN+1; i--; )
411 rp->amblndx[i] = -1;
412
413 /* PMAP: restore photon mapping defaults */
414 ray_defaults_pmap(rp);
415 }
