root/radiance/ray/src/rt/raycalls.c
Revision: 2.17
Committed: Sat Dec 12 05:20:10 2009 UTC (14 years, 5 months ago) by greg
2 static const char RCSid[] = "$Id: raycalls.c,v 2.16 2006/04/05 06:22:56 greg Exp $";
5 * raycalls.c - interface for running Radiance rendering as a library
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are designed to aid the programmer who wishes
14 * to call Radiance as a library. Unfortunately, the system was
15 * not originally intended to be run this way, and there are some
16 * awkward limitations to contend with. The most irritating
17 * perhaps is that the global variables and functions do not have
18 * a prefix, and the symbols are a bit generic. This results in a
19 * serious invasion of the calling application's name-space, and
20 * you may need to rename either some Radiance routines or some
21 * of your routines to avoid conflicts. Another limitation is
22 * that the global variables are not gathered together into any
23 * sort of context, so it is impossible to simultaneously run
24 * this library on multiple scenes or in multiple threads.
25 * You get one scene and one thread, and if you want more, you
26 * will have to go with the process model defined in raypcalls.c.
27 * Finally, unrecoverable errors result in a call to the application-
28 * defined function quit(). The usual thing to do is to call exit().
29 * You might want to do something else instead, like
30 * call setjmp()/longjmp() to bring you back to the calling
31 * function for recovery. You may also wish to define your own
32 * wputs(s) and eputs(s) functions to output warning and error
33 * messages, respectively.
34 *
35 * With those caveats, we have attempted to make the interface
36 * as simple as we can. Global variables and their defaults
37 * are defined below, and including "ray.h" declares these
38 * along with all the routines you are likely to need. First,
39 * assign the global variable progname to your argv[0], then
40 * change the rendering parameters as you like. If you have a set
41 * of option arguments you are working from, the getrenderopt(ac,av)
42 * call should be very useful. Before tracing any rays, you
43 * must read in the octree with a call to ray_init(oct).
44 * Passing NULL for the file name causes ray_init() to read
45 * the octree from the standard input -- rarely a good idea.
46 * However, one may read an octree from a program (such as
47 * oconv) by preceding a shell command by a '!' character.
48 *
49 * To trace a ray, define a RAY object myRay and assign:
50 *
51 * myRay.rorg = ( ray origin point )
52 * myRay.rdir = ( normalized ray direction )
53 * myRay.rmax = ( maximum length, or zero for no limit )
54 *
55 * If you are rendering from a VIEW structure, this can be
56 * accomplished with a single call for the ray at (x,y):
57 *
58 * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59 *
60 * Then, trace the primary ray with:
61 *
62 * ray_trace(&myRay);
63 *
64 * The resulting contents of myRay should provide you with
65 * more than enough information about what the ray hit,
66 * the computed value, etc. For further clues of how to
67 * compute irradiance, how to get callbacks on the evaluated
68 * ray tree, etc., see the contents of rtrace.c. See
69 * also the rpmain.c, rtmain.c, and rvmain.c modules
70 * to learn more how rendering options are processed.
71 *
72 * When you are done, you may call ray_done(1) to clean
73 * up memory used by Radiance. It doesn't free everything,
74 * but it makes a valiant effort. If you call ray_done(0),
75 * it leaves data that is likely to be reused, including
76 * loaded data files and fonts. The library may be
77 * restarted at any point by calling ray_init() on a new
78 * octree.
79 *
80 * The call ray_save(rp) fills a parameter structure
81 * with the current global parameter settings, which may be
82 * restored at any time with a call to ray_restore(rp).
83 * This buffer contains no linked information, and thus
84 * may be passed between processes using write() and
85 * read() calls, so long as byte order is maintained.
86 * Calling ray_restore(NULL) restores the original
87 * default parameters, which is also retrievable with
88 * the call ray_defaults(rp). (These should be the
89 * same as the defaults for rtrace.)
90 */
91
92 #include <string.h>
93 #include <time.h>
94
95 #include "ray.h"
96 #include "source.h"
97 #include "ambient.h"
98 #include "otypes.h"
99 #include "random.h"
100 #include "data.h"
101 #include "font.h"
102
103 char *progname = "unknown_app"; /* caller sets to argv[0] */
104
105 char *octname; /* octree name we are given */
106
107 char *shm_boundary = NULL; /* boundary of shared memory */
108
109 CUBE thescene; /* our scene */
110 OBJECT nsceneobjs; /* number of objects in our scene */
111
112 int dimlist[MAXDIM]; /* sampling dimensions */
113 int ndims = 0; /* number of sampling dimensions */
114 int samplendx = 0; /* index for this sample */
115
116 void (*trace)() = NULL; /* trace call */
117
118 void (*addobjnotify[8])() = {ambnotify, NULL};
119
120 int do_irrad = 0; /* compute irradiance? */
121
122 int rand_samp = 0; /* pure Monte Carlo sampling? */
123
124 double dstrsrc = 0.0; /* square source distribution */
125 double shadthresh = .03; /* shadow threshold */
126 double shadcert = .75; /* shadow certainty */
127 int directrelay = 2; /* number of source relays */
128 int vspretest = 512; /* virtual source pretest density */
129 int directvis = 1; /* sources visible? */
130 double srcsizerat = .2; /* maximum ratio source size/dist. */
131
132 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
133 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
134 double seccg = 0.; /* global scattering eccentricity */
135 double ssampdist = 0.; /* scatter sampling distance */
136
137 double specthresh = .15; /* specular sampling threshold */
138 double specjitter = 1.; /* specular sampling jitter */
139
140 int backvis = 1; /* back face visibility */
141
142 int maxdepth = 8; /* maximum recursion depth */
143 double minweight = 2e-3; /* minimum ray weight */
144
145 char *ambfile = NULL; /* ambient file name */
146 COLOR ambval = BLKCOLOR; /* ambient value */
147 int ambvwt = 0; /* initial weight for ambient value */
148 double ambacc = 0.1; /* ambient accuracy */
149 int ambres = 256; /* ambient resolution */
150 int ambdiv = 1024; /* ambient divisions */
151 int ambssamp = 512; /* ambient super-samples */
152 int ambounce = 0; /* ambient bounces */
153 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
154 int ambincl = -1; /* include == 1, exclude == 0 */
155
156
157 void
158 ray_init( /* initialize ray-tracing calculation */
159 char *otnm
160 )
161 {
162 if (nobjects > 0) /* free old scene data */
163 ray_done(0);
164 /* initialize object types */
165 if (ofun[OBJ_SPHERE].funp == o_default)
166 initotypes();
167 /* initialize urand */
168 if (rand_samp) {
169 srandom((long)time(0));
170 initurand(0);
171 } else {
172 srandom(0L);
173 initurand(2048);
174 }
175 /* read scene octree */
176 readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
177 nsceneobjs = nobjects;
178 /* find and mark sources */
179 marksources();
180 /* initialize ambient calculation */
181 setambient();
182 /* ready to go... */
183 }
184
185 void
186 ray_trace( /* trace a primary ray */
187 RAY *r
188 )
189 {
190 rayorigin(r, PRIMARY, NULL, NULL);
191 samplendx++;
192 rayvalue(r); /* assumes origin and direction are set */
193 }
194
195
196 void
197 ray_done( /* free ray-tracing data */
198 int freall
199 )
200 {
201 retainfonts = 1;
202 ambdone();
203 ambnotify(OVOID);
204 freesources();
205 freeobjects(0, nobjects);
206 donesets();
207 octdone();
208 thescene.cutree = EMPTY;
209 octname = NULL;
210 if (freall) {
211 retainfonts = 0;
212 freefont(NULL);
213 freedata(NULL);
214 initurand(0);
215 }
216 if (nobjects > 0) {
217 sprintf(errmsg, "%ld objects left after call to ray_done()",
218 nobjects);
219 error(WARNING, errmsg);
220 }
221 }
222
223
224 void
225 ray_save( /* save current parameter settings */
226 RAYPARAMS *rp
227 )
228 {
229 int i, ndx;
230
231 if (rp == NULL)
232 return;
233 rp->do_irrad = do_irrad;
234 rp->dstrsrc = dstrsrc;
235 rp->shadthresh = shadthresh;
236 rp->shadcert = shadcert;
237 rp->directrelay = directrelay;
238 rp->vspretest = vspretest;
239 rp->directvis = directvis;
240 rp->srcsizerat = srcsizerat;
241 copycolor(rp->cextinction, cextinction);
242 copycolor(rp->salbedo, salbedo);
243 rp->seccg = seccg;
244 rp->ssampdist = ssampdist;
245 rp->specthresh = specthresh;
246 rp->specjitter = specjitter;
247 rp->backvis = backvis;
248 rp->maxdepth = maxdepth;
249 rp->minweight = minweight;
250 copycolor(rp->ambval, ambval);
251 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
252 if (ambfile != NULL)
253 strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
254 rp->ambvwt = ambvwt;
255 rp->ambacc = ambacc;
256 rp->ambres = ambres;
257 rp->ambdiv = ambdiv;
258 rp->ambssamp = ambssamp;
259 rp->ambounce = ambounce;
260 rp->ambincl = ambincl;
261 memset(rp->amblval, '\0', sizeof(rp->amblval));
262 ndx = 0;
263 for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
264 int len = strlen(amblist[i]);
265 if (ndx+len >= sizeof(rp->amblval))
266 break;
267 strcpy(rp->amblval+ndx, amblist[i]);
268 ndx += len+1;
269 }
270 while (i <= AMBLLEN)
271 rp->amblndx[i++] = -1;
272 }
273
274
275 void
276 ray_restore( /* restore parameter settings */
277 RAYPARAMS *rp
278 )
279 {
280 register int i;
281
282 if (rp == NULL) { /* restore defaults */
283 RAYPARAMS dflt;
284 ray_defaults(&dflt);
285 ray_restore(&dflt);
286 return;
287 }
288 /* restore saved settings */
289 do_irrad = rp->do_irrad;
290 dstrsrc = rp->dstrsrc;
291 shadthresh = rp->shadthresh;
292 shadcert = rp->shadcert;
293 directrelay = rp->directrelay;
294 vspretest = rp->vspretest;
295 directvis = rp->directvis;
296 srcsizerat = rp->srcsizerat;
297 copycolor(cextinction, rp->cextinction);
298 copycolor(salbedo, rp->salbedo);
299 seccg = rp->seccg;
300 ssampdist = rp->ssampdist;
301 specthresh = rp->specthresh;
302 specjitter = rp->specjitter;
303 backvis = rp->backvis;
304 maxdepth = rp->maxdepth;
305 minweight = rp->minweight;
306 copycolor(ambval, rp->ambval);
307 ambvwt = rp->ambvwt;
308 ambdiv = rp->ambdiv;
309 ambssamp = rp->ambssamp;
310 ambounce = rp->ambounce;
311 for (i = 0; rp->amblndx[i] >= 0; i++)
312 amblist[i] = rp->amblval + rp->amblndx[i];
313 while (i <= AMBLLEN)
314 amblist[i++] = NULL;
315 ambincl = rp->ambincl;
316 /* update ambient calculation */
317 ambnotify(OVOID);
318 if (thescene.cutree != EMPTY) {
319 int newamb = (ambfile == NULL) ? rp->ambfile[0] :
320 strcmp(ambfile, rp->ambfile) ;
321
322 if (amblist[0] != NULL)
323 for (i = 0; i < nobjects; i++)
324 ambnotify(i);
325
326 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
327 if (newamb) {
328 ambres = rp->ambres;
329 ambacc = rp->ambacc;
330 setambient();
331 } else {
332 setambres(rp->ambres);
333 setambacc(rp->ambacc);
334 }
335 } else {
336 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
337 ambres = rp->ambres;
338 ambacc = rp->ambacc;
339 }
340 }
341
342
343 void
344 ray_defaults( /* get default parameter values */
345 RAYPARAMS *rp
346 )
347 {
348 int i;
349
350 if (rp == NULL)
351 return;
352
353 rp->do_irrad = 0;
354 rp->dstrsrc = 0.0;
355 rp->shadthresh = .03;
356 rp->shadcert = .75;
357 rp->directrelay = 2;
358 rp->vspretest = 512;
359 rp->directvis = 1;
360 rp->srcsizerat = .2;
361 setcolor(rp->cextinction, 0., 0., 0.);
362 setcolor(rp->salbedo, 0., 0., 0.);
363 rp->seccg = 0.;
364 rp->ssampdist = 0.;
365 rp->specthresh = .15;
366 rp->specjitter = 1.;
367 rp->backvis = 1;
368 rp->maxdepth = 8;
369 rp->minweight = 2e-3;
370 setcolor(rp->ambval, 0., 0., 0.);
371 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
372 rp->ambvwt = 0;
373 rp->ambres = 256;
374 rp->ambacc = 0.15;
375 rp->ambdiv = 1024;
376 rp->ambssamp = 512;
377 rp->ambounce = 0;
378 rp->ambincl = -1;
379 memset(rp->amblval, '\0', sizeof(rp->amblval));
380 for (i = AMBLLEN+1; i--; )
381 rp->amblndx[i] = -1;
382 }
