--- ray/src/rt/raycalls.c 2019/04/19 16:29:10 2.25 +++ ray/src/rt/raycalls.c 2023/02/02 18:55:09 2.28 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: raycalls.c,v 2.25 2019/04/19 16:29:10 greg Exp $"; +static const char RCSid[] = "$Id: raycalls.c,v 2.28 2023/02/02 18:55:09 greg Exp $"; #endif /* * raycalls.c - interface for running Radiance rendering as a library @@ -119,6 +119,8 @@ void (*trace)() = NULL; /* trace call */ void (*addobjnotify[8])() = {ambnotify, NULL}; +int castonly = 0; /* only doing ray-casting? */ + int do_irrad = 0; /* compute irradiance? */ int rand_samp = 1; /* pure Monte Carlo sampling? */ @@ -142,7 +144,7 @@ double specjitter = 1.; /* specular sampling jitter * int backvis = 1; /* back face visibility */ int maxdepth = -10; /* maximum recursion depth */ -double minweight = 2e-3; /* minimum ray weight */ +double minweight = 1e-4; /* minimum ray weight */ char *ambfile = NULL; /* ambient file name */ COLOR ambval = BLKCOLOR; /* ambient value */ @@ -181,16 +183,20 @@ ray_init( /* initialize ray-tracing calculation */ initotypes(); /* initialize urand */ reset_random(); - /* read scene octree */ - readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL); + + octname = savqstr(otnm); /* read scene octree */ + readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL); nsceneobjs = nobjects; - /* PMAP: Init & load photon maps */ - ray_init_pmap(); - /* find and mark sources */ - marksources(); - /* initialize ambient calculation */ - setambient(); - /* ready to go... (almost) */ + + if (!castonly) { /* any actual ray traversal to do? */ + + ray_init_pmap(); /* PMAP: set up & load photon maps */ + + marksources(); /* find and mark sources */ + + setambient(); /* initialize ambient calculation */ + } else + distantsources(); /* else mark only distant sources */ } @@ -218,7 +224,7 @@ ray_done( /* free ray-tracing data */ donesets(); octdone(); thescene.cutree = EMPTY; - octname = NULL; + freeqstr(octname); octname = NULL; retainfonts = 0; if (freall) { freefont(NULL); @@ -382,8 +388,8 @@ ray_defaults( /* get default parameter values */ rp->do_irrad = 0; rp->rand_samp = 1; rp->dstrsrc = 0.0; - rp->shadthresh = .03; - rp->shadcert = .75; + rp->shadthresh = 0.03; + rp->shadcert = 0.75; rp->directrelay = 2; rp->vspretest = 512; rp->directvis = 1; @@ -392,16 +398,16 @@ ray_defaults( /* get default parameter values */ setcolor(rp->salbedo, 0., 0., 0.); rp->seccg = 0.; rp->ssampdist = 0.; - rp->specthresh = .15; + rp->specthresh = 0.15; rp->specjitter = 1.; rp->backvis = 1; rp->maxdepth = -10; - rp->minweight = 2e-3; + rp->minweight = 1e-4; memset(rp->ambfile, '\0', sizeof(rp->ambfile)); setcolor(rp->ambval, 0., 0., 0.); rp->ambvwt = 0; rp->ambres = 256; - rp->ambacc = 0.15; + rp->ambacc = 0.1; rp->ambdiv = 1024; rp->ambssamp = 512; rp->ambounce = 0;
