root/Development/ray/src/rt/raycalls.c
Revision: 2.10
Committed: Thu Oct 21 23:40:04 2004 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R6P1
Changes since 2.9: +5 -6 lines
Corrected ambient accuracy (-aa) setting to match rtrace
2 static const char RCSid[] = "$Id: raycalls.c,v 2.9 2004/03/30 16:13:01 schorsch Exp $";
5 * raycalls.c - interface for running Radiance rendering as a library
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are designed to aid the programmer who wishes
14 * to call Radiance as a library. Unfortunately, the system was
15 * not originally intended to be run this way, and there are some
16 * awkward limitations to contend with. The most irritating
17 * perhaps is that the global variables and functions do not have
18 * a prefix, and the symbols are a bit generic. This results in a
19 * serious invasion of the calling application's name-space, and
20 * you may need to rename either some Radiance routines or some
21 * of your routines to avoid conflicts. Another limitation is
22 * that the global variables are not gathered together into any
23 * sort of context, so it is impossible to simultaneously run
24 * this library on multiple scenes or in multiple threads.
25 * You get one scene and one thread, and if you want more, you
26 * will have to go with the process model defined in raypcalls.c.
27 * Finally, unrecoverable errors result in a call to the application-
28 * defined function quit(). The usual thing to do is to call exit().
29 * You might want to do something else instead, like
30 * call setjmp()/longjmp() to bring you back to the calling
31 * function for recovery. You may also wish to define your own
32 * wputs(s) and eputs(s) functions to output warning and error
33 * messages, respectively.
34 *
35 * With those caveats, we have attempted to make the interface
36 * as simple as we can. Global variables and their defaults
37 * are defined below, and including "ray.h" declares these
38 * along with all the routines you are likely to need. First,
39 * assign the global variable progname to your argv[0], then
40 * change the rendering parameters as you like. If you have a set
41 * of option arguments you are working from, the getrenderopt(ac,av)
42 * call should be very useful. Before tracing any rays, you
43 * must read in the octree with a call to ray_init(oct).
44 * Passing NULL for the file name causes ray_init() to read
45 * the octree from the standard input -- rarely a good idea.
46 * However, one may read an octree from a program (such as
47 * oconv) by preceding a shell command by a '!' character.
48 *
49 * To trace a ray, define a RAY object myRay and assign:
50 *
51 * myRay.rorg = ( ray origin point )
52 * myRay.rdir = ( normalized ray direction )
53 * myRay.rmax = ( maximum length, or zero for no limit )
54 *
55 * If you are rendering from a VIEW structure, this can be
56 * accomplished with a single call for the ray at (x,y):
57 *
58 * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59 *
60 * Then, trace the primary ray with:
61 *
62 * ray_trace(&myRay);
63 *
64 * The resulting contents of myRay should provide you with
65 * more than enough information about what the ray hit,
66 * the computed value, etc. For further clues of how to
67 * compute irradiance, how to get callbacks on the evaluated
68 * ray tree, etc., see the contents of rtrace.c. See
69 * also the rpmain.c, rtmain.c, and rvmain.c modules
70 * to learn more how rendering options are processed.
71 *
72 * When you are done, you may call ray_done(1) to clean
73 * up memory used by Radiance. It doesn't free everything,
74 * but it makes a valiant effort. If you call ray_done(0),
75 * it leaves data that is likely to be reused, including
76 * loaded data files and fonts. The library may be
77 * restarted at any point by calling ray_init() on a new
78 * octree.
79 *
80 * The call ray_save(rp) fills a parameter structure
81 * with the current global parameter settings, which may be
82 * restored at any time with a call to ray_restore(rp).
83 * This buffer contains no linked information, and thus
84 * may be passed between processes using write() and
85 * read() calls, so long as byte order is maintained.
86 * Calling ray_restore(NULL) restores the original
87 * default parameters, which is also retrievable with
88 * the call ray_defaults(rp). (These should be the
89 * same as the defaults for rtrace.)
90 */
91
92 #include <string.h>
93
94 #include "ray.h"
95 #include "source.h"
96 #include "ambient.h"
97 #include "otypes.h"
98 #include "random.h"
99 #include "data.h"
100 #include "font.h"
101
102 char *progname = "unknown_app"; /* caller sets to argv[0] */
103
104 char *octname; /* octree name we are given */
105
106 char *shm_boundary = NULL; /* boundary of shared memory */
107
108 CUBE thescene; /* our scene */
109 OBJECT nsceneobjs; /* number of objects in our scene */
110
111 int dimlist[MAXDIM]; /* sampling dimensions */
112 int ndims = 0; /* number of sampling dimensions */
113 int samplendx = 0; /* index for this sample */
114
115 void (*trace)() = NULL; /* trace call */
116
117 void (*addobjnotify[8])() = {ambnotify, NULL};
118
119 int do_irrad = 0; /* compute irradiance? */
120
121 double dstrsrc = 0.0; /* square source distribution */
122 double shadthresh = .03; /* shadow threshold */
123 double shadcert = .75; /* shadow certainty */
124 int directrelay = 2; /* number of source relays */
125 int vspretest = 512; /* virtual source pretest density */
126 int directvis = 1; /* sources visible? */
127 double srcsizerat = .2; /* maximum ratio source size/dist. */
128
129 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
130 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
131 double seccg = 0.; /* global scattering eccentricity */
132 double ssampdist = 0.; /* scatter sampling distance */
133
134 double specthresh = .15; /* specular sampling threshold */
135 double specjitter = 1.; /* specular sampling jitter */
136
137 int backvis = 1; /* back face visibility */
138
139 int maxdepth = 8; /* maximum recursion depth */
140 double minweight = 2e-3; /* minimum ray weight */
141
142 char *ambfile = NULL; /* ambient file name */
143 COLOR ambval = BLKCOLOR; /* ambient value */
144 int ambvwt = 0; /* initial weight for ambient value */
145 double ambacc = 0.1; /* ambient accuracy */
146 int ambres = 256; /* ambient resolution */
147 int ambdiv = 1024; /* ambient divisions */
148 int ambssamp = 512; /* ambient super-samples */
149 int ambounce = 0; /* ambient bounces */
150 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
151 int ambincl = -1; /* include == 1, exclude == 0 */
152
153
154 extern void
155 ray_init( /* initialize ray-tracing calculation */
156 char *otnm
157 )
158 {
159 if (nobjects > 0) /* free old scene data */
160 ray_done(0);
161 /* initialize object types */
162 if (ofun[OBJ_SPHERE].funp == o_default)
163 initotypes();
164 /* initialize urand */
165 initurand(2048);
166 /* read scene octree */
167 readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
168 nsceneobjs = nobjects;
169 /* find and mark sources */
170 marksources();
171 /* initialize ambient calculation */
172 setambient();
173 /* ready to go... */
174 }
175
176 extern void
177 ray_trace( /* trace a primary ray */
178 RAY *r
179 )
180 {
181 rayorigin(r, NULL, PRIMARY, 1.0);
182 samplendx++;
183 rayvalue(r); /* assumes origin and direction are set */
184 }
185
186
187 extern void
188 ray_done( /* free ray-tracing data */
189 int freall
190 )
191 {
192 retainfonts = 1;
193 ambdone();
194 ambnotify(OVOID);
195 freesources();
196 freeobjects(0, nobjects);
197 donesets();
198 octdone();
199 thescene.cutree = EMPTY;
200 octname = NULL;
201 if (freall) {
202 retainfonts = 0;
203 freefont(NULL);
204 freedata(NULL);
205 initurand(0);
206 }
207 if (nobjects > 0) {
208 sprintf(errmsg, "%ld objects left after call to ray_done()",
209 nobjects);
210 error(WARNING, errmsg);
211 }
212 }
213
214
215 extern void
216 ray_save( /* save current parameter settings */
217 RAYPARAMS *rp
218 )
219 {
220 int i, ndx;
221
222 if (rp == NULL)
223 return;
224 rp->do_irrad = do_irrad;
225 rp->dstrsrc = dstrsrc;
226 rp->shadthresh = shadthresh;
227 rp->shadcert = shadcert;
228 rp->directrelay = directrelay;
229 rp->vspretest = vspretest;
230 rp->directvis = directvis;
231 rp->srcsizerat = srcsizerat;
232 copycolor(rp->cextinction, cextinction);
233 copycolor(rp->salbedo, salbedo);
234 rp->seccg = seccg;
235 rp->ssampdist = ssampdist;
236 rp->specthresh = specthresh;
237 rp->specjitter = specjitter;
238 rp->backvis = backvis;
239 rp->maxdepth = maxdepth;
240 rp->minweight = minweight;
241 copycolor(rp->ambval, ambval);
242 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
243 if (ambfile != NULL)
244 strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
245 rp->ambvwt = ambvwt;
246 rp->ambacc = ambacc;
247 rp->ambres = ambres;
248 rp->ambdiv = ambdiv;
249 rp->ambssamp = ambssamp;
250 rp->ambounce = ambounce;
251 rp->ambincl = ambincl;
252 memset(rp->amblval, '\0', sizeof(rp->amblval));
253 ndx = 0;
254 for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
255 int len = strlen(amblist[i]);
256 if (ndx+len >= sizeof(rp->amblval))
257 break;
258 strcpy(rp->amblval+ndx, amblist[i]);
259 ndx += len+1;
260 }
261 while (i <= AMBLLEN)
262 rp->amblndx[i++] = -1;
263 }
264
265
266 extern void
267 ray_restore( /* restore parameter settings */
268 RAYPARAMS *rp
269 )
270 {
271 register int i;
272
273 if (rp == NULL) { /* restore defaults */
274 RAYPARAMS dflt;
275 ray_defaults(&dflt);
276 ray_restore(&dflt);
277 return;
278 }
279 /* restore saved settings */
280 do_irrad = rp->do_irrad;
281 dstrsrc = rp->dstrsrc;
282 shadthresh = rp->shadthresh;
283 shadcert = rp->shadcert;
284 directrelay = rp->directrelay;
285 vspretest = rp->vspretest;
286 directvis = rp->directvis;
287 srcsizerat = rp->srcsizerat;
288 copycolor(cextinction, rp->cextinction);
289 copycolor(salbedo, rp->salbedo);
290 seccg = rp->seccg;
291 ssampdist = rp->ssampdist;
292 specthresh = rp->specthresh;
293 specjitter = rp->specjitter;
294 backvis = rp->backvis;
295 maxdepth = rp->maxdepth;
296 minweight = rp->minweight;
297 copycolor(ambval, rp->ambval);
298 ambvwt = rp->ambvwt;
299 ambdiv = rp->ambdiv;
300 ambssamp = rp->ambssamp;
301 ambounce = rp->ambounce;
302 for (i = 0; rp->amblndx[i] >= 0; i++)
303 amblist[i] = rp->amblval + rp->amblndx[i];
304 while (i <= AMBLLEN)
305 amblist[i++] = NULL;
306 ambincl = rp->ambincl;
307 /* update ambient calculation */
308 ambnotify(OVOID);
309 if (thescene.cutree != EMPTY) {
310 int newamb = (ambfile == NULL) ? rp->ambfile[0] :
311 strcmp(ambfile, rp->ambfile) ;
312
313 if (amblist[0] != NULL)
314 for (i = 0; i < nobjects; i++)
315 ambnotify(i);
316
317 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
318 if (newamb) {
319 ambres = rp->ambres;
320 ambacc = rp->ambacc;
321 setambient();
322 } else {
323 setambres(rp->ambres);
324 setambacc(rp->ambacc);
325 }
326 } else {
327 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
328 ambres = rp->ambres;
329 ambacc = rp->ambacc;
330 }
331 }
332
333
334 extern void
335 ray_defaults( /* get default parameter values */
336 RAYPARAMS *rp
337 )
338 {
339 int i;
340
341 if (rp == NULL)
342 return;
343
344 rp->do_irrad = 0;
345 rp->dstrsrc = 0.0;
346 rp->shadthresh = .03;
347 rp->shadcert = .75;
348 rp->directrelay = 2;
349 rp->vspretest = 512;
350 rp->directvis = 1;
351 rp->srcsizerat = .2;
352 setcolor(rp->cextinction, 0., 0., 0.);
353 setcolor(rp->salbedo, 0., 0., 0.);
354 rp->seccg = 0.;
355 rp->ssampdist = 0.;
356 rp->specthresh = .15;
357 rp->specjitter = 1.;
358 rp->backvis = 1;
359 rp->maxdepth = 8;
360 rp->minweight = 2e-3;
361 setcolor(rp->ambval, 0., 0., 0.);
362 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
363 rp->ambvwt = 0;
364 rp->ambres = 256;
365 rp->ambacc = 0.15;
366 rp->ambdiv = 1024;
367 rp->ambssamp = 512;
368 rp->ambounce = 0;
369 rp->ambincl = -1;
370 memset(rp->amblval, '\0', sizeof(rp->amblval));
371 for (i = AMBLLEN+1; i--; )
372 rp->amblndx[i] = -1;
373 }
