root/radiance/ray/src/rt/raycalls.c
Wed Nov 2 22:09:14 2016 UTC (7 years, 7 months ago) by greg
Diff to previous 2.21 , to selected 2.9
Fixed bug in ranimove introduced with photon map
Tue Feb 24 19:39:27 2015 UTC (9 years, 3 months ago) by greg
Changes since 2.20: +13 -2 lines
Diff to previous 2.20 , to selected 2.9
Fri Feb 25 06:51:50 2011 UTC (13 years, 3 months ago) by greg
Diff to previous 2.19 , to selected 2.9
Decreased -lw default
Changes since 2.18: +4 -2 lines
Diff to previous 2.18 , to selected 2.9
Sun Sep 26 15:51:15 2010 UTC (13 years, 8 months ago) by greg
Diff to previous 2.17 , to selected 2.9
Sat Dec 12 05:20:10 2009 UTC (14 years, 6 months ago) by greg
Diff to previous 2.16 , to selected 2.9
Wed Apr 5 06:22:56 2006 UTC (18 years, 2 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.15: +9 -4 lines
Diff to previous 2.15 , to selected 2.9
Made -u+ option truly random
Tue Jun 21 00:26:44 2005 UTC (18 years, 11 months ago) by greg
Wed Jun 15 15:36:52 2005 UTC (19 years ago) by greg
Tue Jun 14 02:46:30 2005 UTC (19 years ago) by greg
Forgot to add rand_samp definition
Mon Jun 13 20:07:56 2005 UTC (19 years ago) by greg
Thu Oct 21 23:40:04 2004 UTC (19 years, 7 months ago) by greg
CVS Tags: rad3R6P1
Changes since 2.9: +5 -6 lines
Corrected ambient accuracy (-aa) setting to match rtrace
Changes since 2.8: +26 -21 lines
Sat Oct 4 14:39:53 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.7: +11 -11 lines
More adjustments and corrections to default parameters
Wed Sep 24 14:55:54 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.6: +7 -7 lines
Tue Aug 26 04:24:26 2003 UTC (20 years, 9 months ago) by greg
Minor improvements
Mon Jun 30 18:19:53 2003 UTC (20 years, 11 months ago) by greg
Removed check of urperm, which didn't work with -DMC
Changes since 2.3: +7 -11 lines
Thu May 15 05:13:35 2003 UTC (21 years, 1 month ago) by greg
Diff to selected 2.9
