root/radiance/ray/src/rt/raycalls.c
Revision: 2.6
Committed: Tue Aug 26 04:24:26 2003 UTC (21 years, 8 months ago) by greg
Minor improvements
2 static const char RCSid[] = "$Id: raycalls.c,v 2.5 2003/06/30 18:19:53 greg Exp $";
5 * raycalls.c - interface for running Radiance rendering as a library
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are designed to aid the programmer who wishes
14 * to call Radiance as a library. Unfortunately, the system was
15 * not originally intended to be run this way, and there are some
16 * awkward limitations to contend with. The most irritating
17 * perhaps is that the global variables and functions do not have
18 * a prefix, and the symbols are a bit generic. This results in a
19 * serious invasion of the calling application's name-space, and
20 * you may need to rename either some Radiance routines or some
21 * of your routines to avoid conflicts. Another limitation is
22 * that the global variables are not gathered together into any
23 * sort of context, so it is impossible to simultaneously run
24 * this library on multiple scenes or in multiple threads.
25 * You get one scene and one thread, and if you want more, you
26 * will have to go with the process model used by the programs
27 * gen/mkillum, hd/rholo, and px/pinterp. Finally, unrecoverable
28 * errors result in a call to the application-defined function
29 * quit(). The usual thing to do is to call exit().
30 * You might want to do something else instead, like
31 * call setjmp()/longjmp() to bring you back to the calling
32 * function for recovery. You may also wish to define your own
33 * wputs(s) and eputs(s) functions to output warning and error
34 * messages, respectively.
35 *
36 * With those caveats, we have attempted to make the interface
37 * as simple as we can. Global variables and their defaults
38 * are defined below, and including "ray.h" declares these
39 * along with all the routines you are likely to need. First,
40 * assign the global variable progname to your argv[0], then
41 * change the rendering parameters as you like. If you have a set
42 * of option arguments you are working from, the getrenderopt(ac,av)
43 * call should be very useful. Before tracing any rays, you
44 * must read in the octree with a call to ray_init(oct).
45 * Passing NULL for the file name causes ray_init() to read
46 * the octree from the standard input -- rarely a good idea.
47 * However, one may read an octree from a program (such as
48 * oconv) by preceding a shell command by a '!' character.
49 *
50 * To trace a ray, define a RAY object myRay and assign:
51 *
52 * myRay.rorg = ( ray origin point )
53 * myRay.rdir = ( normalized ray direction )
54 * myRay.rmax = ( maximum length, or zero for no limit )
55 *
56 * If you are rendering from a VIEW structure, this can be
57 * accomplished with a single call for the ray at (x,y):
58 *
59 * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
60 *
61 * Then, trace the primary ray with:
62 *
63 * ray_trace(&myRay);
64 *
65 * The resulting contents of myRay should provide you with
66 * more than enough information about what the ray hit,
67 * the computed value, etc. For further clues of how to
68 * compute irradiance, how to get callbacks on the evaluated
69 * ray tree, etc., see the contents of rtrace.c. See
70 * also the rpmain.c, rtmain.c, and rvmain.c modules
71 * to learn more how rendering options are processed.
72 *
73 * When you are done, you may call ray_done(1) to clean
74 * up memory used by Radiance. It doesn't free everything,
75 * but it makes a valiant effort. If you call ray_done(0),
76 * it leaves data that is likely to be reused, including
77 * loaded data files and fonts. The library may be
78 * restarted at any point by calling ray_init() on a new
79 * octree.
80 *
81 * The call ray_save(rp) fills a parameter structure
82 * with the current global parameter settings, which may be
83 * restored at any time with a call to ray_restore(rp).
84 * This buffer contains no linked information, and thus
85 * may be passed between processes using write() and
86 * read() calls, so long as byte order is maintained.
87 * Calling ray_restore(NULL) restores the original
88 * default parameters, which is also retrievable with
89 * the call ray_defaults(rp). (These should be the
90 * same as the defaults for rtrace.)
91 */
92
93 #include <string.h>
94
95 #include "ray.h"
96 #include "source.h"
97 #include "ambient.h"
98 #include "otypes.h"
99 #include "random.h"
100 #include "data.h"
101 #include "font.h"
102
103 char *progname = "unknown_app"; /* caller sets to argv[0] */
104
105 char *octname; /* octree name we are given */
106
107 char *shm_boundary = NULL; /* boundary of shared memory */
108
109 CUBE thescene; /* our scene */
110 OBJECT nsceneobjs; /* number of objects in our scene */
111
112 int dimlist[MAXDIM]; /* sampling dimensions */
113 int ndims = 0; /* number of sampling dimensions */
114 int samplendx = 0; /* index for this sample */
115
116 void (*trace)() = NULL; /* trace call */
117
118 extern void ambnotify();
119 void (*addobjnotify[8])() = {ambnotify, NULL};
120
121 int do_irrad = 0; /* compute irradiance? */
122
123 double dstrsrc = 0.0; /* square source distribution */
124 double shadthresh = .05; /* shadow threshold */
125 double shadcert = .5; /* shadow certainty */
126 int directrelay = 2; /* number of source relays */
127 int vspretest = 512; /* virtual source pretest density */
128 int directvis = 1; /* sources visible? */
129 double srcsizerat = .2; /* maximum ratio source size/dist. */
130
131 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
132 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
133 double seccg = 0.; /* global scattering eccentricity */
134 double ssampdist = 0.; /* scatter sampling distance */
135
136 double specthresh = .15; /* specular sampling threshold */
137 double specjitter = 1.; /* specular sampling jitter */
138
139 int backvis = 1; /* back face visibility */
140
141 int maxdepth = 6; /* maximum recursion depth */
142 double minweight = 4e-3; /* minimum ray weight */
143
144 char *ambfile = NULL; /* ambient file name */
145 COLOR ambval = BLKCOLOR; /* ambient value */
146 int ambvwt = 0; /* initial weight for ambient value */
147 double ambacc = 0.2; /* ambient accuracy */
148 int ambres = 128; /* ambient resolution */
149 int ambdiv = 512; /* ambient divisions */
150 int ambssamp = 0; /* ambient super-samples */
151 int ambounce = 0; /* ambient bounces */
152 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
153 int ambincl = -1; /* include == 1, exclude == 0 */
154
155
156 void
157 ray_init(otnm) /* initialize ray-tracing calculation */
158 char *otnm;
159 {
160 if (nobjects > 0) /* free old scene data */
161 ray_done(0);
162 /* initialize object types */
163 if (ofun[OBJ_SPHERE].funp == o_default)
164 initotypes();
165 /* initialize urand */
166 initurand(2048);
167 /* read scene octree */
168 readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
169 nsceneobjs = nobjects;
170 /* find and mark sources */
171 marksources();
172 /* initialize ambient calculation */
173 setambient();
174 /* ready to go... */
175 }
176
177 void
178 ray_trace(r) /* trace a primary ray */
179 RAY *r;
180 {
181 rayorigin(r, NULL, PRIMARY, 1.0);
182 samplendx++;
183 rayvalue(r); /* assumes origin and direction are set */
184 }
185
186
187 void
188 ray_done(freall) /* free ray-tracing data */
189 int freall;
190 {
191 retainfonts = 1;
192 ambdone();
193 ambnotify(OVOID);
194 freesources();
195 freeobjects(0, nobjects);
196 donesets();
197 octdone();
198 thescene.cutree = EMPTY;
199 octname = NULL;
200 if (freall) {
201 retainfonts = 0;
202 freefont(NULL);
203 freedata(NULL);
204 initurand(0);
205 }
206 if (nobjects > 0) {
207 sprintf(errmsg, "%d objects left after call to ray_done()",
208 nobjects);
209 error(WARNING, errmsg);
210 }
211 }
212
213
214 void
215 ray_save(rp) /* save current parameter settings */
216 RAYPARAMS *rp;
217 {
218 int i, ndx;
219
220 if (rp == NULL)
221 return;
222 rp->do_irrad = do_irrad;
223 rp->dstrsrc = dstrsrc;
224 rp->shadthresh = shadthresh;
225 rp->shadcert = shadcert;
226 rp->directrelay = directrelay;
227 rp->vspretest = vspretest;
228 rp->directvis = directvis;
229 rp->srcsizerat = srcsizerat;
230 copycolor(rp->cextinction, cextinction);
231 copycolor(rp->salbedo, salbedo);
232 rp->seccg = seccg;
233 rp->ssampdist = ssampdist;
234 rp->specthresh = specthresh;
235 rp->specjitter = specjitter;
236 rp->backvis = backvis;
237 rp->maxdepth = maxdepth;
238 rp->minweight = minweight;
239 copycolor(rp->ambval, ambval);
240 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
241 if (ambfile != NULL)
242 strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
243 rp->ambvwt = ambvwt;
244 rp->ambacc = ambacc;
245 rp->ambres = ambres;
246 rp->ambdiv = ambdiv;
247 rp->ambssamp = ambssamp;
248 rp->ambounce = ambounce;
249 rp->ambincl = ambincl;
250 memset(rp->amblval, '\0', sizeof(rp->amblval));
251 ndx = 0;
252 for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
253 int len = strlen(amblist[i]);
254 if (ndx+len >= sizeof(rp->amblval))
255 break;
256 strcpy(rp->amblval+ndx, amblist[i]);
257 ndx += len+1;
258 }
259 while (i <= AMBLLEN)
260 rp->amblndx[i++] = -1;
261 }
262
263
264 void
265 ray_restore(rp) /* restore parameter settings */
266 RAYPARAMS *rp;
267 {
268 register int i;
269
270 if (rp == NULL) { /* restore defaults */
271 RAYPARAMS dflt;
272 ray_defaults(&dflt);
273 ray_restore(&dflt);
274 return;
275 }
276 /* restore saved settings */
277 do_irrad = rp->do_irrad;
278 dstrsrc = rp->dstrsrc;
279 shadthresh = rp->shadthresh;
280 shadcert = rp->shadcert;
281 directrelay = rp->directrelay;
282 vspretest = rp->vspretest;
283 directvis = rp->directvis;
284 srcsizerat = rp->srcsizerat;
285 copycolor(cextinction, rp->cextinction);
286 copycolor(salbedo, rp->salbedo);
287 seccg = rp->seccg;
288 ssampdist = rp->ssampdist;
289 specthresh = rp->specthresh;
290 specjitter = rp->specjitter;
291 backvis = rp->backvis;
292 maxdepth = rp->maxdepth;
293 minweight = rp->minweight;
294 copycolor(ambval, rp->ambval);
295 ambvwt = rp->ambvwt;
296 ambdiv = rp->ambdiv;
297 ambssamp = rp->ambssamp;
298 ambounce = rp->ambounce;
299 for (i = 0; rp->amblndx[i] >= 0; i++)
300 amblist[i] = rp->amblval + rp->amblndx[i];
301 while (i <= AMBLLEN)
302 amblist[i++] = NULL;
303 ambincl = rp->ambincl;
304 /* update ambient calculation */
305 ambnotify(OVOID);
306 if (thescene.cutree != EMPTY) {
307 int newamb = (ambfile == NULL) ? rp->ambfile[0] :
308 strcmp(ambfile, rp->ambfile) ;
309
310 if (amblist[0] != NULL)
311 for (i = 0; i < nobjects; i++)
312 ambnotify(i);
313
314 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
315 if (newamb) {
316 ambres = rp->ambres;
317 ambacc = rp->ambacc;
318 setambient();
319 } else {
320 setambres(rp->ambres);
321 setambacc(rp->ambacc);
322 }
323 } else {
324 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
325 ambres = rp->ambres;
326 ambacc = rp->ambacc;
327 }
328 }
329
330
331 void
332 ray_defaults(rp) /* get default parameter values */
333 RAYPARAMS *rp;
334 {
335 int i;
336
337 if (rp == NULL)
338 return;
339
340 rp->do_irrad = 0;
341 rp->dstrsrc = 0.0;
342 rp->shadthresh = .05;
343 rp->shadcert = .5;
344 rp->directrelay = 2;
345 rp->vspretest = 512;
346 rp->directvis = 1;
347 rp->srcsizerat = .2;
348 setcolor(rp->cextinction, 0., 0., 0.);
349 setcolor(rp->salbedo, 0., 0., 0.);
350 rp->seccg = 0.;
351 rp->ssampdist = 0.;
352 rp->specthresh = .15;
353 rp->specjitter = 1.;
354 rp->backvis = 1;
355 rp->maxdepth = 6;
356 rp->minweight = 4e-3;
357 setcolor(rp->ambval, 0., 0., 0.);
358 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
359 rp->ambvwt = 0;
360 rp->ambres = 128;
361 rp->ambacc = 0.2;
362 rp->ambdiv = 512;
363 rp->ambssamp = 0;
364 rp->ambounce = 0;
365 rp->ambincl = -1;
366 memset(rp->amblval, '\0', sizeof(rp->amblval));
367 for (i = AMBLLEN+1; i--; )
368 rp->amblndx[i] = -1;
369 }
