--- ray/src/rt/raycalls.c 2004/03/30 16:13:01 2.9 +++ ray/src/rt/raycalls.c 2005/06/15 15:36:52 2.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: raycalls.c,v 2.9 2004/03/30 16:13:01 schorsch Exp $"; +static const char RCSid[] = "$Id: raycalls.c,v 2.14 2005/06/15 15:36:52 greg Exp $"; #endif /* * raycalls.c - interface for running Radiance rendering as a library @@ -23,10 +23,9 @@ static const char RCSid[] = "$Id: raycalls.c,v 2.9 200 * sort of context, so it is impossible to simultaneously run * this library on multiple scenes or in multiple threads. * You get one scene and one thread, and if you want more, you - * will have to go with the process model used by the programs - * gen/mkillum, hd/rholo, and px/pinterp. Finally, unrecoverable - * errors result in a call to the application-defined function - * quit(). The usual thing to do is to call exit(). + * will have to go with the process model defined in raypcalls.c. + * Finally, unrecoverable errors result in a call to the application- + * defined function quit(). The usual thing to do is to call exit(). * You might want to do something else instead, like * call setjmp()/longjmp() to bring you back to the calling * function for recovery. You may also wish to define your own @@ -91,6 +90,7 @@ static const char RCSid[] = "$Id: raycalls.c,v 2.9 200 */ #include +#include #include "ray.h" #include "source.h" @@ -119,6 +119,8 @@ void (*addobjnotify[8])() = {ambnotify, NULL}; int do_irrad = 0; /* compute irradiance? */ +int rand_samp = 0; /* pure Monte Carlo sampling? */ + double dstrsrc = 0.0; /* square source distribution */ double shadthresh = .03; /* shadow threshold */ double shadcert = .75; /* shadow certainty */ @@ -164,6 +166,7 @@ ray_init( /* initialize ray-tracing calculation */ initotypes(); /* initialize urand */ initurand(2048); + srandom(rand_samp ? (long)time(0) : 0L); /* read scene octree */ readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL); nsceneobjs = nobjects; @@ -179,8 +182,8 @@ ray_trace( /* trace a primary ray */ RAY *r ) { - rayorigin(r, NULL, PRIMARY, 1.0); - samplendx++; + rayorigin(r, PRIMARY, NULL, NULL); + samplendx = rand_samp ? random() : samplendx+1; rayvalue(r); /* assumes origin and direction are set */ } @@ -363,7 +366,7 @@ ray_defaults( /* get default parameter values */ memset(rp->ambfile, '\0', sizeof(rp->ambfile)); rp->ambvwt = 0; rp->ambres = 256; - rp->ambacc = 0.1; + rp->ambacc = 0.15; rp->ambdiv = 1024; rp->ambssamp = 512; rp->ambounce = 0;
