--- ray/src/rt/raycalls.c 2004/03/30 16:13:01 2.9 +++ ray/src/rt/raycalls.c 2005/04/19 01:15:06 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: raycalls.c,v 2.9 2004/03/30 16:13:01 schorsch Exp $"; +static const char RCSid[] = "$Id: raycalls.c,v 2.11 2005/04/19 01:15:06 greg Exp $"; #endif /* * raycalls.c - interface for running Radiance rendering as a library @@ -23,10 +23,9 @@ static const char RCSid[] = "$Id: raycalls.c,v 2.9 200 * sort of context, so it is impossible to simultaneously run * this library on multiple scenes or in multiple threads. * You get one scene and one thread, and if you want more, you - * will have to go with the process model used by the programs - * gen/mkillum, hd/rholo, and px/pinterp. Finally, unrecoverable - * errors result in a call to the application-defined function - * quit(). The usual thing to do is to call exit(). + * will have to go with the process model defined in raypcalls.c. + * Finally, unrecoverable errors result in a call to the application- + * defined function quit(). The usual thing to do is to call exit(). * You might want to do something else instead, like * call setjmp()/longjmp() to bring you back to the calling * function for recovery. You may also wish to define your own @@ -179,7 +178,7 @@ ray_trace( /* trace a primary ray */ RAY *r ) { - rayorigin(r, NULL, PRIMARY, 1.0); + rayorigin(r, PRIMARY, NULL, NULL); samplendx++; rayvalue(r); /* assumes origin and direction are set */ } @@ -363,7 +362,7 @@ ray_defaults( /* get default parameter values */ memset(rp->ambfile, '\0', sizeof(rp->ambfile)); rp->ambvwt = 0; rp->ambres = 256; - rp->ambacc = 0.1; + rp->ambacc = 0.15; rp->ambdiv = 1024; rp->ambssamp = 512; rp->ambounce = 0;
