root/Development/ray/src/rt/raycalls.c
Revision: 2.15
Committed: Tue Jun 21 00:26:44 2005 UTC (20 years, 6 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.15 static const char RCSid[] = "$Id: raycalls.c,v 2.14 2005/06/15 15:36:52 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * raycalls.c - interface for running Radiance rendering as a library
6     *
7     * External symbols declared in ray.h
8     */
9
10 greg 2.2 #include "copyright.h"
11 greg 2.1
12     /*
13     * These routines are designed to aid the programmer who wishes
14     * to call Radiance as a library. Unfortunately, the system was
15     * not originally intended to be run this way, and there are some
16     * awkward limitations to contend with. The most irritating
17     * perhaps is that the global variables and functions do not have
18     * a prefix, and the symbols are a bit generic. This results in a
19     * serious invasion of the calling application's name-space, and
20     * you may need to rename either some Radiance routines or some
21     * of your routines to avoid conflicts. Another limitation is
22     * that the global variables are not gathered together into any
23     * sort of context, so it is impossible to simultaneously run
24     * this library on multiple scenes or in multiple threads.
25     * You get one scene and one thread, and if you want more, you
26 greg 2.10 * will have to go with the process model defined in raypcalls.c.
27     * Finally, unrecoverable errors result in a call to the application-
28     * defined function quit(). The usual thing to do is to call exit().
29 greg 2.1 * You might want to do something else instead, like
30     * call setjmp()/longjmp() to bring you back to the calling
31     * function for recovery. You may also wish to define your own
32     * wputs(s) and eputs(s) functions to output warning and error
33     * messages, respectively.
34     *
35     * With those caveats, we have attempted to make the interface
36     * as simple as we can. Global variables and their defaults
37     * are defined below, and including "ray.h" declares these
38     * along with all the routines you are likely to need. First,
39     * assign the global variable progname to your argv[0], then
40     * change the rendering parameters as you like. If you have a set
41     * of option arguments you are working from, the getrenderopt(ac,av)
42     * call should be very useful. Before tracing any rays, you
43     * must read in the octree with a call to ray_init(oct).
44     * Passing NULL for the file name causes ray_init() to read
45     * the octree from the standard input -- rarely a good idea.
46     * However, one may read an octree from a program (such as
47     * oconv) by preceding a shell command by a '!' character.
48     *
49     * To trace a ray, define a RAY object myRay and assign:
50     *
51     * myRay.rorg = ( ray origin point )
52     * myRay.rdir = ( normalized ray direction )
53     * myRay.rmax = ( maximum length, or zero for no limit )
54     *
55     * If you are rendering from a VIEW structure, this can be
56     * accomplished with a single call for the ray at (x,y):
57     *
58     * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59     *
60     * Then, trace the primary ray with:
61     *
62     * ray_trace(&myRay);
63     *
64     * The resulting contents of myRay should provide you with
65     * more than enough information about what the ray hit,
66     * the computed value, etc. For further clues of how to
67     * compute irradiance, how to get callbacks on the evaluated
68     * ray tree, etc., see the contents of rtrace.c. See
69     * also the rpmain.c, rtmain.c, and rvmain.c modules
70     * to learn more how rendering options are processed.
71     *
72     * When you are done, you may call ray_done(1) to clean
73     * up memory used by Radiance. It doesn't free everything,
74     * but it makes a valiant effort. If you call ray_done(0),
75     * it leaves data that is likely to be reused, including
76     * loaded data files and fonts. The library may be
77     * restarted at any point by calling ray_init() on a new
78     * octree.
79     *
80 greg 2.3 * The call ray_save(rp) fills a parameter structure
81 greg 2.1 * with the current global parameter settings, which may be
82     * restored at any time with a call to ray_restore(rp).
83     * This buffer contains no linked information, and thus
84     * may be passed between processes using write() and
85     * read() calls, so long as byte order is maintained.
86     * Calling ray_restore(NULL) restores the original
87     * default parameters, which is also retrievable with
88     * the call ray_defaults(rp). (These should be the
89     * same as the defaults for rtrace.)
90     */
91
92 schorsch 2.4 #include <string.h>
93 greg 2.14 #include <time.h>
94 schorsch 2.4
95 greg 2.1 #include "ray.h"
96     #include "source.h"
97     #include "ambient.h"
98     #include "otypes.h"
99     #include "random.h"
100     #include "data.h"
101     #include "font.h"
102
103     char *progname = "unknown_app"; /* caller sets to argv[0] */
104
105     char *octname; /* octree name we are given */
106
107     char *shm_boundary = NULL; /* boundary of shared memory */
108
109     CUBE thescene; /* our scene */
110     OBJECT nsceneobjs; /* number of objects in our scene */
111
112     int dimlist[MAXDIM]; /* sampling dimensions */
113     int ndims = 0; /* number of sampling dimensions */
114     int samplendx = 0; /* index for this sample */
115
116     void (*trace)() = NULL; /* trace call */
117
118 greg 2.6 void (*addobjnotify[8])() = {ambnotify, NULL};
119 greg 2.1
120     int do_irrad = 0; /* compute irradiance? */
121
122 greg 2.13 int rand_samp = 0; /* pure Monte Carlo sampling? */
123
124 greg 2.1 double dstrsrc = 0.0; /* square source distribution */
125 greg 2.8 double shadthresh = .03; /* shadow threshold */
126     double shadcert = .75; /* shadow certainty */
127 greg 2.1 int directrelay = 2; /* number of source relays */
128     int vspretest = 512; /* virtual source pretest density */
129     int directvis = 1; /* sources visible? */
130     double srcsizerat = .2; /* maximum ratio source size/dist. */
131
132     COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
133     COLOR salbedo = BLKCOLOR; /* global scattering albedo */
134     double seccg = 0.; /* global scattering eccentricity */
135     double ssampdist = 0.; /* scatter sampling distance */
136
137     double specthresh = .15; /* specular sampling threshold */
138     double specjitter = 1.; /* specular sampling jitter */
139
140     int backvis = 1; /* back face visibility */
141
142 greg 2.8 int maxdepth = 8; /* maximum recursion depth */
143     double minweight = 2e-3; /* minimum ray weight */
144 greg 2.1
145     char *ambfile = NULL; /* ambient file name */
146     COLOR ambval = BLKCOLOR; /* ambient value */
147     int ambvwt = 0; /* initial weight for ambient value */
148 greg 2.8 double ambacc = 0.1; /* ambient accuracy */
149     int ambres = 256; /* ambient resolution */
150     int ambdiv = 1024; /* ambient divisions */
151     int ambssamp = 512; /* ambient super-samples */
152 greg 2.1 int ambounce = 0; /* ambient bounces */
153     char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
154     int ambincl = -1; /* include == 1, exclude == 0 */
155
156
157 schorsch 2.9 extern void
158     ray_init( /* initialize ray-tracing calculation */
159     char *otnm
160     )
161 greg 2.1 {
162     if (nobjects > 0) /* free old scene data */
163     ray_done(0);
164     /* initialize object types */
165     if (ofun[OBJ_SPHERE].funp == o_default)
166     initotypes();
167     /* initialize urand */
168 greg 2.15 srandom(rand_samp ? (long)time(0) : 0L);
169 greg 2.5 initurand(2048);
170 greg 2.1 /* read scene octree */
171     readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
172     nsceneobjs = nobjects;
173     /* find and mark sources */
174     marksources();
175     /* initialize ambient calculation */
176     setambient();
177     /* ready to go... */
178     }
179
180 schorsch 2.9 extern void
181     ray_trace( /* trace a primary ray */
182     RAY *r
183     )
184 greg 2.1 {
185 greg 2.11 rayorigin(r, PRIMARY, NULL, NULL);
186 greg 2.12 samplendx = rand_samp ? random() : samplendx+1;
187 greg 2.1 rayvalue(r); /* assumes origin and direction are set */
188     }
189
190
191 schorsch 2.9 extern void
192     ray_done( /* free ray-tracing data */
193     int freall
194     )
195 greg 2.1 {
196     retainfonts = 1;
197     ambdone();
198     ambnotify(OVOID);
199     freesources();
200     freeobjects(0, nobjects);
201     donesets();
202     octdone();
203     thescene.cutree = EMPTY;
204     octname = NULL;
205     if (freall) {
206     retainfonts = 0;
207     freefont(NULL);
208     freedata(NULL);
209     initurand(0);
210     }
211     if (nobjects > 0) {
212 schorsch 2.9 sprintf(errmsg, "%ld objects left after call to ray_done()",
213 greg 2.1 nobjects);
214     error(WARNING, errmsg);
215     }
216     }
217
218
219 schorsch 2.9 extern void
220     ray_save( /* save current parameter settings */
221     RAYPARAMS *rp
222     )
223 greg 2.1 {
224     int i, ndx;
225
226     if (rp == NULL)
227     return;
228     rp->do_irrad = do_irrad;
229     rp->dstrsrc = dstrsrc;
230     rp->shadthresh = shadthresh;
231     rp->shadcert = shadcert;
232     rp->directrelay = directrelay;
233     rp->vspretest = vspretest;
234     rp->directvis = directvis;
235     rp->srcsizerat = srcsizerat;
236     copycolor(rp->cextinction, cextinction);
237     copycolor(rp->salbedo, salbedo);
238     rp->seccg = seccg;
239     rp->ssampdist = ssampdist;
240     rp->specthresh = specthresh;
241     rp->specjitter = specjitter;
242     rp->backvis = backvis;
243     rp->maxdepth = maxdepth;
244     rp->minweight = minweight;
245     copycolor(rp->ambval, ambval);
246 schorsch 2.4 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
247 greg 2.1 if (ambfile != NULL)
248     strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
249     rp->ambvwt = ambvwt;
250     rp->ambacc = ambacc;
251     rp->ambres = ambres;
252     rp->ambdiv = ambdiv;
253     rp->ambssamp = ambssamp;
254     rp->ambounce = ambounce;
255     rp->ambincl = ambincl;
256 schorsch 2.4 memset(rp->amblval, '\0', sizeof(rp->amblval));
257 greg 2.1 ndx = 0;
258     for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
259     int len = strlen(amblist[i]);
260     if (ndx+len >= sizeof(rp->amblval))
261     break;
262     strcpy(rp->amblval+ndx, amblist[i]);
263     ndx += len+1;
264     }
265     while (i <= AMBLLEN)
266     rp->amblndx[i++] = -1;
267     }
268
269
270 schorsch 2.9 extern void
271     ray_restore( /* restore parameter settings */
272     RAYPARAMS *rp
273     )
274 greg 2.1 {
275     register int i;
276
277     if (rp == NULL) { /* restore defaults */
278     RAYPARAMS dflt;
279     ray_defaults(&dflt);
280     ray_restore(&dflt);
281     return;
282     }
283     /* restore saved settings */
284     do_irrad = rp->do_irrad;
285     dstrsrc = rp->dstrsrc;
286     shadthresh = rp->shadthresh;
287     shadcert = rp->shadcert;
288     directrelay = rp->directrelay;
289     vspretest = rp->vspretest;
290     directvis = rp->directvis;
291     srcsizerat = rp->srcsizerat;
292     copycolor(cextinction, rp->cextinction);
293     copycolor(salbedo, rp->salbedo);
294     seccg = rp->seccg;
295     ssampdist = rp->ssampdist;
296     specthresh = rp->specthresh;
297     specjitter = rp->specjitter;
298     backvis = rp->backvis;
299     maxdepth = rp->maxdepth;
300     minweight = rp->minweight;
301     copycolor(ambval, rp->ambval);
302     ambvwt = rp->ambvwt;
303     ambdiv = rp->ambdiv;
304     ambssamp = rp->ambssamp;
305     ambounce = rp->ambounce;
306     for (i = 0; rp->amblndx[i] >= 0; i++)
307     amblist[i] = rp->amblval + rp->amblndx[i];
308     while (i <= AMBLLEN)
309     amblist[i++] = NULL;
310     ambincl = rp->ambincl;
311     /* update ambient calculation */
312     ambnotify(OVOID);
313     if (thescene.cutree != EMPTY) {
314     int newamb = (ambfile == NULL) ? rp->ambfile[0] :
315     strcmp(ambfile, rp->ambfile) ;
316
317     if (amblist[0] != NULL)
318     for (i = 0; i < nobjects; i++)
319     ambnotify(i);
320
321     ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
322     if (newamb) {
323     ambres = rp->ambres;
324     ambacc = rp->ambacc;
325     setambient();
326     } else {
327     setambres(rp->ambres);
328     setambacc(rp->ambacc);
329     }
330     } else {
331     ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
332     ambres = rp->ambres;
333     ambacc = rp->ambacc;
334     }
335     }
336
337
338 schorsch 2.9 extern void
339     ray_defaults( /* get default parameter values */
340     RAYPARAMS *rp
341     )
342 greg 2.1 {
343     int i;
344
345     if (rp == NULL)
346     return;
347
348     rp->do_irrad = 0;
349     rp->dstrsrc = 0.0;
350 greg 2.8 rp->shadthresh = .03;
351     rp->shadcert = .75;
352 greg 2.1 rp->directrelay = 2;
353     rp->vspretest = 512;
354     rp->directvis = 1;
355     rp->srcsizerat = .2;
356     setcolor(rp->cextinction, 0., 0., 0.);
357     setcolor(rp->salbedo, 0., 0., 0.);
358     rp->seccg = 0.;
359     rp->ssampdist = 0.;
360     rp->specthresh = .15;
361     rp->specjitter = 1.;
362     rp->backvis = 1;
363 greg 2.7 rp->maxdepth = 8;
364     rp->minweight = 2e-3;
365 greg 2.1 setcolor(rp->ambval, 0., 0., 0.);
366 schorsch 2.4 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
367 greg 2.1 rp->ambvwt = 0;
368 greg 2.7 rp->ambres = 256;
369 greg 2.10 rp->ambacc = 0.15;
370 greg 2.7 rp->ambdiv = 1024;
371     rp->ambssamp = 512;
372 greg 2.1 rp->ambounce = 0;
373     rp->ambincl = -1;
374 schorsch 2.4 memset(rp->amblval, '\0', sizeof(rp->amblval));
375 greg 2.1 for (i = AMBLLEN+1; i--; )
376     rp->amblndx[i] = -1;
377     }
