root/Development/ray/src/rt/raycalls.c
Revision: 2.10
Committed: Thu Oct 21 23:40:04 2004 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R6P1
Changes since 2.9: +5 -6 lines
Corrected ambient accuracy (-aa) setting to match rtrace
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.10 static const char RCSid[] = "$Id: raycalls.c,v 2.9 2004/03/30 16:13:01 schorsch Exp $";
3 greg 2.1 #endif
4     /*
5     * raycalls.c - interface for running Radiance rendering as a library
6     *
7     * External symbols declared in ray.h
8     */
9
10 greg 2.2 #include "copyright.h"
11 greg 2.1
12     /*
13     * These routines are designed to aid the programmer who wishes
14     * to call Radiance as a library. Unfortunately, the system was
15     * not originally intended to be run this way, and there are some
16     * awkward limitations to contend with. The most irritating
17     * perhaps is that the global variables and functions do not have
18     * a prefix, and the symbols are a bit generic. This results in a
19     * serious invasion of the calling application's name-space, and
20     * you may need to rename either some Radiance routines or some
21     * of your routines to avoid conflicts. Another limitation is
22     * that the global variables are not gathered together into any
23     * sort of context, so it is impossible to simultaneously run
24     * this library on multiple scenes or in multiple threads.
25     * You get one scene and one thread, and if you want more, you
26 greg 2.10 * will have to go with the process model defined in raypcalls.c.
27     * Finally, unrecoverable errors result in a call to the application-
28     * defined function quit(). The usual thing to do is to call exit().
29 greg 2.1 * You might want to do something else instead, like
30     * call setjmp()/longjmp() to bring you back to the calling
31     * function for recovery. You may also wish to define your own
32     * wputs(s) and eputs(s) functions to output warning and error
33     * messages, respectively.
34     *
35     * With those caveats, we have attempted to make the interface
36     * as simple as we can. Global variables and their defaults
37     * are defined below, and including "ray.h" declares these
38     * along with all the routines you are likely to need. First,
39     * assign the global variable progname to your argv[0], then
40     * change the rendering parameters as you like. If you have a set
41     * of option arguments you are working from, the getrenderopt(ac,av)
42     * call should be very useful. Before tracing any rays, you
43     * must read in the octree with a call to ray_init(oct).
44     * Passing NULL for the file name causes ray_init() to read
45     * the octree from the standard input -- rarely a good idea.
46     * However, one may read an octree from a program (such as
47     * oconv) by preceding a shell command by a '!' character.
48     *
49     * To trace a ray, define a RAY object myRay and assign:
50     *
51     * myRay.rorg = ( ray origin point )
52     * myRay.rdir = ( normalized ray direction )
53     * myRay.rmax = ( maximum length, or zero for no limit )
54     *
55     * If you are rendering from a VIEW structure, this can be
56     * accomplished with a single call for the ray at (x,y):
57     *
58     * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59     *
60     * Then, trace the primary ray with:
61     *
62     * ray_trace(&myRay);
63     *
64     * The resulting contents of myRay should provide you with
65     * more than enough information about what the ray hit,
66     * the computed value, etc. For further clues of how to
67     * compute irradiance, how to get callbacks on the evaluated
68     * ray tree, etc., see the contents of rtrace.c. See
69     * also the rpmain.c, rtmain.c, and rvmain.c modules
70     * to learn more how rendering options are processed.
71     *
72     * When you are done, you may call ray_done(1) to clean
73     * up memory used by Radiance. It doesn't free everything,
74     * but it makes a valiant effort. If you call ray_done(0),
75     * it leaves data that is likely to be reused, including
76     * loaded data files and fonts. The library may be
77     * restarted at any point by calling ray_init() on a new
78     * octree.
79     *
80 greg 2.3 * The call ray_save(rp) fills a parameter structure
81 greg 2.1 * with the current global parameter settings, which may be
82     * restored at any time with a call to ray_restore(rp).
83     * This buffer contains no linked information, and thus
84     * may be passed between processes using write() and
85     * read() calls, so long as byte order is maintained.
86     * Calling ray_restore(NULL) restores the original
87     * default parameters, which is also retrievable with
88     * the call ray_defaults(rp). (These should be the
89     * same as the defaults for rtrace.)
90     */
91
92 schorsch 2.4 #include <string.h>
93
94 greg 2.1 #include "ray.h"
95     #include "source.h"
96     #include "ambient.h"
97     #include "otypes.h"
98     #include "random.h"
99     #include "data.h"
100     #include "font.h"
101
102     char *progname = "unknown_app"; /* caller sets to argv[0] */
103
104     char *octname; /* octree name we are given */
105
106     char *shm_boundary = NULL; /* boundary of shared memory */
107
108     CUBE thescene; /* our scene */
109     OBJECT nsceneobjs; /* number of objects in our scene */
110
111     int dimlist[MAXDIM]; /* sampling dimensions */
112     int ndims = 0; /* number of sampling dimensions */
113     int samplendx = 0; /* index for this sample */
114
115     void (*trace)() = NULL; /* trace call */
116
117 greg 2.6 void (*addobjnotify[8])() = {ambnotify, NULL};
118 greg 2.1
119     int do_irrad = 0; /* compute irradiance? */
120
121     double dstrsrc = 0.0; /* square source distribution */
122 greg 2.8 double shadthresh = .03; /* shadow threshold */
123     double shadcert = .75; /* shadow certainty */
124 greg 2.1 int directrelay = 2; /* number of source relays */
125     int vspretest = 512; /* virtual source pretest density */
126     int directvis = 1; /* sources visible? */
127     double srcsizerat = .2; /* maximum ratio source size/dist. */
128
129     COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
130     COLOR salbedo = BLKCOLOR; /* global scattering albedo */
131     double seccg = 0.; /* global scattering eccentricity */
132     double ssampdist = 0.; /* scatter sampling distance */
133
134     double specthresh = .15; /* specular sampling threshold */
135     double specjitter = 1.; /* specular sampling jitter */
136
137     int backvis = 1; /* back face visibility */
138
139 greg 2.8 int maxdepth = 8; /* maximum recursion depth */
140     double minweight = 2e-3; /* minimum ray weight */
141 greg 2.1
142     char *ambfile = NULL; /* ambient file name */
143     COLOR ambval = BLKCOLOR; /* ambient value */
144     int ambvwt = 0; /* initial weight for ambient value */
145 greg 2.8 double ambacc = 0.1; /* ambient accuracy */
146     int ambres = 256; /* ambient resolution */
147     int ambdiv = 1024; /* ambient divisions */
148     int ambssamp = 512; /* ambient super-samples */
149 greg 2.1 int ambounce = 0; /* ambient bounces */
150     char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
151     int ambincl = -1; /* include == 1, exclude == 0 */
152
153
154 schorsch 2.9 extern void
155     ray_init( /* initialize ray-tracing calculation */
156     char *otnm
157     )
158 greg 2.1 {
159     if (nobjects > 0) /* free old scene data */
160     ray_done(0);
161     /* initialize object types */
162     if (ofun[OBJ_SPHERE].funp == o_default)
163     initotypes();
164     /* initialize urand */
165 greg 2.5 initurand(2048);
166 greg 2.1 /* read scene octree */
167     readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
168     nsceneobjs = nobjects;
169     /* find and mark sources */
170     marksources();
171     /* initialize ambient calculation */
172     setambient();
173     /* ready to go... */
174     }
175
176 schorsch 2.9 extern void
177     ray_trace( /* trace a primary ray */
178     RAY *r
179     )
180 greg 2.1 {
181     rayorigin(r, NULL, PRIMARY, 1.0);
182     samplendx++;
183     rayvalue(r); /* assumes origin and direction are set */
184     }
185
186
187 schorsch 2.9 extern void
188     ray_done( /* free ray-tracing data */
189     int freall
190     )
191 greg 2.1 {
192     retainfonts = 1;
193     ambdone();
194     ambnotify(OVOID);
195     freesources();
196     freeobjects(0, nobjects);
197     donesets();
198     octdone();
199     thescene.cutree = EMPTY;
200     octname = NULL;
201     if (freall) {
202     retainfonts = 0;
203     freefont(NULL);
204     freedata(NULL);
205     initurand(0);
206     }
207     if (nobjects > 0) {
208 schorsch 2.9 sprintf(errmsg, "%ld objects left after call to ray_done()",
209 greg 2.1 nobjects);
210     error(WARNING, errmsg);
211     }
212     }
213
214
215 schorsch 2.9 extern void
216     ray_save( /* save current parameter settings */
217     RAYPARAMS *rp
218     )
219 greg 2.1 {
220     int i, ndx;
221
222     if (rp == NULL)
223     return;
224     rp->do_irrad = do_irrad;
225     rp->dstrsrc = dstrsrc;
226     rp->shadthresh = shadthresh;
227     rp->shadcert = shadcert;
228     rp->directrelay = directrelay;
229     rp->vspretest = vspretest;
230     rp->directvis = directvis;
231     rp->srcsizerat = srcsizerat;
232     copycolor(rp->cextinction, cextinction);
233     copycolor(rp->salbedo, salbedo);
234     rp->seccg = seccg;
235     rp->ssampdist = ssampdist;
236     rp->specthresh = specthresh;
237     rp->specjitter = specjitter;
238     rp->backvis = backvis;
239     rp->maxdepth = maxdepth;
240     rp->minweight = minweight;
241     copycolor(rp->ambval, ambval);
242 schorsch 2.4 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
243 greg 2.1 if (ambfile != NULL)
244     strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
245     rp->ambvwt = ambvwt;
246     rp->ambacc = ambacc;
247     rp->ambres = ambres;
248     rp->ambdiv = ambdiv;
249     rp->ambssamp = ambssamp;
250     rp->ambounce = ambounce;
251     rp->ambincl = ambincl;
252 schorsch 2.4 memset(rp->amblval, '\0', sizeof(rp->amblval));
253 greg 2.1 ndx = 0;
254     for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
255     int len = strlen(amblist[i]);
256     if (ndx+len >= sizeof(rp->amblval))
257     break;
258     strcpy(rp->amblval+ndx, amblist[i]);
259     ndx += len+1;
260     }
261     while (i <= AMBLLEN)
262     rp->amblndx[i++] = -1;
263     }
264
265
266 schorsch 2.9 extern void
267     ray_restore( /* restore parameter settings */
268     RAYPARAMS *rp
269     )
270 greg 2.1 {
271     register int i;
272
273     if (rp == NULL) { /* restore defaults */
274     RAYPARAMS dflt;
275     ray_defaults(&dflt);
276     ray_restore(&dflt);
277     return;
278     }
279     /* restore saved settings */
280     do_irrad = rp->do_irrad;
281     dstrsrc = rp->dstrsrc;
282     shadthresh = rp->shadthresh;
283     shadcert = rp->shadcert;
284     directrelay = rp->directrelay;
285     vspretest = rp->vspretest;
286     directvis = rp->directvis;
287     srcsizerat = rp->srcsizerat;
288     copycolor(cextinction, rp->cextinction);
289     copycolor(salbedo, rp->salbedo);
290     seccg = rp->seccg;
291     ssampdist = rp->ssampdist;
292     specthresh = rp->specthresh;
293     specjitter = rp->specjitter;
294     backvis = rp->backvis;
295     maxdepth = rp->maxdepth;
296     minweight = rp->minweight;
297     copycolor(ambval, rp->ambval);
298     ambvwt = rp->ambvwt;
299     ambdiv = rp->ambdiv;
300     ambssamp = rp->ambssamp;
301     ambounce = rp->ambounce;
302     for (i = 0; rp->amblndx[i] >= 0; i++)
303     amblist[i] = rp->amblval + rp->amblndx[i];
304     while (i <= AMBLLEN)
305     amblist[i++] = NULL;
306     ambincl = rp->ambincl;
307     /* update ambient calculation */
308     ambnotify(OVOID);
309     if (thescene.cutree != EMPTY) {
310     int newamb = (ambfile == NULL) ? rp->ambfile[0] :
311     strcmp(ambfile, rp->ambfile) ;
312
313     if (amblist[0] != NULL)
314     for (i = 0; i < nobjects; i++)
315     ambnotify(i);
316
317     ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
318     if (newamb) {
319     ambres = rp->ambres;
320     ambacc = rp->ambacc;
321     setambient();
322     } else {
323     setambres(rp->ambres);
324     setambacc(rp->ambacc);
325     }
326     } else {
327     ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
328     ambres = rp->ambres;
329     ambacc = rp->ambacc;
330     }
331     }
332
333
334 schorsch 2.9 extern void
335     ray_defaults( /* get default parameter values */
336     RAYPARAMS *rp
337     )
338 greg 2.1 {
339     int i;
340
341     if (rp == NULL)
342     return;
343
344     rp->do_irrad = 0;
345     rp->dstrsrc = 0.0;
346 greg 2.8 rp->shadthresh = .03;
347     rp->shadcert = .75;
348 greg 2.1 rp->directrelay = 2;
349     rp->vspretest = 512;
350     rp->directvis = 1;
351     rp->srcsizerat = .2;
352     setcolor(rp->cextinction, 0., 0., 0.);
353     setcolor(rp->salbedo, 0., 0., 0.);
354     rp->seccg = 0.;
355     rp->ssampdist = 0.;
356     rp->specthresh = .15;
357     rp->specjitter = 1.;
358     rp->backvis = 1;
359 greg 2.7 rp->maxdepth = 8;
360     rp->minweight = 2e-3;
361 greg 2.1 setcolor(rp->ambval, 0., 0., 0.);
362 schorsch 2.4 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
363 greg 2.1 rp->ambvwt = 0;
364 greg 2.7 rp->ambres = 256;
365 greg 2.10 rp->ambacc = 0.15;
366 greg 2.7 rp->ambdiv = 1024;
367     rp->ambssamp = 512;
368 greg 2.1 rp->ambounce = 0;
369     rp->ambincl = -1;
370 schorsch 2.4 memset(rp->amblval, '\0', sizeof(rp->amblval));
371 greg 2.1 for (i = AMBLLEN+1; i--; )
372     rp->amblndx[i] = -1;
373     }
