root/radiance/ray/src/rt/raycalls.c
Revision: 2.24
Committed: Thu Apr 18 23:58:22 2019 UTC (5 years, 1 month ago) by greg
Changes since 2.23: +12 -8 lines
Made settings consistent with claims of matching rtrace and added missing rand_samp
2 static const char RCSid[] = "$Id: raycalls.c,v 2.23 2018/01/23 23:37:11 greg Exp $";
5 * raycalls.c - interface for running Radiance rendering as a library
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are designed to aid the programmer who wishes
14 * to call Radiance as a library. Unfortunately, the system was
15 * not originally intended to be run this way, and there are some
16 * awkward limitations to contend with. The most irritating
17 * perhaps is that the global variables and functions do not have
18 * a prefix, and the symbols are a bit generic. This results in a
19 * serious invasion of the calling application's name-space, and
20 * you may need to rename either some Radiance routines or some
21 * of your routines to avoid conflicts. Another limitation is
22 * that the global variables are not gathered together into any
23 * sort of context, so it is impossible to simultaneously run
24 * this library on multiple scenes or in multiple threads.
25 * You get one scene and one thread, and if you want more, you
26 * will have to go with the process model defined in raypcalls.c.
27 * Finally, unrecoverable errors result in a call to the application-
28 * defined function quit(). The usual thing to do is to call exit().
29 * You might want to do something else instead, like
30 * call setjmp()/longjmp() to bring you back to the calling
31 * function for recovery. You may also wish to define your own
32 * wputs(s) and eputs(s) functions to output warning and error
33 * messages, respectively.
34 *
35 * With those caveats, we have attempted to make the interface
36 * as simple as we can. Global variables and their defaults
37 * are defined below, and including "ray.h" declares these
38 * along with all the routines you are likely to need. First,
39 * assign the global variable progname to your argv[0], then
40 * change the rendering parameters as you like. If you have a set
41 * of option arguments you are working from, the getrenderopt(ac,av)
42 * call should be very useful. Before tracing any rays, you
43 * must read in the octree with a call to ray_init(oct).
44 * Passing NULL for the file name causes ray_init() to read
45 * the octree from the standard input -- rarely a good idea.
46 * However, one may read an octree from a program (such as
47 * oconv) by preceding a shell command by a '!' character.
48 *
49 * To trace a ray, define a RAY object myRay and assign:
50 *
51 * myRay.rorg = ( ray origin point )
52 * myRay.rdir = ( normalized ray direction )
53 * myRay.rmax = ( maximum length, or zero for no limit )
54 *
55 * If you are rendering from a VIEW structure, this can be
56 * accomplished with a single call for the ray at (x,y):
57 *
58 * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59 *
60 * Then, trace the primary ray with:
61 *
62 * ray_trace(&myRay);
63 *
64 * The resulting contents of myRay should provide you with
65 * more than enough information about what the ray hit,
66 * the computed value, etc. For further clues of how to
67 * compute irradiance, how to get callbacks on the evaluated
68 * ray tree, etc., see the contents of rtrace.c. See
69 * also the rpmain.c, rtmain.c, and rvmain.c modules
70 * to learn more how rendering options are processed.
71 *
72 * When you are done, you may call ray_done(1) to clean
73 * up memory used by Radiance. It doesn't free everything,
74 * but it makes a valiant effort. If you call ray_done(0),
75 * it leaves data that is likely to be reused, including
76 * loaded data files and fonts. The library may be
77 * restarted at any point by calling ray_init() on a new
78 * octree.
79 *
80 * The call ray_save(rp) fills a parameter structure
81 * with the current global parameter settings, which may be
82 * restored at any time with a call to ray_restore(rp).
83 * This buffer contains no linked information, and thus
84 * may be passed between processes using write() and
85 * read() calls, so long as byte order is maintained.
86 * Calling ray_restore(NULL) restores the original
87 * default parameters, which is also retrievable with
88 * the call ray_defaults(rp). (These should be the
89 * same as the defaults for rtrace.)
90 */
91
92 #include <string.h>
93 #include <time.h>
94
95 #include "ray.h"
96 #include "source.h"
97 #include "bsdf.h"
98 #include "ambient.h"
99 #include "otypes.h"
100 #include "random.h"
101 #include "data.h"
102 #include "font.h"
103 #include "pmapray.h"
104
105 char *progname = "unknown_app"; /* caller sets to argv[0] */
106
107 char *octname; /* octree name we are given */
108
109 char *shm_boundary = NULL; /* boundary of shared memory */
110
111 CUBE thescene; /* our scene */
112 OBJECT nsceneobjs; /* number of objects in our scene */
113
114 int dimlist[MAXDIM]; /* sampling dimensions */
115 int ndims = 0; /* number of sampling dimensions */
116 int samplendx = 0; /* index for this sample */
117
118 void (*trace)() = NULL; /* trace call */
119
120 void (*addobjnotify[8])() = {ambnotify, NULL};
121
122 int do_irrad = 0; /* compute irradiance? */
123
124 int rand_samp = 1; /* pure Monte Carlo sampling? */
125
126 double dstrsrc = 0.0; /* square source distribution */
127 double shadthresh = .03; /* shadow threshold */
128 double shadcert = .75; /* shadow certainty */
129 int directrelay = 2; /* number of source relays */
130 int vspretest = 512; /* virtual source pretest density */
131 int directvis = 1; /* sources visible? */
132 double srcsizerat = .2; /* maximum ratio source size/dist. */
133
134 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
135 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
136 double seccg = 0.; /* global scattering eccentricity */
137 double ssampdist = 0.; /* scatter sampling distance */
138
139 double specthresh = .15; /* specular sampling threshold */
140 double specjitter = 1.; /* specular sampling jitter */
141
142 int backvis = 1; /* back face visibility */
143
144 int maxdepth = -10; /* maximum recursion depth */
145 double minweight = 2e-3; /* minimum ray weight */
146
147 char *ambfile = NULL; /* ambient file name */
148 COLOR ambval = BLKCOLOR; /* ambient value */
149 int ambvwt = 0; /* initial weight for ambient value */
150 double ambacc = 0.1; /* ambient accuracy */
151 int ambres = 256; /* ambient resolution */
152 int ambdiv = 1024; /* ambient divisions */
153 int ambssamp = 512; /* ambient super-samples */
154 int ambounce = 0; /* ambient bounces */
155 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
156 int ambincl = -1; /* include == 1, exclude == 0 */
157
158
159 void
160 ray_init( /* initialize ray-tracing calculation */
161 char *otnm
162 )
163 {
164 if (nobjects > 0) /* free old scene data */
165 ray_done(0);
166 /* initialize object types */
167 if (ofun[OBJ_SPHERE].funp == o_default)
168 initotypes();
169 /* initialize urand */
170 if (rand_samp) {
171 srandom((long)time(0));
172 initurand(0);
173 } else {
174 srandom(0L);
175 initurand(2048);
176 }
177 /* read scene octree */
178 readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
179 nsceneobjs = nobjects;
180 /* PMAP: Init & load photon maps */
181 ray_init_pmap();
182 /* find and mark sources */
183 marksources();
184 /* initialize ambient calculation */
185 setambient();
186 /* ready to go... (almost) */
187 }
188
189 void
190 ray_trace( /* trace a primary ray */
191 RAY *r
192 )
193 {
194 rayorigin(r, PRIMARY, NULL, NULL);
195 samplendx++;
196 rayvalue(r); /* assumes origin and direction are set */
197 }
198
199
200 void
201 ray_done( /* free ray-tracing data */
202 int freall
203 )
204 {
205 retainfonts = 1;
206 ambdone();
207 ambnotify(OVOID);
208 freesources();
209 freeobjects(0, nobjects);
210 donesets();
211 octdone();
212 thescene.cutree = EMPTY;
213 octname = NULL;
214 retainfonts = 0;
215 if (freall) {
216 freefont(NULL);
217 freedata(NULL);
218 SDfreeCache(NULL);
219 initurand(0);
220 }
221 if (nobjects > 0) {
222 sprintf(errmsg, "%ld objects left after call to ray_done()",
223 (long)nobjects);
224 error(WARNING, errmsg);
225 }
226
227 ray_done_pmap();
228 }
229
230
231 void
232 ray_save( /* save current parameter settings */
233 RAYPARAMS *rp
234 )
235 {
236 int i, ndx;
237
238 if (rp == NULL)
239 return;
240 rp->do_irrad = do_irrad;
241 rp->rand_samp = rand_samp;
242 rp->dstrsrc = dstrsrc;
243 rp->shadthresh = shadthresh;
244 rp->shadcert = shadcert;
245 rp->directrelay = directrelay;
246 rp->vspretest = vspretest;
247 rp->directvis = directvis;
248 rp->srcsizerat = srcsizerat;
249 copycolor(rp->cextinction, cextinction);
250 copycolor(rp->salbedo, salbedo);
251 rp->seccg = seccg;
252 rp->ssampdist = ssampdist;
253 rp->specthresh = specthresh;
254 rp->specjitter = specjitter;
255 rp->backvis = backvis;
256 rp->maxdepth = maxdepth;
257 rp->minweight = minweight;
258 if (ambfile != NULL)
259 strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
260 else
261 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
262 copycolor(rp->ambval, ambval);
263 rp->ambvwt = ambvwt;
264 rp->ambacc = ambacc;
265 rp->ambres = ambres;
266 rp->ambdiv = ambdiv;
267 rp->ambssamp = ambssamp;
268 rp->ambounce = ambounce;
269 rp->ambincl = ambincl;
270 memset(rp->amblval, '\0', sizeof(rp->amblval));
271 ndx = 0;
272 for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
273 int len = strlen(amblist[i]);
274 if (ndx+len >= sizeof(rp->amblval))
275 break;
276 strcpy(rp->amblval+ndx, amblist[i]);
277 rp->amblndx[i] = ndx;
278 ndx += len+1;
279 }
280 while (i <= AMBLLEN)
281 rp->amblndx[i++] = -1;
282
283 /* PMAP: save photon mapping params */
284 ray_save_pmap(rp);
285 }
286
287
288 void
289 ray_restore( /* restore parameter settings */
290 RAYPARAMS *rp
291 )
292 {
293 register int i;
294
295 if (rp == NULL) { /* restore defaults */
296 RAYPARAMS dflt;
297 ray_defaults(&dflt);
298 ray_restore(&dflt);
299 return;
300 }
301 /* restore saved settings */
302 do_irrad = rp->do_irrad;
303 rand_samp = rp->rand_samp;
304 dstrsrc = rp->dstrsrc;
305 shadthresh = rp->shadthresh;
306 shadcert = rp->shadcert;
307 directrelay = rp->directrelay;
308 vspretest = rp->vspretest;
309 directvis = rp->directvis;
310 srcsizerat = rp->srcsizerat;
311 copycolor(cextinction, rp->cextinction);
312 copycolor(salbedo, rp->salbedo);
313 seccg = rp->seccg;
314 ssampdist = rp->ssampdist;
315 specthresh = rp->specthresh;
316 specjitter = rp->specjitter;
317 backvis = rp->backvis;
318 maxdepth = rp->maxdepth;
319 minweight = rp->minweight;
320 copycolor(ambval, rp->ambval);
321 ambvwt = rp->ambvwt;
322 ambdiv = rp->ambdiv;
323 ambssamp = rp->ambssamp;
324 ambounce = rp->ambounce;
325 for (i = 0; rp->amblndx[i] >= 0; i++)
326 amblist[i] = rp->amblval + rp->amblndx[i];
327 while (i <= AMBLLEN)
328 amblist[i++] = NULL;
329 ambincl = rp->ambincl;
330 /* update ambient calculation */
331 ambnotify(OVOID);
332 if (thescene.cutree != EMPTY) {
333 int newamb = (ambfile == NULL) ? rp->ambfile[0] :
334 strcmp(ambfile, rp->ambfile) ;
335
336 if (amblist[0] != NULL)
337 for (i = 0; i < nobjects; i++)
338 ambnotify(i);
339
340 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
341 if (newamb) {
342 ambres = rp->ambres;
343 ambacc = rp->ambacc;
344 setambient();
345 } else {
346 setambres(rp->ambres);
347 setambacc(rp->ambacc);
348 }
349 } else {
350 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
351 ambres = rp->ambres;
352 ambacc = rp->ambacc;
353 }
354
355 /* PMAP: restore photon mapping params */
356 ray_restore_pmap(rp);
357 }
358
359
360 void
361 ray_defaults( /* get default parameter values */
362 RAYPARAMS *rp
363 )
364 {
365 int i;
366
367 if (rp == NULL)
368 return;
369
370 rp->do_irrad = 0;
371 rp->rand_samp = 1;
372 rp->dstrsrc = 0.0;
373 rp->shadthresh = .03;
374 rp->shadcert = .75;
375 rp->directrelay = 2;
376 rp->vspretest = 512;
377 rp->directvis = 1;
378 rp->srcsizerat = .2;
379 setcolor(rp->cextinction, 0., 0., 0.);
380 setcolor(rp->salbedo, 0., 0., 0.);
381 rp->seccg = 0.;
382 rp->ssampdist = 0.;
383 rp->specthresh = .15;
384 rp->specjitter = 1.;
385 rp->backvis = 1;
386 rp->maxdepth = -10;
387 rp->minweight = 2e-3;
388 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
389 setcolor(rp->ambval, 0., 0., 0.);
390 rp->ambvwt = 0;
391 rp->ambres = 256;
392 rp->ambacc = 0.15;
393 rp->ambdiv = 1024;
394 rp->ambssamp = 512;
395 rp->ambounce = 0;
396 rp->ambincl = -1;
397 memset(rp->amblval, '\0', sizeof(rp->amblval));
398 for (i = AMBLLEN+1; i--; )
399 rp->amblndx[i] = -1;
400
401 /* PMAP: restore photon mapping defaults */
402 ray_defaults_pmap(rp);
403 }
