root/radiance/ray/src/rt/raycalls.c
Revision: 2.32
Committed: Wed Apr 23 02:35:26 2025 UTC (10 days, 21 hours ago) by greg
Changes since 2.31: +4 -1 lines
fix: Added missing calls to initfunc()
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.32 static const char RCSid[] = "$Id: raycalls.c,v 2.31 2024/08/21 20:42:20 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * raycalls.c - interface for running Radiance rendering as a library
6     *
7     * External symbols declared in ray.h
8     */
9
10 greg 2.2 #include "copyright.h"
11 greg 2.1
12     /*
13     * These routines are designed to aid the programmer who wishes
14     * to call Radiance as a library. Unfortunately, the system was
15     * not originally intended to be run this way, and there are some
16     * awkward limitations to contend with. The most irritating
17     * perhaps is that the global variables and functions do not have
18     * a prefix, and the symbols are a bit generic. This results in a
19     * serious invasion of the calling application's name-space, and
20     * you may need to rename either some Radiance routines or some
21     * of your routines to avoid conflicts. Another limitation is
22     * that the global variables are not gathered together into any
23     * sort of context, so it is impossible to simultaneously run
24     * this library on multiple scenes or in multiple threads.
25     * You get one scene and one thread, and if you want more, you
26 greg 2.10 * will have to go with the process model defined in raypcalls.c.
27     * Finally, unrecoverable errors result in a call to the application-
28     * defined function quit(). The usual thing to do is to call exit().
29 greg 2.1 * You might want to do something else instead, like
30     * call setjmp()/longjmp() to bring you back to the calling
31     * function for recovery. You may also wish to define your own
32     * wputs(s) and eputs(s) functions to output warning and error
33     * messages, respectively.
34     *
35     * With those caveats, we have attempted to make the interface
36     * as simple as we can. Global variables and their defaults
37     * are defined below, and including "ray.h" declares these
38     * along with all the routines you are likely to need. First,
39     * assign the global variable progname to your argv[0], then
40     * change the rendering parameters as you like. If you have a set
41     * of option arguments you are working from, the getrenderopt(ac,av)
42     * call should be very useful. Before tracing any rays, you
43     * must read in the octree with a call to ray_init(oct).
44     * Passing NULL for the file name causes ray_init() to read
45     * the octree from the standard input -- rarely a good idea.
46     * However, one may read an octree from a program (such as
47     * oconv) by preceding a shell command by a '!' character.
48     *
49     * To trace a ray, define a RAY object myRay and assign:
50     *
51     * myRay.rorg = ( ray origin point )
52     * myRay.rdir = ( normalized ray direction )
53     * myRay.rmax = ( maximum length, or zero for no limit )
54     *
55     * If you are rendering from a VIEW structure, this can be
56     * accomplished with a single call for the ray at (x,y):
57     *
58     * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59     *
60     * Then, trace the primary ray with:
61     *
62     * ray_trace(&myRay);
63     *
64     * The resulting contents of myRay should provide you with
65     * more than enough information about what the ray hit,
66     * the computed value, etc. For further clues of how to
67     * compute irradiance, how to get callbacks on the evaluated
68     * ray tree, etc., see the contents of rtrace.c. See
69     * also the rpmain.c, rtmain.c, and rvmain.c modules
70     * to learn more how rendering options are processed.
71     *
72     * When you are done, you may call ray_done(1) to clean
73     * up memory used by Radiance. It doesn't free everything,
74     * but it makes a valiant effort. If you call ray_done(0),
75     * it leaves data that is likely to be reused, including
76     * loaded data files and fonts. The library may be
77     * restarted at any point by calling ray_init() on a new
78     * octree.
79     *
80 greg 2.3 * The call ray_save(rp) fills a parameter structure
81 greg 2.1 * with the current global parameter settings, which may be
82     * restored at any time with a call to ray_restore(rp).
83     * This buffer contains no linked information, and thus
84     * may be passed between processes using write() and
85     * read() calls, so long as byte order is maintained.
86     * Calling ray_restore(NULL) restores the original
87     * default parameters, which is also retrievable with
88     * the call ray_defaults(rp). (These should be the
89     * same as the defaults for rtrace.)
90     */
91
92 schorsch 2.4 #include <string.h>
93 greg 2.14 #include <time.h>
94 schorsch 2.4
95 greg 2.1 #include "ray.h"
96     #include "source.h"
97 greg 2.19 #include "bsdf.h"
98 greg 2.1 #include "ambient.h"
99     #include "otypes.h"
100     #include "random.h"
101 greg 2.32 #include "func.h"
102 greg 2.1 #include "data.h"
103     #include "font.h"
104 greg 2.21 #include "pmapray.h"
105 greg 2.1
106     char *progname = "unknown_app"; /* caller sets to argv[0] */
107
108     char *octname; /* octree name we are given */
109
110     CUBE thescene; /* our scene */
111     OBJECT nsceneobjs; /* number of objects in our scene */
112
113     int dimlist[MAXDIM]; /* sampling dimensions */
114     int ndims = 0; /* number of sampling dimensions */
115     int samplendx = 0; /* index for this sample */
116
117     void (*trace)() = NULL; /* trace call */
118
119 greg 2.6 void (*addobjnotify[8])() = {ambnotify, NULL};
120 greg 2.1
121 greg 2.27 int castonly = 0; /* only doing ray-casting? */
122
123 greg 2.1 int do_irrad = 0; /* compute irradiance? */
124
125 greg 2.24 int rand_samp = 1; /* pure Monte Carlo sampling? */
126 greg 2.13
127 greg 2.1 double dstrsrc = 0.0; /* square source distribution */
128 greg 2.8 double shadthresh = .03; /* shadow threshold */
129     double shadcert = .75; /* shadow certainty */
130 greg 2.1 int directrelay = 2; /* number of source relays */
131     int vspretest = 512; /* virtual source pretest density */
132     int directvis = 1; /* sources visible? */
133     double srcsizerat = .2; /* maximum ratio source size/dist. */
134
135     COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
136     COLOR salbedo = BLKCOLOR; /* global scattering albedo */
137     double seccg = 0.; /* global scattering eccentricity */
138     double ssampdist = 0.; /* scatter sampling distance */
139
140     double specthresh = .15; /* specular sampling threshold */
141     double specjitter = 1.; /* specular sampling jitter */
142
143     int backvis = 1; /* back face visibility */
144
145 greg 2.24 int maxdepth = -10; /* maximum recursion depth */
146 greg 2.26 double minweight = 1e-4; /* minimum ray weight */
147 greg 2.1
148     char *ambfile = NULL; /* ambient file name */
149     COLOR ambval = BLKCOLOR; /* ambient value */
150     int ambvwt = 0; /* initial weight for ambient value */
151 greg 2.8 double ambacc = 0.1; /* ambient accuracy */
152     int ambres = 256; /* ambient resolution */
153     int ambdiv = 1024; /* ambient divisions */
154     int ambssamp = 512; /* ambient super-samples */
155 greg 2.1 int ambounce = 0; /* ambient bounces */
156     char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
157     int ambincl = -1; /* include == 1, exclude == 0 */
158
159
160 greg 2.25 static void
161     reset_random(void) /* re-initialize random number generator */
162     {
163     if (rand_samp) {
164     srandom((long)time(0));
165     initurand(0);
166     } else {
167     srandom(0L);
168     initurand(2048);
169     }
170     }
171
172
173 greg 2.17 void
174 schorsch 2.9 ray_init( /* initialize ray-tracing calculation */
175     char *otnm
176     )
177 greg 2.1 {
178     if (nobjects > 0) /* free old scene data */
179     ray_done(0);
180     /* initialize object types */
181     if (ofun[OBJ_SPHERE].funp == o_default)
182     initotypes();
183 greg 2.32 /* initialize calcomp routines */
184     initfunc();
185 greg 2.1 /* initialize urand */
186 greg 2.25 reset_random();
187 greg 2.30 /* initialize spectral sampling */
188     if (setspectrsamp(CNDX, WLPART) < 0)
189     error(USER, "unsupported spectral sampling");
190 greg 2.27
191     octname = savqstr(otnm); /* read scene octree */
192     readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
193 greg 2.1 nsceneobjs = nobjects;
194 greg 2.27
195     if (!castonly) { /* any actual ray traversal to do? */
196
197     ray_init_pmap(); /* PMAP: set up & load photon maps */
198
199     marksources(); /* find and mark sources */
200
201     setambient(); /* initialize ambient calculation */
202     } else
203     distantsources(); /* else mark only distant sources */
204 greg 2.1 }
205
206 greg 2.25
207 greg 2.17 void
208 schorsch 2.9 ray_trace( /* trace a primary ray */
209     RAY *r
210     )
211 greg 2.1 {
212 greg 2.11 rayorigin(r, PRIMARY, NULL, NULL);
213 greg 2.16 samplendx++;
214 greg 2.1 rayvalue(r); /* assumes origin and direction are set */
215     }
216
217
218 greg 2.17 void
219 schorsch 2.9 ray_done( /* free ray-tracing data */
220     int freall
221     )
222 greg 2.1 {
223     retainfonts = 1;
224     ambdone();
225     ambnotify(OVOID);
226     freesources();
227     freeobjects(0, nobjects);
228     donesets();
229     octdone();
230     thescene.cutree = EMPTY;
231 greg 2.28 freeqstr(octname); octname = NULL;
232 greg 2.19 retainfonts = 0;
233 greg 2.1 if (freall) {
234     freefont(NULL);
235     freedata(NULL);
236 greg 2.19 SDfreeCache(NULL);
237 greg 2.1 initurand(0);
238     }
239     if (nobjects > 0) {
240 schorsch 2.9 sprintf(errmsg, "%ld objects left after call to ray_done()",
241 greg 2.18 (long)nobjects);
242 greg 2.1 error(WARNING, errmsg);
243     }
244 greg 2.21
245     ray_done_pmap();
246 greg 2.1 }
247
248
249 greg 2.17 void
250 schorsch 2.9 ray_save( /* save current parameter settings */
251     RAYPARAMS *rp
252     )
253 greg 2.1 {
254     int i, ndx;
255
256     if (rp == NULL)
257     return;
258     rp->do_irrad = do_irrad;
259 greg 2.24 rp->rand_samp = rand_samp;
260 greg 2.1 rp->dstrsrc = dstrsrc;
261     rp->shadthresh = shadthresh;
262     rp->shadcert = shadcert;
263     rp->directrelay = directrelay;
264     rp->vspretest = vspretest;
265     rp->directvis = directvis;
266     rp->srcsizerat = srcsizerat;
267     copycolor(rp->cextinction, cextinction);
268     copycolor(rp->salbedo, salbedo);
269     rp->seccg = seccg;
270     rp->ssampdist = ssampdist;
271     rp->specthresh = specthresh;
272     rp->specjitter = specjitter;
273     rp->backvis = backvis;
274     rp->maxdepth = maxdepth;
275     rp->minweight = minweight;
276     if (ambfile != NULL)
277     strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
278 greg 2.24 else
279     memset(rp->ambfile, '\0', sizeof(rp->ambfile));
280     copycolor(rp->ambval, ambval);
281 greg 2.1 rp->ambvwt = ambvwt;
282     rp->ambacc = ambacc;
283     rp->ambres = ambres;
284     rp->ambdiv = ambdiv;
285     rp->ambssamp = ambssamp;
286     rp->ambounce = ambounce;
287     rp->ambincl = ambincl;
288 schorsch 2.4 memset(rp->amblval, '\0', sizeof(rp->amblval));
289 greg 2.1 ndx = 0;
290     for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
291     int len = strlen(amblist[i]);
292     if (ndx+len >= sizeof(rp->amblval))
293     break;
294     strcpy(rp->amblval+ndx, amblist[i]);
295 greg 2.23 rp->amblndx[i] = ndx;
296 greg 2.1 ndx += len+1;
297     }
298     while (i <= AMBLLEN)
299     rp->amblndx[i++] = -1;
300 greg 2.21
301     /* PMAP: save photon mapping params */
302     ray_save_pmap(rp);
303 greg 2.1 }
304
305
306 greg 2.17 void
307 schorsch 2.9 ray_restore( /* restore parameter settings */
308     RAYPARAMS *rp
309     )
310 greg 2.1 {
311 greg 2.25 int i;
312 greg 2.1
313     if (rp == NULL) { /* restore defaults */
314     RAYPARAMS dflt;
315     ray_defaults(&dflt);
316     ray_restore(&dflt);
317     return;
318     }
319     /* restore saved settings */
320     do_irrad = rp->do_irrad;
321 greg 2.25 if (!rand_samp != !rp->rand_samp) {
322     rand_samp = rp->rand_samp;
323     reset_random();
324     }
325 greg 2.1 dstrsrc = rp->dstrsrc;
326     shadthresh = rp->shadthresh;
327     shadcert = rp->shadcert;
328     directrelay = rp->directrelay;
329     vspretest = rp->vspretest;
330     directvis = rp->directvis;
331     srcsizerat = rp->srcsizerat;
332     copycolor(cextinction, rp->cextinction);
333     copycolor(salbedo, rp->salbedo);
334     seccg = rp->seccg;
335     ssampdist = rp->ssampdist;
336     specthresh = rp->specthresh;
337     specjitter = rp->specjitter;
338     backvis = rp->backvis;
339     maxdepth = rp->maxdepth;
340     minweight = rp->minweight;
341     copycolor(ambval, rp->ambval);
342     ambvwt = rp->ambvwt;
343     ambdiv = rp->ambdiv;
344     ambssamp = rp->ambssamp;
345     ambounce = rp->ambounce;
346 greg 2.25 /* a bit dangerous if not static */
347 greg 2.1 for (i = 0; rp->amblndx[i] >= 0; i++)
348     amblist[i] = rp->amblval + rp->amblndx[i];
349     while (i <= AMBLLEN)
350     amblist[i++] = NULL;
351     ambincl = rp->ambincl;
352     /* update ambient calculation */
353     ambnotify(OVOID);
354 greg 2.29 if ((thescene.cutree != EMPTY) & !castonly) {
355 greg 2.1 int newamb = (ambfile == NULL) ? rp->ambfile[0] :
356     strcmp(ambfile, rp->ambfile) ;
357
358     if (amblist[0] != NULL)
359     for (i = 0; i < nobjects; i++)
360     ambnotify(i);
361
362     ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
363     if (newamb) {
364     ambres = rp->ambres;
365     ambacc = rp->ambacc;
366     setambient();
367     } else {
368     setambres(rp->ambres);
369     setambacc(rp->ambacc);
370     }
371     } else {
372     ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
373     ambres = rp->ambres;
374     ambacc = rp->ambacc;
375     }
376 greg 2.21
377     /* PMAP: restore photon mapping params */
378     ray_restore_pmap(rp);
379 greg 2.1 }
380
381
382 greg 2.17 void
383 schorsch 2.9 ray_defaults( /* get default parameter values */
384     RAYPARAMS *rp
385     )
386 greg 2.1 {
387     int i;
388
389     if (rp == NULL)
390     return;
391
392     rp->do_irrad = 0;
393 greg 2.24 rp->rand_samp = 1;
394 greg 2.1 rp->dstrsrc = 0.0;
395 greg 2.27 rp->shadthresh = 0.03;
396     rp->shadcert = 0.75;
397 greg 2.1 rp->directrelay = 2;
398     rp->vspretest = 512;
399     rp->directvis = 1;
400     rp->srcsizerat = .2;
401     setcolor(rp->cextinction, 0., 0., 0.);
402     setcolor(rp->salbedo, 0., 0., 0.);
403     rp->seccg = 0.;
404     rp->ssampdist = 0.;
405 greg 2.27 rp->specthresh = 0.15;
406 greg 2.1 rp->specjitter = 1.;
407     rp->backvis = 1;
408 greg 2.24 rp->maxdepth = -10;
409 greg 2.27 rp->minweight = 1e-4;
410 greg 2.24 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
411 greg 2.1 setcolor(rp->ambval, 0., 0., 0.);
412     rp->ambvwt = 0;
413 greg 2.7 rp->ambres = 256;
414 greg 2.27 rp->ambacc = 0.1;
415 greg 2.7 rp->ambdiv = 1024;
416     rp->ambssamp = 512;
417 greg 2.1 rp->ambounce = 0;
418     rp->ambincl = -1;
419 schorsch 2.4 memset(rp->amblval, '\0', sizeof(rp->amblval));
420 greg 2.1 for (i = AMBLLEN+1; i--; )
421     rp->amblndx[i] = -1;
422 greg 2.22
423     /* PMAP: restore photon mapping defaults */
424     ray_defaults_pmap(rp);
425 greg 2.1 }
