root/radiance/ray/src/rt/raycalls.c
Revision: 2.14
Committed: Wed Jun 15 15:36:52 2005 UTC (19 years ago) by greg
2 static const char RCSid[] = "$Id: raycalls.c,v 2.13 2005/06/14 02:46:30 greg Exp $";
5 * raycalls.c - interface for running Radiance rendering as a library
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 /*
13 * These routines are designed to aid the programmer who wishes
14 * to call Radiance as a library. Unfortunately, the system was
15 * not originally intended to be run this way, and there are some
16 * awkward limitations to contend with. The most irritating
17 * perhaps is that the global variables and functions do not have
18 * a prefix, and the symbols are a bit generic. This results in a
19 * serious invasion of the calling application's name-space, and
20 * you may need to rename either some Radiance routines or some
21 * of your routines to avoid conflicts. Another limitation is
22 * that the global variables are not gathered together into any
23 * sort of context, so it is impossible to simultaneously run
24 * this library on multiple scenes or in multiple threads.
25 * You get one scene and one thread, and if you want more, you
26 * will have to go with the process model defined in raypcalls.c.
27 * Finally, unrecoverable errors result in a call to the application-
28 * defined function quit(). The usual thing to do is to call exit().
29 * You might want to do something else instead, like
30 * call setjmp()/longjmp() to bring you back to the calling
31 * function for recovery. You may also wish to define your own
32 * wputs(s) and eputs(s) functions to output warning and error
33 * messages, respectively.
34 *
35 * With those caveats, we have attempted to make the interface
36 * as simple as we can. Global variables and their defaults
37 * are defined below, and including "ray.h" declares these
38 * along with all the routines you are likely to need. First,
39 * assign the global variable progname to your argv[0], then
40 * change the rendering parameters as you like. If you have a set
41 * of option arguments you are working from, the getrenderopt(ac,av)
42 * call should be very useful. Before tracing any rays, you
43 * must read in the octree with a call to ray_init(oct).
44 * Passing NULL for the file name causes ray_init() to read
45 * the octree from the standard input -- rarely a good idea.
46 * However, one may read an octree from a program (such as
47 * oconv) by preceding a shell command by a '!' character.
48 *
49 * To trace a ray, define a RAY object myRay and assign:
50 *
51 * myRay.rorg = ( ray origin point )
52 * myRay.rdir = ( normalized ray direction )
53 * myRay.rmax = ( maximum length, or zero for no limit )
54 *
55 * If you are rendering from a VIEW structure, this can be
56 * accomplished with a single call for the ray at (x,y):
57 *
58 * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59 *
60 * Then, trace the primary ray with:
61 *
62 * ray_trace(&myRay);
63 *
64 * The resulting contents of myRay should provide you with
65 * more than enough information about what the ray hit,
66 * the computed value, etc. For further clues of how to
67 * compute irradiance, how to get callbacks on the evaluated
68 * ray tree, etc., see the contents of rtrace.c. See
69 * also the rpmain.c, rtmain.c, and rvmain.c modules
70 * to learn more how rendering options are processed.
71 *
72 * When you are done, you may call ray_done(1) to clean
73 * up memory used by Radiance. It doesn't free everything,
74 * but it makes a valiant effort. If you call ray_done(0),
75 * it leaves data that is likely to be reused, including
76 * loaded data files and fonts. The library may be
77 * restarted at any point by calling ray_init() on a new
78 * octree.
79 *
80 * The call ray_save(rp) fills a parameter structure
81 * with the current global parameter settings, which may be
82 * restored at any time with a call to ray_restore(rp).
83 * This buffer contains no linked information, and thus
84 * may be passed between processes using write() and
85 * read() calls, so long as byte order is maintained.
86 * Calling ray_restore(NULL) restores the original
87 * default parameters, which is also retrievable with
88 * the call ray_defaults(rp). (These should be the
89 * same as the defaults for rtrace.)
90 */
91
92 #include <string.h>
93 #include <time.h>
94
95 #include "ray.h"
96 #include "source.h"
97 #include "ambient.h"
98 #include "otypes.h"
99 #include "random.h"
100 #include "data.h"
101 #include "font.h"
102
103 char *progname = "unknown_app"; /* caller sets to argv[0] */
104
105 char *octname; /* octree name we are given */
106
107 char *shm_boundary = NULL; /* boundary of shared memory */
108
109 CUBE thescene; /* our scene */
110 OBJECT nsceneobjs; /* number of objects in our scene */
111
112 int dimlist[MAXDIM]; /* sampling dimensions */
113 int ndims = 0; /* number of sampling dimensions */
114 int samplendx = 0; /* index for this sample */
115
116 void (*trace)() = NULL; /* trace call */
117
118 void (*addobjnotify[8])() = {ambnotify, NULL};
119
120 int do_irrad = 0; /* compute irradiance? */
121
122 int rand_samp = 0; /* pure Monte Carlo sampling? */
123
124 double dstrsrc = 0.0; /* square source distribution */
125 double shadthresh = .03; /* shadow threshold */
126 double shadcert = .75; /* shadow certainty */
127 int directrelay = 2; /* number of source relays */
128 int vspretest = 512; /* virtual source pretest density */
129 int directvis = 1; /* sources visible? */
130 double srcsizerat = .2; /* maximum ratio source size/dist. */
131
132 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
133 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
134 double seccg = 0.; /* global scattering eccentricity */
135 double ssampdist = 0.; /* scatter sampling distance */
136
137 double specthresh = .15; /* specular sampling threshold */
138 double specjitter = 1.; /* specular sampling jitter */
139
140 int backvis = 1; /* back face visibility */
141
142 int maxdepth = 8; /* maximum recursion depth */
143 double minweight = 2e-3; /* minimum ray weight */
144
145 char *ambfile = NULL; /* ambient file name */
146 COLOR ambval = BLKCOLOR; /* ambient value */
147 int ambvwt = 0; /* initial weight for ambient value */
148 double ambacc = 0.1; /* ambient accuracy */
149 int ambres = 256; /* ambient resolution */
150 int ambdiv = 1024; /* ambient divisions */
151 int ambssamp = 512; /* ambient super-samples */
152 int ambounce = 0; /* ambient bounces */
153 char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
154 int ambincl = -1; /* include == 1, exclude == 0 */
155
156
157 extern void
158 ray_init( /* initialize ray-tracing calculation */
159 char *otnm
160 )
161 {
162 if (nobjects > 0) /* free old scene data */
163 ray_done(0);
164 /* initialize object types */
165 if (ofun[OBJ_SPHERE].funp == o_default)
166 initotypes();
167 /* initialize urand */
168 initurand(2048);
169 srandom(rand_samp ? (long)time(0) : 0L);
170 /* read scene octree */
171 readoct(octname = otnm, ~(IO_FILES|IO_INFO), &thescene, NULL);
172 nsceneobjs = nobjects;
173 /* find and mark sources */
174 marksources();
175 /* initialize ambient calculation */
176 setambient();
177 /* ready to go... */
178 }
179
180 extern void
181 ray_trace( /* trace a primary ray */
182 RAY *r
183 )
184 {
185 rayorigin(r, PRIMARY, NULL, NULL);
186 samplendx = rand_samp ? random() : samplendx+1;
187 rayvalue(r); /* assumes origin and direction are set */
188 }
189
190
191 extern void
192 ray_done( /* free ray-tracing data */
193 int freall
194 )
195 {
196 retainfonts = 1;
197 ambdone();
198 ambnotify(OVOID);
199 freesources();
200 freeobjects(0, nobjects);
201 donesets();
202 octdone();
203 thescene.cutree = EMPTY;
204 octname = NULL;
205 if (freall) {
206 retainfonts = 0;
207 freefont(NULL);
208 freedata(NULL);
209 initurand(0);
210 }
211 if (nobjects > 0) {
212 sprintf(errmsg, "%ld objects left after call to ray_done()",
213 nobjects);
214 error(WARNING, errmsg);
215 }
216 }
217
218
219 extern void
220 ray_save( /* save current parameter settings */
221 RAYPARAMS *rp
222 )
223 {
224 int i, ndx;
225
226 if (rp == NULL)
227 return;
228 rp->do_irrad = do_irrad;
229 rp->dstrsrc = dstrsrc;
230 rp->shadthresh = shadthresh;
231 rp->shadcert = shadcert;
232 rp->directrelay = directrelay;
233 rp->vspretest = vspretest;
234 rp->directvis = directvis;
235 rp->srcsizerat = srcsizerat;
236 copycolor(rp->cextinction, cextinction);
237 copycolor(rp->salbedo, salbedo);
238 rp->seccg = seccg;
239 rp->ssampdist = ssampdist;
240 rp->specthresh = specthresh;
241 rp->specjitter = specjitter;
242 rp->backvis = backvis;
243 rp->maxdepth = maxdepth;
244 rp->minweight = minweight;
245 copycolor(rp->ambval, ambval);
246 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
247 if (ambfile != NULL)
248 strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
249 rp->ambvwt = ambvwt;
250 rp->ambacc = ambacc;
251 rp->ambres = ambres;
252 rp->ambdiv = ambdiv;
253 rp->ambssamp = ambssamp;
254 rp->ambounce = ambounce;
255 rp->ambincl = ambincl;
256 memset(rp->amblval, '\0', sizeof(rp->amblval));
257 ndx = 0;
258 for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
259 int len = strlen(amblist[i]);
260 if (ndx+len >= sizeof(rp->amblval))
261 break;
262 strcpy(rp->amblval+ndx, amblist[i]);
263 ndx += len+1;
264 }
265 while (i <= AMBLLEN)
266 rp->amblndx[i++] = -1;
267 }
268
269
270 extern void
271 ray_restore( /* restore parameter settings */
272 RAYPARAMS *rp
273 )
274 {
275 register int i;
276
277 if (rp == NULL) { /* restore defaults */
278 RAYPARAMS dflt;
279 ray_defaults(&dflt);
280 ray_restore(&dflt);
281 return;
282 }
283 /* restore saved settings */
284 do_irrad = rp->do_irrad;
285 dstrsrc = rp->dstrsrc;
286 shadthresh = rp->shadthresh;
287 shadcert = rp->shadcert;
288 directrelay = rp->directrelay;
289 vspretest = rp->vspretest;
290 directvis = rp->directvis;
291 srcsizerat = rp->srcsizerat;
292 copycolor(cextinction, rp->cextinction);
293 copycolor(salbedo, rp->salbedo);
294 seccg = rp->seccg;
295 ssampdist = rp->ssampdist;
296 specthresh = rp->specthresh;
297 specjitter = rp->specjitter;
298 backvis = rp->backvis;
299 maxdepth = rp->maxdepth;
300 minweight = rp->minweight;
301 copycolor(ambval, rp->ambval);
302 ambvwt = rp->ambvwt;
303 ambdiv = rp->ambdiv;
304 ambssamp = rp->ambssamp;
305 ambounce = rp->ambounce;
306 for (i = 0; rp->amblndx[i] >= 0; i++)
307 amblist[i] = rp->amblval + rp->amblndx[i];
308 while (i <= AMBLLEN)
309 amblist[i++] = NULL;
310 ambincl = rp->ambincl;
311 /* update ambient calculation */
312 ambnotify(OVOID);
313 if (thescene.cutree != EMPTY) {
314 int newamb = (ambfile == NULL) ? rp->ambfile[0] :
315 strcmp(ambfile, rp->ambfile) ;
316
317 if (amblist[0] != NULL)
318 for (i = 0; i < nobjects; i++)
319 ambnotify(i);
320
321 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
322 if (newamb) {
323 ambres = rp->ambres;
324 ambacc = rp->ambacc;
325 setambient();
326 } else {
327 setambres(rp->ambres);
328 setambacc(rp->ambacc);
329 }
330 } else {
331 ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
332 ambres = rp->ambres;
333 ambacc = rp->ambacc;
334 }
335 }
336
337
338 extern void
339 ray_defaults( /* get default parameter values */
340 RAYPARAMS *rp
341 )
342 {
343 int i;
344
345 if (rp == NULL)
346 return;
347
348 rp->do_irrad = 0;
349 rp->dstrsrc = 0.0;
350 rp->shadthresh = .03;
351 rp->shadcert = .75;
352 rp->directrelay = 2;
353 rp->vspretest = 512;
354 rp->directvis = 1;
355 rp->srcsizerat = .2;
356 setcolor(rp->cextinction, 0., 0., 0.);
357 setcolor(rp->salbedo, 0., 0., 0.);
358 rp->seccg = 0.;
359 rp->ssampdist = 0.;
360 rp->specthresh = .15;
361 rp->specjitter = 1.;
362 rp->backvis = 1;
363 rp->maxdepth = 8;
364 rp->minweight = 2e-3;
365 setcolor(rp->ambval, 0., 0., 0.);
366 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
367 rp->ambvwt = 0;
368 rp->ambres = 256;
369 rp->ambacc = 0.15;
370 rp->ambdiv = 1024;
371 rp->ambssamp = 512;
372 rp->ambounce = 0;
373 rp->ambincl = -1;
374 memset(rp->amblval, '\0', sizeof(rp->amblval));
375 for (i = AMBLLEN+1; i--; )
376 rp->amblndx[i] = -1;
377 }
