root/Development/ray/src/rt/raycalls.c
Fri Jun 20 03:43:17 2025 UTC (6 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.33 , to selected 2.15
fix(rvu): Issue with live reset of -u boolean and consistency improvements
Tue Jun 3 21:31:51 2025 UTC (7 months ago) by greg
Changes since 2.32: +4 -6 lines
Diff to previous 2.32 , to selected 2.15
Wed Apr 23 02:35:26 2025 UTC (8 months, 1 week ago) by greg
Changes since 2.31: +4 -1 lines
Diff to previous 2.31 , to selected 2.15
fix: Added missing calls to initfunc()
Wed Aug 21 20:42:20 2024 UTC (16 months, 1 week ago) by greg
Changes since 2.30: +1 -3 lines
Diff to previous 2.30 , to selected 2.15
refactor: moved memory sharing routines to preload.c with common call interface
Thu May 2 15:02:08 2024 UTC (20 months ago) by greg
Changes since 2.29: +4 -1 lines
Diff to previous 2.29 , to selected 2.15
fix: Added call to set up spectral sampling for calling program
Thu Feb 2 19:13:13 2023 UTC (2 years, 11 months ago) by greg
Diff to previous 2.28 , to selected 2.15
fix: Forgot castonly as consideration when changing ambient file
Thu Feb 2 18:55:09 2023 UTC (2 years, 11 months ago) by greg
Diff to previous 2.27 , to selected 2.15
fix: Paired savqstr() and freeqstr() calls for octname
Thu Feb 2 18:45:23 2023 UTC (2 years, 11 months ago) by greg
Changes since 2.26: +21 -15 lines
Diff to previous 2.26 , to selected 2.15
refactor: made "castonly" variable accessible outside rtrace
Tue Jan 24 21:54:49 2023 UTC (2 years, 11 months ago) by greg
Diff to previous 2.25 , to selected 2.15
Fri Apr 19 16:29:10 2019 UTC (6 years, 8 months ago) by greg
Changes since 2.24: +22 -10 lines
Diff to previous 2.24 , to selected 2.15
Added reset of random sampling
Thu Apr 18 23:58:22 2019 UTC (6 years, 8 months ago) by greg
Changes since 2.23: +12 -8 lines
Diff to previous 2.23 , to selected 2.15
Made settings consistent with claims of matching rtrace and added missing rand_samp
Tue Jan 23 23:37:11 2018 UTC (7 years, 11 months ago) by greg
Changes since 2.22: +2 -1 lines
Diff to previous 2.22 , to selected 2.15
Fixed saving of ambient include/exclude list
Wed Nov 2 22:09:14 2016 UTC (9 years, 2 months ago) by greg
Diff to previous 2.21 , to selected 2.15
Fixed bug in ranimove introduced with photon map
Tue Feb 24 19:39:27 2015 UTC (10 years, 10 months ago) by greg
Changes since 2.20: +13 -2 lines
Diff to previous 2.20 , to selected 2.15
Fri Feb 25 06:51:50 2011 UTC (14 years, 10 months ago) by greg
Diff to previous 2.19 , to selected 2.15
Decreased -lw default
Fri Feb 18 00:40:25 2011 UTC (14 years, 10 months ago) by greg
Changes since 2.18: +4 -2 lines
Diff to previous 2.18 , to selected 2.15
Sun Sep 26 15:51:15 2010 UTC (15 years, 3 months ago) by greg
Diff to previous 2.17 , to selected 2.15
Sat Dec 12 05:20:10 2009 UTC (16 years ago) by greg
Diff to previous 2.16 , to selected 2.15
Wed Apr 5 06:22:56 2006 UTC (19 years, 9 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.15: +9 -4 lines
Diff to previous 2.15
Made -u+ option truly random
Revision 2.15 - (view) (download) (annotate) - [selected]
Tue Jun 21 00:26:44 2005 UTC (20 years, 6 months ago) by greg
Diff to previous 2.14
Wed Jun 15 15:36:52 2005 UTC (20 years, 6 months ago) by greg
Diff to previous 2.13 , to selected 2.15
Tue Jun 14 02:46:30 2005 UTC (20 years, 6 months ago) by greg
Diff to previous 2.12 , to selected 2.15
Forgot to add rand_samp definition
Mon Jun 13 20:07:56 2005 UTC (20 years, 6 months ago) by greg
Diff to previous 2.11 , to selected 2.15
Tue Apr 19 01:15:06 2005 UTC (20 years, 8 months ago) by greg
Diff to previous 2.10 , to selected 2.15
Thu Oct 21 23:40:04 2004 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R6P1
Changes since 2.9: +5 -6 lines
Diff to previous 2.9 , to selected 2.15
Corrected ambient accuracy (-aa) setting to match rtrace
Tue Mar 30 16:13:01 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.8: +26 -21 lines
Diff to previous 2.8 , to selected 2.15
Sat Oct 4 14:39:53 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.7: +11 -11 lines
Diff to previous 2.7 , to selected 2.15
More adjustments and corrections to default parameters
Wed Sep 24 14:55:54 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.6: +7 -7 lines
Diff to previous 2.6 , to selected 2.15
Tue Aug 26 04:24:26 2003 UTC (22 years, 4 months ago) by greg
Diff to previous 2.5 , to selected 2.15
Minor improvements
Mon Jun 30 18:19:53 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 2.4 , to selected 2.15
Removed check of urperm, which didn't work with -DMC
Mon Jun 30 14:59:12 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 2.3: +7 -11 lines
Diff to previous 2.3 , to selected 2.15
Thu May 15 05:13:35 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.2 , to selected 2.15
Tue Feb 25 02:47:23 2003 UTC (22 years, 10 months ago) by greg
Diff to previous 2.1 , to selected 2.15
Sat Feb 22 02:07:29 2003 UTC (22 years, 10 months ago) by greg
Diff to selected 2.15
