root/Development/ray/src/rt/raycalls.c
Revision: 2.34
Committed: Fri Jun 20 03:43:17 2025 UTC (6 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
fix(rvu): Issue with live reset of -u boolean and consistency improvements
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.34 static const char RCSid[] = "$Id: raycalls.c,v 2.33 2025/06/03 21:31:51 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * raycalls.c - interface for running Radiance rendering as a library
6     *
7     * External symbols declared in ray.h
8     */
9
10 greg 2.2 #include "copyright.h"
11 greg 2.1
12     /*
13     * These routines are designed to aid the programmer who wishes
14     * to call Radiance as a library. Unfortunately, the system was
15     * not originally intended to be run this way, and there are some
16     * awkward limitations to contend with. The most irritating
17     * perhaps is that the global variables and functions do not have
18     * a prefix, and the symbols are a bit generic. This results in a
19     * serious invasion of the calling application's name-space, and
20     * you may need to rename either some Radiance routines or some
21     * of your routines to avoid conflicts. Another limitation is
22     * that the global variables are not gathered together into any
23     * sort of context, so it is impossible to simultaneously run
24     * this library on multiple scenes or in multiple threads.
25     * You get one scene and one thread, and if you want more, you
26 greg 2.10 * will have to go with the process model defined in raypcalls.c.
27     * Finally, unrecoverable errors result in a call to the application-
28     * defined function quit(). The usual thing to do is to call exit().
29 greg 2.1 * You might want to do something else instead, like
30     * call setjmp()/longjmp() to bring you back to the calling
31     * function for recovery. You may also wish to define your own
32     * wputs(s) and eputs(s) functions to output warning and error
33     * messages, respectively.
34     *
35     * With those caveats, we have attempted to make the interface
36     * as simple as we can. Global variables and their defaults
37     * are defined below, and including "ray.h" declares these
38     * along with all the routines you are likely to need. First,
39 greg 2.33 * assign the global variable progname by calling fixargv0(argv[0]),
40     * then change the rendering parameters as you like. If you have a
41     * set of option arguments you are working from, the getrenderopt()
42 greg 2.1 * call should be very useful. Before tracing any rays, you
43     * must read in the octree with a call to ray_init(oct).
44     * Passing NULL for the file name causes ray_init() to read
45     * the octree from the standard input -- rarely a good idea.
46     * However, one may read an octree from a program (such as
47     * oconv) by preceding a shell command by a '!' character.
48     *
49     * To trace a ray, define a RAY object myRay and assign:
50     *
51     * myRay.rorg = ( ray origin point )
52     * myRay.rdir = ( normalized ray direction )
53     * myRay.rmax = ( maximum length, or zero for no limit )
54     *
55     * If you are rendering from a VIEW structure, this can be
56     * accomplished with a single call for the ray at (x,y):
57     *
58     * myRay.rmax = viewray(myRay.rorg, myRay.rdir, &myView, x, y);
59     *
60     * Then, trace the primary ray with:
61     *
62     * ray_trace(&myRay);
63     *
64     * The resulting contents of myRay should provide you with
65     * more than enough information about what the ray hit,
66     * the computed value, etc. For further clues of how to
67     * compute irradiance, how to get callbacks on the evaluated
68     * ray tree, etc., see the contents of rtrace.c. See
69     * also the rpmain.c, rtmain.c, and rvmain.c modules
70     * to learn more how rendering options are processed.
71     *
72     * When you are done, you may call ray_done(1) to clean
73     * up memory used by Radiance. It doesn't free everything,
74     * but it makes a valiant effort. If you call ray_done(0),
75     * it leaves data that is likely to be reused, including
76     * loaded data files and fonts. The library may be
77     * restarted at any point by calling ray_init() on a new
78     * octree.
79     *
80 greg 2.3 * The call ray_save(rp) fills a parameter structure
81 greg 2.1 * with the current global parameter settings, which may be
82     * restored at any time with a call to ray_restore(rp).
83     * This buffer contains no linked information, and thus
84     * may be passed between processes using write() and
85     * read() calls, so long as byte order is maintained.
86     * Calling ray_restore(NULL) restores the original
87     * default parameters, which is also retrievable with
88     * the call ray_defaults(rp). (These should be the
89     * same as the defaults for rtrace.)
90     */
91
92 schorsch 2.4 #include <string.h>
93 greg 2.14 #include <time.h>
94 schorsch 2.4
95 greg 2.1 #include "ray.h"
96     #include "source.h"
97 greg 2.19 #include "bsdf.h"
98 greg 2.1 #include "ambient.h"
99     #include "otypes.h"
100     #include "random.h"
101 greg 2.32 #include "func.h"
102 greg 2.1 #include "data.h"
103     #include "font.h"
104 greg 2.21 #include "pmapray.h"
105 greg 2.1
106     char *octname; /* octree name we are given */
107
108     CUBE thescene; /* our scene */
109     OBJECT nsceneobjs; /* number of objects in our scene */
110
111     int dimlist[MAXDIM]; /* sampling dimensions */
112     int ndims = 0; /* number of sampling dimensions */
113 greg 2.34 unsigned long samplendx = 0; /* index for this sample */
114 greg 2.1
115     void (*trace)() = NULL; /* trace call */
116
117 greg 2.6 void (*addobjnotify[8])() = {ambnotify, NULL};
118 greg 2.1
119 greg 2.27 int castonly = 0; /* only doing ray-casting? */
120
121 greg 2.1 int do_irrad = 0; /* compute irradiance? */
122
123 greg 2.24 int rand_samp = 1; /* pure Monte Carlo sampling? */
124 greg 2.13
125 greg 2.1 double dstrsrc = 0.0; /* square source distribution */
126 greg 2.8 double shadthresh = .03; /* shadow threshold */
127     double shadcert = .75; /* shadow certainty */
128 greg 2.1 int directrelay = 2; /* number of source relays */
129     int vspretest = 512; /* virtual source pretest density */
130     int directvis = 1; /* sources visible? */
131     double srcsizerat = .2; /* maximum ratio source size/dist. */
132
133     COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
134     COLOR salbedo = BLKCOLOR; /* global scattering albedo */
135     double seccg = 0.; /* global scattering eccentricity */
136     double ssampdist = 0.; /* scatter sampling distance */
137
138     double specthresh = .15; /* specular sampling threshold */
139     double specjitter = 1.; /* specular sampling jitter */
140
141     int backvis = 1; /* back face visibility */
142
143 greg 2.24 int maxdepth = -10; /* maximum recursion depth */
144 greg 2.26 double minweight = 1e-4; /* minimum ray weight */
145 greg 2.1
146     char *ambfile = NULL; /* ambient file name */
147     COLOR ambval = BLKCOLOR; /* ambient value */
148     int ambvwt = 0; /* initial weight for ambient value */
149 greg 2.8 double ambacc = 0.1; /* ambient accuracy */
150     int ambres = 256; /* ambient resolution */
151     int ambdiv = 1024; /* ambient divisions */
152     int ambssamp = 512; /* ambient super-samples */
153 greg 2.1 int ambounce = 0; /* ambient bounces */
154     char *amblist[AMBLLEN+1]; /* ambient include/exclude list */
155     int ambincl = -1; /* include == 1, exclude == 0 */
156
157
158 greg 2.34 void
159 greg 2.25 reset_random(void) /* re-initialize random number generator */
160     {
161     if (rand_samp) {
162     srandom((long)time(0));
163     initurand(0);
164     } else {
165     srandom(0L);
166     initurand(2048);
167     }
168     }
169
170
171 greg 2.17 void
172 schorsch 2.9 ray_init( /* initialize ray-tracing calculation */
173     char *otnm
174     )
175 greg 2.1 {
176     if (nobjects > 0) /* free old scene data */
177     ray_done(0);
178     /* initialize object types */
179     if (ofun[OBJ_SPHERE].funp == o_default)
180     initotypes();
181 greg 2.32 /* initialize calcomp routines */
182     initfunc();
183 greg 2.1 /* initialize urand */
184 greg 2.25 reset_random();
185 greg 2.30 /* initialize spectral sampling */
186     if (setspectrsamp(CNDX, WLPART) < 0)
187     error(USER, "unsupported spectral sampling");
188 greg 2.27
189     octname = savqstr(otnm); /* read scene octree */
190     readoct(octname, ~(IO_FILES|IO_INFO), &thescene, NULL);
191 greg 2.1 nsceneobjs = nobjects;
192 greg 2.27
193     if (!castonly) { /* any actual ray traversal to do? */
194
195     ray_init_pmap(); /* PMAP: set up & load photon maps */
196
197     marksources(); /* find and mark sources */
198
199     setambient(); /* initialize ambient calculation */
200     } else
201     distantsources(); /* else mark only distant sources */
202 greg 2.1 }
203
204 greg 2.25
205 greg 2.17 void
206 schorsch 2.9 ray_trace( /* trace a primary ray */
207     RAY *r
208     )
209 greg 2.1 {
210 greg 2.11 rayorigin(r, PRIMARY, NULL, NULL);
211 greg 2.16 samplendx++;
212 greg 2.1 rayvalue(r); /* assumes origin and direction are set */
213     }
214
215
216 greg 2.17 void
217 schorsch 2.9 ray_done( /* free ray-tracing data */
218     int freall
219     )
220 greg 2.1 {
221     retainfonts = 1;
222     ambdone();
223     ambnotify(OVOID);
224     freesources();
225     freeobjects(0, nobjects);
226     donesets();
227     octdone();
228     thescene.cutree = EMPTY;
229 greg 2.28 freeqstr(octname); octname = NULL;
230 greg 2.19 retainfonts = 0;
231 greg 2.1 if (freall) {
232     freefont(NULL);
233     freedata(NULL);
234 greg 2.19 SDfreeCache(NULL);
235 greg 2.1 initurand(0);
236     }
237     if (nobjects > 0) {
238 schorsch 2.9 sprintf(errmsg, "%ld objects left after call to ray_done()",
239 greg 2.18 (long)nobjects);
240 greg 2.1 error(WARNING, errmsg);
241     }
242 greg 2.21
243     ray_done_pmap();
244 greg 2.1 }
245
246
247 greg 2.17 void
248 schorsch 2.9 ray_save( /* save current parameter settings */
249     RAYPARAMS *rp
250     )
251 greg 2.1 {
252     int i, ndx;
253
254     if (rp == NULL)
255     return;
256     rp->do_irrad = do_irrad;
257 greg 2.24 rp->rand_samp = rand_samp;
258 greg 2.1 rp->dstrsrc = dstrsrc;
259     rp->shadthresh = shadthresh;
260     rp->shadcert = shadcert;
261     rp->directrelay = directrelay;
262     rp->vspretest = vspretest;
263     rp->directvis = directvis;
264     rp->srcsizerat = srcsizerat;
265     copycolor(rp->cextinction, cextinction);
266     copycolor(rp->salbedo, salbedo);
267     rp->seccg = seccg;
268     rp->ssampdist = ssampdist;
269     rp->specthresh = specthresh;
270     rp->specjitter = specjitter;
271     rp->backvis = backvis;
272     rp->maxdepth = maxdepth;
273     rp->minweight = minweight;
274     if (ambfile != NULL)
275     strncpy(rp->ambfile, ambfile, sizeof(rp->ambfile)-1);
276 greg 2.24 else
277     memset(rp->ambfile, '\0', sizeof(rp->ambfile));
278     copycolor(rp->ambval, ambval);
279 greg 2.1 rp->ambvwt = ambvwt;
280     rp->ambacc = ambacc;
281     rp->ambres = ambres;
282     rp->ambdiv = ambdiv;
283     rp->ambssamp = ambssamp;
284     rp->ambounce = ambounce;
285     rp->ambincl = ambincl;
286 schorsch 2.4 memset(rp->amblval, '\0', sizeof(rp->amblval));
287 greg 2.1 ndx = 0;
288     for (i = 0; i < AMBLLEN && amblist[i] != NULL; i++) {
289     int len = strlen(amblist[i]);
290     if (ndx+len >= sizeof(rp->amblval))
291     break;
292     strcpy(rp->amblval+ndx, amblist[i]);
293 greg 2.23 rp->amblndx[i] = ndx;
294 greg 2.1 ndx += len+1;
295     }
296     while (i <= AMBLLEN)
297     rp->amblndx[i++] = -1;
298 greg 2.21
299     /* PMAP: save photon mapping params */
300     ray_save_pmap(rp);
301 greg 2.1 }
302
303
304 greg 2.17 void
305 schorsch 2.9 ray_restore( /* restore parameter settings */
306     RAYPARAMS *rp
307     )
308 greg 2.1 {
309 greg 2.25 int i;
310 greg 2.1
311     if (rp == NULL) { /* restore defaults */
312     RAYPARAMS dflt;
313     ray_defaults(&dflt);
314     ray_restore(&dflt);
315     return;
316     }
317     /* restore saved settings */
318     do_irrad = rp->do_irrad;
319 greg 2.25 if (!rand_samp != !rp->rand_samp) {
320     rand_samp = rp->rand_samp;
321     reset_random();
322     }
323 greg 2.1 dstrsrc = rp->dstrsrc;
324     shadthresh = rp->shadthresh;
325     shadcert = rp->shadcert;
326     directrelay = rp->directrelay;
327     vspretest = rp->vspretest;
328     directvis = rp->directvis;
329     srcsizerat = rp->srcsizerat;
330     copycolor(cextinction, rp->cextinction);
331     copycolor(salbedo, rp->salbedo);
332     seccg = rp->seccg;
333     ssampdist = rp->ssampdist;
334     specthresh = rp->specthresh;
335     specjitter = rp->specjitter;
336     backvis = rp->backvis;
337     maxdepth = rp->maxdepth;
338     minweight = rp->minweight;
339     copycolor(ambval, rp->ambval);
340     ambvwt = rp->ambvwt;
341     ambdiv = rp->ambdiv;
342     ambssamp = rp->ambssamp;
343     ambounce = rp->ambounce;
344 greg 2.25 /* a bit dangerous if not static */
345 greg 2.1 for (i = 0; rp->amblndx[i] >= 0; i++)
346     amblist[i] = rp->amblval + rp->amblndx[i];
347     while (i <= AMBLLEN)
348     amblist[i++] = NULL;
349     ambincl = rp->ambincl;
350     /* update ambient calculation */
351     ambnotify(OVOID);
352 greg 2.29 if ((thescene.cutree != EMPTY) & !castonly) {
353 greg 2.1 int newamb = (ambfile == NULL) ? rp->ambfile[0] :
354     strcmp(ambfile, rp->ambfile) ;
355
356     if (amblist[0] != NULL)
357     for (i = 0; i < nobjects; i++)
358     ambnotify(i);
359
360     ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
361     if (newamb) {
362     ambres = rp->ambres;
363     ambacc = rp->ambacc;
364     setambient();
365     } else {
366     setambres(rp->ambres);
367     setambacc(rp->ambacc);
368     }
369     } else {
370     ambfile = (rp->ambfile[0]) ? rp->ambfile : (char *)NULL;
371     ambres = rp->ambres;
372     ambacc = rp->ambacc;
373     }
374 greg 2.21
375     /* PMAP: restore photon mapping params */
376     ray_restore_pmap(rp);
377 greg 2.1 }
378
379
380 greg 2.17 void
381 schorsch 2.9 ray_defaults( /* get default parameter values */
382     RAYPARAMS *rp
383     )
384 greg 2.1 {
385     int i;
386
387     if (rp == NULL)
388     return;
389
390     rp->do_irrad = 0;
391 greg 2.24 rp->rand_samp = 1;
392 greg 2.1 rp->dstrsrc = 0.0;
393 greg 2.27 rp->shadthresh = 0.03;
394     rp->shadcert = 0.75;
395 greg 2.1 rp->directrelay = 2;
396     rp->vspretest = 512;
397     rp->directvis = 1;
398     rp->srcsizerat = .2;
399     setcolor(rp->cextinction, 0., 0., 0.);
400     setcolor(rp->salbedo, 0., 0., 0.);
401     rp->seccg = 0.;
402     rp->ssampdist = 0.;
403 greg 2.27 rp->specthresh = 0.15;
404 greg 2.1 rp->specjitter = 1.;
405     rp->backvis = 1;
406 greg 2.24 rp->maxdepth = -10;
407 greg 2.27 rp->minweight = 1e-4;
408 greg 2.24 memset(rp->ambfile, '\0', sizeof(rp->ambfile));
409 greg 2.1 setcolor(rp->ambval, 0., 0., 0.);
410     rp->ambvwt = 0;
411 greg 2.7 rp->ambres = 256;
412 greg 2.27 rp->ambacc = 0.1;
413 greg 2.7 rp->ambdiv = 1024;
414     rp->ambssamp = 512;
415 greg 2.1 rp->ambounce = 0;
416     rp->ambincl = -1;
417 schorsch 2.4 memset(rp->amblval, '\0', sizeof(rp->amblval));
418 greg 2.1 for (i = AMBLLEN+1; i--; )
419     rp->amblndx[i] = -1;
420 greg 2.22
421     /* PMAP: restore photon mapping defaults */
422     ray_defaults_pmap(rp);
423 greg 2.1 }
