root/Development/ray/src/rt/ray.h
Revision: 2.60
Committed: Fri Jun 20 16:34:23 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.59: +4 -2 lines
fix: Avoid array bounds errors in dimlist[] in deep ray trees
1 /* RCSid $Id: ray.h,v 2.59 2025/06/20 03:43:17 greg Exp $ */
2 /*
3 * ray.h - header file for routines using rays.
4 */
5 #ifndef _RAD_RAY_H_
6 #define _RAD_RAY_H_
7
8 #include "standard.h"
9 #include "octree.h"
10 #include "object.h"
11 #include "color.h"
12 #include "pmapparm.h"
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18 #ifndef RNUMBER
19 #define RNUMBER size_t /* ray counter (>= sizeof pointer) */
20 #endif
21
22 #define MAXDIM 36 /* maximum number of sampling dimensions */
23 #define XTRADIM 3 /* #spare dimensions */
24 #define ndims_inc (ndims -= ndims>=MAXDIM-XTRADIM, ndims++)
25
26 /* ray type flags */
27 #define PRIMARY 01 /* original ray */
28 #define RSHADOW 02 /* reflected ray to light source */
29 #define REFLECTED 04 /* reflected ray */
30 #define REFRACTED 010 /* refracted (bent) ray */
31 #define TRANS 020 /* transmitted/transferred ray */
32 #define RAMBIENT 040 /* reflected diffuse interreflection */
33 #define RSPECULAR 0100 /* reflected specular */
34 #define TSHADOW 0200 /* transmitted shadow */
35 #define TAMBIENT 0400 /* transmitted ambient */
36 #define TSPECULAR 01000 /* transmitted specular */
37 #define SHADOW (RSHADOW|TSHADOW)
38 #define AMBIENT (RAMBIENT|TAMBIENT)
39 #define SPECULAR (RSPECULAR|TSPECULAR)
40
41 /* reflected ray types */
42 #define RAYREFL (RSHADOW|REFLECTED|RAMBIENT|RSPECULAR)
43
44 /* Arrange so double's come first for optimal alignment */
45 /* Pointers and long's come second for 64-bit mode */
46 /* Int's next (unknown length), then floats, followed by short's & char's */
47 typedef struct ray {
48 FVECT rorg; /* origin of ray */
49 FVECT rdir; /* normalized direction of ray */
50 RREAL rmax; /* maximum distance (aft clipping plane) */
51 RREAL rot; /* distance to object */
52 FVECT rop; /* intersection point */
53 FVECT ron; /* intersection surface normal */
54 RREAL rod; /* -DOT(rdir, ron) */
55 RREAL uv[2]; /* local coordinates */
56 FVECT pert; /* surface normal perturbation */
57 RREAL rmt; /* returned mirrored ray length */
58 RREAL rxt; /* returned unmirrored ray length */
59 const struct ray *parent; /* ray this originated from */
60 OBJECT *clipset; /* set of objects currently clipped */
61 OBJECT *newcset; /* next clipset, used for transmission */
62 void (*revf)(struct ray *); /* ray evaluation function */
63 void (*hitf)(OBJECT *, struct ray *); /* custom hit test */
64 OBJREC *ro; /* intersected object (one with material) */
65 FULLXF *rox; /* object transformation */
66 int *slights; /* list of lights to test for scattering */
67 RNUMBER rno; /* unique ray number */
68 OBJECT robj; /* intersected object number */
69 int rsrc; /* source we're aiming for (or ones to skip) */
70 float rweight; /* cumulative weight (for termination) */
71 float gecc; /* scattering eccentricity coefficient */
72 SCOLOR rcoef; /* contribution coefficient w.r.t. parent */
73 SCOLOR pcol; /* pattern color */
74 SCOLOR mcol; /* mirrored color contribution */
75 SCOLOR rcol; /* returned radiance value */
76 COLOR cext; /* medium extinction coefficient */
77 COLOR albedo; /* medium scattering albedo */
78 short rflips; /* surface orientation has been reversed */
79 short rlvl; /* number of reflections for this ray */
80 short rtype; /* ray type */
81 short crtype; /* cumulative ray type */
82 } RAY;
83
84 #define rayvalue(r) (*(r)->revf)(r)
85
86 #define thrudir(r,v) ((r)->rod > 0 ^ DOT((r)->ron,v) > 0)
87
88 #define raydistance(r) (pbright((r)->mcol) > 0.5*pbright((r)->rcol) ? \
89 (r)->rmt : (r)->rxt)
90
91 #define rayreorient(r) if ((r)->rflips & 1) flipsurface(r); else
92
93 extern char VersionID[]; /* Radiance version ID string */
94 extern char RFeatureList[]; /* newline-separated feature list */
95
96 extern CUBE thescene; /* our scene */
97 extern OBJECT nsceneobjs; /* number of objects in our scene */
98
99 extern RNUMBER raynum; /* next ray ID */
100 extern RNUMBER nrays; /* total rays traced so far */
101
102 extern OBJREC Lamb; /* a Lambertian surface */
103 extern OBJREC Aftplane; /* aft clipping object */
104
105 extern void (*trace)(RAY*); /* global trace reporting callback */
106
107 extern int dimlist[]; /* dimension list for distribution */
108 extern int ndims; /* number of dimensions so far */
109 extern unsigned long
110 samplendx; /* index for this sample */
111
112 extern int do_irrad; /* compute irradiance? */
113
114 extern int rand_samp; /* pure Monte Carlo sampling? */
115
116 extern double dstrsrc; /* square source distribution */
117 extern double shadthresh; /* shadow threshold */
118 extern double shadcert; /* shadow testing certainty */
119 extern int directrelay; /* number of source relays */
120 extern int vspretest; /* virtual source pretest density */
121 extern int directvis; /* light sources visible to eye? */
122 extern double srcsizerat; /* maximum source size/dist. ratio */
123
124 extern double specthresh; /* specular sampling threshold */
125 extern double specjitter; /* specular sampling jitter */
126
127 extern COLOR cextinction; /* global extinction coefficient */
128 extern COLOR salbedo; /* global scattering albedo */
129 extern double seccg; /* global scattering eccentricity */
130 extern double ssampdist; /* scatter sampling distance */
131
132 extern int backvis; /* back face visibility */
133
134 extern int maxdepth; /* maximum recursion depth */
135 extern double minweight; /* minimum ray weight */
136
137 extern char *ambfile; /* ambient file name */
138 extern COLOR ambval; /* ambient value */
139 extern int ambvwt; /* initial weight for ambient value */
140 extern double ambacc; /* ambient accuracy */
141 extern int ambres; /* ambient resolution */
142 extern int ambdiv; /* ambient divisions */
143 extern int ambssamp; /* ambient super-samples */
144 extern int ambounce; /* ambient bounces */
145 extern char *amblist[]; /* ambient include/exclude list */
146 extern int ambincl; /* include == 1, exclude == 0 */
147
148 extern int ray_pnprocs; /* number of child processes */
149 extern int ray_pnidle; /* number of idle processes */
150
151 #ifndef AMBLLEN
152 #define AMBLLEN 512 /* max. ambient list length */
153 #endif
154 #define AMBWORD 12 /* average word length */
155
156 typedef struct { /* rendering parameter holder */
157 int do_irrad;
158 int rand_samp;
159 double dstrsrc;
160 double shadthresh;
161 double shadcert;
162 int directrelay;
163 int vspretest;
164 int directvis;
165 double srcsizerat;
166 COLOR cextinction;
167 COLOR salbedo;
168 double seccg;
169 double ssampdist;
170 double specthresh;
171 double specjitter;
172 int backvis;
173 int maxdepth;
174 double minweight;
175 char ambfile[512];
176 COLOR ambval;
177 int ambvwt;
178 double ambacc;
179 int ambres;
180 int ambdiv;
181 int ambssamp;
182 int ambounce;
183 int ambincl;
184 short amblndx[AMBLLEN+1];
185 char amblval[AMBLLEN*AMBWORD];
186
187 /* PMAP: photon mapping parameters */
188 PhotonMapParams pmapParams [NUM_PMAP_TYPES];
189 } RAYPARAMS;
190
191 #define rpambmod(p,i) ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \
192 (char *)NULL : (p)->amblval+(p)->amblndx[i] )
193
194 /* defined in duphead.c */
195 extern void headclean(void);
196 extern void openheader(void);
197 extern void dupheader(void);
198 /* defined in persist.c */
199 extern void persistfile(char *pfn);
200 extern void pfdetach(void);
201 extern void pfclean(void);
202 extern void pflock(int lf);
203 extern void pfhold(void);
204 extern void io_process(void);
205 /* defined in freeobjmem.c */
206 extern int free_objs(OBJECT on, OBJECT no);
207 extern void free_objmem(void);
208 /* defined in preload.c */
209 extern int load_os(OBJREC *op);
210 extern void preload_objs(void);
211 extern char *shm_boundary;
212 extern void cow_memshare(void);
213 extern void cow_doneshare(void);
214 /* defined in raycalls.c */
215 extern void ray_init(char *otnm);
216 extern void ray_trace(RAY *r);
217 extern void ray_done(int freall);
218 extern void ray_save(RAYPARAMS *rp);
219 extern void ray_restore(RAYPARAMS *rp);
220 extern void ray_defaults(RAYPARAMS *rp);
221 extern void reset_random(void);
222 /* defined in raypcalls.c */
223 extern void ray_pinit(char *otnm, int nproc);
224 extern int ray_psend(RAY *r);
225 extern int ray_pqueue(RAY *r);
226 extern int ray_presult(RAY *r, int poll);
227 extern void ray_pdone(int freall);
228 extern void ray_popen(int nadd);
229 extern void ray_pclose(int nsub);
230 /* defined in ray_fifo.c */
231 extern int (*ray_fifo_out)(RAY *r);
232 extern int ray_fifo_in(RAY *r);
233 extern int ray_fifo_flush(void);
234 /* defined in raytrace.c */
235 extern int rayorigin(RAY *r, int rt, const RAY *ro, const SCOLOR rc);
236 extern void rayclear(RAY *r);
237 extern void raytrace(RAY *r);
238 extern int rayreject(OBJREC *o, RAY *r, double t, double rod);
239 extern void rayhit(OBJECT *oset, RAY *r);
240 extern void raycont(RAY *r);
241 extern void raytrans(RAY *r);
242 extern int raytirrad(OBJREC *m, RAY *r);
243 extern int rayshade(RAY *r, int mod);
244 extern void rayparticipate(RAY *r);
245 extern void raytexture(RAY *r, OBJECT mod);
246 extern int raymixture(RAY *r, OBJECT fore, OBJECT back, double coef);
247 extern void raycontrib(SCOLOR rc, const RAY *r, int flags);
248 extern double raydist(const RAY *r, int flags);
249 extern double raynormal(FVECT norm, RAY *r);
250 extern void newrayxf(RAY *r);
251 extern void flipsurface(RAY *r);
252 extern int localhit(RAY *r, CUBE *scene);
253 /* defined in renderopts.c */
254 extern int feature_status(int ac, char *av[]);
255 extern int getrenderopt(int ac, char *av[]);
256 extern void print_rdefaults(void);
257 /* defined in srcdraw.c */
258 extern void init_drawsources(int rad);
259 extern void drawsources(COLORV *pic[], RGBPRIMP primp, float *zbf[],
260 int x0, int xsiz, int y0, int ysiz);
261 /* defined in rt/initotypes.c */
262 extern void initotypes(void);
263 /* module main procedures */
264 extern void rtrace(char *fname, int nproc);
265 extern const char *formstr(int f);
266 extern void rview(void);
267 extern void rpict(int seq, char *pout, char *zout, char *prvr);
268
269 #ifdef __FAST_MATH__
270 #define checknorm(vn) (void)normalize(vn)
271 #else
272 #define checknorm(vn)
273 #endif
274
275 #ifdef __cplusplus
276 }
277 #endif
278 #endif /* _RAD_RAY_H_ */
279
